bei dem weiteren account, der als Benutzername und Durchwahl reg mit 49 beginnt, kommt der Unsinn mit der Vorwahl
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
– Executing [4909177777777@mdc_incoming-6:1] Set(“SIP/mdc_trunk_conf-6-00000002”, “MDC_CALLER_NUM_TRUNK=491718888888”) in new stack
– Executing [4909177777777@mdc_incoming-6:2] Set(“SIP/mdc_trunk_conf-6-00000002”, “MDC_CALLEE_NUM_TRUNK=4909177777777”) in new stack
– Executing [4909177777777@mdc_incoming-6:3] Goto(“SIP/mdc_trunk_conf-6-00000002”, “mdc_trunk-3,s,1”) in new stack
– Goto (mdc_trunk-3,s,1)
– Executing [s@mdc_trunk-3:1] Verbose(“SIP/mdc_trunk_conf-6-00000002”, “1,callee number: 4909177777777 caller number: 491718888888”) in new stack
– Executing [s@mdc_trunk-3:2] Gosub(“SIP/mdc_trunk_conf-6-00000002”, “sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,491718888888,00,49,0,91)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“SIP/mdc_trunk_conf-6-00000002”, “1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - number: 491718888888 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 91”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?s-emergency,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, " 0?s-convert,1") in new stack
– Executing [s@sub_nat2int:6] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:7] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:8] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:9] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?s-nat,1”) in new stack
– Executing [s@sub_nat2int:10] Goto(“SIP/mdc_trunk_conf-6-00000002”, “s-local,1”) in new stack
– Goto (sub_nat2int,s-local,1)
– Executing [s-local@sub_nat2int:1] Verbose(“SIP/mdc_trunk_conf-6-00000002”, “1,local”) in new stack
local
– Executing [s-local@sub_nat2int:2] Set(“SIP/mdc_trunk_conf-6-00000002”, “MDC_CALLER_NUM_INTERNAT=004991491718888888”) in new stack
– Executing [s-local@sub_nat2int:3] Return(“SIP/mdc_trunk_conf-6-00000002”, “”) in new stack
– Executing [s@mdc_trunk-3:3] Set(“SIP/mdc_trunk_conf-6-00000002”, “CALLERID(num)=004991491718888888”) in new stack
– Executing [s@mdc_trunk-3:4] Gosub(“SIP/mdc_trunk_conf-6-00000002”, “sub_int2nat,s,1(MDC_CALLER_NUM_NAT,004991491718888888,00,49,0,91)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“SIP/mdc_trunk_conf-6-00000002”, “1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 004991491718888888 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 91”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?s-emergency,1”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?nat”) in new stack
– Executing [s@sub_int2nat:4] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“SIP/mdc_trunk_conf-6-00000002”, “MDC_CALLER_NUM_NAT=091491718888888”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“SIP/mdc_trunk_conf-6-00000002”, “”) in new stack
– Executing [s@mdc_trunk-3:5] Set(“SIP/mdc_trunk_conf-6-00000002”, “CALLERID(num)=091491718888888”) in new stack
– Executing [s@mdc_trunk-3:6] UserEvent(“SIP/mdc_trunk_conf-6-00000002”, “ResolveCallerName,Strategy: default,Outbound: 0,Channel: SIP/mdc_trunk_conf-6-00000002”) in new stack
– Executing [s@mdc_trunk-3:7] Wait(“SIP/mdc_trunk_conf-6-00000002”, “0.25”) in new stack
– Executing [s@mdc_trunk-3:8] Verbose(“SIP/mdc_trunk_conf-6-00000002”, “1,MDC_RESOLVENAME_HITS = 0”) in new stack
– Executing [s@mdc_trunk-3:9] Verbose(“SIP/mdc_trunk_conf-6-00000002”, "1,CALLERID(name) = ") in new stack
CALLERID(name) =
– Executing [s@mdc_trunk-3:10] Set(“SIP/mdc_trunk_conf-6-00000002”, “MDC_NUMPREFIX_TRUNK=0”) in new stack
– Executing [s@mdc_trunk-3:11] ExecIf(“SIP/mdc_trunk_conf-6-00000002”, “1?Set(CALLERID(num)=0091491718888888)”) in new stack
– Executing [s@mdc_trunk-3:12] Goto(“SIP/mdc_trunk_conf-6-00000002”, “mdc_mapping-3,4909177777777,1”) in new stack
– Goto (mdc_mapping-3,4909177777777,1)
– Executing [4909177777777@mdc_mapping-3:1] Set(“SIP/mdc_trunk_conf-6-00000002”, “CHANNEL(language)=de”) in new stack
– Executing [4909177777777@mdc_mapping-3:2] Verbose(“SIP/mdc_trunk_conf-6-00000002”, "1,mapping from _%#a-zA-Z0-9]. to 150") in new stack
– Executing [4909177777777@mdc_mapping-3:3] Goto(“SIP/mdc_trunk_conf-6-00000002”, “mdc_external,150,1”) in new stack
– Goto (mdc_external,150,1)
– Executing [150@mdc_external:1] SIPAddHeader(“SIP/mdc_trunk_conf-6-00000002”, "“Alert-Info:<http://www.notused.de>;info=alert-external;x-line-id=0"”) in new stack
– Executing [150@mdc_external:2] GosubIf(“SIP/mdc_trunk_conf-6-00000002”, “1?sub_initcall,s,1(ext,150)”) in new stack
– Executing [s@sub_initcall:1] Verbose(“SIP/mdc_trunk_conf-6-00000002”, “1,sub_initcall descent: ext exten: 150”) in new stack
– Executing [s@sub_initcall:2] GosubIf(“SIP/mdc_trunk_conf-6-00000002”, “1?sub_initloop,s,1”) in new stack
– Executing [s@sub_initloop:1] Verbose(“SIP/mdc_trunk_conf-6-00000002”, “1,initial loop”) in new stack
initial loop
– Executing [s@sub_initloop:2] Set(“SIP/mdc_trunk_conf-6-00000002”, “MDC_ALIAS_HOP=0”) in new stack
– Executing [s@sub_initloop:3] Return(“SIP/mdc_trunk_conf-6-00000002”, “”) in new stack
– Executing [s@sub_initcall:3] Set(“SIP/mdc_trunk_conf-6-00000002”, “__MDC_TRANSFERBACK_HOP=0”) in new stack
– Executing [s@sub_initcall:4] Set(“SIP/mdc_trunk_conf-6-00000002”, “__MDC_DIALDESCENT=ext”) in new stack
– Executing [s@sub_initcall:5] Goto(“SIP/mdc_trunk_conf-6-00000002”, “ext,1”) in new stack
– Goto (sub_initcall,ext,1)
– Executing [ext@sub_initcall:1] Set(“SIP/mdc_trunk_conf-6-00000002”, “__MDC_DIALCALLERNUMINIT=491718888888”) in new stack
– Executing [ext@sub_initcall:2] Set(“SIP/mdc_trunk_conf-6-00000002”, “__MDC_DIALCALLEENUMINIT=4909177777777”) in new stack
– Executing [ext@sub_initcall:3] Set(“SIP/mdc_trunk_conf-6-00000002”, “__MDC_DIALCALLEENUMMAP=150”) in new stack
– Executing [ext@sub_initcall:4] Return(“SIP/mdc_trunk_conf-6-00000002”, “”) in new stack
– Executing [150@mdc_external:3] Goto(“SIP/mdc_trunk_conf-6-00000002”, “main,150,1”) in new stack
– Goto (main,150,1)
– Executing [150@main:1] Gosub(“SIP/mdc_trunk_conf-6-00000002”, “sub_defcall,s,1(150)”) in new stack
– Executing [s@sub_defcall:1] Set(“SIP/mdc_trunk_conf-6-00000002”, “__MDC_ALIAS_HOP=1”) in new stack
– Executing [s@sub_defcall:2] Set(“SIP/mdc_trunk_conf-6-00000002”, “__MDC_DIALCALLEENUM=150”) in new stack
– Executing [s@sub_defcall:3] Set(“SIP/mdc_trunk_conf-6-00000002”, “__MDC_DIALCALLERNUM=0091491718888888”) in new stack
– Executing [s@sub_defcall:4] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “1?nozap”) in new stack
– Goto (sub_defcall,s,8)
– Executing [s@sub_defcall:8] Set(“SIP/mdc_trunk_conf-6-00000002”, “__MDC_DIALCALLERNAME=”) in new stack
– Executing [s@sub_defcall:9] Set(“SIP/mdc_trunk_conf-6-00000002”, “__MDC_DIALCHANNELNAME=mdc_trunk_conf-6”) in new stack
– Executing [s@sub_defcall:10] Return(“SIP/mdc_trunk_conf-6-00000002”, “”) in new stack
– Executing [150@main:2] Goto(“SIP/mdc_trunk_conf-6-00000002”, “mdc_distribute,150,1”) in new stack
– Goto (mdc_distribute,150,1)
– Executing [150@mdc_distribute:1] Gosub(“SIP/mdc_trunk_conf-6-00000002”, “sub_user,s,1(callee,1,David.Studnicka,David Studnička,150,150)”) in new stack
– Executing [s@sub_user:1] Verbose(“SIP/mdc_trunk_conf-6-00000002”, “1,sub_user mode callee”) in new stack
– Executing [s@sub_user:2] Goto(“SIP/mdc_trunk_conf-6-00000002”, “s-callee,1”) in new stack
– Goto (sub_user,s-callee,1)
– Executing [s-callee@sub_user:1] Verbose(“SIP/mdc_trunk_conf-6-00000002”, “1,sub_user user id: 1 - user: David.Studnicka - realname: David Studnička - own mailbox: 150 - watched mailbox: 150”) in new stack
– Executing [s-callee@sub_user:2] Set(“SIP/mdc_trunk_conf-6-00000002”, “_MDC_CALLEE_USER_ID=1”) in new stack
– Executing [s-callee@sub_user:3] Set(“SIP/mdc_trunk_conf-6-00000002”, “_MDC_CALLEE_ACC_NAME=David.Studnicka”) in new stack
– Executing [s-callee@sub_user:4] Set(“SIP/mdc_trunk_conf-6-00000002”, “_MDC_CALLEE_ACC_REALNAME=David Studnička”) in new stack
– Executing [s-callee@sub_user:5] Set(“SIP/mdc_trunk_conf-6-00000002”, “_MDC_CALLEE_VM_OWN=150”) in new stack
– Executing [s-callee@sub_user:6] Set(“SIP/mdc_trunk_conf-6-00000002”, “_MDC_CALLEE_VM_WATCHED=150”) in new stack
– Executing [s-callee@sub_user:7] Return(“SIP/mdc_trunk_conf-6-00000002”, “”) in new stack
– Executing [150@mdc_distribute:2] Goto(“SIP/mdc_trunk_conf-6-00000002”, “mdc_ident-1,150,1”) in new stack
– Goto (mdc_ident-1,150,1)
– Executing [150@mdc_ident-1:1] NoOp(“SIP/mdc_trunk_conf-6-00000002”, “alias-check:: call forwarding from 150 - 0”) in new stack
– Executing [150@mdc_ident-1:2] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?150-uml,1:150-dial,1”) in new stack
– Goto (mdc_ident-1,150-dial,1)
– Executing [150-dial@mdc_ident-1:1] Set(“SIP/mdc_trunk_conf-6-00000002”, “__MDC_EXTEN=150”) in new stack
– Executing [150-dial@mdc_ident-1:2] Gosub(“SIP/mdc_trunk_conf-6-00000002”, “sub_prefix-150,ext,1”) in new stack
– Executing [ext@sub_prefix-150:1] Verbose(“SIP/mdc_trunk_conf-6-00000002”, “1,no action”) in new stack
no action
– Executing [ext@sub_prefix-150:2] Return(“SIP/mdc_trunk_conf-6-00000002”, “”) in new stack
– Executing [150-dial@mdc_ident-1:3] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?150-unavail,1”) in new stack
– Executing [150-dial@mdc_ident-1:4] GotoIf(“SIP/mdc_trunk_conf-6-00000002”, “0?150-busy,1”) in new stack
– Executing [150-dial@mdc_ident-1:5] Gosub(“SIP/mdc_trunk_conf-6-00000002”, “sub_main-150,ext,1”) in new stack
– Executing [ext@sub_main-150:1] Set(“SIP/mdc_trunk_conf-6-00000002”, “__PICKUPMARK=150”) in new stack
– Executing [ext@sub_main-150:2] Set(“SIP/mdc_trunk_conf-6-00000002”, “__SPYGROUP=150”) in new stack
– Executing [ext@sub_main-150:3] Dial(“SIP/mdc_trunk_conf-6-00000002”, “Local/150@mdc_diallocation”) in new stack
– Called Local/150@mdc_diallocation
– Executing [150@mdc_diallocation:1] Verbose(“Local/150@mdc_diallocation-00000003;2”, “1,dial to 150 for user 1”) in new stack
– Executing [150@mdc_diallocation:2] Set(“Local/150@mdc_diallocation-00000003;2”, “__MDC_DIALLOCATION_CHANNEL=Local/150@mdc_diallocation-00000003;2”) in new stack
– Executing [150@mdc_diallocation:3] Set(“Local/150@mdc_diallocation-00000003;2”, “SHARED(MDC_CALLEE_PEERS)=”) in new stack
– Executing [150@mdc_diallocation:4] Set(“Local/150@mdc_diallocation-00000003;2”, “MDC_EXTEN=150”) in new stack
– Executing [150@mdc_diallocation:5] ExecIf(“Local/150@mdc_diallocation-00000003;2”, “0?Set(TMP_TARGET=team):Set(TMP_TARGET=ext)”) in new stack
– Executing [150@mdc_diallocation:6] Gosub(“Local/150@mdc_diallocation-00000003;2”, “sub_split-user,s,1(1)”) in new stack
– Executing [s@sub_split-user:1] Verbose(“Local/150@mdc_diallocation-00000003;2”, “1,get locations for for: 1”) in new stack
– Executing [s@sub_split-user:2] GotoIf(“Local/150@mdc_diallocation-00000003;2”, “0?s-zero,1”) in new stack
– Executing [s@sub_split-user:3] Set(“Local/150@mdc_diallocation-00000003;2”, “TMP_LOCATIONS=1;0”) in new stack
– Executing [s@sub_split-user:4] Set(“Local/150@mdc_diallocation-00000003;2”, “TMP_STATIC_ID=1”) in new stack
– Executing [s@sub_split-user:5] Verbose(“Local/150@mdc_diallocation-00000003;2”, “1,static id: 1”) in new stack
static id: 1
– Executing [s@sub_split-user:6] Set(“Local/150@mdc_diallocation-00000003;2”, “TMP_DYN_ID=0”) in new stack
– Executing [s@sub_split-user:7] Verbose(“Local/150@mdc_diallocation-00000003;2”, “1,dynamic id: 0”) in new stack
dynamic id: 0
– Executing [s@sub_split-user:8] Return(“Local/150@mdc_diallocation-00000003;2”, “”) in new stack
– Executing [150@mdc_diallocation:7] GotoIf(“Local/150@mdc_diallocation-00000003;2”, “0?invalid,1”) in new stack
– Executing [150@mdc_diallocation:8] GotoIf(“Local/150@mdc_diallocation-00000003;2”, “0?dynamic,1”) in new stack
– Executing [150@mdc_diallocation:9] GotoIf(“Local/150@mdc_diallocation-00000003;2”, “1?static,1”) in new stack
– Goto (mdc_diallocation,static,1)
– Executing [static@mdc_diallocation:1] Dial(“Local/150@mdc_diallocation-00000003;2”, “Local/ext@mdc_locallocation-1”) in new stack
– Called Local/ext@mdc_locallocation-1
– Executing [ext@mdc_locallocation-1:1] Set(“Local/ext@mdc_locallocation-1-00000004;2”, “PUSH(SHARED(MDC_CALLEE_PEERS,Local/150@mdc_diallocation-00000003;2))=Local/ext-1@mdc_localdevice-1”) in new stack
– Executing [ext@mdc_locallocation-1:2] Dial(“Local/ext@mdc_locallocation-1-00000004;2”, “Local/ext-1@mdc_localdevice-1”) in new stack
– Called Local/ext-1@mdc_localdevice-1
– Executing [ext-1@mdc_localdevice-1:1] Verbose(“Local/ext-1@mdc_localdevice-1-00000005;2”, “1,Dialing with delay of 0 seconds for 999 seconds”) in new stack
Merkwürdig sehr.
