ich versuche gerade mit einer Community-Version (v7.06.03) eine Testumgebung aufzubauen. Dazu habe ich auch einen Sipgate Trunk-Anschluss konfiguriert. Leider bekomme ich nur eingehende Verbindungen hin. Bei ausgehenden Verbindungen erhalte ich immer ein “Temporarily Unavailable”. Im Asterisk-Debug erscheint dazu folgendes:
Connected to Asterisk 11.6-cert1 currently running on mobydick (pid = 3899)
== Using SIP RTP CoS mark 5
-- Executing [02286896297@mdc_location-3:1] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,Ursula Borrmann") in new stack
Ursula Borrmann
-- Executing [02286896297@mdc_location-3:2] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_CALLER_LOCATION_ID=3") in new stack
-- Executing [02286896297@mdc_location-3:3] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_CALLER_LOCATION_NAME=Ursula Borrmann") in new stack
-- Executing [02286896297@mdc_location-3:4] Gosub("SIP/HJFEW0FDm712e96-00000002", "sub_location,s,1(3,02286896297)") in new stack
-- Executing [s@sub_location:1] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,used location id: 3 - dialed extension: 02286896297") in new stack
-- Executing [s@sub_location:2] Set("SIP/HJFEW0FDm712e96-00000002", "MDC_CALLEE_NUM=02286896297") in new stack
-- Executing [s@sub_location:3] Return("SIP/HJFEW0FDm712e96-00000002", "") in new stack
-- Executing [02286896297@mdc_location-3:5] Gosub("SIP/HJFEW0FDm712e96-00000002", "sub_split-location,s,1(3)") in new stack
-- Executing [s@sub_split-location:1] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,get user for location: 3") in new stack
-- Executing [s@sub_split-location:2] GotoIf("SIP/HJFEW0FDm712e96-00000002", "0?s-zero,1") in new stack
-- Executing [s@sub_split-location:3] Set("SIP/HJFEW0FDm712e96-00000002", "TMP_USER_ID=4") in new stack
-- Executing [s@sub_split-location:4] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,user id: 4") in new stack
user id: 4
-- Executing [s@sub_split-location:5] Return("SIP/HJFEW0FDm712e96-00000002", "") in new stack
-- Executing [02286896297@mdc_location-3:6] Goto("SIP/HJFEW0FDm712e96-00000002", "mdc_user-4,02286896297,1") in new stack
-- Goto (mdc_user-4,02286896297,1)
-- Executing [02286896297@mdc_user-4:1] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,uborrmann") in new stack
uborrmann
-- Executing [02286896297@mdc_user-4:2] Gosub("SIP/HJFEW0FDm712e96-00000002", "sub_user,s,1(caller,4,32,uborrmann,Ursula Borrmann,32,32,32)") in new stack
-- Executing [s@sub_user:1] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,sub_user mode caller") in new stack
-- Executing [s@sub_user:2] Goto("SIP/HJFEW0FDm712e96-00000002", "s-caller,1") in new stack
-- Goto (sub_user,s-caller,1)
-- Executing [s-caller@sub_user:1] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,sub_user user id: 4 - user exten: 32 - user: uborrmann - realname: Ursula Borrmann - own mailbox: 32 - watched mailbox: 32 - callerid(num): 32") in new stack
-- Executing [s-caller@sub_user:2] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_CALLER_USER_ID=4") in new stack
-- Executing [s-caller@sub_user:3] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_CALLER_NUM=32") in new stack
-- Executing [s-caller@sub_user:4] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_CALLER_ACC_NAME=uborrmann") in new stack
-- Executing [s-caller@sub_user:5] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_CALLER_ACC_REALNAME=Ursula Borrmann") in new stack
-- Executing [s-caller@sub_user:6] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_CALLER_VM_OWN=32") in new stack
-- Executing [s-caller@sub_user:7] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_CALLER_VM_WATCHED=32") in new stack
-- Executing [s-caller@sub_user:8] Set("SIP/HJFEW0FDm712e96-00000002", "CALLERID(name)=Ursula Borrmann") in new stack
-- Executing [s-caller@sub_user:9] Set("SIP/HJFEW0FDm712e96-00000002", "CALLERID(num)=32") in new stack
-- Executing [s-caller@sub_user:10] Return("SIP/HJFEW0FDm712e96-00000002", "") in new stack
-- Executing [02286896297@mdc_user-4:3] Goto("SIP/HJFEW0FDm712e96-00000002", "internal,02286896297,1") in new stack
-- Goto (internal,02286896297,1)
-- Executing [02286896297@internal:1] SIPAddHeader("SIP/HJFEW0FDm712e96-00000002", ""Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"") in new stack
-- Executing [02286896297@internal:2] GosubIf("SIP/HJFEW0FDm712e96-00000002", "1?sub_initcall,s,1(int,02286896297)") in new stack
-- Executing [s@sub_initcall:1] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,sub_initcall descent: int exten: 02286896297") in new stack
-- Executing [s@sub_initcall:2] GosubIf("SIP/HJFEW0FDm712e96-00000002", "1?sub_initloop,s,1") in new stack
-- Executing [s@sub_initloop:1] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,initial loop") in new stack
initial loop
-- Executing [s@sub_initloop:2] Set("SIP/HJFEW0FDm712e96-00000002", "MDC_ALIAS_HOP=0") in new stack
-- Executing [s@sub_initloop:3] Return("SIP/HJFEW0FDm712e96-00000002", "") in new stack
-- Executing [s@sub_initcall:3] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_DIALDESCENT=int") in new stack
-- Executing [s@sub_initcall:4] Goto("SIP/HJFEW0FDm712e96-00000002", "int,1") in new stack
-- Goto (sub_initcall,int,1)
-- Executing [int@sub_initcall:1] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_DIALCALLERNUMINIT=32") in new stack
-- Executing [int@sub_initcall:2] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_DIALCALLEENUMINIT=02286896297") in new stack
-- Executing [int@sub_initcall:3] Return("SIP/HJFEW0FDm712e96-00000002", "") in new stack
-- Executing [02286896297@internal:3] Goto("SIP/HJFEW0FDm712e96-00000002", "main,02286896297,1") in new stack
-- Goto (main,02286896297,1)
-- Executing [02286896297@main:1] Gosub("SIP/HJFEW0FDm712e96-00000002", "sub_defcall,s,1(02286896297)") in new stack
-- Executing [s@sub_defcall:1] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_ALIAS_HOP=1") in new stack
-- Executing [s@sub_defcall:2] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_DIALCALLEENUM=02286896297") in new stack
-- Executing [s@sub_defcall:3] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_DIALCALLERNUM=32") in new stack
-- Executing [s@sub_defcall:4] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_DIALCHANNELNAME=HJFEW0FDm712e96") in new stack
-- Executing [s@sub_defcall:5] GotoIf("SIP/HJFEW0FDm712e96-00000002", "1?nozap") in new stack
-- Goto (sub_defcall,s,8)
-- Executing [s@sub_defcall:8] Set("SIP/HJFEW0FDm712e96-00000002", "__MDC_DIALCALLERNAME=Ursula Borrmann") in new stack
-- Executing [s@sub_defcall:9] Return("SIP/HJFEW0FDm712e96-00000002", "") in new stack
-- Executing [02286896297@main:2] Goto("SIP/HJFEW0FDm712e96-00000002", "mdc_distribute,02286896297,1") in new stack
-- Goto (mdc_distribute,02286896297,1)
-- Executing [02286896297@mdc_distribute:1] Set("SIP/HJFEW0FDm712e96-00000002", "MDC_INPREFIX_TRUNK=") in new stack
-- Executing [02286896297@mdc_distribute:2] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,remove inprefix: ") in new stack
remove inprefix:
-- Executing [02286896297@mdc_distribute:3] Goto("SIP/HJFEW0FDm712e96-00000002", "mdc_outgoing-3,02286896297,1") in new stack
-- Goto (mdc_outgoing-3,02286896297,1)
-- Executing [02286896297@mdc_outgoing-3:1] Gosub("SIP/HJFEW0FDm712e96-00000002", "sub_trunk-outgoing-3,02286896297,1") in new stack
-- Executing [02286896297@sub_trunk-outgoing-3:1] Gosub("SIP/HJFEW0FDm712e96-00000002", "sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,02286896297,00,49,0,228)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - CALLERID(num): 02286896297 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 228") in new stack
-- Executing [s@sub_nat2int:2] GotoIf("SIP/HJFEW0FDm712e96-00000002", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:3] GotoIf("SIP/HJFEW0FDm712e96-00000002", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:4] GotoIf("SIP/HJFEW0FDm712e96-00000002", "0?s-intshort,1") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("SIP/HJFEW0FDm712e96-00000002", "0?s-natshort,1") in new stack
-- Executing [s@sub_nat2int:6] GotoIf("SIP/HJFEW0FDm712e96-00000002", "1?s-nat,1") in new stack
-- Goto (sub_nat2int,s-nat,1)
-- Executing [s-nat@sub_nat2int:1] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,national") in new stack
national
-- Executing [s-nat@sub_nat2int:2] Set("SIP/HJFEW0FDm712e96-00000002", "MDC_CALLEE_NUM_INTERNAT=00492286896297") in new stack
-- Executing [s-nat@sub_nat2int:3] Return("SIP/HJFEW0FDm712e96-00000002", "") in new stack
-- Executing [02286896297@sub_trunk-outgoing-3:2] Gosub("SIP/HJFEW0FDm712e96-00000002", "sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,00492286896297,00,49,0,228)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 00492286896297 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 228") in new stack
-- Executing [s@sub_int2nat:2] GotoIf("SIP/HJFEW0FDm712e96-00000002", "0?nat") in new stack
-- Executing [s@sub_int2nat:3] GotoIf("SIP/HJFEW0FDm712e96-00000002", "1?s-internat,1") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("SIP/HJFEW0FDm712e96-00000002", "MDC_CALLEE_NUM_NAT=02286896297") in new stack
-- Executing [s-internat@sub_int2nat:2] Return("SIP/HJFEW0FDm712e96-00000002", "") in new stack
-- Executing [02286896297@sub_trunk-outgoing-3:3] SIPAddHeader("SIP/HJFEW0FDm712e96-00000002", "P-Preferred-Identity: sip:4922828695132@sipconnect.sipgate.de") in new stack
-- Executing [02286896297@sub_trunk-outgoing-3:4] UserEvent("SIP/HJFEW0FDm712e96-00000002", "ResolveCallerName,Strategy: default,Outbound: 1,Channel: SIP/HJFEW0FDm712e96-00000002") in new stack
-- Executing [02286896297@sub_trunk-outgoing-3:5] Wait("SIP/HJFEW0FDm712e96-00000002", "0.25") in new stack
-- Executing [02286896297@sub_trunk-outgoing-3:6] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,MDC_RESOLVENAME_HITS = 0") in new stack
-- Executing [02286896297@sub_trunk-outgoing-3:7] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,MDC_DIALCALLEENAME = ") in new stack
-- Executing [02286896297@sub_trunk-outgoing-3:8] Verbose("SIP/HJFEW0FDm712e96-00000002", "1,sipgate - Standardtelefonie") in new stack
-- Executing [02286896297@sub_trunk-outgoing-3:9] Dial("SIP/HJFEW0FDm712e96-00000002", "SIP/mdc_trunk_conf-3/02286896297,,t") in new stack
[Apr 26 17:25:37] WARNING[4482][C-00000002]: app_dial.c:2437 dial_exec_full: Unable to create channel of type 'SIP' (cause 20 - Subscriber absent)
-- Executing [02286896297@sub_trunk-outgoing-3:10] Return("SIP/HJFEW0FDm712e96-00000002", "") in new stack
-- Executing [02286896297@mdc_outgoing-3:2] Hangup("SIP/HJFEW0FDm712e96-00000002", "19") in new stack
== Spawn extension (mdc_outgoing-3, 02286896297, 2) exited non-zero on 'SIP/HJFEW0FDm712e96-00000002'
-- Executing [h@mdc_outgoing-3:1] Gosub("SIP/HJFEW0FDm712e96-00000002", "def_hangup,s,1(,CHANUNAVAIL,,CALL)") in new stack
-- Executing [s@def_hangup:1] NoOp("SIP/HJFEW0FDm712e96-00000002", ">>>def_hangup:: EXTEN: DIALSTATUS: CHANUNAVAIL QUEUESTATUS: REASON: CALL") in new stack
Ich habe auch schon die Threads Sip peer und Voipgate peer und Verbindungsproblem mit Sipgate gelesen. Dementsprechend habe ich die folgenden Ausgaben überprüft:
mobydick*CLI> sip show registry
sipconnect.sipgate.de:5060 N XXXXXXXt0 585 Registered Sat, 26 Apr 2014 17:26:07
1 SIP registrations.
mobydick*CLI> sip show peers
Name/username Host Dyn Forcerport ACL Port Status Description
HJFEW0FDm712e96/HJFEW0FDm 192.168.200.31 D a 5060 OK (5 ms)
InSnMc2gV3fb78a/InSnMc2gV 192.168.200.41 D a 5060 OK (21 ms)
LGPhone (Unspecified) D a 0 UNKNOWN
mdc_trunk_conf-3/XXXXXXXt 217.10.68.150 a 5060 UNREACHABLE
4 sip peers [Monitored: 2 online, 2 offline Unmonitored: 0 online, 0 offline]
Der State=Registered scheint wiederzuspiegeln, dass auf der Sipgate Management-Seite der Anschluss als online geführt wird. Nur den Peer erreichen kann ich nicht.
Dementsprechend habe ich die Konfiguration unter sys/asterisk/configure/sip/file um die Parameter externip, localnet, nat und transport erweitert, wie es in den beiden o.g. Threads beschrieben wurde.
Leider bringt das auch keine Besserung
Die Anlage läuft virtuell auf VMWare hinter einem LANCOM Router, der den Internet-Anschluss bereitstellt. Auf der Firewall konnte ich keine Blockierungen erkennen.
Mit “sip set debug peer mdc_trunk_conf-3” bekomme ich folgende Ausgabe:
<--- SIP read from UDP:217.10.68.150:5060 --->
Reliably Transmitting (no NAT) to 217.10.68.150:5060:
OPTIONS sip:sipconnect.sipgate.de SIP/2.0
Via: SIP/2.0/UDP 192.168.1.251:5060;branch=z9hG4bK3fad19ce
Max-Forwards: 70
From: "asterisk" <sip:XXXXXXXt0@192.168.1.251>;tag=as314b9aa4
To: <sip:sipconnect.sipgate.de>
Contact: <sip:XXXXXXXt0@192.168.1.251:5060>
Call-ID: 070ee473671582cc67a8cc7c5622ddd3@192.168.1.251:5060
CSeq: 102 OPTIONS
User-Agent: Asterisk PBX 11.6-cert1
Date: Sat, 26 Apr 2014 15:38:32 GMT
Supported: replaces, timer
Content-Length: 0
Retransmitting #1 (no NAT) to 217.10.68.150:5060:
Max-Forwards: 70
CSeq: 102 OPTIONS
Content-Length: 0
Retransmitting #2 (no NAT) to 217.10.68.150:5060:
Max-Forwards: 70
CSeq: 102 OPTIONS
Content-Length: 0
Retransmitting #3 (no NAT) to 217.10.68.150:5060:
Max-Forwards: 70
CSeq: 102 OPTIONS
Content-Length: 0
Retransmitting #4 (no NAT) to 217.10.68.150:5060:
Max-Forwards: 70
CSeq: 102 OPTIONS
Content-Length: 0
Really destroying SIP dialog '070ee473671582cc67a8cc7c5622ddd3@192.168.1.251:5060' Method: OPTIONS
mobydick*CLI> sip set debug off
Danach sieht es ja aus, als würde er doch kein NAT benutzen
Ein grep nach der externip auf /etc/asterisk/* brachte auch keine Ausgabe. Werden die Einträge aus der Oberfläche evtl. nicht übernommen? Ich habe nach den jeweiligen Änderungen den Telefonieserver neugeladen/neugestartet.
Hat da noch jemand Tipp für mich?
Danke
Ulf
