soweit läuft das System. Nur hab ich noch ein Problem mit der Mailbox. Und zwar kann ich die Mailbox der Rufgruppe “41” nicht abhören, hier versuche ich es mit der Nebenstelle 14, die Mailbox 41 abzuhören. Die 41 ist der 14 in der Rubrik Voicemail zugeordnet, jedoch greift diese immer auf die 14 zu.
Hat hierzu jemand eine Idee?
obydick (pid = 3984)
Verbosity is at least 3
– Remote UNIX connection
– Executing Set(“SIP/buero1-0821c818”, “MDC_CHANNEL_PROTOCOL=SIP”) in new stack
– Executing Set(“SIP/buero1-0821c818”, “MDC_CHANNEL_ID=buero1-0821c818”) in new stack
– Executing Set(“SIP/buero1-0821c818”, “MDC_CHANNEL_TMP=buero1-0821c818”) in new stack
– Executing Set(“SIP/buero1-0821c818”, “MDC_CHANNEL_NAME=buero1”) in new stack
– Executing GosubIf(“SIP/buero1-0821c818”, “1?mdc_initcall-int|asterisk|1”) in new stack
– Executing NoOp(“SIP/buero1-0821c818”, “initial call”) in new stack
– Executing Set(“SIP/buero1-0821c818”, “MDC_ALIAS_HOP=0”) in new stack
– Executing Set(“SIP/buero1-0821c818”, “__MDC_DIALDESCENT=int”) in new stack
– Executing Set(“SIP/buero1-0821c818”, “__MDC_DIALCALLEENUM=asterisk”) in new stack
– Executing Set(“SIP/buero1-0821c818”, “__MDC_DIALCALLERNUM=14”) in new stack
– Executing GotoIf(“SIP/buero1-0821c818”, “1?nozap”) in new stack
– Goto (mdc_initcall-int,asterisk,9)
– Executing Set(“SIP/buero1-0821c818”, “__MDC_DIALCALLERNAME=Büro1”) in new stack
– Executing Return(“SIP/buero1-0821c818”, “”) in new stack
– Executing Gosub(“SIP/buero1-0821c818”, “mdc_defcall|asterisk|1”) in new stack
– Goto (mdc_defcall,asterisk,4)
– Executing Set(“SIP/buero1-0821c818”, “__MDC_DIALCHANNELNAME=buero1”) in new stack
– Executing SIPAddHeader(“SIP/buero1-0821c818”, "“Alert-Info:<http://www.notused.de>”) in new stack
– Executing Macro(“SIP/buero1-0821c818”, “pre-main”) in new stack
Mar 29 10:16:19 WARNING[8254]: app_macro.c:208 macro_exec: No such context ‘macro-pre-main’ for macro ‘pre-main’
– Executing Goto(“SIP/buero1-0821c818”, “main|asterisk|1”) in new stack
– Goto (main,asterisk,1)
– Executing Set(“SIP/buero1-0821c818”, “MDC_VOICEMAIL=14”) in new stack
– Executing Gosub(“SIP/buero1-0821c818”, “mdc_listen-mailbox|s|1”) in new stack
– Executing NoOp(“SIP/buero1-0821c818”, “mdc_listen-mailbox:: Voicebox: 14”) in new stack
– Executing Macro(“SIP/buero1-0821c818”, “mdc_own-mailbox-check|14”) in new stack
– Executing NoOp(“SIP/buero1-0821c818”, “macro-mdc_own-mailbox-check:: Voicebox: 14”) in new stack
– Executing MailboxExists(“SIP/buero1-0821c818”, “14”) in new stack
– Executing NoOp(“SIP/buero1-0821c818”, “FAILED”) in new stack
– Executing Goto(“SIP/buero1-0821c818”, “s-false|1”) in new stack
– Goto (macro-mdc_own-mailbox-check,s-false,1)
– Executing Set(“SIP/buero1-0821c818”, “MDC_VOICECHECK=0”) in new stack
– Executing GotoIf(“SIP/buero1-0821c818”, “1?false”) in new stack
– Goto (mdc_listen-mailbox,s,6)
– Executing Playback(“SIP/buero1-0821c818”, “mdc-mbx-invalid”) in new stack
– Playing ‘mdc-mbx-invalid’ (language ‘de’)
== Spawn extension (mdc_listen-mailbox, s, 6) exited non-zero on ‘SIP/buero1-0821c818’
Viele Grüße und Danke
Andi
