So hier der Auszug, von dem was passiert.
Connected to Asterisk 11.6-cert2 currently running on mobydick (pid = 1468)
== Using SIP VIDEO CoS mark 6
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
– Executing [0351889xxxxx@mdc_location-2:1] Verbose(“SIP/Privat-0000003e”, “1,Privat”) in new stack
Privat
– Executing [0351889xxxxx@mdc_location-2:2] Set(“SIP/Privat-0000003e”, “__MDC_CALLER_LOCATION_ID=2”) in new stack
– Executing [0351889xxxxx@mdc_location-2:3] Set(“SIP/Privat-0000003e”, “__MDC_CALLER_LOCATION_NAME=Privat”) in new stack
– Executing [0351889xxxxx@mdc_location-2:4] Gosub(“SIP/Privat-0000003e”, “sub_location,s,1(2,0351889xxxxx)”) in new stack
– Executing [s@sub_location:1] Verbose(“SIP/Privat-0000003e”, “1,used location id: 2 - dialed extension: 0351889xxxxx”) in new stack
– Executing [s@sub_location:2] Set(“SIP/Privat-0000003e”, “MDC_CALLEE_NUM=0351889xxxxx”) in new stack
– Executing [s@sub_location:3] Return(“SIP/Privat-0000003e”, “”) in new stack
– Executing [0351889xxxxx@mdc_location-2:5] Gosub(“SIP/Privat-0000003e”, “sub_split-location,s,1(2)”) in new stack
– Executing [s@sub_split-location:1] Verbose(“SIP/Privat-0000003e”, “1,get user for location: 2”) in new stack
– Executing [s@sub_split-location:2] GotoIf(“SIP/Privat-0000003e”, “0?s-zero,1”) in new stack
– Executing [s@sub_split-location:3] Set(“SIP/Privat-0000003e”, “TMP_USER_ID=3”) in new stack
– Executing [s@sub_split-location:4] Verbose(“SIP/Privat-0000003e”, “1,user id: 3”) in new stack
user id: 3
– Executing [s@sub_split-location:5] Return(“SIP/Privat-0000003e”, “”) in new stack
– Executing [0351889xxxxx@mdc_location-2:6] Goto(“SIP/Privat-0000003e”, “mdc_user-3,0351889xxxxx,1”) in new stack
– Goto (mdc_user-3,0351889xxxxx,1)
– Executing [035188941996@mdc_user-3:1] Verbose(“SIP/Privat-0000003e”, “1,Privat”) in new stack
Privat
– Executing [0351889xxxxx@mdc_user-3:2] Gosub(“SIP/Privat-0000003e”, “sub_user,s,1(caller,3,21,Privat,Privat,21,21,21)”) in new stack
– Executing [s@sub_user:1] Verbose(“SIP/Privat-0000003e”, “1,sub_user mode caller”) in new stack
– Executing [s@sub_user:2] Goto(“SIP/Privat-0000003e”, “s-caller,1”) in new stack
– Goto (sub_user,s-caller,1)
– Executing [s-caller@sub_user:1] Verbose(“SIP/Privat-0000003e”, “1,sub_user user id: 3 - user exten: 21 - user: Privat - realname: Privat - own mailbox: 21 - watched mailbox: 21 - callerid(num): 21”) in new stack
– Executing [s-caller@sub_user:2] Set(“SIP/Privat-0000003e”, “__MDC_CALLER_USER_ID=3”) in new stack
– Executing [s-caller@sub_user:3] Set(“SIP/Privat-0000003e”, “__MDC_CALLER_NUM=21”) in new stack
– Executing [s-caller@sub_user:4] Set(“SIP/Privat-0000003e”, “__MDC_CALLER_ACC_NAME=Privat”) in new stack
– Executing [s-caller@sub_user:5] Set(“SIP/Privat-0000003e”, “__MDC_CALLER_ACC_REALNAME=Privat”) in new stack
– Executing [s-caller@sub_user:6] Set(“SIP/Privat-0000003e”, “__MDC_CALLER_VM_OWN=21”) in new stack
– Executing [s-caller@sub_user:7] Set(“SIP/Privat-0000003e”, “__MDC_CALLER_VM_WATCHED=21”) in new stack
– Executing [s-caller@sub_user:8] Set(“SIP/Privat-0000003e”, “CALLERID(name)=Privat”) in new stack
– Executing [s-caller@sub_user:9] Set(“SIP/Privat-0000003e”, “CALLERID(num)=21”) in new stack
– Executing [s-caller@sub_user:10] Return(“SIP/Privat-0000003e”, “”) in new stack
– Executing [0351889xxxxx@mdc_user-3:3] Goto(“SIP/Privat-0000003e”, “internal,0351889xxxxx,1”) in new stack
– Goto (internal,0351889xxxxx,1)
– Executing [0351889xxxxx@internal:1] SIPAddHeader(“SIP/Privat-0000003e”, "“Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"”) in new stack
– Executing [0351889xxxxx@internal:2] GosubIf(“SIP/Privat-0000003e”, “1?sub_initcall,s,1(int,0351889xxxxx)”) in new stack
– Executing [s@sub_initcall:1] Verbose(“SIP/Privat-0000003e”, “1,sub_initcall descent: int exten: 0351889xxxxx”) in new stack
– Executing [s@sub_initcall:2] GosubIf(“SIP/Privat-0000003e”, “1?sub_initloop,s,1”) in new stack
– Executing [s@sub_initloop:1] Verbose(“SIP/Privat-0000003e”, “1,initial loop”) in new stack
initial loop
– Executing [s@sub_initloop:2] Set(“SIP/Privat-0000003e”, “MDC_ALIAS_HOP=0”) in new stack
– Executing [s@sub_initloop:3] Return(“SIP/Privat-0000003e”, “”) in new stack
– Executing [s@sub_initcall:3] Set(“SIP/Privat-0000003e”, “__MDC_TRANSFERBACK_HOP=0”) in new stack
– Executing [s@sub_initcall:4] Set(“SIP/Privat-0000003e”, “__MDC_DIALDESCENT=int”) in new stack
– Executing [s@sub_initcall:5] Goto(“SIP/Privat-0000003e”, “int,1”) in new stack
– Goto (sub_initcall,int,1)
– Executing [int@sub_initcall:1] Set(“SIP/Privat-0000003e”, “__MDC_DIALCALLERNUMINIT=21”) in new stack
– Executing [int@sub_initcall:2] Set(“SIP/Privat-0000003e”, “__MDC_DIALCALLEENUMINIT=035188941996”) in new stack
– Executing [int@sub_initcall:3] Set(“SIP/Privat-0000003e”, “__MDC_DIALCALLEENUMMAP=035188941996”) in new stack
– Executing [int@sub_initcall:4] Return(“SIP/Privat-0000003e”, “”) in new stack
– Executing [0351889xxxxx@internal:3] Goto(“SIP/Privat-0000003e”, “main,0351889xxxxx,1”) in new stack
– Goto (main,0351889xxxxx,1)
– Executing [0351889xxxxx@main:1] Gosub(“SIP/Privat-0000003e”, “sub_defcall,s,1(0351889xxxxx)”) in new stack
– Executing [s@sub_defcall:1] Set(“SIP/Privat-0000003e”, “__MDC_ALIAS_HOP=1”) in new stack
– Executing [s@sub_defcall:2] Set(“SIP/Privat-0000003e”, “__MDC_DIALCALLEENUM=0351889xxxxx”) in new stack
– Executing [s@sub_defcall:3] Set(“SIP/Privat-0000003e”, “__MDC_DIALCALLERNUM=21”) in new stack
– Executing [s@sub_defcall:4] GotoIf(“SIP/Privat-0000003e”, “1?nozap”) in new stack
– Goto (sub_defcall,s,8)
– Executing [s@sub_defcall:8] Set(“SIP/Privat-0000003e”, “__MDC_DIALCALLERNAME=Privat”) in new stack
– Executing [s@sub_defcall:9] Set(“SIP/Privat-0000003e”, “__MDC_DIALCHANNELNAME=Privat”) in new stack
– Executing [s@sub_defcall:10] Return(“SIP/Privat-0000003e”, “”) in new stack
– Executing [0351889xxxxx@main:2] Goto(“SIP/Privat-0000003e”, “mdc_distribute,0351889xxxxx,1”) in new stack
– Goto (mdc_distribute,0351889xxxxx,1)
– Executing [0351889xxxxx@mdc_distribute:1] Set(“SIP/Privat-0000003e”, “MDC_INPREFIX_TRUNK=”) in new stack
– Executing [0351889xxxxx@mdc_distribute:2] Verbose(“SIP/Privat-0000003e”, "1,remove inprefix: ") in new stack
remove inprefix:
– Executing [0351889xxxxx@mdc_distribute:3] Goto(“SIP/Privat-0000003e”, “mdc_outgoing-6,0351889xxxxx,1”) in new stack
– Goto (mdc_outgoing-6,0351889xxxxx,1)
– Executing [0351889xxxxx@mdc_outgoing-6:1] Gosub(“SIP/Privat-0000003e”, “sub_trunk-outgoing-6,0351889xxxxx,1”) in new stack
– Executing [0351889xxxxx@sub_trunk-outgoing-6:1] Gosub(“SIP/Privat-0000003e”, “sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,0351889xxxxx,00,49,0,3501)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“SIP/Privat-0000003e”, “1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - CALLERID(num): 0351889xxxxx - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 3501”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“SIP/Privat-0000003e”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“SIP/Privat-0000003e”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“SIP/Privat-0000003e”, “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“SIP/Privat-0000003e”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:6] GotoIf(“SIP/Privat-0000003e”, “1?s-nat,1”) in new stack
– Goto (sub_nat2int,s-nat,1)
– Executing [s-nat@sub_nat2int:1] Verbose(“SIP/Privat-0000003e”, “1,national”) in new stack
national
– Executing [s-nat@sub_nat2int:2] Set(“SIP/Privat-0000003e”, “MDC_CALLEE_NUM_INTERNAT=0049351889xxxxx”) in new stack
– Executing [s-nat@sub_nat2int:3] Return(“SIP/Privat-0000003e”, “”) in new stack
– Executing [0351889xxxxx@sub_trunk-outgoing-6:2] Gosub(“SIP/Privat-0000003e”, “sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,0049351889xxxxx,00,49,0,3501)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“SIP/Privat-0000003e”, “1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 0049351889xxxxx - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 3501”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“SIP/Privat-0000003e”, “0?nat”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“SIP/Privat-0000003e”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“SIP/Privat-0000003e”, “MDC_CALLEE_NUM_NAT=0351889xxxxx”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“SIP/Privat-0000003e”, “”) in new stack
– Executing [0351889xxxxx@sub_trunk-outgoing-6:3] Set(“SIP/Privat-0000003e”, “CALLERID(name)=0049350179xxxxx”) in new stack
– Executing [0351889xxxxx@sub_trunk-outgoing-6:4] Set(“SIP/Privat-0000003e”, “CALLERID(num)=0049350179xxxxx”) in new stack
– Executing [0351889xxxxx@sub_trunk-outgoing-6:5] UserEvent(“SIP/Privat-0000003e”, “ResolveCallerName,Strategy: default,Outbound: 1,Channel: SIP/Privat-0000003e”) in new stack
– Executing [0351889xxxxx@sub_trunk-outgoing-6:6] Wait(“SIP/Privat-0000003e”, “0.25”) in new stack
– Executing [0351889xxxxx@sub_trunk-outgoing-6:7] Verbose(“SIP/Privat-0000003e”, “1,MDC_RESOLVENAME_HITS = 0”) in new stack
– Executing [0351889xxxxx@sub_trunk-outgoing-6:8] Verbose(“SIP/Privat-0000003e”, "1,MDC_DIALCALLEENAME = ") in new stack
– Executing [0351889xxxxx@sub_trunk-outgoing-6:9] Verbose(“SIP/Privat-0000003e”, “1,T-Online - Privat”) in new stack
T-Online - Privat
– Executing [0351889xxxxx@sub_trunk-outgoing-6:10] Dial(“SIP/Privat-0000003e”, “SIP/mdc_trunk_conf-7/0351889xxxxx,t”) in new stack
– Called SIP/mdc_trunk_conf-7/0351889xxxxx
– Executing [0351889xxxxx@sub_trunk-outgoing-6:11] Return(“SIP/Privat-0000003e”, “”) in new stack
[Jun 27 19:17:42] WARNING[14495][C-0000001f]: pbx.c:6643 __ast_pbx_run: Channel ‘SIP/Privat-0000003e’ sent to invalid extension but no invalid handler: context,exten,priority=mdc_outgoing-6,0351889xxxxx,2
– Executing [h@mdc_outgoing-6:1] Gosub(“SIP/Privat-0000003e”, “def_hangup,s,1(,CHANUNAVAIL,CALL)”) in new stack
– Executing [s@def_hangup:1] NoOp(“SIP/Privat-0000003e”, “>>>def_hangup:: EXTEN: DIALSTATUS: CHANUNAVAIL QUEUESTATUS: REASON: CALL”) in new stack
