Pascom Client v61 BETA
pascom Client v61 BETA (61.D896)
German Overview
  • Im Betriebssystem konfigurierte Http-Proxies werden nun beim Update berücksichtigt
  • Automatische Updates können nun in den erweiterten Einstellungen deaktiviert werden
  • Filtern der Kontaktliste ist jetzt zuverlässiger, es werden keine Zeichen mehr doppelt eingegeben
  • Android: Eingehende Anrufe werden nun in einem Optimierten Bildschirm dargestellt um Fehlbedienungen zu vermeiden
  • Die Freisprech-Funktion ist nun zuverlässiger “laut”
English Overview
  • Proxy Servers configured at OS level are now used for fetching Updates
  • Automatic Updates can now be disabled in Settings
  • Contact list filtering is more reliable, character duplication is avoided
  • Android: Incoming calls are now displayed in an optimized screen to avoid usage problems
  • Hands-Free function increases gain more reliably
Tickets
  • [CL-94] - Proper http proxy support in pascom Client
  • [CL-370] - Weird behaviour if recording stops
  • [CL-534] - Disable menu buttons if we already are in the correct view
  • [CL-564] - Create a switch in Advanced Settings to change “Call Mode” on android
  • [CL-686] - Disable automatic updates via “Advanced Settings”
  • [CL-693] - Improve logging of client proxy
  • [CL-729] - Introduce chat inline notifications
  • [CL-839] - Disable proxymity sensor when handsfree speaker is active
  • [CL-879] - Correctly handle pushed messages on iOS and Android
  • [CL-894] - Show group chat message origin in android and ios notification
  • [CL-909] - Hide away (yellow) user state on pascom 19
  • [CL-950] - Save outgoing message immediately to the database
  • [CL-971] - Prohibit to open empty settings on mobile during pairing process
  • [CL-980] - pascom Client looses characters when typing into the roster filter
  • [CL-994] - Bring back redial function on dial button
  • [CL-998] - Resolve caller number of local (DATEV) phone book in pickup notifications
  • [CL-1004] - Do not resynchronize on every server version change
  • [CL-1006] - Implement a special incoming call screen on android
  • [CL-1018] - Check for microphone access is broken on windows
  • [CL-1019] - Re-Implement alert() / request attention feature in desktop client
  • [CL-1031] - Client crashes on shutdown on macOS in pjsip libDestroy()
  • [CL-1040] - Crash in WinnotificationController::findToastFromHistory()
  • [CL-1044] - TAPI doesn’t immediately use changed preferred device
  • [CL-1047] - You can’t use Escape to close the settings screen
  • [CL-1068] - Hover for outlook settings button ‘add’ vanishes text
  • [CL-1074] - Change status text after switching focus
  • [CL-1079] - An active redirection is not shown in the roster anymore
  • [CL-1080] - Don’t change position of filtered roster (sorted by name) after presence change
  • [CL-1081] - Crash in MdTonePlayer::stop() on android
  • [CL-1084] - Back button does not work correctly on android
  • [CL-1086] - User chat is opened instead of group chat when clicking on a group notification
  • [CL-1089] - iOS shows sip connection error message after wakeup
  • [CL-1090] - Handsfree speaker is not correctly handled if gain increase is disabled
Bei mir passiert an meinem Honor 7c nichts, wenn ich auf den Lautsprecher wechsele.
LG THOMAS
Das gleiche ist mit meinem Nokia 8. Auch da wechselt er nicht ins Freisprechen. Es passiert nichts.
Hallo!
Also, mit der Beta ist es nur noch möglich bei einem eingehenden Anruf diesen abzulehnen, oder anzunehmen. Ich möchte aber, so wie es vorher funktionierte (wenn ich unterwegs bin), vor dem Annehmen des Gesprächs wissen, ob die Kollegen im Büro alle belegt sind, bevor ich ran gehe. Ich komme aber während eines eingehenden Anrufs nicht in die Mitgliederliste / die App.
Bitte, bitte wieder einbauen. Danke!
THOMAS
Auch um mal positives Feedback weiter zu geben :smiley: :
Ich verwende hier am Smartphone zwar noch die letzte stable v60.R872 aber auch/schon hier funktioniert auf meinem Nokia 7.2 mit Android (One) v9 (mit Jänner Patch) Freisprechen wie es soll, auch die Lautstärke ist für mich OK. Die angesprochenen Probleme liegen dann wahrscheinlich an den unterschiedlichen Hardwarehersteller-Modifikationen und/oder Android-Versionen.
Btw. auch Bluetooth/Kfz-Integration funktioniert bei mir recht gut seit den Updates der letzten Versionen bezüglich Android Connection Services.
Danke dafür,
Robert
Also, die aktuelle Beta ist kaum brauchbar auf meinem Honor 7c, wie ich nach heutiger intensiver Nutzung leider feststellen musste.
Im Auto konnte ich mehrfach Gespräche nicht annehmen, weder an der FSE noch über die App. Ablehnen funktionierte ebenfalls nicht, der Anruf klingelte über die Auto Lautsprecher, bis ich die Bluetooth Verbindung gekappt habe.
Bei ausgehenden Calls sagte der Client, das der Softclient keine Verbindung habe, neu verbinden ging dann, kam auch sehr oft vor.
Werden die Betas von Pascom vor dem ausrollen nicht getestet?
LG Thomas
Du glaubst doch nicht wirklich das die jedes Handy testen können?
Zur Ehrrettung von Pascom habe schon immer die Beta drauf und bis auf ein paar kleine Probleme ging bei mir immer alles.
Und ich habe auch nicht irgendwelche Teuren Handy sondern schon immer Chinahandys. Aber ganz ehrlich ein Honor 7c ist ja auch nicht wirklich das aktuellste.
Da gebe ich dir recht, in der vorherigen App Version war halt noch alles schick un ich war gestern ziemlich genervt , deswegen auch meine Reaktion.
danke für euer Feedback. Zum Thema Prozess / Testen: Bevor eine neue Beta öffentlich wird, testen wir diese zuerst intern bei uns im Produktivbetrieb. Ungetestete Rollouts gibt es bei uns nicht. Der Play-Store listet uns für die aktuelle pascom App aber über 9200 verschiedene Gerätemodelle auf - da können wir leider tatsächlich nicht alles testen.
Gerade deswegen gibt es ja die Beta der App, damit wir in der Lage sind die App in mehr Umgebungen zu testen und mehr Fehler zu finden bevor alle betroffen sind :wink:
Thema Freisprechen: Wir werden uns das Thema ansehen, Intern sind keine Probleme bekannt - das sind aber hauptsächlich Samsung Geräte.
Thema Rufannahme im Auto: Welches Fahrzeug? Koppelung rein über Bluetooth oder Android Auto? Welche Android Version ist auf dem Telefon installiert?
Thema “Softclient hat keine Verbindung”: Wie häufig kommt das vor? Die erste interne Beta zeigte auch häufig ein “Softphone hat keine SIP-Verbindung” nach dem aufwachen der App. Wir sind aber der Meinung das gefixt zu haben. Ist noch jemand von diesem Problem betroffen?
Thema “Neuer Anruf-Bildschirm”: Wir haben diesen Screen spezifisch gebaut um die häufigen Fehlbedienungen abzustellen, wenn man das Gerät aus der Hosentasche zieht. Deswegen auch die Konzentration auf die wesentlichsten Funktionen - die Entscheidung “Anruf annehmen oder Ablehnen” ist ja im Allgemeinen zeitlich recht begrenzt.
Ist sonst noch jemand darauf angewiesen während eines eigenenden Anrufs auf den restlichen Client zugreifen zu müssen?
Zwei verschiedene Fahrzeuge. Skoda Octavia und Renault Traffic. Auf beiden gab es diese Probleme in der vorherigen App Version nur ab und an, nun aber ziemlich oft. Das ganze passiert über Bluetooth. Android 8.0.0 ist auf dem betroffenden Gerät installiert.
Bei mir gestern fast bei jedem Anruf, den ich ausgehend über das Rufjournal tätigen wollte. Wegen dem Rufannahme / ablehen Problem, musste ich viele Kunden zurückrufen, da ich das Gespräch ja nicht annehmen konnte.
Ich habe nicht einmal mit dem alten Sceen versehentlich aufgelegt, oder abgenommen, daher verstehe ich nicht, wie das passieren kann. Ich wäre wirklich “traurig”, wenn die alte Funktion nicht mehr möglich ist…, daher bitte alle sagen, das die alte Funktion benötigt wird :wink:
pascom Client v61 BETA (61.D897)
German Overview
  • Android: Die App wacht jetzt wieder zuverlässiger auf bei eingehenden Anrufen
  • Android: Umschalten auf Lautsprecher funktioniert jetzt auch auf Geräten mit Connection Service API
  • Android: Der Schalter um die Connection Service API ein oder auszuschalten ist jetzt wieder in den Settings
  • pascom19: Die Reihenfolge von Nachrichten im Chatverlauf konnte kurzzeitig vertauscht werden, wenn viele Nachrichten hintereinander gesendet wurden
English Overview
  • Android: The app now wakes up more reliably on incoming calls
  • Android: Switching to handsfree now works on devices using Connection Service API
  • Android: The switch for enabling/disabling the use of Connection Service API is now available again in Advanced Settings.
  • pascom19: The order of messages in the chat history could be wrong for a short time if a lot of messages are sent in a short timeframe
Tickets
  • CL-928 Switching to handsfree speaker doesn’t work
  • CL-950 Save outgoing message immediately to the database
  • CL-1102 android pascom Client sometimes does not wake up to calls
  • CL-1106 Use Connection Service Switch is missing from the Advanced Settings on android
pascom Client v61 BETA (61.D902) - iOS / Android
German Overview
  • Android: Weitere Absturzursachen beim in-den-hintergrund-legen der Anwendung behoben
  • Android / iOS: Anruflautstärke (Lautsprecher Gain) erhöht
English Overview
  • Android: Fixed another crash when putting the app into background
  • Android / iOS: Increased speaker volume / gain for calls
Tickets
  • [CL-1104] - Gain increase doesn’t work on certain ios devices
Hallo @jlorenz
Ich bin wieder online :slight_smile: Ich habe seit ca. Release 60 wieder Probleme mit der App, Im Moment ist die 61.D897 installiert und folgende Themen ergeben sich:
  • Push funktioniert eigentlich nicht mehr (in den Release Notes habe ich einen Hinweis gesehen, hat aber keine Besserung gebracht)
  • Immer wenn ich einen Anruf tätigen will steht neuerdings oben wieder keine SIP-Verbindung, neu Verbinden (unabhängig von Netztyp oder Qualität), das hatte ich so lange nicht mehr.
Ausserdem zur Connection-Service Integration:
  • Android lässt die Wahl einer VoIP App als Standard-Telefonie App zu.
  • Die pascom App wird hier aber nicht angezeigt, ich nehme an dass eine einfache Integration hier möglich ist über eine Code-Option.
Hallo @voipstack,
danke schonmal für das Feedback.
  • Push funktioniert nicht: D. h. das Gerät wacht bei eingehendne Anrufen nicht auf? Hier bitte die aktuelle Beta v61.D902 installieren und nochmals testen. Es gab mit dem Connection-Service hier ein paar Glitches / Race Conditions die aber mittlerweile alle ausgeräumt sein sollten.
  • SIP-Verbindung: Das haben bereits mehrere Leute gemeldet, ist aber nur schwer reproduzierbar. Wir sind dran.
  • Android-App als Default-Dialer Applikation: Ist in Arbeit, kommt vorraussichtlich mit v62.
Hi!
Nun funktioniert der Lautsprecher! Danke!
THOMAS
Hallo @jlorenz
Danke. Werde ich testen. Unabhägnig von der Android App haben wir übrigens festgestellt, dass der Client sich vermehrt aufhängt auf Windows (Release v60+ mit Pascom 19.xx).
pascom Client v61 BETA (61.D905)
German Overview
  • Lautstärke des Softphones auf allen Plattformen angehoben
  • Echo-Cancelling (AEC) bei Anrufen und Freisprechen verbessert
  • Automatische-Gain-Anpassung (AGC) abgeschaltet
  • SIP-Re-Registrierung auf Mobilgeräten beschleunigt
English Overview
  • Increased softphone gain on all platforms
  • Improved acoustic echo cancellation (AEC) while in call and also while in handsfree mode
  • Disabled automatic gain control (AGC)
  • SIP re-registration is faster on mobile devices
Tickets
  • [CL-1089] - Mobile apps shows sip connection error message after wakeup
  • [CL-1120] - Improve echo cancellation and audio quality in pascom Client
Sind im Client (Windows) automatische Updates per Default deaktiviert?
Dieses musste ich nach dem letzten Update wieder manuell aktiveren (Erweitert -> _Enable automatic updates).
Oder es wird nur falsch dargestellt, im Log steht direkt nach der Installation (also erster Start):
Auto Update initialized. Scheduling next check in "00:04:35"
Rapha
Hallo @rapha,
Automatische Updates sind standardmäßig aktiviert. Ein rot gefärbter Schalter bedeutet “ein”. Ist der Schalter nach einem Neustart der App wieder aus. Wenn ja, dann wäre das ein Bug… :wink:
