Pascom Client v49 BETA
pascom Client v49 BETA (49.D236)
German Overview
  • Systemanrufe können nun aus dem Journal gefiltert werden
  • Bei eingehenden Chat-Nachrichten wird nun ein Ton abgespielt
  • Beim pascom Softphone kann nun eine Verstärkung für Mikrofon und Lautsprecher konfiguriert werden
English Overview
  • System calls can now be filtered from the journal
  • The client now plays a sound when receiving an incoming chat message
  • A custom speaker and/or microphone gain can be configured for pascom softphone
Tickets
  • [CL-14] - Switches changing color in client settings
  • [CL-38] - Scroll loop in client journal
  • [CL-100] - Save Settings (FollowMe) on pressing Home-Button
  • [CL-281] - Chat room glitches
  • [CL-299] - Simplify login forms for pascom.cloud users
  • [CL-326] - Play a sound when receiving an incoming chat message
  • [CL-345] - Improve tabbing through settings
  • [CL-366] - Bright context menu in dark theme
  • [CL-390] - Call volume is still to low on certain mobile devices
  • [CL-395] - Pickup call clicking on phone icon
  • [CL-396] - Preserve entered mobile number if the app goes to sleep
  • [CL-401] - Remove deprecated logging window and model
  • [CL-402] - Select dark theme automatically if the main theme of windows is dark
  • [CL-405] - Callback notification shown twice
  • [CL-415] - Headset not selected as speaker
  • [CL-419] - Enhance “offline contact filter” - also filter out user that have a paired mobile but an offline phone presence
  • [CL-422] - Introduce a switch to filter out system calls from journal
  • [CL-442] - Missing activity after voicemailbox answers
  • [CL-446] - Notifications has incorrect position on windows
  • [CL-452] - pascom Client does not recognize eSim on a iPhone Xr/Xs
  • [CL-453] - Phonecall duration is incorrect
  • [CL-455] - Softphone not reacting on rejected call
  • [CL-473] - Pairing not working
pascom Client v49 BETA (49.D240)
German Overview
  • Crash beim Abspielen des Benachrichtigungstons auf macOS behoben
  • Bessere Behandlung von Anruf-Audio auf Android-Geräten
English Overview
  • Fixed a crash when playing a notification tone on macOS
  • Improved Handling of Call Audio on Android devices
Mit der aktuellen Beta (49.R265) funktioniert DTMF nicht, wenn ich den Clienten per OSX nutze. Ich erhalte immer die Info, dass meine Eingabe nicht erkannt wurde.
Hallo @hazington,
das lässt sich so spontan nicht reproduzieren - hier klappt das DTMF unter macOS 10.14. Bist du sicher das es an der Version und nicht evtl. an einer anderen Konfiguration liegt?
Woran könnte es denn theoretisch liegen? Ich habe vorhin den Microsoft-Support anrufen müssen und DTMF wurde per Pascom Client auf OSX nicht erkannt. Ich teste mal eben das ganze per Android Client.
Dort wird es auch nicht erkannt. Das muss dann eine andere Ursache haben.
Edit: Ich werde den Support-Bereich kontaktieren und schauen, was die dazu sagen. Ich danke dir zunächst für das Testen!
