Hier ist der Auszug aus der CLI, wobei ich die Rufnummern geändert habe 01731231231 ist die Nummer von der aus angerufen wird und 01721234567 ist die Nummer des Mobiltelefons.
== Using SIP RTP CoS mark 5
-- Executing [621@mdc_incoming-7:1] Set("SIP/mdc_trunk_conf-7-00000015", "MDC_CALLER_NUM_TRUNK=01731231231") in new stack
-- Executing [621@mdc_incoming-7:2] Set("SIP/mdc_trunk_conf-7-00000015", "MDC_CALLEE_NUM_TRUNK=621") in new stack
-- Executing [621@mdc_incoming-7:3] Goto("SIP/mdc_trunk_conf-7-00000015", "mdc_trunk-1,s,1") in new stack
-- Goto (mdc_trunk-1,s,1)
-- Executing [s@mdc_trunk-1:1] Verbose("SIP/mdc_trunk_conf-7-00000015", "1,callee number: 621 caller number: 01731231231") in new stack
-- Executing [s@mdc_trunk-1:2] GosubIf("SIP/mdc_trunk_conf-7-00000015", "0?sub_internat,s,1(CALLERID(num),01731231231,00)") in new stack
-- Executing [s@mdc_trunk-1:3] Gosub("SIP/mdc_trunk_conf-7-00000015", "sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,01731231231,00,49,0,5231)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-7-00000015", "1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - CALLERID(num): 01731231231 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 5231") in new stack
-- Executing [s@sub_nat2int:2] GotoIf("SIP/mdc_trunk_conf-7-00000015", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:3] GotoIf("SIP/mdc_trunk_conf-7-00000015", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:4] GotoIf("SIP/mdc_trunk_conf-7-00000015", "0?s-intshort,1") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("SIP/mdc_trunk_conf-7-00000015", "0?s-natshort,1") in new stack
-- Executing [s@sub_nat2int:6] GotoIf("SIP/mdc_trunk_conf-7-00000015", "1?s-nat,1") in new stack
-- Goto (sub_nat2int,s-nat,1)
-- Executing [s-nat@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-7-00000015", "1,national") in new stack
national
-- Executing [s-nat@sub_nat2int:2] Set("SIP/mdc_trunk_conf-7-00000015", "MDC_CALLER_NUM_INTERNAT=00491731231231") in new stack
-- Executing [s-nat@sub_nat2int:3] Return("SIP/mdc_trunk_conf-7-00000015", "") in new stack
-- Executing [s@mdc_trunk-1:4] Set("SIP/mdc_trunk_conf-7-00000015", "CALLERID(num)=00491731231231") in new stack
-- Executing [s@mdc_trunk-1:5] Gosub("SIP/mdc_trunk_conf-7-00000015", "sub_int2nat,s,1(MDC_CALLER_NUM_NAT,00491731231231,00,49,0,5231)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("SIP/mdc_trunk_conf-7-00000015", "1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 00491731231231 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 5231") in new stack
-- Executing [s@sub_int2nat:2] GotoIf("SIP/mdc_trunk_conf-7-00000015", "0?nat") in new stack
-- Executing [s@sub_int2nat:3] GotoIf("SIP/mdc_trunk_conf-7-00000015", "1?s-internat,1") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("SIP/mdc_trunk_conf-7-00000015", "MDC_CALLER_NUM_NAT=01731231231") in new stack
-- Executing [s-internat@sub_int2nat:2] Return("SIP/mdc_trunk_conf-7-00000015", "") in new stack
-- Executing [s@mdc_trunk-1:6] Set("SIP/mdc_trunk_conf-7-00000015", "CALLERID(num)=01731231231") in new stack
-- Executing [s@mdc_trunk-1:7] Set("SIP/mdc_trunk_conf-7-00000015", "MDC_NUMPREFIX_TRUNK=") in new stack
-- Executing [s@mdc_trunk-1:8] Goto("SIP/mdc_trunk_conf-7-00000015", "mdc_mapping-1,621,1") in new stack
-- Goto (mdc_mapping-1,621,1)
-- Executing [621@mdc_mapping-1:1] Set("SIP/mdc_trunk_conf-7-00000015", "CHANNEL(language)=de") in new stack
-- Executing [621@mdc_mapping-1:2] Set("SIP/mdc_trunk_conf-7-00000015", "CALLERID(num)=3048211") in new stack
-- Executing [621@mdc_mapping-1:3] Verbose("SIP/mdc_trunk_conf-7-00000015", "1,mapping from 621 to 621") in new stack
-- Executing [621@mdc_mapping-1:4] Goto("SIP/mdc_trunk_conf-7-00000015", "mdc_external,621,1") in new stack
-- Goto (mdc_external,621,1)
-- Executing [621@mdc_external:1] SIPAddHeader("SIP/mdc_trunk_conf-7-00000015", ""Alert-Info:<http://www.notused.de>;info=alert-external;x-line-id=0"") in new stack
-- Executing [621@mdc_external:2] GosubIf("SIP/mdc_trunk_conf-7-00000015", "1?sub_initcall,s,1(ext,621)") in new stack
-- Executing [s@sub_initcall:1] Verbose("SIP/mdc_trunk_conf-7-00000015", "1,sub_initcall descent: ext exten: 621") in new stack
-- Executing [s@sub_initcall:2] GosubIf("SIP/mdc_trunk_conf-7-00000015", "1?sub_initloop,s,1") in new stack
-- Executing [s@sub_initloop:1] Verbose("SIP/mdc_trunk_conf-7-00000015", "1,initial loop") in new stack
initial loop
-- Executing [s@sub_initloop:2] Set("SIP/mdc_trunk_conf-7-00000015", "MDC_ALIAS_HOP=0") in new stack
-- Executing [s@sub_initloop:3] Return("SIP/mdc_trunk_conf-7-00000015", "") in new stack
-- Executing [s@sub_initcall:3] Set("SIP/mdc_trunk_conf-7-00000015", "__MDC_DIALDESCENT=ext") in new stack
-- Executing [s@sub_initcall:4] Goto("SIP/mdc_trunk_conf-7-00000015", "ext,1") in new stack
-- Goto (sub_initcall,ext,1)
-- Executing [ext@sub_initcall:1] Set("SIP/mdc_trunk_conf-7-00000015", "__MDC_DIALCALLERNUMINIT=01731231231") in new stack
-- Executing [ext@sub_initcall:2] Set("SIP/mdc_trunk_conf-7-00000015", "__MDC_DIALCALLEENUMINIT=621") in new stack
-- Executing [ext@sub_initcall:3] Return("SIP/mdc_trunk_conf-7-00000015", "") in new stack
-- Executing [621@mdc_external:3] Goto("SIP/mdc_trunk_conf-7-00000015", "main,621,1") in new stack
-- Goto (main,621,1)
-- Executing [621@main:1] Gosub("SIP/mdc_trunk_conf-7-00000015", "sub_defcall,s,1(621)") in new stack
-- Executing [s@sub_defcall:1] Set("SIP/mdc_trunk_conf-7-00000015", "__MDC_ALIAS_HOP=1") in new stack
-- Executing [s@sub_defcall:2] Set("SIP/mdc_trunk_conf-7-00000015", "__MDC_DIALCALLEENUM=621") in new stack
-- Executing [s@sub_defcall:3] Set("SIP/mdc_trunk_conf-7-00000015", "__MDC_DIALCALLERNUM=3048211") in new stack
-- Executing [s@sub_defcall:4] Set("SIP/mdc_trunk_conf-7-00000015", "__MDC_DIALCHANNELNAME=mdc_trunk_conf-7") in new stack
-- Executing [s@sub_defcall:5] GotoIf("SIP/mdc_trunk_conf-7-00000015", "1?nozap") in new stack
-- Goto (sub_defcall,s,8)
-- Executing [s@sub_defcall:8] Set("SIP/mdc_trunk_conf-7-00000015", "__MDC_DIALCALLERNAME=") in new stack
-- Executing [s@sub_defcall:9] Return("SIP/mdc_trunk_conf-7-00000015", "") in new stack
-- Executing [621@main:2] Goto("SIP/mdc_trunk_conf-7-00000015", "mdc_distribute,621,1") in new stack
-- Goto (mdc_distribute,621,1)
-- Executing [621@mdc_distribute:1] Gosub("SIP/mdc_trunk_conf-7-00000015", "sub_user,s,1(callee,1,christian,Christian Richter,621,621)") in new stack
-- Executing [s@sub_user:1] Verbose("SIP/mdc_trunk_conf-7-00000015", "1,sub_user mode callee") in new stack
-- Executing [s@sub_user:2] Goto("SIP/mdc_trunk_conf-7-00000015", "s-callee,1") in new stack
-- Goto (sub_user,s-callee,1)
-- Executing [s-callee@sub_user:1] Verbose("SIP/mdc_trunk_conf-7-00000015", "1,sub_user user id: 1 - user: christian - realname: Christian Richter - own mailbox: 621 - watched mailbox: 621") in new stack
-- Executing [s-callee@sub_user:2] Set("SIP/mdc_trunk_conf-7-00000015", "_MDC_CALLEE_USER_ID=1") in new stack
-- Executing [s-callee@sub_user:3] Set("SIP/mdc_trunk_conf-7-00000015", "_MDC_CALLEE_ACC_NAME=christian") in new stack
-- Executing [s-callee@sub_user:4] Set("SIP/mdc_trunk_conf-7-00000015", "_MDC_CALLEE_ACC_REALNAME=Christian Richter") in new stack
-- Executing [s-callee@sub_user:5] Set("SIP/mdc_trunk_conf-7-00000015", "_MDC_CALLEE_VM_OWN=621") in new stack
-- Executing [s-callee@sub_user:6] Set("SIP/mdc_trunk_conf-7-00000015", "_MDC_CALLEE_VM_WATCHED=621") in new stack
-- Executing [s-callee@sub_user:7] Return("SIP/mdc_trunk_conf-7-00000015", "") in new stack
-- Executing [621@mdc_distribute:2] Goto("SIP/mdc_trunk_conf-7-00000015", "mdc_ident-1,621,1") in new stack
-- Goto (mdc_ident-1,621,1)
-- Executing [621@mdc_ident-1:1] NoOp("SIP/mdc_trunk_conf-7-00000015", "alias-check:: call forwarding from 621 - 0") in new stack
-- Executing [621@mdc_ident-1:2] GotoIf("SIP/mdc_trunk_conf-7-00000015", "0?621-uml,1:621-dial,1") in new stack
-- Goto (mdc_ident-1,621-dial,1)
-- Executing [621-dial@mdc_ident-1:1] Set("SIP/mdc_trunk_conf-7-00000015", "__MDC_EXTEN=621") in new stack
-- Executing [621-dial@mdc_ident-1:2] Gosub("SIP/mdc_trunk_conf-7-00000015", "sub_prefix-621,ext,1") in new stack
-- Executing [ext@sub_prefix-621:1] Verbose("SIP/mdc_trunk_conf-7-00000015", "1,no action") in new stack
no action
-- Executing [ext@sub_prefix-621:2] Return("SIP/mdc_trunk_conf-7-00000015", "") in new stack
-- Executing [621-dial@mdc_ident-1:3] GotoIf("SIP/mdc_trunk_conf-7-00000015", "0?621-unavail,1") in new stack
-- Executing [621-dial@mdc_ident-1:4] GotoIf("SIP/mdc_trunk_conf-7-00000015", "0?621-busy,1") in new stack
-- Executing [621-dial@mdc_ident-1:5] Gosub("SIP/mdc_trunk_conf-7-00000015", "sub_main-621,ext,1") in new stack
-- Executing [ext@sub_main-621:1] Set("SIP/mdc_trunk_conf-7-00000015", "__PICKUPMARK=621") in new stack
-- Executing [ext@sub_main-621:2] Set("SIP/mdc_trunk_conf-7-00000015", "__SPYGROUP=621") in new stack
-- Executing [ext@sub_main-621:3] Dial("SIP/mdc_trunk_conf-7-00000015", "Local/621@mdc_diallocation") in new stack
-- Called Local/621@mdc_diallocation
-- Executing [621@mdc_diallocation:1] Verbose("Local/621@mdc_diallocation-00000033;2", "1,dial to 621 for user 1") in new stack
-- Executing [621@mdc_diallocation:2] Set("Local/621@mdc_diallocation-00000033;2", "MDC_EXTEN=621") in new stack
-- Executing [621@mdc_diallocation:3] Gosub("Local/621@mdc_diallocation-00000033;2", "sub_split-user,s,1(1)") in new stack
-- Executing [s@sub_split-user:1] Verbose("Local/621@mdc_diallocation-00000033;2", "1,get locations for for: 1") in new stack
-- Executing [s@sub_split-user:2] GotoIf("Local/621@mdc_diallocation-00000033;2", "0?s-zero,1") in new stack
-- Executing [s@sub_split-user:3] Set("Local/621@mdc_diallocation-00000033;2", "TMP_LOCATIONS=1;0") in new stack
-- Executing [s@sub_split-user:4] Set("Local/621@mdc_diallocation-00000033;2", "TMP_STATIC_ID=1") in new stack
-- Executing [s@sub_split-user:5] Verbose("Local/621@mdc_diallocation-00000033;2", "1,static id: 1") in new stack
static id: 1
-- Executing [s@sub_split-user:6] Set("Local/621@mdc_diallocation-00000033;2", "TMP_DYN_ID=0") in new stack
-- Executing [s@sub_split-user:7] Verbose("Local/621@mdc_diallocation-00000033;2", "1,dynamic id: 0") in new stack
dynamic id: 0
-- Executing [s@sub_split-user:8] Return("Local/621@mdc_diallocation-00000033;2", "") in new stack
-- Executing [621@mdc_diallocation:4] GotoIf("Local/621@mdc_diallocation-00000033;2", "0?invalid,1") in new stack
-- Executing [621@mdc_diallocation:5] GotoIf("Local/621@mdc_diallocation-00000033;2", "0?dynamic,1") in new stack
-- Executing [621@mdc_diallocation:6] GotoIf("Local/621@mdc_diallocation-00000033;2", "1?static,1") in new stack
-- Goto (mdc_diallocation,static,1)
-- Executing [static@mdc_diallocation:1] Dial("Local/621@mdc_diallocation-00000033;2", "Local/ext@mdc_locallocation-1") in new stack
-- Called Local/ext@mdc_locallocation-1
-- Executing [ext@mdc_locallocation-1:1] Dial("Local/ext@mdc_locallocation-1-00000034;2", "Local/ext-2@mdc_localdevice-1&Local/ext-6@mdc_localdevice-1&Local/ext-1@mdc_localdevice-1") in new stack
-- Called Local/ext-2@mdc_localdevice-1
-- Called Local/ext-6@mdc_localdevice-1
-- Called Local/ext-1@mdc_localdevice-1
-- Executing [ext-2@mdc_localdevice-1:1] Verbose("Local/ext-2@mdc_localdevice-1-00000035;2", "1,Dialing with delay of 0 seconds for 20 seconds") in new stack
-- Executing [ext-2@mdc_localdevice-1:2] Dial("Local/ext-2@mdc_localdevice-1-00000035;2", "SIP/jhKjEryNV34c3a0,20") in new stack
-- Called SIP/jhKjEryNV34c3a0
-- Executing [ext-6@mdc_localdevice-1:1] Verbose("Local/ext-6@mdc_localdevice-1-00000036;2", "1,Dialing with delay of 0 seconds for 20 seconds") in new stack
-- Executing [ext-6@mdc_localdevice-1:2] Dial("Local/ext-6@mdc_localdevice-1-00000036;2", "Local/s@mdc_extphone-4,20") in new stack
-- Called Local/s@mdc_extphone-4
-- Executing [ext-1@mdc_localdevice-1:1] Verbose("Local/ext-1@mdc_localdevice-1-00000037;2", "1,Dialing with delay of 0 seconds for 20 seconds") in new stack
-- Executing [ext-1@mdc_localdevice-1:2] Dial("Local/ext-1@mdc_localdevice-1-00000037;2", "SIP/softphone_621,20") in new stack
-- Called SIP/softphone_621
-- Executing [s@mdc_extphone-4:1] Dial("Local/s@mdc_extphone-4-00000038;2", "Local/01721234567@mdc_outgoing") in new stack
[May 27 15:37:41] NOTICE[22710][C-00000007]: chan_local.c:968 local_call: No such extension/context 01721234567@mdc_outgoing while calling Local channel
-- Couldn't call Local/01721234567@mdc_outgoing
== Everyone is busy/congested at this time (0:0/0/0)
-- Executing [s@mdc_extphone-4:2] NoOp("Local/s@mdc_extphone-4-00000038;2", "Dialstatus: CHANUNAVAIL") in new stack
-- Auto fallthrough, channel 'Local/s@mdc_extphone-4-00000038;2' status is 'CHANUNAVAIL'
-- Local/s@mdc_extphone-4-00000038;1 is circuit-busy
== Everyone is busy/congested at this time (1:0/1/0)
-- Executing [ext-6@mdc_localdevice-1:3] Verbose("Local/ext-6@mdc_localdevice-1-00000036;2", "1,mdc_localdevice-Dialstatus: CONGESTION - cause: 0") in new stack
-- Executing [ext-6@mdc_localdevice-1:4] Gosub("Local/ext-6@mdc_localdevice-1-00000036;2", "sub_hangup,s,1(CONGESTION)") in new stack
-- Executing [s@sub_hangup:1] Verbose("Local/ext-6@mdc_localdevice-1-00000036;2", "1,sub_hangup dialstatus: CONGESTION") in new stack
-- Executing [s@sub_hangup:2] GotoIf("Local/ext-6@mdc_localdevice-1-00000036;2", "0?noanswer,1") in new stack
-- Executing [s@sub_hangup:3] GotoIf("Local/ext-6@mdc_localdevice-1-00000036;2", "0?busy,1") in new stack
-- Executing [s@sub_hangup:4] Goto("Local/ext-6@mdc_localdevice-1-00000036;2", "unavailable,1") in new stack
-- Goto (sub_hangup,unavailable,1)
-- Executing [unavailable@sub_hangup:1] Hangup("Local/ext-6@mdc_localdevice-1-00000036;2", "20") in new stack
== Spawn extension (sub_hangup, unavailable, 1) exited non-zero on 'Local/ext-6@mdc_localdevice-1-00000036;2'
-- Executing [h@mdc_extphone-4:1] Gosub("Local/s@mdc_extphone-4-00000038;2", "def_hangup,s,1(,CHANUNAVAIL,,CALL)") in new stack
-- Executing [s@def_hangup:1] NoOp("Local/s@mdc_extphone-4-00000038;2", ">>>def_hangup:: EXTEN: DIALSTATUS: CHANUNAVAIL QUEUESTATUS: REASON: CALL") in new stack
-- SIP/softphone_621-00000017 is ringing
-- Local/ext-1@mdc_localdevice-1-00000037;1 is ringing
-- Local/ext@mdc_locallocation-1-00000034;1 is ringing
-- Local/621@mdc_diallocation-00000033;1 is ringing
-- SIP/jhKjEryNV34c3a0-00000016 is ringing
-- Local/ext-2@mdc_localdevice-1-00000035;1 is ringing
== Spawn extension (sub_main-621, ext, 3) exited non-zero on 'SIP/mdc_trunk_conf-7-00000015'
-- Executing [h@sub_main-621:1] Gosub("SIP/mdc_trunk_conf-7-00000015", "def_hangup,s,1(621,CANCEL,,CALL)") in new stack
-- Executing [s@def_hangup:1] NoOp("SIP/mdc_trunk_conf-7-00000015", ">>>def_hangup:: EXTEN: 621 DIALSTATUS: CANCEL QUEUESTATUS: REASON: CALL") in new stack
== Spawn extension (mdc_diallocation, static, 1) exited non-zero on 'Local/621@mdc_diallocation-00000033;2'
== Spawn extension (mdc_locallocation-1, ext, 1) exited non-zero on 'Local/ext@mdc_locallocation-1-00000034;2'
== Spawn extension (mdc_localdevice-1, ext-2, 2) exited non-zero on 'Local/ext-2@mdc_localdevice-1-00000035;2'
== Spawn extension (mdc_localdevice-1, ext-1, 2) exited non-zero on 'Local/ext-1@mdc_localdevice-1-00000037;2'
Christian
