Moin,
wir haben ein Problem mit eingehenden Anrufen. Ausgehende Anrufe funktionieren. Hier ein Schnipsel des Logs.
-- Goto (mdc_distribute,*60,1)
-- Executing [*60@mdc_distribute:1] Gosub("SIP/mdc_trunk_conf-14-000000c8", "sub_mobility,s,1(0157XXXXXXXX)") in new stack
-- Executing [s@sub_mobility:1] Verbose("SIP/mdc_trunk_conf-14-000000c8", "1,sub_mobility:: callerid(num): 0157XXXXXXXX") in new stack
– Executing [s@sub_mobility:2] Set(“SIP/mdc_trunk_conf-14-000000c8”, “__MDC_DIALDESCENT=int”) in new stack
– Executing [s@sub_mobility:3] Set(“SIP/mdc_trunk_conf-14-000000c8”, “__MDC_MOBILITY_INCOMING=1”) in new stack
– Executing [s@sub_mobility:4] GotoIf(“SIP/mdc_trunk_conf-14-000000c8”, “0?failed,1”) in new stack
– Executing [s@sub_mobility:5] Verbose(“SIP/mdc_trunk_conf-14-000000c8”, “1,Request data for caller: 0157XXXXXXXX”) in new stack
– Executing [s@sub_mobility:6] Set(“SIP/mdc_trunk_conf-14-000000c8”, “CURLOPT(hashcompat)=yes”) in new stack
– Executing [s@sub_mobility:7] Set(“SIP/mdc_trunk_conf-14-000000c8”, “CURLOPT(httptimeout)=3”) in new stack
– Executing [s@sub_mobility:8] Set(“SIP/mdc_trunk_conf-14-000000c8”, “CURLOPT(conntimeout)=5”) in new stack
– Executing [s@sub_mobility:9] Set(“SIP/mdc_trunk_conf-14-000000c8”, “HASH(curl)=UNKNOWN”) in new stack
– Executing [s@sub_mobility:10] GotoIf(“SIP/mdc_trunk_conf-14-000000c8”, “0?failed,1”) in new stack
– Executing [s@sub_mobility:11] GotoIf(“SIP/mdc_trunk_conf-14-000000c8”, “1?failed,1”) in new stack
– Goto (sub_mobility,failed,1)
– Executing [failed@sub_mobility:1] Answer(“SIP/mdc_trunk_conf-14-000000c8”, “”) in new stack
– Executing [failed@sub_mobility:2] Playback(“SIP/mdc_trunk_conf-14-000000c8”, “invalid”) in new stack
– <SIP/mdc_trunk_conf-14-000000c8> Playing ‘invalid.alaw’ (language ‘de’)
== Spawn extension (sub_mobility, failed, 2) exited non-zero on ‘SIP/mdc_trunk_conf-14-000000c8’
– Executing [h@sub_mobility:1] Gosub(“SIP/mdc_trunk_conf-14-000000c8”, “def_hangup,s,1(,CALL)”) in new stack
– Executing [s@def_hangup:1] NoOp(“SIP/mdc_trunk_conf-14-000000c8”, “>>>def_hangup:: EXTEN: DIALSTATUS: QUEUESTATUS: REASON: CALL”) in new stack
Wir nutzen die voreingestellten Regeln für das Telekom-SIP-Amt
VG,
Warmitrax
