Hier mal Infos aus der Cli:
Connected to Asterisk 1.8.11.1-1digium1~squeeze currently running on mobydick (pid = 1414)
Verbosity is at least 3
== Using SIP RTP CoS mark 5
– Executing [620@mdc_incoming-4:1] Set(“SIP/mdc_trunk_conf-4-00000094”, “MDC_CALLER_NUM_TRUNK=06xxxxx6951”) in new stack
– Executing [620@mdc_incoming-4:2] Set(“SIP/mdc_trunk_conf-4-00000094”, “MDC_CALLEE_NUM_TRUNK=620”) in new stack
– Executing [620@mdc_incoming-4:3] Goto(“SIP/mdc_trunk_conf-4-00000094”, “mdc_trunk-2,s,1”) in new stack
– Goto (mdc_trunk-2,s,1)
– Executing [s@mdc_trunk-2:1] Verbose(“SIP/mdc_trunk_conf-4-00000094”, “1,callee number: 620 caller number: 06xxxxx6951”) in new stack
– Executing [s@mdc_trunk-2:2] GosubIf(“SIP/mdc_trunk_conf-4-00000094”, “0?sub_internat,s,1(CALLERID(num),06xxxxx6951,00)”) in new stack
– Executing [s@mdc_trunk-2:3] Gosub(“SIP/mdc_trunk_conf-4-00000094”, “sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,06xxxxx6951,00,49,0,6132)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“SIP/mdc_trunk_conf-4-00000094”, “1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - CALLERID(num): 06xxxxx6951 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 6132”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:6] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “1?s-nat,1”) in new stack
– Goto (sub_nat2int,s-nat,1)
– Executing [s-nat@sub_nat2int:1] Verbose(“SIP/mdc_trunk_conf-4-00000094”, “1,national”) in new stack
national
– Executing [s-nat@sub_nat2int:2] Set(“SIP/mdc_trunk_conf-4-00000094”, “MDC_CALLER_NUM_INTERNAT=00496xxxxx6951”) in new stack
– Executing [s-nat@sub_nat2int:3] Return(“SIP/mdc_trunk_conf-4-00000094”, “”) in new stack
– Executing [s@mdc_trunk-2:4] Set(“SIP/mdc_trunk_conf-4-00000094”, “CALLERID(num)=00496xxxxx6951”) in new stack
– Executing [s@mdc_trunk-2:5] Gosub(“SIP/mdc_trunk_conf-4-00000094”, “sub_int2nat,s,1(MDC_CALLER_NUM_NAT,00496xxxxx6951,00,49,0,6132)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“SIP/mdc_trunk_conf-4-00000094”, “1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 00496xxxxx6951 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 6132”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “0?nat”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“SIP/mdc_trunk_conf-4-00000094”, “MDC_CALLER_NUM_NAT=06xxxxx6951”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“SIP/mdc_trunk_conf-4-00000094”, “”) in new stack
– Executing [s@mdc_trunk-2:6] Set(“SIP/mdc_trunk_conf-4-00000094”, “CALLERID(num)=06xxxxx6951”) in new stack
– Executing [s@mdc_trunk-2:7] Set(“SIP/mdc_trunk_conf-4-00000094”, “MDC_NUMPREFIX_TRUNK=”) in new stack
– Executing [s@mdc_trunk-2:8] Goto(“SIP/mdc_trunk_conf-4-00000094”, “mdc_mapping-2,620,1”) in new stack
– Goto (mdc_mapping-2,620,1)
– Executing [620@mdc_mapping-2:1] Set(“SIP/mdc_trunk_conf-4-00000094”, “CHANNEL(language)=de”) in new stack
– Executing [620@mdc_mapping-2:2] Verbose(“SIP/mdc_trunk_conf-4-00000094”, “1,mapping from 620 to 99”) in new stack
– Executing [620@mdc_mapping-2:3] Goto(“SIP/mdc_trunk_conf-4-00000094”, “mdc_external,99,1”) in new stack
– Goto (mdc_external,99,1)
– Executing [99@mdc_external:1] SIPAddHeader(“SIP/mdc_trunk_conf-4-00000094”, "“Alert-Info:<http://www.notused.de>;info=alert-external;x-line-id=0"”) in new stack
– Executing [99@mdc_external:2] GosubIf(“SIP/mdc_trunk_conf-4-00000094”, “1?sub_initcall,s,1(ext,99)”) in new stack
– Executing [s@sub_initcall:1] Verbose(“SIP/mdc_trunk_conf-4-00000094”, “1,sub_initcall descent: ext exten: 99”) in new stack
– Executing [s@sub_initcall:2] GosubIf(“SIP/mdc_trunk_conf-4-00000094”, “1?sub_initloop,s,1”) in new stack
– Executing [s@sub_initloop:1] Verbose(“SIP/mdc_trunk_conf-4-00000094”, “1,initial loop”) in new stack
initial loop
– Executing [s@sub_initloop:2] Set(“SIP/mdc_trunk_conf-4-00000094”, “MDC_ALIAS_HOP=0”) in new stack
– Executing [s@sub_initloop:3] Return(“SIP/mdc_trunk_conf-4-00000094”, “”) in new stack
– Executing [s@sub_initcall:3] Set(“SIP/mdc_trunk_conf-4-00000094”, “__MDC_DIALDESCENT=ext”) in new stack
– Executing [s@sub_initcall:4] Goto(“SIP/mdc_trunk_conf-4-00000094”, “ext,1”) in new stack
– Goto (sub_initcall,ext,1)
– Executing [ext@sub_initcall:1] Set(“SIP/mdc_trunk_conf-4-00000094”, “__MDC_DIALCALLERNUMINIT=06xxxxx6951”) in new stack
– Executing [ext@sub_initcall:2] Set(“SIP/mdc_trunk_conf-4-00000094”, “__MDC_DIALCALLEENUMINIT=620”) in new stack
– Executing [ext@sub_initcall:3] Return(“SIP/mdc_trunk_conf-4-00000094”, “”) in new stack
– Executing [99@mdc_external:3] Goto(“SIP/mdc_trunk_conf-4-00000094”, “main,99,1”) in new stack
– Goto (main,99,1)
– Executing [99@main:1] Gosub(“SIP/mdc_trunk_conf-4-00000094”, “sub_defcall,s,1(99)”) in new stack
[Jun 17 10:37:42] NOTICE[21671]: func_math.c:424 crement_function_read: The value is now: 1
– Executing [s@sub_defcall:1] Set(“SIP/mdc_trunk_conf-4-00000094”, “MDC_ALIAS_HOP=1”) in new stack
– Executing [s@sub_defcall:2] Set(“SIP/mdc_trunk_conf-4-00000094”, “__MDC_DIALCALLEENUM=99”) in new stack
– Executing [s@sub_defcall:3] Set(“SIP/mdc_trunk_conf-4-00000094”, “__MDC_DIALCALLERNUM=06xxxxx6951”) in new stack
– Executing [s@sub_defcall:4] Set(“SIP/mdc_trunk_conf-4-00000094”, “__MDC_DIALCHANNELNAME=mdc_trunk_conf-4”) in new stack
– Executing [s@sub_defcall:5] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “1?nozap”) in new stack
– Goto (sub_defcall,s,8)
– Executing [s@sub_defcall:8] Set(“SIP/mdc_trunk_conf-4-00000094”, “__MDC_DIALCALLERNAME=Tino”) in new stack
– Executing [s@sub_defcall:9] Return(“SIP/mdc_trunk_conf-4-00000094”, “”) in new stack
– Executing [99@main:2] Goto(“SIP/mdc_trunk_conf-4-00000094”, “mdc_distribute,99,1”) in new stack
– Goto (mdc_distribute,99,1)
– Executing [99@mdc_distribute:1] Gosub(“SIP/mdc_trunk_conf-4-00000094”, “sub_team,s,1(1,Abfragestellen,Abfragestellen,99)”) in new stack
– Executing [s@sub_team:1] Verbose(“SIP/mdc_trunk_conf-4-00000094”, “1,team id: 1 team name: Abfragestellen team realname: Abfragestellen own vm: 99”) in new stack
– Executing [s@sub_team:2] Set(“SIP/mdc_trunk_conf-4-00000094”, “_MDC_CALLEE_TM_ID=1”) in new stack
– Executing [s@sub_team:3] Set(“SIP/mdc_trunk_conf-4-00000094”, “_MDC_CALLEE_TM_NAME=Abfragestellen”) in new stack
– Executing [s@sub_team:4] Set(“SIP/mdc_trunk_conf-4-00000094”, “_MDC_CALLEE_TM_REALNAME=Abfragestellen”) in new stack
– Executing [s@sub_team:5] Set(“SIP/mdc_trunk_conf-4-00000094”, “_MDC_CALLEE_VM_OWN=99”) in new stack
– Executing [s@sub_team:6] Return(“SIP/mdc_trunk_conf-4-00000094”, “”) in new stack
– Executing [99@mdc_distribute:2] Goto(“SIP/mdc_trunk_conf-4-00000094”, “mdc_team-1,99,1”) in new stack
– Goto (mdc_team-1,99,1)
– Executing [99@mdc_team-1:1] NoOp(“SIP/mdc_trunk_conf-4-00000094”, “alias-check:: call forwarding from 99 - 0”) in new stack
– Executing [99@mdc_team-1:2] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “0?99-uml,1:99-dial,1”) in new stack
– Goto (mdc_team-1,99-dial,1)
– Executing [99-dial@mdc_team-1:1] Set(“SIP/mdc_trunk_conf-4-00000094”, “__MDC_EXTEN=99”) in new stack
– Executing [99-dial@mdc_team-1:2] Gosub(“SIP/mdc_trunk_conf-4-00000094”, “sub_prefix-99,ext,1”) in new stack
– Executing [ext@sub_prefix-99:1] Verbose(“SIP/mdc_trunk_conf-4-00000094”, “1,no action”) in new stack
no action
– Executing [ext@sub_prefix-99:2] Return(“SIP/mdc_trunk_conf-4-00000094”, “”) in new stack
– Executing [99-dial@mdc_team-1:3] Gosub(“SIP/mdc_trunk_conf-4-00000094”, “sub_main-99,ext,1”) in new stack
– Executing [ext@sub_main-99:1] Set(“SIP/mdc_trunk_conf-4-00000094”, “CALLERID(name)=Abfragestellen”) in new stack
– Executing [ext@sub_main-99:2] Gosub(“SIP/mdc_trunk_conf-4-00000094”, “sub_queue-free,s,1(MDC_QUEUE_FREE,Abfragestellen)”) in new stack
– Executing [s@sub_queue-free:1] Verbose(“SIP/mdc_trunk_conf-4-00000094”, “1,sub_queue-free:: variable: MDC_QUEUE_FREE queue: Abfragestellen”) in new stack
– Executing [s@sub_queue-free:2] Verbose(“SIP/mdc_trunk_conf-4-00000094”, "1,member(logged): 2 - member(free): 2 - member(ready): 2 - member(count): 2 - ") in new stack
– Executing [s@sub_queue-free:3] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “0?notfree”) in new stack
– Executing [s@sub_queue-free:4] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “0?notfree”) in new stack
– Executing [s@sub_queue-free:5] Set(“SIP/mdc_trunk_conf-4-00000094”, “MDC_QUEUE_FREE=1”) in new stack
– Executing [s@sub_queue-free:6] Return(“SIP/mdc_trunk_conf-4-00000094”, “”) in new stack
– Executing [ext@sub_main-99:3] GotoIf(“SIP/mdc_trunk_conf-4-00000094”, “1?free”) in new stack
– Goto (sub_main-99,ext,7)
– Executing [ext@sub_main-99:7] Set(“SIP/mdc_trunk_conf-4-00000094”, “__PICKUPMARK=99”) in new stack
– Executing [ext@sub_main-99:8] Queue(“SIP/mdc_trunk_conf-4-00000094”, “Abfragestellen,r,30”) in new stack
– Called Local/10@mdc_multidial-10
– Executing [10@mdc_multidial-10:1] Set(“Local/10@mdc_multidial-10-7ebd;2”, “__MDC_CALLEE_USER_ID=3”) in new stack
– Executing [10@mdc_multidial-10:2] Set(“Local/10@mdc_multidial-10-7ebd;2”, “__PICKUPMARK=10”) in new stack
– Executing [10@mdc_multidial-10:3] Dial(“Local/10@mdc_multidial-10-7ebd;2”, “Local/10@mdc_diallocation,c”) in new stack
– Called Local/20@mdc_multidial-20
– Executing [20@mdc_multidial-20:1] Set(“Local/20@mdc_multidial-20-4610;2”, “__MDC_CALLEE_USER_ID=4”) in new stack
– Executing [20@mdc_multidial-20:2] Set(“Local/20@mdc_multidial-20-4610;2”, “__PICKUPMARK=20”) in new stack
– Executing [20@mdc_multidial-20:3] Dial(“Local/20@mdc_multidial-20-4610;2”, “Local/20@mdc_diallocation,c”) in new stack
– Called Local/10@mdc_diallocation
– Executing [10@mdc_diallocation:1] Verbose(“Local/10@mdc_diallocation-f64b;2”, “1,dial to 10 for user 3”) in new stack
– Executing [10@mdc_diallocation:2] Gosub(“Local/10@mdc_diallocation-f64b;2”, “sub_split-user,s,1(3)”) in new stack
– Executing [s@sub_split-user:1] Verbose(“Local/10@mdc_diallocation-f64b;2”, “1,get locations for for: 3”) in new stack
– Executing [s@sub_split-user:2] GotoIf(“Local/10@mdc_diallocation-f64b;2”, “0?s-zero,1”) in new stack
– Executing [s@sub_split-user:3] Set(“Local/10@mdc_diallocation-f64b;2”, “TMP_LOCATIONS=2;0”) in new stack
– Called Local/20@mdc_diallocation
– Executing [s@sub_split-user:4] Set(“Local/10@mdc_diallocation-f64b;2”, “TMP_STATIC_ID=2”) in new stack
– Executing [20@mdc_diallocation:1] Verbose(“Local/20@mdc_diallocation-2cfc;2”, “1,dial to 20 for user 4”) in new stack
– Executing [s@sub_split-user:5] Verbose(“Local/10@mdc_diallocation-f64b;2”, “1,static id: 2”) in new stack
– Executing [20@mdc_diallocation:2] Gosub(“Local/20@mdc_diallocation-2cfc;2”, “sub_split-user,s,1(4)”) in new stack
static id: 2
– Executing [s@sub_split-user:6] Set(“Local/10@mdc_diallocation-f64b;2”, “TMP_DYN_ID=0”) in new stack
– Executing [s@sub_split-user:1] Verbose(“Local/20@mdc_diallocation-2cfc;2”, “1,get locations for for: 4”) in new stack
– Executing [s@sub_split-user:7] Verbose(“Local/10@mdc_diallocation-f64b;2”, “1,dynamic id: 0”) in new stack
dynamic id: 0
– Executing [s@sub_split-user:8] Return(“Local/10@mdc_diallocation-f64b;2”, “”) in new stack
– Executing [s@sub_split-user:2] GotoIf(“Local/20@mdc_diallocation-2cfc;2”, “0?s-zero,1”) in new stack
– Executing [10@mdc_diallocation:3] GotoIf(“Local/10@mdc_diallocation-f64b;2”, “0?invalid,1”) in new stack
– Executing [s@sub_split-user:3] Set(“Local/20@mdc_diallocation-2cfc;2”, “TMP_LOCATIONS=3;0”) in new stack
– Executing [10@mdc_diallocation:4] GotoIf(“Local/10@mdc_diallocation-f64b;2”, “0?dynamic,1”) in new stack
– Executing [s@sub_split-user:4] Set(“Local/20@mdc_diallocation-2cfc;2”, “TMP_STATIC_ID=3”) in new stack
– Executing [10@mdc_diallocation:5] GotoIf(“Local/10@mdc_diallocation-f64b;2”, “1?static,1”) in new stack
– Goto (mdc_diallocation,static,1)
– Executing [s@sub_split-user:5] Verbose(“Local/20@mdc_diallocation-2cfc;2”, “1,static id: 3”) in new stack
– Executing [static@mdc_diallocation:1] Dial(“Local/10@mdc_diallocation-f64b;2”, “Local/ext@mdc_locallocation-2”) in new stack
static id: 3
– Executing [s@sub_split-user:6] Set(“Local/20@mdc_diallocation-2cfc;2”, “TMP_DYN_ID=0”) in new stack
– Executing [s@sub_split-user:7] Verbose(“Local/20@mdc_diallocation-2cfc;2”, “1,dynamic id: 0”) in new stack
dynamic id: 0
– Executing [s@sub_split-user:8] Return(“Local/20@mdc_diallocation-2cfc;2”, “”) in new stack
– Executing [20@mdc_diallocation:3] GotoIf(“Local/20@mdc_diallocation-2cfc;2”, “0?invalid,1”) in new stack
– Executing [20@mdc_diallocation:4] GotoIf(“Local/20@mdc_diallocation-2cfc;2”, “0?dynamic,1”) in new stack
– Executing [20@mdc_diallocation:5] GotoIf(“Local/20@mdc_diallocation-2cfc;2”, “1?static,1”) in new stack
– Executing [static@mdc_diallocation:1] Dial(“Local/20@mdc_diallocation-2cfc;2”, “Local/ext@mdc_locallocation-3”) in new stack
– Called Local/ext@mdc_locallocation-2
– Called Local/ext@mdc_locallocation-3
– Executing [ext@mdc_locallocation-2:1] Dial(“Local/ext@mdc_locallocation-2-c1bf;2”, “Local/ext-6@mdc_localdevice-2”) in new stack
– Executing [ext@mdc_locallocation-3:1] Dial(“Local/ext@mdc_locallocation-3-7934;2”, “Local/ext-8@mdc_localdevice-3&Local/ext-2@mdc_localdevice-3”) in new stack
– Called Local/ext-8@mdc_localdevice-3
– Called Local/ext-6@mdc_localdevice-2
– Executing [ext-6@mdc_localdevice-2:1] Verbose(“Local/ext-6@mdc_localdevice-2-5934;2”, “1,Dialing with delay of 0 seconds for 20 seconds”) in new stack
– Executing [ext-6@mdc_localdevice-2:2] Dial(“Local/ext-6@mdc_localdevice-2-5934;2”, “SIP/SnomM9,20”) in new stack
– Called Local/ext-2@mdc_localdevice-3
– Executing [ext-8@mdc_localdevice-3:1] Verbose(“Local/ext-8@mdc_localdevice-3-1575;2”, “1,Dialing with delay of 0 seconds for 20 seconds”) in new stack
– Executing [ext-8@mdc_localdevice-3:2] Dial(“Local/ext-8@mdc_localdevice-3-1575;2”, “Local/s@mdc_extphone-2,20”) in new stack
– Called Local/s@mdc_extphone-2
– Called SIP/SnomM9
– Executing [s@mdc_extphone-2:1] Dial(“Local/s@mdc_extphone-2-5626;2”, “Local/00049151xxxxxx@mdc_outgoing”) in new stack
– Executing [ext-2@mdc_localdevice-3:1] Verbose(“Local/ext-2@mdc_localdevice-3-28cd;2”, “1,Dialing with delay of 0 seconds for 20 seconds”) in new stack
– Executing [ext-2@mdc_localdevice-3:2] Dial(“Local/ext-2@mdc_localdevice-3-28cd;2”, “SIP/DvSsE4FLY712108,20”) in new stack
– Called Local/00049151xxxxxx@mdc_outgoing
– Called SIP/DvSsE4FLY712108
– Executing [00049151xxxxxx@mdc_outgoing:1] Set(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “MDC_INPREFIX_TRUNK=”) in new stack
– Executing [00049151xxxxxx@mdc_outgoing:2] Verbose(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, "1,remove inprefix: ") in new stack
remove inprefix:
– Executing [00049151xxxxxx@mdc_outgoing:3] Goto(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “mdc_outgoing-6,00049151xxxxxx,1”) in new stack
– Goto (mdc_outgoing-6,00049151xxxxxx,1)
– Executing [00049151xxxxxx@mdc_outgoing-6:1] Gosub(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “sub_trunk-outgoing-6,00049151xxxxxx,1”) in new stack
– Executing [00049151xxxxxx@sub_trunk-outgoing-6:1] Gosub(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,00049151xxxxxx,00,49,0,6132)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 00049151xxxxxx - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 6132”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “0?nat”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “0?s-internat,1”) in new stack
– Executing [s@sub_int2nat:4] Set(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “MDC_CALLEE_NUM_NAT=00049151xxxxxx”) in new stack
– Executing [s@sub_int2nat:5] Return(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “”) in new stack
– Executing [00049151xxxxxx@sub_trunk-outgoing-6:2] Gosub(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,00049151xxxxxx,00,49,0,6132)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - CALLERID(num): 00049151xxxxxx - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 6132”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “1?s-int,1”) in new stack
– Goto (sub_nat2int,s-int,1)
– Executing [s-int@sub_nat2int:1] Verbose(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “1,international”) in new stack
international
– Executing [s-int@sub_nat2int:2] Set(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “MDC_CALLEE_NUM_INTERNAT=00049151xxxxxx”) in new stack
– Executing [s-int@sub_nat2int:3] Return(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “”) in new stack
– Executing [00049151xxxxxx@sub_trunk-outgoing-6:3] Set(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “CALLERID(num)=061329736045”) in new stack
– Executing [00049151xxxxxx@sub_trunk-outgoing-6:4] Verbose(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “1,7270 - Standardtelefonie”) in new stack
– Executing [00049151xxxxxx@sub_trunk-outgoing-6:5] Dial(“Local/00049151xxxxxx@mdc_outgoing-b7fa;2”, “SIP/mdc_trunk_conf-4/00049151xxxxxx,t”) in new stack
