… das hier konnte ich gerade aus dem cli holen:
Ich habe mich selbst auf dem Handy angerufen. Mit dem SoftClient.
Es kam gar nichts über 20 Sekunden, nicht einmal ein Rufsignal.
MDC_RESOLVENAME_HITS = 1
– Executing [00491732000000@sub_trunk-outgoing-1:9] Verbose(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “1,MDC_DIALCALLEENAME = PascomNewbie”) in new stack
– Executing [00491732000000@sub_trunk-outgoing-1:10] Verbose(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “1,end call deflection”) in new stack
end call deflection
– Executing [00491732000000@sub_trunk-outgoing-1:11] Verbose(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “1,sipgate - sipgate”) in new stack
sipgate - sipgate
– Executing [00491732000000@sub_trunk-outgoing-1:12] Set(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “__SPYGROUP=01732000000:101”) in new stack
– Executing [00491732000000@sub_trunk-outgoing-1:13] ExecIf(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “0?Set(CHANNEL(hangup_handler_push)=hdlr-hint,s,1())”) in new stack
– Executing [00491732000000@sub_trunk-outgoing-1:14] ExecIf(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “0?Set(DEVICE_STATE(Custom:)=INUSE)”) in new stack
– Executing [00491732000000@sub_trunk-outgoing-1:15] Set(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “CONNECTEDLINE(num,i)=00491732000000”) in new stack
– Executing [00491732000000@sub_trunk-outgoing-1:16] Set(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “CONNECTEDLINE(num-pres,i)=allowed”) in new stack
– Executing [00491732000000@sub_trunk-outgoing-1:17] Set(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “CONNECTEDLINE(name,i)=PascomNewbie”) in new stack
– Executing [00491732000000@sub_trunk-outgoing-1:18] Set(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “CONNECTEDLINE(name-pres)=allowed”) in new stack
– Executing [00491732000000@sub_trunk-outgoing-1:19] Set(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “no=01732000000”) in new stack
– Executing [00491732000000@sub_trunk-outgoing-1:20] Dial(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “PJSIP/01732000000@mdc_trunk_conf-1,Itb(mdc_outgoing_predial^s^1)U(mdc_outgoing_postanswer^s^1)”) in new stack
– PJSIP/mdc_trunk_conf-1-0000008d Internal Gosub(mdc_outgoing_predial,s,1) start
– Executing [s@mdc_outgoing_predial:1] Set(“PJSIP/mdc_trunk_conf-1-0000008d”, “HEADER_KEYS=”) in new stack
– Executing [s@mdc_outgoing_predial:2] Set(“PJSIP/mdc_trunk_conf-1-0000008d”, “counter=1”) in new stack
– Executing [s@mdc_outgoing_predial:3] Set(“PJSIP/mdc_trunk_conf-1-0000008d”, “currentHeader=”) in new stack
– Executing [s@mdc_outgoing_predial:4] While(“PJSIP/mdc_trunk_conf-1-0000008d”, “”) in new stack
– Jumping to priority 9
– Executing [s@mdc_outgoing_predial:10] Verbose(“PJSIP/mdc_trunk_conf-1-0000008d”, “1,Clip is: auto”) in new stack
Clip is: auto
– Executing [s@mdc_outgoing_predial:11] Verbose(“PJSIP/mdc_trunk_conf-1-0000008d”, "1,Default numer is: ") in new stack
Default numer is:
– Executing [s@mdc_outgoing_predial:12] ExecIf(“PJSIP/mdc_trunk_conf-1-0000008d”, “0?Set(PJSIP_HEADER(add,P-Preferred-Identity)=sip:+496000000000@sipgate.de)”) in new stack
– Executing [s@mdc_outgoing_predial:13] ExecIf(“PJSIP/mdc_trunk_conf-1-0000008d”, “0?Set(PJSIP_HEADER(add,P-Asserted-Identity)=sip:+496000000000@sipgate.de)”) in new stack
– Executing [s@mdc_outgoing_predial:14] ExecIf(“PJSIP/mdc_trunk_conf-1-0000008d”, “1?Set(PJSIP_HEADER(add,P-Preferred-Identity)=sip:+496000000000@sipgate.de)”) in new stack
– Executing [s@mdc_outgoing_predial:15] ExecIf(“PJSIP/mdc_trunk_conf-1-0000008d”, “1?Set(PJSIP_HEADER(add,P-Asserted-Identity)=sip:+496000000000@sipgate.de)”) in new stack
– Executing [s@mdc_outgoing_predial:16] Return(“PJSIP/mdc_trunk_conf-1-0000008d”, “”) in new stack
== Spawn extension (mdc_incoming-1, 00491732000000, 1) exited non-zero on ‘PJSIP/mdc_trunk_conf-1-0000008d’
– PJSIP/mdc_trunk_conf-1-0000008d Internal Gosub(mdc_outgoing_predial,s,1) complete GOSUB_RETVAL=
– Called PJSIP/01732000000@mdc_trunk_conf-1
== Using SIP RTP Audio TOS bits 184
== Using SIP RTP Audio CoS mark 5
– Connected line update to PJSIP/TCt8ifdxzE6pwfr-0000008c prevented.
– PJSIP/mdc_trunk_conf-1-0000008d is making progress passing it to PJSIP/TCt8ifdxzE6pwfr-0000008c
– PJSIP/mdc_trunk_conf-1-0000008d answered PJSIP/TCt8ifdxzE6pwfr-0000008c
– PJSIP/mdc_trunk_conf-1-0000008d Internal Gosub(mdc_outgoing_postanswer,s,1(s,1)) start
– Executing [s@mdc_outgoing_postanswer:1] Playback(“PJSIP/mdc_trunk_conf-1-0000008d”, “silence/025”) in new stack
– <PJSIP/mdc_trunk_conf-1-0000008d> Playing ‘silence/025.slin’ (language ‘en’)
– Executing [s@mdc_outgoing_postanswer:2] Return(“PJSIP/mdc_trunk_conf-1-0000008d”, “”) in new stack
== Spawn extension (mdc_incoming-1, , 1) exited non-zero on ‘PJSIP/mdc_trunk_conf-1-0000008d’
– PJSIP/mdc_trunk_conf-1-0000008d Internal Gosub(mdc_outgoing_postanswer,s,1(s,1)) complete GOSUB_RETVAL=
– Channel PJSIP/mdc_trunk_conf-1-0000008d joined ‘simple_bridge’ basic-bridge <77b56da7-6aea-439d-826c-6704ab321632>
– Channel PJSIP/TCt8ifdxzE6pwfr-0000008c joined ‘simple_bridge’ basic-bridge <77b56da7-6aea-439d-826c-6704ab321632>
– Manager ‘phpasm’ from 127.0.0.1, hanging up channel: PJSIP/TCt8ifdxzE6pwfr-0000008c
– Channel PJSIP/TCt8ifdxzE6pwfr-0000008c left ‘simple_bridge’ basic-bridge <77b56da7-6aea-439d-826c-6704ab321632>
== Spawn extension (sub_trunk-outgoing-1, 00491732000000, 20) exited non-zero on ‘PJSIP/TCt8ifdxzE6pwfr-0000008c’
– Executing [h@sub_trunk-outgoing-1:1] Gosub(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “def_hangup,s,1(,ANSWER,CALL)”) in new stack
– Executing [s@def_hangup:1] NoOp(“PJSIP/TCt8ifdxzE6pwfr-0000008c”, “>>>def_hangup:: EXTEN: DIALSTATUS: ANSWER QUEUESTATUS: REASON: CALL”) in new stack
– Channel PJSIP/mdc_trunk_conf-1-0000008d left ‘simple_bridge’ basic-bridge <77b56da7-6aea-439d-826c-6704ab321632>
