und hier der Rest (da der Post sonst zu lang ist)
0.410071] pnp 00:03: Plug and Play ACPI device, IDs PNP0103 (active)
0.410094] pnp 00:04: [io 0x0010-0x001f]
0.410097] pnp 00:04: [io 0x0022-0x002d]
0.410101] pnp 00:04: [io 0x0030-0x003f]
0.410104] pnp 00:04: [io 0x0044-0x005f]
0.410107] pnp 00:04: [io 0x0062-0x0063]
0.410110] pnp 00:04: [io 0x0065-0x006f]
0.410113] pnp 00:04: [io 0x0072-0x007f]
0.410116] pnp 00:04: [io 0x0080]
0.410120] pnp 00:04: [io 0x0084-0x0086]
0.410123] pnp 00:04: [io 0x0088]
0.410126] pnp 00:04: [io 0x008c-0x008e]
0.410129] pnp 00:04: [io 0x0090-0x009f]
0.410132] pnp 00:04: [io 0x00a2-0x00bd]
0.410135] pnp 00:04: [io 0x00e0-0x00ef]
0.410140] pnp 00:04: [io 0x08a0-0x08a3]
0.410143] pnp 00:04: [io 0x0cc0-0x0ccf]
0.410146] pnp 00:04: [io 0x04d0-0x04d1]
0.410183] system 00:04: [io 0x08a0-0x08a3] has been reserved
0.410188] system 00:04: [io 0x0cc0-0x0ccf] has been reserved
0.410192] system 00:04: [io 0x04d0-0x04d1] has been reserved
0.410196] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
0.410210] pnp 00:05: [dma 4]
0.410214] pnp 00:05: [io 0x0000-0x000f]
0.410217] pnp 00:05: [io 0x0081-0x0083]
0.410221] pnp 00:05: [io 0x0087]
0.410224] pnp 00:05: [io 0x0089-0x008b]
0.410227] pnp 00:05: [io 0x008f]
0.410230] pnp 00:05: [io 0x00c0-0x00df]
0.410233] pnp 00:05: [io 0x0480-0x048f]
0.410260] pnp 00:05: Plug and Play ACPI device, IDs PNP0200 (active)
0.410275] pnp 00:06: [io 0x0070-0x0071]
0.410290] xen: --> pirq=16 -> irq=8 (gsi=8)
0.410294] pnp 00:06: [irq 8]
0.410322] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
0.410334] pnp 00:07: [io 0x0061]
0.410360] pnp 00:07: Plug and Play ACPI device, IDs PNP0800 (active)
0.410389] xen: --> pirq=17 -> irq=12 (gsi=12)
0.410393] pnp 00:08: [irq 12]
0.410419] pnp 00:08: Plug and Play ACPI device, IDs PNP0f13 (active)
0.410438] pnp 00:09: [io 0x0060]
0.410441] pnp 00:09: [io 0x0064]
0.410450] xen: --> pirq=18 -> irq=1 (gsi=1)
0.410453] pnp 00:09: [irq 1]
0.410487] pnp 00:09: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
0.410507] pnp 00:0a: [io 0x03f0-0x03f5]
0.410511] pnp 00:0a: [io 0x03f7]
0.410519] xen: --> pirq=19 -> irq=6 (gsi=6)
0.410524] pnp 00:0a: [irq 6]
0.410528] pnp 00:0a: [dma 2]
0.410556] pnp 00:0a: Plug and Play ACPI device, IDs PNP0700 (active)
0.410582] pnp 00:0b: [io 0x03f8-0x03ff]
0.410590] xen: --> pirq=20 -> irq=4 (gsi=4)
0.410594] pnp 00:0b: [irq 4]
0.410621] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active)
0.410657] pnp 00:0c: [io 0x0378-0x037f]
0.410666] xen: --> pirq=21 -> irq=7 (gsi=7)
0.410670] pnp 00:0c: [irq 7]
0.410699] pnp 00:0c: Plug and Play ACPI device, IDs PNP0400 (active)
0.446189] pnp: PnP ACPI: found 13 devices
0.446193] ACPI: ACPI bus type pnp unregistered
0.453069] PCI: max bus depth: 0 pci_try_num: 1
0.453077] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
0.453081] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
0.453084] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
0.453088] pci_bus 0000:00: resource 7 [mem 0xf0000000-0xfbffffff]
0.453127] NET: Registered protocol family 2
0.453241] IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
0.453860] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
0.455903] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
0.456491] TCP: Hash tables configured (established 262144 bind 65536)
0.456494] TCP reno registered
0.456516] UDP hash table entries: 1024 (order: 3, 32768 bytes)
0.456544] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
0.456694] NET: Registered protocol family 1
0.456711] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
0.456795] pci 0000:00:01.0: PIIX3: Enabling Passive Release
0.456887] pci 0000:00:01.0: Activating ISA DMA hang workarounds
0.457045] xen: --> pirq=22 -> irq=23 (gsi=23)
0.457560] pci 0000:00:02.0: Boot video device
0.457641] PCI: CLS 0 bytes, default 64
0.457695] Unpacking initramfs...
0.753211] Freeing initrd memory: 13704k freed
0.758041] audit: initializing netlink socket (disabled)
0.758059] type=2000 audit(1378899032.541:1): initialized
0.776016] HugeTLB registered 2 MB page size, pre-allocated 0 pages
0.776364] VFS: Disk quotas dquot_6.5.2
0.776397] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
0.776486] msgmni has been set to 2495
0.776689] alg: No test for stdrng (krng)
0.776715] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
0.776720] io scheduler noop registered
0.776722] io scheduler deadline registered
0.776733] io scheduler cfq registered (default)
0.776806] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
0.776831] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
0.776834] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
0.777000] acpiphp: Slot [0] registered
0.777078] acpiphp: Slot [1] registered
0.777152] acpiphp: Slot [2] registered
0.777222] acpiphp: Slot [3] registered
0.777294] acpiphp: Slot [4] registered
0.777367] acpiphp: Slot [5] registered
0.777437] acpiphp: Slot [6] registered
0.777509] acpiphp: Slot [7] registered
0.777583] acpiphp: Slot [8] registered
0.777655] acpiphp: Slot [9] registered
0.777726] acpiphp: Slot [10] registered
0.777798] acpiphp: Slot [11] registered
0.777872] acpiphp: Slot [12] registered
0.777944] acpiphp: Slot [13] registered
0.778016] acpiphp: Slot [14] registered
0.778089] acpiphp: Slot [15] registered
0.778164] acpiphp: Slot [16] registered
0.778236] acpiphp: Slot [17] registered
0.778309] acpiphp: Slot [18] registered
0.778382] acpiphp: Slot [19] registered
0.778456] acpiphp: Slot [20] registered
0.778528] acpiphp: Slot [21] registered
0.778602] acpiphp: Slot [22] registered
0.778675] acpiphp: Slot [23] registered
0.778747] acpiphp: Slot [24] registered
0.778822] acpiphp: Slot [25] registered
0.778895] acpiphp: Slot [26] registered
0.778967] acpiphp: Slot [27] registered
0.779041] acpiphp: Slot [28] registered
0.779113] acpiphp: Slot [29] registered
0.779185] acpiphp: Slot [30] registered
0.779258] acpiphp: Slot [31] registered
0.779922] intel_idle: does not run on family 6 model 23
0.779942] ERST: Table is not found!
0.779945] GHES: HEST is not enabled!
0.780043] xen: --> pirq=23 -> irq=30 (gsi=30)
0.782105] Grant table initialized
0.784749] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
0.820449] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
0.854380] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
0.854737] Linux agpgart interface v0.103
0.854953] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
0.856685] serio: i8042 KBD port at 0x60,0x64 irq 1
0.856696] serio: i8042 AUX port at 0x60,0x64 irq 12
0.856873] mousedev: PS/2 mouse device common for all mice
0.857564] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
0.857977] rtc_cmos 00:06: RTC can wake from S4
0.858102] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
0.858170] rtc0: alarms up to one day, 114 bytes nvram, hpet irqs
0.858183] cpuidle: using governor ladder
0.858186] cpuidle: using governor menu
0.858534] TCP cubic registered
0.858563] NET: Registered protocol family 10
0.859117] Mobile IPv6
0.859132] NET: Registered protocol family 17
0.859138] Registering the dns_resolver key type
0.859395] PM: Hibernation image not present or could not be loaded.
0.859452] registered taskstats version 1
0.861066] XENBUS: Device with no driver: device/vbd/768
0.861070] XENBUS: Device with no driver: device/vbd/5696
0.861073] XENBUS: Device with no driver: device/vif/0
0.861118] rtc_cmos 00:06: setting system clock to 2013-09-11 11:30:32 UTC (1378899032)
0.861143] Initializing network drop monitor service
0.862607] Freeing unused kernel memory: 576k freed
0.862790] Write protecting the kernel read-only data: 6144k
0.865465] Freeing unused kernel memory: 660k freed
0.868296] Freeing unused kernel memory: 680k freed
1.036736] udevd[48]: starting version 175
1.122845] SCSI subsystem initialized
1.138528] usbcore: registered new interface driver usbfs
1.138554] usbcore: registered new interface driver hub
1.159356] Initialising Xen virtual ethernet driver.
1.174589] usbcore: registered new device driver usb
1.175563] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
1.216841] libata version 3.00 loaded.
1.217472] ata_piix 0000:00:01.1: version 2.13
1.217661] ata_piix 0000:00:01.1: setting latency timer to 64
1.220286] uhci_hcd: USB Universal Host Controller Interface driver
1.237216] vbd vbd-5696: 19 xenbus_dev_probe on device/vbd/5696
1.238179] scsi0 : ata_piix
1.240812] scsi1 : ata_piix
1.240886] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0xc220 irq 14
1.240891] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0xc228 irq 15
1.241121] uhci_hcd 0000:00:01.2: setting latency timer to 64
1.241160] uhci_hcd 0000:00:01.2: UHCI Host Controller
1.241193] uhci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
1.241726] uhci_hcd 0000:00:01.2: irq 23, io base 0x0000c200
1.242243] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
1.242247] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
1.242251] usb usb1: Product: UHCI Host Controller
1.242254] usb usb1: Manufacturer: Linux 3.2.0-4-amd64 uhci_hcd
1.242257] usb usb1: SerialNumber: 0000:00:01.2
1.242431] hub 1-0:1.0: USB hub found
1.242439] hub 1-0:1.0: 2 ports detected
1.243584] blkfront: xvda: barrier: enabled
1.273565] xvda: xvda1 xvda2 xvda3
1.279111] FDC 0 is a S82078B
1.415010] ata2.01: ATAPI: QEMU DVD-ROM, 0.10.2, max UDMA/100
1.417738] ata2.01: configured for MWDMA2
1.420388] scsi 1:0:1:0: CD-ROM QEMU QEMU DVD-ROM 0.10 PQ: 0 ANSI: 5
1.446428] sr0: scsi3-mmc drive: 4x/4x xa/form2 tray
1.446437] cdrom: Uniform CD-ROM driver Revision: 3.20
1.446767] sr 1:0:1:0: Attached scsi CD-ROM sr0
1.452738] sr 1:0:1:0: Attached scsi generic sg0 type 5
1.552112] usb 1-2: new full-speed USB device number 2 using uhci_hcd
1.670580] device-mapper: uevent: version 1.0.3
1.670998] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: [email]dm-devel@redhat.com[/email]
1.756959] Refined TSC clocksource calibration: 2333.427 MHz.
1.838951] ISO 9660 Extensions: Microsoft Joliet Level 3
1.844605] ISO 9660 Extensions: RRIP_1991A
1.872640] aufs: module is from the staging directory, the quality is unknown, you have been warned.
1.875409] aufs 3.2-20130204
1.908488] loop: module loaded
2.029940] squashfs: version 4.0 (2009/01/31) Phillip Lougher
2.043799] usb 1-2: New USB device found, idVendor=0627, idProduct=0001
2.043804] usb 1-2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2.043807] usb 1-2: Product: QEMU USB Tablet
2.043810] usb 1-2: Manufacturer: QEMU 0.10.2
2.043813] usb 1-2: SerialNumber: 1
2.208421] input: QEMU 0.10.2 QEMU USB Tablet as /devices/pci0000:00/0000:00:01.2/usb1/1-2/1-2:1.0/input/input1
2.209212] generic-usb 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Pointer [QEMU 0.10.2 QEMU USB Tablet] on usb-0000:00:01.2-2/input0
2.209237] usbcore: registered new interface driver usbhid
2.209240] usbhid: USB HID core driver
10.591700] udevd[696]: starting version 175
11.010305] input: PC Speaker as /devices/platform/pcspkr/input/input2
11.051208] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
11.051216] ACPI: Power Button [PWRF]
11.051293] input: Sleep Button as /devices/LNXSYSTM:00/LNXSLPBN:00/input/input4
11.051298] ACPI: Sleep Button [SLPF]
11.214155] piix4_smbus 0000:00:01.3: SMBus base address uninitialized - upgrade BIOS or use force_addr=0xaddr
11.375030] parport_pc 00:0c: reported by Plug and Play ACPI
11.377415] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
11.519012] Error: Driver ‘pcspkr’ is already registered, aborting…
11.949568] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input5
16.310550] NET: Registered protocol family 8
16.310554] NET: Registered protocol family 20
19.817308] NET: Registered protocol family 15
19.852446] alg: No test for cipher_null (cipher_null-generic)
19.852494] alg: No test for ecb(cipher_null) (ecb-cipher_null)
19.852534] alg: No test for digest_null (digest_null-generic)
19.852574] alg: No test for compress_null (compress_null-generic)
19.957455] sha1_ssse3: Using SSSE3 optimized SHA-1 implementation
20.903211] Initializing XFRM netlink socket
21.689967] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input6
22.798649] Netfilter messages via NETLINK v0.30.
25.069946] Bluetooth: Core ver 2.16
25.069973] NET: Registered protocol family 31
25.069976] Bluetooth: HCI device and connection manager initialized
25.069980] Bluetooth: HCI socket layer initialized
25.069983] Bluetooth: L2CAP socket layer initialized
25.070220] Bluetooth: SCO socket layer initialized
25.099367] Bluetooth: RFCOMM TTY layer initialized
25.099373] Bluetooth: RFCOMM socket layer initialized
25.099376] Bluetooth: RFCOMM ver 1.11
25.116738] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
25.116742] Bluetooth: BNEP filters: protocol multicast
25.234586] lp0: using parport0 (interrupt-driven).
25.244124] ppdev: user-space parallel port driver
28.599683] ip_tables: © 2000-2006 Netfilter Core Team
28.704076] eth0: no IPv6 routers present
