Ich bekomme in einer onsite Anlage immer wieder Anrufe aus dem Easybelltrunk, die nichts mit dem Trunk zu tun haben.
Executing [99110441519460088@mdc_incoming-1:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, “1,Inbound call on trunk: easybell ZweiLinden, getting number by: request-uri”) in new stack
– Executing [99110441519460088@mdc_incoming-1:2] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “MDC_CALLER_NUM_TRUNK=8889027718”) in new stack
– Executing [99110441519460088@mdc_incoming-1:3] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “MDC_CALLEE_NUM_TRUNK=99110441519460088”) in new stack
– Executing [99110441519460088@mdc_incoming-1:4] Goto(“PJSIP/mdc_trunk_conf-1-00000013”, “mdc_trunk-1,s,1”) in new stack
– Goto (mdc_trunk-1,s,1)
– Executing [s@mdc_trunk-1:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, “1,callee number: 99110441519460088 caller number: 8889027718”) in new stack
– Executing [s@mdc_trunk-1:2] ExecIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?Set(CALLERID(num)=anonymous)”) in new stack
– Executing [s@mdc_trunk-1:3] ExecIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?Set(CALLERID(num)=anonymous)”) in new stack
– Executing [s@mdc_trunk-1:4] ExecIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?Set(CALLERID(num)=anonymous)”) in new stack
– Executing [s@mdc_trunk-1:5] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “CHANNEL(language)=de”) in new stack
– Executing [s@mdc_trunk-1:6] Ringing(“PJSIP/mdc_trunk_conf-1-00000013”, “”) in new stack
– Executing [s@mdc_trunk-1:7] Progress(“PJSIP/mdc_trunk_conf-1-00000013”, “”) in new stack
– Executing [s@mdc_trunk-1:8] Gosub(“PJSIP/mdc_trunk_conf-1-00000013”, “sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,8889027718,00,49,0,2225,1)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, “1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - number: 8889027718 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 2225 - incoming: 1”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?s-emergency,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?s-convert,1”) in new stack
– Executing [s@sub_nat2int:6] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:7] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:8] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:9] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?s-nat,1”) in new stack
– Executing [s@sub_nat2int:10] Goto(“PJSIP/mdc_trunk_conf-1-00000013”, “s-local,1”) in new stack
– Goto (sub_nat2int,s-local,1)
– Executing [s-local@sub_nat2int:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, “1,local”) in new stack
local
– Executing [s-local@sub_nat2int:2] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “MDC_CALLER_NUM_INTERNAT=004922258889027718”) in new stack
– Executing [s-local@sub_nat2int:3] Return(“PJSIP/mdc_trunk_conf-1-00000013”, “”) in new stack
– Executing [s@mdc_trunk-1:9] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “CALLERID(num)=004922258889027718”) in new stack
– Executing [s@mdc_trunk-1:10] Gosub(“PJSIP/mdc_trunk_conf-1-00000013”, “sub_int2nat,s,1(MDC_CALLER_NUM_NAT,004922258889027718,00,49,0,2225,1)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, “1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 004922258889027718 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 2225 - incoming: 1”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?s-emergency,1”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?nat”) in new stack
– Executing [s@sub_int2nat:4] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “MDC_CALLER_NUM_NAT=022258889027718”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“PJSIP/mdc_trunk_conf-1-00000013”, “”) in new stack
– Executing [s@mdc_trunk-1:11] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “CALLERID(num)=022258889027718”) in new stack
– Executing [s@mdc_trunk-1:12] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “MDC_NUMPREFIX_TRUNK=0”) in new stack
– Executing [s@mdc_trunk-1:13] ExecIf(“PJSIP/mdc_trunk_conf-1-00000013”, “1?Set(CALLERID(all)=0022258889027718)”) in new stack
– Executing [s@mdc_trunk-1:14] UserEvent(“PJSIP/mdc_trunk_conf-1-00000013”, “ResolveCallerName,Strategy: system,Outbound: 0”) in new stack
– Executing [s@mdc_trunk-1:15] Wait(“PJSIP/mdc_trunk_conf-1-00000013”, “0.25”) in new stack
– Executing [s@mdc_trunk-1:16] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, “1,MDC_RESOLVENAME_HITS = 0”) in new stack
– Executing [s@mdc_trunk-1:17] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, "1,CALLERID(name) = ") in new stack
CALLERID(name) =
– Executing [s@mdc_trunk-1:18] Goto(“PJSIP/mdc_trunk_conf-1-00000013”, “mdc_mapping-1,99110441519460088,1”) in new stack
– Goto (mdc_mapping-1,99110441519460088,1)
– Executing [99110441519460088@mdc_mapping-1:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, “1,Central”) in new stack
Central
– Executing [99110441519460088@mdc_mapping-1:2] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, “1,Check !RegEx: 942000?$”) in new stack
– Executing [99110441519460088@mdc_mapping-1:3] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “1?prio2”) in new stack
– Goto (mdc_mapping-1,99110441519460088,7)
Executing [99110441519460088@mdc_mapping-1:7] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, “1,Durchwahl 2-stellig”) in new stack
Durchwahl 2-stellig
– Executing [99110441519460088@mdc_mapping-1:8] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “CHANNEL(language)=de”) in new stack
– Executing [99110441519460088@mdc_mapping-1:9] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, "1,mapping from _[+%#a-zA-Z0-9]. to 88") in new stack
– Executing [99110441519460088@mdc_mapping-1:10] Goto(“PJSIP/mdc_trunk_conf-1-00000013”, “mdc_external,88,1”) in new stack
– Goto (mdc_external,88,1)
– Executing [88@mdc_external:1] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “HASH(__SIPHEADERS,Alert-info)=http://www.notused.de;info=alert-external;x-line-id=0”) in new stack
– Executing [88@mdc_external:2] GosubIf(“PJSIP/mdc_trunk_conf-1-00000013”, “1?sub_initcall,s,1(ext,88)”) in new stack
– Executing [s@sub_initcall:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, “1,sub_initcall descent: ext exten: 88”) in new stack
– Executing [s@sub_initcall:2] GosubIf(“PJSIP/mdc_trunk_conf-1-00000013”, “1?sub_initloop,s,1”) in new stack
– Executing [s@sub_initloop:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000013”, “1,initial loop”) in new stack
initial loop
– Executing [s@sub_initloop:2] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “MDC_ALIAS_HOP=0”) in new stack
– Executing [s@sub_initloop:3] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “MDC_MAIN_HOP=0”) in new stack
– Executing [s@sub_initloop:4] Return(“PJSIP/mdc_trunk_conf-1-00000013”, “”) in new stack
– Executing [s@sub_initcall:3] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “__MDC_TRANSFERBACK_HOP=0”) in new stack
– Executing [s@sub_initcall:4] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “__MDC_DIALDESCENT=ext”) in new stack
– Executing [s@sub_initcall:5] Goto(“PJSIP/mdc_trunk_conf-1-00000013”, “ext,1”) in new stack
– Goto (sub_initcall,ext,1)
– Executing [ext@sub_initcall:1] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “__MDC_DIALCALLERNUMINIT=8889027718”) in new stack
– Executing [ext@sub_initcall:2] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “__MDC_DIALCALLEENUMINIT=99110441519460088”) in new stack
– Executing [ext@sub_initcall:3] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “__MDC_DIALCALLEENUMMAP=88”) in new stack
– Executing [ext@sub_initcall:4] Return(“PJSIP/mdc_trunk_conf-1-00000013”, “”) in new stack
– Executing [88@mdc_external:3] Goto(“PJSIP/mdc_trunk_conf-1-00000013”, “main,88,1”) in new stack
– Goto (main,88,1)
– Executing [88@main:1] ExecIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?Set(MDC_MAIN_HOP=0)”) in new stack
– Executing [88@main:2] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “MDC_MAIN_HOP=1”) in new stack
– Executing [88@main:3] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?mdc_loop,s,1”) in new stack
– Executing [88@main:4] Gosub(“PJSIP/mdc_trunk_conf-1-00000013”, “sub_defcall,s,1(88)”) in new stack
– Executing [s@sub_defcall:1] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “__MDC_ALIAS_HOP=1”) in new stack
– Executing [s@sub_defcall:2] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “__MDC_DIALCALLEENUM=88”) in new stack
– Executing [s@sub_defcall:3] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “__MDC_DIALCALLERNUM=0022258889027718”) in new stack
– Executing [s@sub_defcall:4] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “__MDC_DIALCALLERLANGUAGE=de”) in new stack
– Executing [s@sub_defcall:5] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “__MDC_DIALCALLERNAME=”) in new stack
– Executing [s@sub_defcall:6] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “__MDC_DIALCHANNELNAME=mdc_trunk_conf-1”) in new stack
– Executing [s@sub_defcall:7] Return(“PJSIP/mdc_trunk_conf-1-00000013”, “”) in new stack
– Executing [88@main:5] GosubIf(“PJSIP/mdc_trunk_conf-1-00000013”, “1?sub_homer,s,1”) in new stack
– Executing [s@sub_homer:1] Set(“PJSIP/mdc_trunk_conf-1-00000013”, “PJSIP_HEADER(remove,P-cs-cid)=”) in new stack
– Executing [s@sub_homer:2] ExecIf(“PJSIP/mdc_trunk_conf-1-00000013”, “1?Set(PJSIP_HEADER(add,P-cs-cid)=z7QTgp7uaWZROoCnBX98FBn0sqnJeDpM0VdHBN8F)”) in new stack
– Executing [s@sub_homer:3] Return(“PJSIP/mdc_trunk_conf-1-00000013”, “”) in new stack
– Executing [88@main:6] Goto(“PJSIP/mdc_trunk_conf-1-00000013”, “mdc_distribute,88,1”) in new stack
– Goto (mdc_distribute,88,1)
– Executing [88@mdc_distribute:1] Gosub(“PJSIP/mdc_trunk_conf-1-00000013”, “def_exception,s,1”) in new stack
– Executing [s@def_exception:1] GotoIf(“PJSIP/mdc_trunk_conf-1-00000013”, “0?main,1”) in new stack
– Executing [s@def_exception:2] Answer(“PJSIP/mdc_trunk_conf-1-00000013”, “”) in new stack
– Executing [s@def_exception:3] Playback(“PJSIP/mdc_trunk_conf-1-00000013”, “pbx-invalid”) in new stack
– <PJSIP/mdc_trunk_conf-1-00000013> Playing ‘pbx-invalid.slin’ (language ‘de’)
– Executing [s@def_exception:4] Hangup(“PJSIP/mdc_trunk_conf-1-00000013”, “”) in new stack
== Spawn extension (def_exception, s, 4) exited non-zero on ‘PJSIP/mdc_trunk_conf-1-00000013’
Immer wieder kommen irgendwelche Anrufe, die dann auch auf interne Durchwahlen gehen. Gibt es eine Einstellung, die solche Störfeuer nicht durchlässt?
Hendrik
