hier der gewünschte Auszug …
mobydickCLI>
== Using SIP VIDEO CoS mark 6
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
– Executing [12#309022@mdc_berofix-d8df0d001b95:1] Goto(“SIP/d8df0d001b95-000001cd”, “mdc_incoming-gw1,309022,1”) in new stack
– Goto (mdc_incoming-gw1,309022,1)
– Executing [309022@mdc_incoming-gw1:1] Set(“SIP/d8df0d001b95-000001cd”, “MDC_CALLER_NUM_TRUNK=06092995035”) in new stack
– Executing [309022@mdc_incoming-gw1:2] Set(“SIP/d8df0d001b95-000001cd”, “MDC_CALLEE_NUM_TRUNK=309022”) in new stack
– Executing [309022@mdc_incoming-gw1:3] Goto(“SIP/d8df0d001b95-000001cd”, “mdc_trunk-1,s,1”) in new stack
– Goto (mdc_trunk-1,s,1)
– Executing [s@mdc_trunk-1:1] Verbose(“SIP/d8df0d001b95-000001cd”, “1,callee number: 309022 caller number: 06092995035”) in new stack
– Executing [s@mdc_trunk-1:2] Set(“SIP/d8df0d001b95-000001cd”, “MDC_FALLBACK_TRUNK=10”) in new stack
– Executing [s@mdc_trunk-1:3] Gosub(“SIP/d8df0d001b95-000001cd”, “sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,06092995035,00,49,0,6021,1)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“SIP/d8df0d001b95-000001cd”, “1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - number: 06092995035 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 6021 - incoming: 1”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?s-emergency,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?s-convert,1”) in new stack
– Executing [s@sub_nat2int:6] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:7] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:8] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:9] GotoIf(“SIP/d8df0d001b95-000001cd”, “1?s-nat,1”) in new stack
– Goto (sub_nat2int,s-nat,1)
– Executing [s-nat@sub_nat2int:1] Verbose(“SIP/d8df0d001b95-000001cd”, “1,national”) in new stack
national
– Executing [s-nat@sub_nat2int:2] Set(“SIP/d8df0d001b95-000001cd”, “MDC_CALLER_NUM_INTERNAT=00496092995035”) in new stack
– Executing [s-nat@sub_nat2int:3] Return(“SIP/d8df0d001b95-000001cd”, “”) in new stack
– Executing [s@mdc_trunk-1:4] Set(“SIP/d8df0d001b95-000001cd”, “CALLERID(num)=00496092995035”) in new stack
– Executing [s@mdc_trunk-1:5] Gosub(“SIP/d8df0d001b95-000001cd”, “sub_int2nat,s,1(MDC_CALLER_NUM_NAT,00496092995035,00,49,0,6021,1)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“SIP/d8df0d001b95-000001cd”, “1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 00496092995035 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 6021 - incoming: 1”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?s-emergency,1”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?nat”) in new stack
– Executing [s@sub_int2nat:4] GotoIf(“SIP/d8df0d001b95-000001cd”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“SIP/d8df0d001b95-000001cd”, “MDC_CALLER_NUM_NAT=06092995035”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“SIP/d8df0d001b95-000001cd”, “”) in new stack
– Executing [s@mdc_trunk-1:6] Set(“SIP/d8df0d001b95-000001cd”, “CALLERID(num)=06092995035”) in new stack
– Executing [s@mdc_trunk-1:7] UserEvent(“SIP/d8df0d001b95-000001cd”, “ResolveCallerName,Strategy: default,Outbound: 0,Channel: SIP/d8df0d001b95-000001cd”) in new stack
– Executing [s@mdc_trunk-1:8] Wait(“SIP/d8df0d001b95-000001cd”, “0.25”) in new stack
– Executing [s@mdc_trunk-1:9] Verbose(“SIP/d8df0d001b95-000001cd”, “1,MDC_RESOLVENAME_HITS = 1”) in new stack
– Executing [s@mdc_trunk-1:10] Verbose(“SIP/d8df0d001b95-000001cd”, “1,CALLERID(name) = Amrhein, Patrick”) in new stack
– Executing [s@mdc_trunk-1:11] Set(“SIP/d8df0d001b95-000001cd”, “MDC_NUMPREFIX_TRUNK=0”) in new stack
– Executing [s@mdc_trunk-1:12] ExecIf(“SIP/d8df0d001b95-000001cd”, “1?Set(CALLERID(num)=006092995035)”) in new stack
– Executing [s@mdc_trunk-1:13] Goto(“SIP/d8df0d001b95-000001cd”, “mdc_mapping-1,309022,1”) in new stack
– Goto (mdc_mapping-1,309022,1)
– Executing [309022@mdc_mapping-1:1] Set(“SIP/d8df0d001b95-000001cd”, “CHANNEL(language)=de”) in new stack
– Executing [309022@mdc_mapping-1:2] Verbose(“SIP/d8df0d001b95-000001cd”, “1,mapping from _3090XX to 22”) in new stack
– Executing [309022@mdc_mapping-1:3] Goto(“SIP/d8df0d001b95-000001cd”, “mdc_external,22,1”) in new stack
– Goto (mdc_external,22,1)
– Executing [22@mdc_external:1] SIPAddHeader(“SIP/d8df0d001b95-000001cd”, "“Alert-Info:<http://www.notused.de>;info=alert-external;x-line-id=0"”) in new stack
– Executing [22@mdc_external:2] GosubIf(“SIP/d8df0d001b95-000001cd”, “1?sub_initcall,s,1(ext,22)”) in new stack
– Executing [s@sub_initcall:1] Verbose(“SIP/d8df0d001b95-000001cd”, “1,sub_initcall descent: ext exten: 22”) in new stack
– Executing [s@sub_initcall:2] GosubIf(“SIP/d8df0d001b95-000001cd”, “1?sub_initloop,s,1”) in new stack
– Executing [s@sub_initloop:1] Verbose(“SIP/d8df0d001b95-000001cd”, “1,initial loop”) in new stack
initial loop
– Executing [s@sub_initloop:2] Set(“SIP/d8df0d001b95-000001cd”, “MDC_ALIAS_HOP=0”) in new stack
– Executing [s@sub_initloop:3] Return(“SIP/d8df0d001b95-000001cd”, “”) in new stack
– Executing [s@sub_initcall:3] Set(“SIP/d8df0d001b95-000001cd”, “__MDC_TRANSFERBACK_HOP=0”) in new stack
– Executing [s@sub_initcall:4] Set(“SIP/d8df0d001b95-000001cd”, “__MDC_DIALDESCENT=ext”) in new stack
– Executing [s@sub_initcall:5] Goto(“SIP/d8df0d001b95-000001cd”, “ext,1”) in new stack
– Goto (sub_initcall,ext,1)
– Executing [ext@sub_initcall:1] Set(“SIP/d8df0d001b95-000001cd”, “__MDC_DIALCALLERNUMINIT=06092995035”) in new stack
– Executing [ext@sub_initcall:2] Set(“SIP/d8df0d001b95-000001cd”, “__MDC_DIALCALLEENUMINIT=309022”) in new stack
– Executing [ext@sub_initcall:3] Set(“SIP/d8df0d001b95-000001cd”, “__MDC_DIALCALLEENUMMAP=22”) in new stack
– Executing [ext@sub_initcall:4] Return(“SIP/d8df0d001b95-000001cd”, “”) in new stack
– Executing [22@mdc_external:3] Goto(“SIP/d8df0d001b95-000001cd”, “main,22,1”) in new stack
– Goto (main,22,1)
– Executing [22@main:1] Gosub(“SIP/d8df0d001b95-000001cd”, “sub_defcall,s,1(22)”) in new stack
– Executing [s@sub_defcall:1] Set(“SIP/d8df0d001b95-000001cd”, “__MDC_ALIAS_HOP=1”) in new stack
– Executing [s@sub_defcall:2] Set(“SIP/d8df0d001b95-000001cd”, “__MDC_DIALCALLEENUM=22”) in new stack
– Executing [s@sub_defcall:3] Set(“SIP/d8df0d001b95-000001cd”, “__MDC_DIALCALLERNUM=006092995035”) in new stack
– Executing [s@sub_defcall:4] GotoIf(“SIP/d8df0d001b95-000001cd”, “1?nozap”) in new stack
– Goto (sub_defcall,s,8)
– Executing [s@sub_defcall:8] Set(“SIP/d8df0d001b95-000001cd”, “__MDC_DIALCALLERNAME=Amrhein, Patrick”) in new stack
– Executing [s@sub_defcall:9] Set(“SIP/d8df0d001b95-000001cd”, “__MDC_DIALCHANNELNAME=d8df0d001b95”) in new stack
– Executing [s@sub_defcall:10] Return(“SIP/d8df0d001b95-000001cd”, “”) in new stack
– Executing [22@main:2] Goto(“SIP/d8df0d001b95-000001cd”, “mdc_distribute,22,1”) in new stack
– Goto (mdc_distribute,22,1)
– Executing [22@mdc_distribute:1] Gosub(“SIP/d8df0d001b95-000001cd”, “sub_user,s,1(callee,5,kh,Karl-Heinz Huth,22,22)”) in new stack
– Executing [s@sub_user:1] Verbose(“SIP/d8df0d001b95-000001cd”, “1,sub_user mode callee”) in new stack
– Executing [s@sub_user:2] Goto(“SIP/d8df0d001b95-000001cd”, “s-callee,1”) in new stack
– Goto (sub_user,s-callee,1)
– Executing [s-callee@sub_user:1] Verbose(“SIP/d8df0d001b95-000001cd”, “1,sub_user user id: 5 - user: kh - realname: Karl-Heinz Huth - own mailbox: 22 - watched mailbox: 22”) in new stack
– Executing [s-callee@sub_user:2] Set(“SIP/d8df0d001b95-000001cd”, “_MDC_CALLEE_USER_ID=5”) in new stack
– Executing [s-callee@sub_user:3] Set(“SIP/d8df0d001b95-000001cd”, “_MDC_CALLEE_ACC_NAME=kh”) in new stack
– Executing [s-callee@sub_user:4] Set(“SIP/d8df0d001b95-000001cd”, “_MDC_CALLEE_ACC_REALNAME=Karl-Heinz Huth”) in new stack
– Executing [s-callee@sub_user:5] Set(“SIP/d8df0d001b95-000001cd”, “_MDC_CALLEE_VM_OWN=22”) in new stack
– Executing [s-callee@sub_user:6] Set(“SIP/d8df0d001b95-000001cd”, “_MDC_CALLEE_VM_WATCHED=22”) in new stack
– Executing [s-callee@sub_user:7] Return(“SIP/d8df0d001b95-000001cd”, “”) in new stack
– Executing [22@mdc_distribute:2] Goto(“SIP/d8df0d001b95-000001cd”, “mdc_ident-5,22,1”) in new stack
– Goto (mdc_ident-5,22,1)
– Executing [22@mdc_ident-5:1] NoOp(“SIP/d8df0d001b95-000001cd”, “alias-check:: call forwarding from 22 - 0”) in new stack
– Executing [22@mdc_ident-5:2] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?22-uml,1:22-dial,1”) in new stack
– Goto (mdc_ident-5,22-dial,1)
– Executing [22-dial@mdc_ident-5:1] Set(“SIP/d8df0d001b95-000001cd”, “__MDC_EXTEN=22”) in new stack
– Executing [22-dial@mdc_ident-5:2] Gosub(“SIP/d8df0d001b95-000001cd”, “sub_prefix-22,ext,1”) in new stack
– Executing [ext@sub_prefix-22:1] Verbose(“SIP/d8df0d001b95-000001cd”, “1,no action”) in new stack
no action
– Executing [ext@sub_prefix-22:2] Return(“SIP/d8df0d001b95-000001cd”, “”) in new stack
– Executing [22-dial@mdc_ident-5:3] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?22-unavail,1”) in new stack
– Executing [22-dial@mdc_ident-5:4] GotoIf(“SIP/d8df0d001b95-000001cd”, “0?22-busy,1”) in new stack
– Executing [22-dial@mdc_ident-5:5] Gosub(“SIP/d8df0d001b95-000001cd”, “sub_main-22,ext,1”) in new stack
– Executing [ext@sub_main-22:1] Set(“SIP/d8df0d001b95-000001cd”, “__PICKUPMARK=22”) in new stack
– Executing [ext@sub_main-22:2] Set(“SIP/d8df0d001b95-000001cd”, “__SPYGROUP=22”) in new stack
– Executing [ext@sub_main-22:3] Dial(“SIP/d8df0d001b95-000001cd”, “Local/22@mdc_diallocation”) in new stack
– Called Local/22@mdc_diallocation
– Executing [22@mdc_diallocation:1] Verbose(“Local/22@mdc_diallocation-00000407;2”, “1,dial to 22 for user 5”) in new stack
– Executing [22@mdc_diallocation:2] Set(“Local/22@mdc_diallocation-00000407;2”, “__MDC_DIALLOCATION_CHANNEL=Local/22@mdc_diallocation-00000407;2”) in new stack
– Executing [22@mdc_diallocation:3] Set(“Local/22@mdc_diallocation-00000407;2”, “SHARED(MDC_CALLEE_PEERS)=”) in new stack
– Executing [22@mdc_diallocation:4] Set(“Local/22@mdc_diallocation-00000407;2”, “MDC_EXTEN=22”) in new stack
– Executing [22@mdc_diallocation:5] ExecIf(“Local/22@mdc_diallocation-00000407;2”, “0?Set(TMP_TARGET=team):Set(TMP_TARGET=ext)”) in new stack
– Executing [22@mdc_diallocation:6] Gosub(“Local/22@mdc_diallocation-00000407;2”, “sub_split-user,s,1(5)”) in new stack
– Executing [s@sub_split-user:1] Verbose(“Local/22@mdc_diallocation-00000407;2”, “1,get locations for for: 5”) in new stack
– Executing [s@sub_split-user:2] GotoIf(“Local/22@mdc_diallocation-00000407;2”, “0?s-zero,1”) in new stack
– Executing [s@sub_split-user:3] Set(“Local/22@mdc_diallocation-00000407;2”, “TMP_LOCATIONS=0;6”) in new stack
– Executing [s@sub_split-user:4] Set(“Local/22@mdc_diallocation-00000407;2”, “TMP_STATIC_ID=0”) in new stack
– Executing [s@sub_split-user:5] Verbose(“Local/22@mdc_diallocation-00000407;2”, “1,static id: 0”) in new stack
static id: 0
– Executing [s@sub_split-user:6] Set(“Local/22@mdc_diallocation-00000407;2”, “TMP_DYN_ID=6”) in new stack
– Executing [s@sub_split-user:7] Verbose(“Local/22@mdc_diallocation-00000407;2”, “1,dynamic id: 6”) in new stack
dynamic id: 6
– Executing [s@sub_split-user:8] Return(“Local/22@mdc_diallocation-00000407;2”, “”) in new stack
– Executing [22@mdc_diallocation:7] GotoIf(“Local/22@mdc_diallocation-00000407;2”, “0?invalid,1”) in new stack
– Executing [22@mdc_diallocation:8] GotoIf(“Local/22@mdc_diallocation-00000407;2”, “1?dynamic,1”) in new stack
– Goto (mdc_diallocation,dynamic,1)
– Executing [dynamic@mdc_diallocation:1] Dial(“Local/22@mdc_diallocation-00000407;2”, “Local/ext@mdc_locallocation-6”) in new stack
– Called Local/ext@mdc_locallocation-6
– Executing [ext@mdc_locallocation-6:1] Set(“Local/ext@mdc_locallocation-6-00000408;2”, “PUSH(SHARED(MDC_CALLEE_PEERS,Local/22@mdc_diallocation-00000407;2))=Local/ext-2@mdc_localdevice-6”) in new stack
– Executing [ext@mdc_locallocation-6:2] Dial(“Local/ext@mdc_locallocation-6-00000408;2”, “Local/ext-2@mdc_localdevice-6”) in new stack
– Called Local/ext-2@mdc_localdevice-6
– Executing [ext-2@mdc_localdevice-6:1] Verbose(“Local/ext-2@mdc_localdevice-6-00000409;2”, “1,Dialing with delay of 0 seconds for 20 seconds”) in new stack
– Executing [ext-2@mdc_localdevice-6:2] Dial(“Local/ext-2@mdc_localdevice-6-00000409;2”, “SIP/yE28d079P718885,20”) in new stack
– Called SIP/yE28d079P718885
== Extension Changed 22[mdc_hint-ident] new state Ringing for Notify User coXMhdVQW718801
== Extension Changed 22[mdc_hint-ident] new state Ringing for Notify User msuCSLijO718805
== Extension Changed 22[mdc_hint-ident] new state Ringing for Notify User P5R6df26Z718827
== Extension Changed 22[mdc_hint-ident] new state Ringing for Notify User yE28d079P718885
== Extension Changed 22[mdc_hint-ident] new state Ringing for Notify User eOwakJFfT71870d
– SIP/yE28d079P718885-000001ce is ringing
– Local/ext-2@mdc_localdevice-6-00000409;1 is ringing
– Local/ext@mdc_locallocation-6-00000408;1 is ringing
– Local/22@mdc_diallocation-00000407;1 is ringing
– Nobody picked up in 20000 ms
– Executing [ext-2@mdc_localdevice-6:3] Verbose(“Local/ext-2@mdc_localdevice-6-00000409;2”, “1,mdc_localdevice-Dialstatus: NOANSWER - cause: 0”) in new stack
– Executing [ext-2@mdc_localdevice-6:4] Gosub(“Local/ext-2@mdc_localdevice-6-00000409;2”, “sub_hangup,s,1(NOANSWER)”) in new stack
== Extension Changed 22[mdc_hint-ident] new state Idle for Notify User coXMhdVQW718801
– Executing [s@sub_hangup:1] Verbose(“Local/ext-2@mdc_localdevice-6-00000409;2”, “1,sub_hangup dialstatus: NOANSWER”) in new stack
== Extension Changed 22[mdc_hint-ident] new state Idle for Notify User msuCSLijO718805
– Executing [s@sub_hangup:2] GotoIf(“Local/ext-2@mdc_localdevice-6-00000409;2”, “1?noanswer,1”) in new stack
– Goto (sub_hangup,noanswer,1)
– Executing [noanswer@sub_hangup:1] Hangup(“Local/ext-2@mdc_localdevice-6-00000409;2”, “19”) in new stack
== Extension Changed 22[mdc_hint-ident] new state Idle for Notify User P5R6df26Z718827
== Spawn extension (sub_hangup, noanswer, 1) exited non-zero on ‘Local/ext-2@mdc_localdevice-6-00000409;2’
== Extension Changed 22[mdc_hint-ident] new state Idle for Notify User yE28d079P718885
– No one is available to answer at this time (1:0/0/0)
– Executing [ext@mdc_locallocation-6:3] Verbose(“Local/ext@mdc_locallocation-6-00000408;2”, “1,mdc_locallocation-Dialstatus: NOANSWER - cause: 19”) in new stack
== Extension Changed 22[mdc_hint-ident] new state Idle for Notify User eOwakJFfT71870d
– Executing [ext@mdc_locallocation-6:4] ExecIf(“Local/ext@mdc_locallocation-6-00000408;2”, “1?HangUp(19)”) in new stack
== Spawn extension (mdc_locallocation-6, ext, 4) exited non-zero on ‘Local/ext@mdc_locallocation-6-00000408;2’
– Executing [dynamic@mdc_diallocation:2] Verbose(“Local/22@mdc_diallocation-00000407;2”, “1,mdc_diallocationDialstatus: NOANSWER - cause: 19”) in new stack
– Executing [dynamic@mdc_diallocation:3] ExecIf(“Local/22@mdc_diallocation-00000407;2”, “1?HangUp(19)”) in new stack
== Spawn extension (mdc_diallocation, dynamic, 3) exited non-zero on ‘Local/22@mdc_diallocation-00000407;2’
– Executing [ext@sub_main-22:4] Verbose(“SIP/d8df0d001b95-000001cd”, “1,sub_main-Dialstatus: NOANSWER”) in new stack
– Executing [ext@sub_main-22:5] Return(“SIP/d8df0d001b95-000001cd”, “”) in new stack
– Executing [22-dial@mdc_ident-5:6] Gosub(“SIP/d8df0d001b95-000001cd”, “sub_suffix-22,ext,1”) in new stack
– Executing [ext@sub_suffix-22:1] GotoIf(“SIP/d8df0d001b95-000001cd”, “1?back”) in new stack
– Goto (sub_suffix-22,ext,4)
– Executing [ext@sub_suffix-22:4] Return(“SIP/d8df0d001b95-000001cd”, “”) in new stack
– Executing [22-dial@mdc_ident-5:7] ExecIf(“SIP/d8df0d001b95-000001cd”, “0?HangUp(21)”) in new stack
– Executing [22-dial@mdc_ident-5:8] ExecIf(“SIP/d8df0d001b95-000001cd”, “1?HangUp(19)”) in new stack
== Spawn extension (mdc_ident-5, 22-dial, 8) exited non-zero on ‘SIP/d8df0d001b95-000001cd’
mobydickCLI>
Vielen Dank
LG trick
