hier habe ich noch ein Paar Info bei einem eingehendem Call:
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
– Executing [4925159066710@mdc_incoming-1:1] Set(“SIP/mdc_trunk_conf-1-00000019”, “MDC_CALLER_NUM_TRUNK=025332811808124”) in new stack
– Executing [4925159066710@mdc_incoming-1:2] Gosub(“SIP/mdc_trunk_conf-1-00000019”, “sub_deterdest,s,1(MDC_CALLEE_NUM_TRUNK, <sip:004925159066710@sipconnect.sipgate.de>)”) in new stack
– Executing [s@sub_deterdest:1] Verbose(“SIP/mdc_trunk_conf-1-00000019”, “1,sub_deterdest:: variable: MDC_CALLEE_NUM_TRUNK header: <sip:004925159066710@sipconnect.sipgate.de>”) in new stack
– Executing [s@sub_deterdest:2] Set(“SIP/mdc_trunk_conf-1-00000019”, "TMP_DN=004925159066710@sipconnect.sipgate.de>") in new stack
– Executing [s@sub_deterdest:3] Set(“SIP/mdc_trunk_conf-1-00000019”, “TMP_DN=004925159066710”) in new stack
– Executing [s@sub_deterdest:4] Set(“SIP/mdc_trunk_conf-1-00000019”, “MDC_CALLEE_NUM_TRUNK=004925159066710”) in new stack
– Executing [s@sub_deterdest:5] Return(“SIP/mdc_trunk_conf-1-00000019”, “”) in new stack
– Executing [4925159066710@mdc_incoming-1:3] Verbose(“SIP/mdc_trunk_conf-1-00000019”, “1,destination 004925159066710 is extracted”) in new stack
– Executing [4925159066710@mdc_incoming-1:4] Goto(“SIP/mdc_trunk_conf-1-00000019”, “mdc_trunk-1,s,1”) in new stack
– Goto (mdc_trunk-1,s,1)
– Executing [s@mdc_trunk-1:1] Verbose(“SIP/mdc_trunk_conf-1-00000019”, “1,callee number: 004925159066710 caller number: 025332811808124”) in new stack
– Executing [s@mdc_trunk-1:2] Gosub(“SIP/mdc_trunk_conf-1-00000019”, “sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,025332811808124,00,49,0,251,1)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“SIP/mdc_trunk_conf-1-00000019”, “1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - number: 025332811808124 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 251 - incoming: 1”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“SIP/mdc_trunk_conf-1-00000019”, “0?s-emergency,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“SIP/mdc_trunk_conf-1-00000019”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“SIP/mdc_trunk_conf-1-00000019”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“SIP/mdc_trunk_conf-1-00000019”, “0?s-convert,1”) in new stack
– Executing [s@sub_nat2int:6] GotoIf(“SIP/mdc_trunk_conf-1-00000019”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:7] GotoIf(“SIP/mdc_trunk_conf-1-00000019”, “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:8] GotoIf(“SIP/mdc_trunk_conf-1-00000019”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:9] GotoIf(“SIP/mdc_trunk_conf-1-00000019”, “1?s-nat,1”) in new stack
– Goto (sub_nat2int,s-nat,1)
– Executing [s-nat@sub_nat2int:1] Verbose(“SIP/mdc_trunk_conf-1-00000019”, “1,national”) in new stack
national
– Executing [s-nat@sub_nat2int:2] Set(“SIP/mdc_trunk_conf-1-00000019”, “MDC_CALLER_NUM_INTERNAT=004925332811808124”) in new stack
– Executing [s-nat@sub_nat2int:3] Return(“SIP/mdc_trunk_conf-1-00000019”, “”) in new stack
– Executing [s@mdc_trunk-1:3] Set(“SIP/mdc_trunk_conf-1-00000019”, “CALLERID(num)=004925332811808124”) in new stack
– Executing [s@mdc_trunk-1:4] Gosub(“SIP/mdc_trunk_conf-1-00000019”, “sub_int2nat,s,1(MDC_CALLER_NUM_NAT,004925332811808124,00,49,0,251,1)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“SIP/mdc_trunk_conf-1-00000019”, “1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 004925332811808124 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 251 - incoming: 1”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“SIP/mdc_trunk_conf-1-00000019”, “0?s-emergency,1”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“SIP/mdc_trunk_conf-1-00000019”, “0?nat”) in new stack
– Executing [s@sub_int2nat:4] GotoIf(“SIP/mdc_trunk_conf-1-00000019”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“SIP/mdc_trunk_conf-1-00000019”, “MDC_CALLER_NUM_NAT=025332811808124”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“SIP/mdc_trunk_conf-1-00000019”, “”) in new stack
– Executing [s@mdc_trunk-1:5] Set(“SIP/mdc_trunk_conf-1-00000019”, “CALLERID(num)=025332811808124”) in new stack
– Executing [s@mdc_trunk-1:6] Set(“SIP/mdc_trunk_conf-1-00000019”, “MDC_NUMPREFIX_TRUNK=0”) in new stack
– Executing [s@mdc_trunk-1:7] ExecIf(“SIP/mdc_trunk_conf-1-00000019”, “1?Set(CALLERID(num)=0025332811808124)”) in new stack
– Executing [s@mdc_trunk-1:8] Goto(“SIP/mdc_trunk_conf-1-00000019”, “mdc_mapping-1,004925159066710,1”) in new stack
– Goto (mdc_mapping-1,004925159066710,1)
[Apr 8 15:49:29] WARNING[47457][C-0000000e]: pbx.c:6643 __ast_pbx_run: Channel ‘SIP/mdc_trunk_conf-1-00000019’ sent to invalid extension but no invalid handler: context,exten,priority=mdc_mapping-1,004925159066710,1
