Ein Vodafone SIP-Trunk wurde gemäß Dokumentation auf der Version 19.02 eingerichtet. Bereits die SIP-Pings werden nicht richtig beantwortet:
18:51:11.106547 IP (tos 0x60, ttl 63, id 46539, offset 0, flags [DF], proto UDP (17), length 603)
192.168.94.237.5069 > 176.95.100.222.5060: [ud18:52:11.126459 IP (tos 0x0, ttl 124, id 0, offset 0, flags [none], proto UDP (17), length 385)
176.95.100.222.5060 > 176.95.209.35.5060: [udp sum ok] SIP, length: 357
OPTIONS sip:pbx1.blsteu.ngn.vodafone.de:5060 SIP/2.0
Via: SIP/2.0/UDP 176.95.100.222:5060;branch=z9hG4bK54pq66302ov3adbhq2l0
Call-ID: 77258150d2d1348976cbae4c78034001050000a1q1500@176.95.100.222
To: sip:ping@pbx1.blsteu.ngn.vodafone.de
From: sip:ping@176.95.100.222;tag=5790b718259024a71346617b58c08366000a1q1
Max-Forwards: 70
CSeq: 5492 OPTIONS
18:52:11.126494 IP (tos 0x0, ttl 123, id 0, offset 0, flags [none], proto UDP (17), length 385)
176.95.100.222.5060 > 192.168.94.237.5069: [udp sum ok] SIP, length: 357
Max-Forwards: 70
CSeq: 5492 OPTIONS
18:52:11.127414 IP (tos 0x60, ttl 63, id 60213, offset 0, flags [DF], proto UDP (17), length 603)
192.168.94.237.5069 > 176.95.100.222.5060: [udp sum ok] SIP, length: 575
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 176.95.100.222:5060;rport=5060;received=176.95.100.222;branch=z9hG4bK54pq66302ov3adbhq2l0
To: sip:ping@pbx1.blsteu.ngn.vodafone.de;tag=z9hG4bK54pq66302ov3adbhq2l0
CSeq: 5492 OPTIONS
WWW-Authenticate: Digest realm=“asterisk”,nonce=“1577123668/3c49e13967414277a39df154d0a2ecb8”,opaque=“29edb0593ee57854”,algorithm=md5,qop=“auth”
Server: Asterisk PBX 16.5.0
Content-Length: 0
18:52:11.127441 IP (tos 0x60, ttl 62, id 60213, offset 0, flags [DF], proto UDP (17), length 603)
176.95.209.35.5060 > 176.95.100.222.5060: [udp sum ok] SIP, length: 575
CSeq: 5492 OPTIONS
Content-Length: 0
[Dec 23 18:59:28] NOTICE[2482]: res_pjsip/pjsip_distributor.c:676 log_failed_request: Request ‘OPTIONS’ from ‘sip:ping@176.95.100.222’ failed for ‘176.95.100.222:5060’ (callid: 77258150d2d1348976cbae4c78034001050000ahs1200@176.95.100.222) - No matching endpoint found
[Dec 23 19:00:28] WARNING[2482]: res_pjsip_endpoint_identifier_ip.c:275 common_identify: Identify ‘mdc_trunk_conf-2-identify’ points to endpoint ‘mdc_trunk_conf-2’ but endpoint could not be found
Was kann die Ursache dafür sein?
Vielen Dank Igor
