Pascom Client v50 BETA
pascom Client v50 BETA (50.D294)
German Overview
  • Alle Benachrichtungen im Desktop-Client wurden neu gestaltet und verbessert
  • Viele Absturzprobleme auf Android behoben
  • Schnellerer Client-Start durch beschleunigtes Avatar-Rendering
  • Bei wartenden Anrufern in einem Team werden nun die Labels des Anrufs angezeigt
English Overview
  • Re-Worked and improved all Notifications on desktop clients
  • Resolved many crash problems on Android
  • Client startup is now faster due to improved avatar rendering
  • Waiting calls in a team now show labels
Tickets
  • [CL-5] - Right click in roster causes strange scrolling
  • [CL-127] - Upgrade Client to Qt 5.12
  • [CL-151] - Show incoming file transfer requests also as toast
  • [CL-358] - Close open fax dialog if connection interrupts
  • [CL-382] - Can’t scroll via mouse wheel on non-primary screen
  • [CL-435] - Improve layout for “Edit” button of phone book entry in call details
  • [CL-404] - Improve custom notifications in client
  • [CL-444] - Show labels in queue waiting calls
  • [CL-464] - Autofocus in LoginPane
  • [CL-465] - Use OpenGL fragmentShader for drawing avatar images
  • [CL-470] - Deactivate call action buttons if device doesn’t support remote control
  • [CL-471] - Exception on registerSoftphone after selecting softphone as preferred device
  • [CL-479] - Mark text if you tab to input filed in login mask
  • [CL-475] - Phonebook entry layout broken after incoming call on mobile client
  • [CL-476] - Roster button schedules callback notification instead of calling destination of call forwarding
  • [CL-483] - Client Crash when displaying pickup notifications
  • [CL-487] - Mobile pairing glitches
  • [CL-494] - Client Freezes with ANGLE in an Windows Server 2012R2 Terminal Server Environment
  • [CL-501] - Client crashes on Windows and OSX if you initiate a call
  • [CL-509] - Copy from phonebook is broken
  • [CL-522] - copy from a chat search result cell copies the wrong text
  • [CL-525] - Can’t show more details to missed call notification with labels
  • [CL-527] - Inconsistent and too low call volume on android
  • [CL-529] - Broken Menubar Layout for iPhone X devices with Qt 5.12
  • [CL-530] - No default avatar shown in team overview
  • [CL-537] - Android client sometimes crashes during first startup
Das neue Layout der Benachrichtigungen ist sehr gut geworden! Der Annahme Button ist nun mehr als ausreichend dimensioniert.
mal eine Frage zu dem Punkt Deactivate call action buttons if device doesn’t support remote control
Wie wird denn entschieden ob ein Endgerät gesteuert werden kann? Mitel SIP Dect z.B. kann sehr wohl über den Client verbinden. Zwar nich über direkte Steuerung von dem Endgerät, aber wenigstens indirekt.(Es kommt ein 2.Anruf, den man am Endgerät nochmal annehmen muss) Das wird ja aber Version 50 nicht mehr funktionieren.
GruĂź Jonas Plaum
50.R318_5cd8b40 mit wichtigen Änderungen oder nur Bugfixes?
Hallo @sbr,
die Änderungen in Version 50 des pascom Clients kannst du wie immer in den Release Notes nachlesen.
GrĂĽĂźe,
@jlorenz
Wann erscheint denn die kommende Version? Es gibt ja noch immer diverse Probleme, wie:
  • Icons in der App verschwinden gelegentlich
  • Wenn am PC das Gespräch angenommen/abgelehnt wurde, klingelt das Smartphone noch 1-3 Sekunden weiter bzw. verzögert (obwohl keine Verzögerung eingestellt wurde)
  • Bei Android funktioniert das Mikro von kabelgebundenen Headsets nicht, wenn das Display gesperrt ist
  • Die App startet manchmal noch immer zu langsam (bis zu 6 Sekunden)
  • Manchmal hat die App keine SIP Verbindung und hat diese erst nach einem Neustart der App wieder
  • Der Näherungssensor funktioniert nicht immer (mit Nova Launcher aktuell gar nicht!) und dadurch wird das Display nicht gesperrt. Folge ist: Mit dem Ohr wird die Schnellstartleiste bedient, was oft zum Flugmodus fĂĽhrt.
