in der Tat, mit dem Rufstatus -nicht gesetzt- funktioniert es.
Und hier die komplette Ausgabe:
Executing [40245294@mdc_patton-4:1] Goto(“SIP/MAC00a0ba08b565ID1-0000003a”, “mdc_incoming-gw4,40245294,1”) in new stack
– Goto (mdc_incoming-gw4,40245294,1)
– Executing [40245294@mdc_incoming-gw4:1] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “MDC_CALLER_NUM_TRUNK=072168032880”) in new stack
– Executing [40245294@mdc_incoming-gw4:2] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “MDC_CALLEE_NUM_TRUNK=40245294”) in new stack
– Executing [40245294@mdc_incoming-gw4:3] Goto(“SIP/MAC00a0ba08b565ID1-0000003a”, “mdc_trunk-4,s,1”) in new stack
– Goto (mdc_trunk-4,s,1)
– Executing [s@mdc_trunk-4:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,callee number: 40245294 caller number: 072168032880”) in new stack
– Executing [s@mdc_trunk-4:2] GosubIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?sub_internat,s,1(CALLERID(num),072168032880,00)”) in new stack
– Executing [s@mdc_trunk-4:3] Gosub(“SIP/MAC00a0ba08b565ID1-0000003a”, “sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,072168032880,00,49,0,721)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - CALLERID(num): 072168032880 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 721”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:6] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “1?s-nat,1”) in new stack
– Goto (sub_nat2int,s-nat,1)
– Executing [s-nat@sub_nat2int:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,national”) in new stack
national
– Executing [s-nat@sub_nat2int:2] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “MDC_CALLER_NUM_INTERNAT=004972168032880”) in new stack
– Executing [s-nat@sub_nat2int:3] Return(“SIP/MAC00a0ba08b565ID1-0000003a”, “”) in new stack
– Executing [s@mdc_trunk-4:4] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “CALLERID(num)=004972168032880”) in new stack
– Executing [s@mdc_trunk-4:5] Gosub(“SIP/MAC00a0ba08b565ID1-0000003a”, “sub_int2nat,s,1(MDC_CALLER_NUM_NAT,004972168032880,00,49,0,721)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 004972168032880 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 721”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?nat”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “MDC_CALLER_NUM_NAT=072168032880”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“SIP/MAC00a0ba08b565ID1-0000003a”, “”) in new stack
– Executing [s@mdc_trunk-4:6] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “CALLERID(num)=072168032880”) in new stack
– Executing [s@mdc_trunk-4:7] Gosub(“SIP/MAC00a0ba08b565ID1-0000003a”, “sub_pb-search,s,1(CALLERID(name),072168032880,072168032880,004972168032880,+4972168032880)”) in new stack
– Executing [s@sub_pb-search:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,sub_pb-search variable: CALLERID(name) calleridnum: 072168032880 national: 072168032880 international: 004972168032880 +internat: +4972168032880”) in new stack
[Aug 6 20:06:19] NOTICE[11769]: res_odbc.c:1527 odbc_obj_connect: Connecting md
[Aug 6 20:06:19] NOTICE[11769]: res_odbc.c:1559 odbc_obj_connect: res_odbc: Connected to md [md]
> Found no rows [SELECT “028pho_bez”, “028pho_firstname”, “028pho_lastname”, “028pho_organisation” FROM “028phonebook” WHERE “028pho_phone”=‘072168032880’ OR “028pho_phone”=‘072168032880’ OR “028pho_phone”=‘004972168032880’ OR “028pho_phone”=’+4972168032880’ OR “028pho_homephone”=‘072168032880’ OR “028pho_homephone”=‘072168032880’ OR “028pho_homephone”=‘004972168032880’ OR “028pho_homephone”=’+4972168032880’ OR “028pho_mobile”=‘072168032880’ OR “028pho_mobile”=‘072168032880’ OR “028pho_mobile”=‘004972168032880’ OR “028pho_mobile”=’+4972168032880’]
– Executing [s@sub_pb-search:2] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “HASH(PB_ENTRY)=”) in new stack
– Executing [s@sub_pb-search:3] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,”) in new stack
-- Executing [s@sub_pb-search:4] Verbose("SIP/MAC00a0ba08b565ID1-0000003a", "1,") in new stack
-- Executing [s@sub_pb-search:5] Verbose("SIP/MAC00a0ba08b565ID1-0000003a", "1,") in new stack
-- Executing [s@sub_pb-search:6] Verbose("SIP/MAC00a0ba08b565ID1-0000003a", "1,") in new stack
-- Executing [s@sub_pb-search:7] Set("SIP/MAC00a0ba08b565ID1-0000003a", "CALLERID(name)=") in new stack
-- Executing [s@sub_pb-search:8] Return("SIP/MAC00a0ba08b565ID1-0000003a", "") in new stack
-- Executing [s@mdc_trunk-4:8] Set("SIP/MAC00a0ba08b565ID1-0000003a", "MDC_NUMPREFIX_TRUNK=") in new stack
-- Executing [s@mdc_trunk-4:9] Goto("SIP/MAC00a0ba08b565ID1-0000003a", "mdc_mapping-4,40245294,1") in new stack
-- Goto (mdc_mapping-4,40245294,1)
-- Executing [40245294@mdc_mapping-4:1] Set("SIP/MAC00a0ba08b565ID1-0000003a", "CHANNEL(language)=de") in new stack
-- Executing [40245294@mdc_mapping-4:2] Set("SIP/MAC00a0ba08b565ID1-0000003a", "CALLERID(name)=KabelBW") in new stack
-- Executing [40245294@mdc_mapping-4:3] Verbose("SIP/MAC00a0ba08b565ID1-0000003a", "1,mapping from _4024X. to 98") in new stack
– Executing [40245294@mdc_mapping-4:4] Goto(“SIP/MAC00a0ba08b565ID1-0000003a”, “mdc_external,98,1”) in new stack
– Goto (mdc_external,98,1)
– Executing [98@mdc_external:1] SIPAddHeader(“SIP/MAC00a0ba08b565ID1-0000003a”, "“Alert-Info:<http://www.notused.de>;info=alert-external;x-line-id=0"”) in new stack
– Executing [98@mdc_external:2] GosubIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “1?sub_initcall,s,1(ext,98)”) in new stack
– Executing [s@sub_initcall:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,sub_initcall descent: ext exten: 98”) in new stack
– Executing [s@sub_initcall:2] GosubIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “1?sub_initloop,s,1”) in new stack
– Executing [s@sub_initloop:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,initial loop”) in new stack
initial loop
– Executing [s@sub_initloop:2] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “MDC_ALIAS_HOP=0”) in new stack
– Executing [s@sub_initloop:3] Return(“SIP/MAC00a0ba08b565ID1-0000003a”, “”) in new stack
– Executing [s@sub_initcall:3] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “__MDC_DIALDESCENT=ext”) in new stack
– Executing [s@sub_initcall:4] Goto(“SIP/MAC00a0ba08b565ID1-0000003a”, “ext,1”) in new stack
– Goto (sub_initcall,ext,1)
– Executing [ext@sub_initcall:1] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “__MDC_DIALCALLERNUMINIT=072168032880”) in new stack
– Executing [ext@sub_initcall:2] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “__MDC_DIALCALLEENUMINIT=40245294”) in new stack
– Executing [ext@sub_initcall:3] Return(“SIP/MAC00a0ba08b565ID1-0000003a”, “”) in new stack
– Executing [98@mdc_external:3] Goto(“SIP/MAC00a0ba08b565ID1-0000003a”, “main,98,1”) in new stack
– Goto (main,98,1)
– Executing [98@main:1] Gosub(“SIP/MAC00a0ba08b565ID1-0000003a”, “sub_defcall,s,1(98)”) in new stack
[Aug 6 20:06:19] NOTICE[11769]: func_math.c:424 crement_function_read: The value is now: 1
– Executing [s@sub_defcall:1] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “MDC_ALIAS_HOP=1”) in new stack
– Executing [s@sub_defcall:2] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “__MDC_DIALCALLEENUM=98”) in new stack
– Executing [s@sub_defcall:3] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “__MDC_DIALCALLERNUM=072168032880”) in new stack
– Executing [s@sub_defcall:4] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “__MDC_DIALCHANNELNAME=MAC00a0ba08b565ID1”) in new stack
– Executing [s@sub_defcall:5] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “1?nozap”) in new stack
– Goto (sub_defcall,s,8)
– Executing [s@sub_defcall:8] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “__MDC_DIALCALLERNAME=KabelBW”) in new stack
– Executing [s@sub_defcall:9] Return(“SIP/MAC00a0ba08b565ID1-0000003a”, “”) in new stack
– Executing [98@main:2] Macro(“SIP/MAC00a0ba08b565ID1-0000003a”, “pre-main”) in new stack
– Executing [s@macro-pre-main:1] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?nofax,1,1”) in new stack
– Executing [98@main:3] Goto(“SIP/MAC00a0ba08b565ID1-0000003a”, “mdc_distribute,98,1”) in new stack
– Goto (mdc_distribute,98,1)
– Executing [98@mdc_distribute:1] Gosub(“SIP/MAC00a0ba08b565ID1-0000003a”, “sub_user,s,1(callee,4,stefanguenther,Stefan Günther,98,98)”) in new stack
– Executing [s@sub_user:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,sub_user mode callee”) in new stack
– Executing [s@sub_user:2] Goto(“SIP/MAC00a0ba08b565ID1-0000003a”, “s-callee,1”) in new stack
– Goto (sub_user,s-callee,1)
– Executing [s-callee@sub_user:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,sub_user user id: 4 - user: stefanguenther - realname: Stefan Günther - own mailbox: 98 - watched mailbox: 98”) in new stack
– Executing [s-callee@sub_user:2] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “_MDC_CALLEE_USER_ID=4”) in new stack
– Executing [s-callee@sub_user:3] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “_MDC_CALLEE_ACC_NAME=stefanguenther”) in new stack
– Executing [s-callee@sub_user:4] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “_MDC_CALLEE_ACC_REALNAME=Stefan Günther”) in new stack
– Executing [s-callee@sub_user:5] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “_MDC_CALLEE_VM_OWN=98”) in new stack
– Executing [s-callee@sub_user:6] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “_MDC_CALLEE_VM_WATCHED=98”) in new stack
– Executing [s-callee@sub_user:7] Return(“SIP/MAC00a0ba08b565ID1-0000003a”, “”) in new stack
– Executing [98@mdc_distribute:2] Goto(“SIP/MAC00a0ba08b565ID1-0000003a”, “mdc_ident-4,98,1”) in new stack
– Goto (mdc_ident-4,98,1)
– Executing [98@mdc_ident-4:1] NoOp(“SIP/MAC00a0ba08b565ID1-0000003a”, “alias-check:: call forwarding from 98 - 0”) in new stack
– Executing [98@mdc_ident-4:2] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?98-uml,1:98-dial,1”) in new stack
– Goto (mdc_ident-4,98-dial,1)
– Executing [98-dial@mdc_ident-4:1] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?98-unavail,1”) in new stack
– Executing [98-dial@mdc_ident-4:2] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?98-busy,1”) in new stack
– Executing [98-dial@mdc_ident-4:3] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “__MDC_EXTEN=98”) in new stack
– Executing [98-dial@mdc_ident-4:4] Gosub(“SIP/MAC00a0ba08b565ID1-0000003a”, “sub_prefix-98,ext,1”) in new stack
– Executing [ext@sub_prefix-98:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,no action”) in new stack
no action
– Executing [ext@sub_prefix-98:2] Return(“SIP/MAC00a0ba08b565ID1-0000003a”, “”) in new stack
– Executing [98-dial@mdc_ident-4:5] Gosub(“SIP/MAC00a0ba08b565ID1-0000003a”, “sub_main-98,ext,1”) in new stack
– Executing [ext@sub_main-98:1] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “__PICKUPMARK=98”) in new stack
– Executing [ext@sub_main-98:2] Queue(“SIP/MAC00a0ba08b565ID1-0000003a”, “mdc_pqueue-4,r,31”) in new stack
– Executing [98@mdc_multidial-98:1] Set(“Local/98@mdc_multidial-98-47ef;2”, “__MDC_CALLEE_USER_ID=4”) in new stack
– Executing [98@mdc_multidial-98:2] Set(“Local/98@mdc_multidial-98-47ef;2”, “__PICKUPMARK=98”) in new stack
– Executing [98@mdc_multidial-98:3] Dial(“Local/98@mdc_multidial-98-47ef;2”, “Local/98@mdc_diallocation,c”) in new stack
– Called Local/98@mdc_diallocation
– Executing [98@mdc_diallocation:1] Verbose(“Local/98@mdc_diallocation-d615;2”, “1,dial to 98 for user 4”) in new stack
– Executing [98@mdc_diallocation:2] Gosub(“Local/98@mdc_diallocation-d615;2”, “sub_split-user,s,1(4)”) in new stack
– Executing [s@sub_split-user:1] Verbose(“Local/98@mdc_diallocation-d615;2”, “1,get locations for for: 4”) in new stack
– Executing [s@sub_split-user:2] GotoIf(“Local/98@mdc_diallocation-d615;2”, “0?s-zero,1”) in new stack
– Executing [s@sub_split-user:3] Set(“Local/98@mdc_diallocation-d615;2”, “TMP_LOCATIONS=2;0”) in new stack
– Executing [s@sub_split-user:4] Set(“Local/98@mdc_diallocation-d615;2”, “TMP_STATIC_ID=2”) in new stack
– Executing [s@sub_split-user:5] Verbose(“Local/98@mdc_diallocation-d615;2”, “1,static id: 2”) in new stack
static id: 2
– Executing [s@sub_split-user:6] Set(“Local/98@mdc_diallocation-d615;2”, “TMP_DYN_ID=0”) in new stack
– Executing [s@sub_split-user:7] Verbose(“Local/98@mdc_diallocation-d615;2”, “1,dynamic id: 0”) in new stack
dynamic id: 0
– Executing [s@sub_split-user:8] Return(“Local/98@mdc_diallocation-d615;2”, “”) in new stack
– Executing [98@mdc_diallocation:3] GotoIf(“Local/98@mdc_diallocation-d615;2”, “0?invalid,1”) in new stack
– Executing [98@mdc_diallocation:4] GotoIf(“Local/98@mdc_diallocation-d615;2”, “0?dynamic,1”) in new stack
– Executing [98@mdc_diallocation:5] GotoIf(“Local/98@mdc_diallocation-d615;2”, “1?static,1”) in new stack
– Goto (mdc_diallocation,static,1)
– Executing [static@mdc_diallocation:1] Dial(“Local/98@mdc_diallocation-d615;2”, “Local/ext@mdc_locallocation-2”) in new stack
– Called Local/ext@mdc_locallocation-2
– Executing [ext@mdc_locallocation-2:1] Dial(“Local/ext@mdc_locallocation-2-d481;2”, “Local/ext-1@mdc_localdevice-2”) in new stack
– Called Local/ext-1@mdc_localdevice-2
– Executing [ext-1@mdc_localdevice-2:1] Verbose(“Local/ext-1@mdc_localdevice-2-3980;2”, “1,Dialing with delay of 0 seconds for 31 seconds”) in new stack
– Executing [ext-1@mdc_localdevice-2:2] Dial(“Local/ext-1@mdc_localdevice-2-3980;2”, “SIP/ne0HZPiRX482f98,31”) in new stack
== Using SIP RTP CoS mark 5
– Called SIP/ne0HZPiRX482f98
– SIP/ne0HZPiRX482f98-0000003b is ringing
– Local/ext-1@mdc_localdevice-2-3980;1 is ringing
– Local/ext@mdc_locallocation-2-d481;1 is ringing
– Local/98@mdc_diallocation-d615;1 is ringing
– Local/98@mdc_multidial-98-47ef;1 is ringing
== Manager ‘phpasm’ logged on from 127.0.0.1
== Manager ‘phpasm’ logged off from 127.0.0.1
– Nobody picked up in 15000 ms
– Executing [ext@sub_main-98:3] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, "1,sub_main-Dialstatus: ") in new stack
– Executing [ext@sub_main-98:4] Return(“SIP/MAC00a0ba08b565ID1-0000003a”, “”) in new stack
– Executing [98-dial@mdc_ident-4:6] Gosub(“SIP/MAC00a0ba08b565ID1-0000003a”, “sub_suffix-98,ext,1”) in new stack
– Executing [ext@sub_suffix-98:1] Gosub(“SIP/MAC00a0ba08b565ID1-0000003a”, “sub_mailbox-recording,s,1(98,us)”) in new stack
– Executing [s@sub_mailbox-recording:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,sub_mailbox-recording:: voicebox: 98 options: us”) in new stack
– Executing [s@sub_mailbox-recording:2] Macro(“SIP/MAC00a0ba08b565ID1-0000003a”, “mdc_mailbox-rec,98,us”) in new stack
– Executing [s@macro-mdc_mailbox-rec:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,mdc_mailbox-rec:: voicebox: 98 parameter: us”) in new stack
– Executing [s@macro-mdc_mailbox-rec:2] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?s-false,1”) in new stack
– Executing [s@macro-mdc_mailbox-rec:3] Macro(“SIP/MAC00a0ba08b565ID1-0000003a”, “mdc_mailbox-check,98”) in new stack
– Executing [s@macro-mdc_mailbox-check:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,macro-mdc_mailbox-check:: voicebox: 98”) in new stack
– Executing [s@macro-mdc_mailbox-check:2] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “1 = “1”?s-true,1:s-false,1”) in new stack
– Goto (macro-mdc_mailbox-check,s-true,1)
– Executing [s-true@macro-mdc_mailbox-check:1] Verbose(“SIP/MAC00a0ba08b565ID1-0000003a”, “1,macro-mdc_mailbox-check:: voicebox: 98 exists”) in new stack
– Executing [s-true@macro-mdc_mailbox-check:2] Set(“SIP/MAC00a0ba08b565ID1-0000003a”, “MDC_VOICECHECK=1”) in new stack
– Executing [s@macro-mdc_mailbox-rec:4] GotoIf(“SIP/MAC00a0ba08b565ID1-0000003a”, “0?s-false,1”) in new stack
– Executing [s@macro-mdc_mailbox-rec:5] VoiceMail(“SIP/MAC00a0ba08b565ID1-0000003a”, “98,us”) in new stack
== Spawn extension (mdc_multidial-98, 98, 3) exited non-zero on ‘Local/98@mdc_multidial-98-47ef;2’
== Spawn extension (mdc_diallocation, static, 1) exited non-zero on ‘Local/98@mdc_diallocation-d615;2’
== Spawn extension (mdc_locallocation-2, ext, 1) exited non-zero on ‘Local/ext@mdc_locallocation-2-d481;2’
== Spawn extension (mdc_localdevice-2, ext-1, 2) exited non-zero on ‘Local/ext-1@mdc_localdevice-2-3980;2’
– <SIP/MAC00a0ba08b565ID1-0000003a> Playing ‘/var/spool/asterisk/voicemail/default/98/unavail.slin’ (language ‘de’)
– <SIP/MAC00a0ba08b565ID1-0000003a> Playing ‘beep.alaw’ (language ‘de’)
– Recording the message
– x=0, open writing: /var/spool/asterisk/voicemail/default/98/tmp/QXsdgu format: wav49, 0x2e10738
– x=1, open writing: /var/spool/asterisk/voicemail/default/98/tmp/QXsdgu format: gsm, 0x2f325d8
– x=2, open writing: /var/spool/asterisk/voicemail/default/98/tmp/QXsdgu format: wav, 0x2fe5ce8
Danke & Gruß,
Stefan
