Hallo zusammen
ich habe dies zweimal ausprobiert:
- Produktiv System mit 19.10.R - Update über “cs host update” auf der shell
- Test System (komplett frischer Install) mit 18.12.R - Update über ISO-Upload via Web
Das einspielen des ISOs funktioniert, der Reboot läuft, aber danach kann der Controller-Container nicht mehr gestartet werden:
$ journalctl -u csstartup.service
-- Logs begin at Tue 2021-01-19 22:25:11 UTC, end at Tue 2021-01-19 22:28:29 UTC. --
Jan 19 22:25:15 pascom.intevo.net systemd[1]: Starting Cloudstack containers...
Jan 19 22:25:16 pascom.intevo.net containersStart.py[1288]: Host Memory: 3.750156 GiB
Jan 19 22:25:21 pascom.intevo.net containersStart.py[1288]: Waiting for consul leader
Jan 19 22:25:26 pascom.intevo.net containersStart.py[1288]: Waiting for consul leader
Jan 19 22:25:26 pascom.intevo.net containersStart.py[1288]: Consul leader is [127.0.0.1:8300]
Jan 19 22:25:31 pascom.intevo.net containersStart.py[1288]: ... update legacy anonymous acl rule
Jan 19 22:25:31 pascom.intevo.net containersStart.py[1288]: Checking for host name change
Jan 19 22:25:31 pascom.intevo.net containersStart.py[1288]: Checking proxy [ifens3]
Jan 19 22:25:31 pascom.intevo.net containersStart.py[1288]: .. uses management interface [ens3]
Jan 19 22:25:31 pascom.intevo.net containersStart.py[1288]: Checking management proxy configuration
Jan 19 22:25:31 pascom.intevo.net containersStart.py[1288]: Newest available image for [ifens3] is [cs-proxy@7.19.12.R]
Jan 19 22:25:31 pascom.intevo.net containersStart.py[1288]: .. has version [7.19.10.R] but [7.19.12.R] is available. Performing update.
Jan 19 22:25:32 pascom.intevo.net containersStart.py[1288]: ==== proxy update.sh start ====
Jan 19 22:25:32 pascom.intevo.net containersStart.py[1288]: RTP Port numbers are ok
Jan 19 22:25:32 pascom.intevo.net containersStart.py[1288]: ==== proxy update.sh end ====
Jan 19 22:25:35 pascom.intevo.net containersStart.py[1288]: Newest available image for [pg] is [cs-postgresql@7.19.12.R]
Jan 19 22:25:35 pascom.intevo.net containersStart.py[1288]: .. has version [7.19.10.R] but [7.19.12.R] is available. Performing update.
Jan 19 22:25:35 pascom.intevo.net containersStart.py[1288]: ==== default update.sh start ====
Jan 19 22:25:35 pascom.intevo.net containersStart.py[1288]: ==== default update.sh end ====
Jan 19 22:25:38 pascom.intevo.net containersStart.py[1288]: Container pg has a limit of 1024 MB memory, calculated value is 1024 MB
Jan 19 22:25:38 pascom.intevo.net containersStart.py[1288]: Starting pg
Jan 19 22:25:41 pascom.intevo.net containersStart.py[1288]: Set desired state pg => RUNNING
Jan 19 22:25:41 pascom.intevo.net containersStart.py[1288]: Database is ready. Prepare postgres superuser
Jan 19 22:25:41 pascom.intevo.net containersStart.py[1288]: Create/update postgres superuser
Jan 19 22:25:42 pascom.intevo.net containersStart.py[1288]: There is no host setup data.
Jan 19 22:25:42 pascom.intevo.net containersStart.py[1288]: Deregistering consul service [teambox]
Jan 19 22:25:42 pascom.intevo.net containersStart.py[1288]: Newest available image for [teambox] is [pbx@7.19.12.R]
Jan 19 22:25:42 pascom.intevo.net containersStart.py[1288]: .. has version [7.19.10.R] but [7.19.12.R] is available. Performing update.
Jan 19 22:25:42 pascom.intevo.net containersStart.py[1288]: ==== md-firmware update.sh start ====
Jan 19 22:25:42 pascom.intevo.net containersStart.py[1288]: ==== md-firmware update.sh end ====
Jan 19 22:25:44 pascom.intevo.net containersStart.py[1288]: Newest available image for [controller] is [cs-controller@7.19.12.R]
Jan 19 22:25:44 pascom.intevo.net containersStart.py[1288]: .. has version [7.19.10.R] but [7.19.12.R] is available. Performing update.
Jan 19 22:25:44 pascom.intevo.net containersStart.py[1288]: ==== controller update.sh start ====
Jan 19 22:25:44 pascom.intevo.net containersStart.py[1288]: remove old grafana.db
Jan 19 22:25:44 pascom.intevo.net containersStart.py[1288]: ==== controller update.sh end ====
Jan 19 22:25:47 pascom.intevo.net containersStart.py[1288]: Container controller has a limit of 512 MB memory, calculated value is 512 MB
Jan 19 22:25:47 pascom.intevo.net containersStart.py[1288]: Starting controller
Jan 19 22:25:48 pascom.intevo.net containersStart.py[1288]: Traceback (most recent call last):
Jan 19 22:25:48 pascom.intevo.net containersStart.py[1288]: File "/usr/lib/cloudstack/containersStart.py", line 826, in <module>
Jan 19 22:25:48 pascom.intevo.net containersStart.py[1288]: if manage_controller():
Jan 19 22:25:48 pascom.intevo.net containersStart.py[1288]: File "/usr/lib/cloudstack/containersStart.py", line 369, in manage_controller
Jan 19 22:25:48 pascom.intevo.net containersStart.py[1288]: controller.start()
Jan 19 22:25:48 pascom.intevo.net containersStart.py[1288]: File "/opt/cstools/cs/container.py", line 110, in start
Jan 19 22:25:48 pascom.intevo.net containersStart.py[1288]: raise Exception("Container %s failed to start" % self.name)
Jan 19 22:25:48 pascom.intevo.net containersStart.py[1288]: Exception: Container controller failed to start
Jan 19 22:25:48 pascom.intevo.net systemd[1]: csstartup.service: Main process exited, code=exited, status=1/FAILURE
Jan 19 22:27:17 pascom.intevo.net systemd[1]: csstartup.service: State 'stop-sigterm' timed out. Killing.
Jan 19 22:27:17 pascom.intevo.net systemd[1]: csstartup.service: Killing process 1548 (containersStart) with signal SIGKILL.
Jan 19 22:27:17 pascom.intevo.net systemd[1]: csstartup.service: Failed with result 'exit-code'.
Jan 19 22:27:17 pascom.intevo.net systemd[1]: Failed to start Cloudstack containers.
Ich hab das Test-System noch nicht zurückgesetzt und kann von dort gern weitere Logs holen - bzw. irgendwelche Hinweise wo ich weitere Logs mit der Ursache finden könnte wären hilfreich.
Beste Grüße
Ben
