Hallo Mathias,
der Pickup wird mit einer Funktionstaste von einem Snom 370 gemacht.
Der CLI output wenn es scheitert:
– SIP/test2-083b7bf0 is ringing
– Executing Set(“SIP/test1-0862a398”, “MDC_CHANNEL_PROTOCOL=SIP”) in new stack
– Executing Set(“SIP/test1-0862a398”, “MDC_CHANNEL_ID=test1-0862a398”) in new stack
– Executing Set(“SIP/test1-0862a398”, “MDC_CHANNEL_TMP=test1-0862a398”) in new stack
– Executing Set(“SIP/test1-0862a398”, “MDC_CHANNEL_NAME=test1”) in new stack
– Executing GosubIf(“SIP/test1-0862a398”, “1?mdc_initcall-int|*8121|1”) in new stack
– Executing NoOp(“SIP/test1-0862a398”, “initial call”) in new stack
– Executing Set(“SIP/test1-0862a398”, “__MDC_DIALDESCENT=int”) in new stack
– Executing Set(“SIP/test1-0862a398”, “__MDC_DIALCALLEENUM=*8121”) in new stack
– Executing Set(“SIP/test1-0862a398”, “__MDC_DIALCALLERNUM=115”) in new stack
– Executing GotoIf(“SIP/test1-0862a398”, “1?nozap”) in new stack
– Goto (mdc_initcall-int,*8121,8)
– Executing Set(“SIP/test1-0862a398”, “__MDC_DIALCALLERNAME=***f") in new stack
– Executing Return(“SIP/test1-0862a398”, “”) in new stack
– Executing Gosub(“SIP/test1-0862a398”, "mdc_defcall|8121|1") in new stack
– Goto (mdc_defcall,8121,4)
– Executing Set(“SIP/test1-0862a398”, “__MDC_DIALCHANNELNAME=test1”) in new stack
– Executing SIPAddHeader(“SIP/test1-0862a398”, "“Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"”) in new stack
– Executing Macro(“SIP/test1-0862a398”, “pre-main”) in new stack
Dec 14 08:13:01 WARNING[27752]: app_macro.c:208 macro_exec: No such context ‘macro-pre-main’ for macro ‘pre-main’
– Executing GosubIf(“SIP/test1-0862a398”, “1?mdc_initloop|s|1”) in new stack
– Executing NoOp(“SIP/test1-0862a398”, “initial loop”) in new stack
– Executing Set(“SIP/test1-0862a398”, “MDC_ALIAS_HOP=0”) in new stack
– Executing Gosub(“SIP/test1-0862a398”, "mdc_cdr-int|8121|1") in new stack
– Executing Set(“SIP/test1-0862a398”, "CDR(mdcdst)=8121") in new stack
– Executing Set(“SIP/test1-0862a398”, "CDR(mdcinitdst)=8121") in new stack
– Executing Set(“SIP/test1-0862a398”, “CDR(mdcname)=test1”) in new stack
– Executing Set(“SIP/test1-0862a398”, “CDR(mdcsrc)=115”) in new stack
Extension Changed 117 new state InUse for Notify User **********
– Executing Set(“SIP/test1-0862a398”, “CDR(mdcinitsrc)=115”) in new stack
Extension Changed 117 new state InUse for Notify User test1
– Executing GotoIf(“SIP/test1-0862a398”, “0?prefix”) in new stack
– Executing Set(“SIP/test1-0862a398”, “CDR(mdcinitsrc)=117”) in new stack
– Executing Set(“SIP/test1-0862a398”, “CDR(mdcprefix)=”) in new stack
– Executing Set(“SIP/test1-0862a398”, “TMP_NAME=”) in new stack
– Executing GotoIf(“SIP/test1-0862a398”, “0?dstname”) in new stack
– Executing Set(“SIP/test1-0862a398”, "TMP_NAME=8121") in new stack
– Executing Set(“SIP/test1-0862a398”, "CDR(mdcdstname)=8121") in new stack
– Executing Set(“SIP/test1-0862a398”, “CDR(mdcdescent)=int”) in new stack
– Executing Set(“SIP/test1-0862a398”, "CDR(mdcsrcname)=”) in new stack
– Executing AGI(“SIP/test1-0862a398”, “script/mdc_billing-pricing.php|0”) in new stack
– Launched AGI Script /var/lib/asterisk/agi-bin/script/mdc_billing-pricing.php
– AGI Script script/mdc_billing-pricing.php completed, returning 0
– Executing Set(“SIP/test1-0862a398”, “CDR(tarifid)=”) in new stack
– Executing Goto(“SIP/test1-0862a398”, “main|*8121|1”) in new stack
– Goto (main,*8121,1)
– Executing Macro(“SIP/test1-0862a398”, “mdc_pickup|121|SIP|test2|115”) in new stack
– Executing NoOp(“SIP/test1-0862a398”, “macro-mdc_pickup:: exten: 121 technology: SIP ident: test2 caller: 115”) in new stack
– Executing AGI(“SIP/test1-0862a398”, “script/mdc_roletype.agi|pickup.group|115|121”) in new stack
– Launched AGI Script /var/lib/asterisk/agi-bin/script/mdc_roletype.agi
– AGI Script script/mdc_roletype.agi completed, returning 0
– Executing GotoIf(“SIP/test1-0862a398”, “0?s-failed|1”) in new stack
– Executing Goto(“SIP/test1-0862a398”, “s-pickup|1”) in new stack
– Goto (macro-mdc_pickup,s-pickup,1)
– Executing PickupChan(“SIP/test1-0862a398”, “SIP/test2”) in new stack
Nice channel, I’ll take it: SIP/test2
– Channel SIP/test1-0862a398 picked up ringing channel SIP/test2-083b7bf0
== Spawn extension (macro-mdc_pickup, s-pickup, 1) exited non-zero on ‘SIP/test1-0862a398’ in macro ‘mdc_pickup’
== Spawn extension (macro-mdc_pickup, s-pickup, 1) exited non-zero on ‘SIP/test1-0862a398<MASQ>’
– SIP/test1-0862a398 answered Zap/22-1
hierbei hat die Nebenstelle 121 die CDI Nummer 120
Der CLI output wenn es funktioniert:
– Executing Set(“SIP/test3-089274e8”, “MDC_CHANNEL_PROTOCOL=SIP”) in new stack
– Executing Set(“SIP/test3-089274e8”, “MDC_CHANNEL_ID=test3-089274e8”) in new stack
– Executing Set(“SIP/test3-089274e8”, “MDC_CHANNEL_TMP=test3-089274e8”) in new stack
– Executing Set(“SIP/test3-089274e8”, “MDC_CHANNEL_NAME=test3”) in new stack
– Executing GosubIf(“SIP/test3-089274e8”, “1?mdc_initcall-int|8115|1") in new stack
– Executing NoOp(“SIP/test3-089274e8”, “initial call”) in new stack
– Executing Set(“SIP/test3-089274e8”, “__MDC_DIALDESCENT=int”) in new stack
– Executing Set(“SIP/test3-089274e8”, "__MDC_DIALCALLEENUM=8115") in new stack
– Executing Set(“SIP/test3-089274e8”, “__MDC_DIALCALLERNUM=115”) in new stack
– Executing GotoIf(“SIP/test3-089274e8”, “1?nozap”) in new stack
– Goto (mdc_initcall-int,8115,8)
– Executing Set(“SIP/test3-089274e8”, “__MDC_DIALCALLERNAME=*****”) in new stack
– Executing Return(“SIP/test3-089274e8”, “”) in new stack
– Executing Gosub(“SIP/test3-089274e8”, "mdc_defcall|8115|1") in new stack
– Goto (mdc_defcall,8115,4)
– Executing Set(“SIP/test3-089274e8”, “__MDC_DIALCHANNELNAME=test3”) in new stack
– Executing SIPAddHeader(“SIP/test3-089274e8”, "“Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"”) in new stack
– Executing Macro(“SIP/test3-089274e8”, “pre-main”) in new stack
Dec 14 08:35:12 WARNING[29245]: app_macro.c:208 macro_exec: No such context ‘macro-pre-main’ for macro ‘pre-main’
– Executing GosubIf(“SIP/test3-089274e8”, “1?mdc_initloop|s|1”) in new stack
– Executing NoOp(“SIP/test3-089274e8”, “initial loop”) in new stack
– Executing Set(“SIP/test3-089274e8”, “MDC_ALIAS_HOP=0”) in new stack
Extension Changed 117 new state InUse for Notify User test3
– Executing Gosub(“SIP/test3-089274e8”, "mdc_cdr-int|8115|1") in new stack
– Executing Set(“SIP/test3-089274e8”, "CDR(mdcdst)=8115") in new stack
– Executing Set(“SIP/test3-089274e8”, "CDR(mdcinitdst)=8115") in new stack
– Executing Set(“SIP/test3-089274e8”, “CDR(mdcname)=test3”) in new stack
– Executing Set(“SIP/test3-089274e8”, “CDR(mdcsrc)=115”) in new stack
– Executing Set(“SIP/test3-089274e8”, “CDR(mdcinitsrc)=115”) in new stack
– Executing GotoIf(“SIP/test3-089274e8”, “0?prefix”) in new stack
– Executing Set(“SIP/test3-089274e8”, “CDR(mdcinitsrc)=117”) in new stack
– Executing Set(“SIP/test3-089274e8”, “CDR(mdcprefix)=”) in new stack
– Executing Set(“SIP/test3-089274e8”, “TMP_NAME=”) in new stack
– Executing GotoIf(“SIP/test3-089274e8”, “0?dstname”) in new stack
– Executing Set(“SIP/test3-089274e8”, "TMP_NAME=8115") in new stack
– Executing Set(“SIP/test3-089274e8”, "CDR(mdcdstname)=8115") in new stack
– Executing Set(“SIP/test3-089274e8”, “CDR(mdcdescent)=int”) in new stack
– Executing Set(“SIP/test3-089274e8”, "CDR(mdcsrcname)=”) in new stack
– Executing AGI(“SIP/test3-089274e8”, “script/mdc_billing-pricing.php|0”) in new stack
– Executing Set(“SIP/test3-089274e8”, “CDR(tarifid)=”) in new stack
– Executing Goto(“SIP/test3-089274e8”, "main|8115|1") in new stack
– Goto (main,8115,1)
– Executing Macro(“SIP/test3-089274e8”, “mdc_pickup|115|SIP||115") in new stack
– Executing NoOp(“SIP/test3-089274e8”, “macro-mdc_pickup:: exten: 115 technology: SIP ident: ******** caller: 115”) in new stack
– Executing AGI(“SIP/test3-089274e8”, “script/mdc_roletype.agi|pickup.group|115|115”) in new stack
– Executing GotoIf(“SIP/test3-089274e8”, “0?s-failed|1”) in new stack
– Executing Goto(“SIP/test3-089274e8”, “s-pickup|1”) in new stack
– Executing PickupChan(“SIP/test3-089274e8”, "SIP/”) in new stack
Nice channel, I’ll take it: SIP/*******
– Channel SIP/test3-089274e8 picked up ringing channel SIP/********-0862a398
== Spawn extension (macro-mdc_pickup, s-pickup, 1) exited non-zero on ‘SIP/test3-089274e8’ in macro ‘mdc_pickup’
== Spawn extension (macro-mdc_pickup, s-pickup, 1) exited non-zero on ‘SIP/test3-089274e8<MASQ>’
– SIP/test3-089274e8 answered Zap/23-1
Hier hat die Nebenstelle die Durchwahl 117 mit der CDI Nummer 115 und der
Pickup funtioniert.
Gruß Ralf
