pascom Client v100 BETA (100.R3240, Windows/macOS)
German
- macOS/Windows: Unterstützung für Yealink Headsets
- Windows: Datev Integration hat unter bestimmten Umständen eine ungültige CallID übermittelt
- Diverse kleinere Bugfixes
Anleitung zur Teilnahme am Beta Test.
English
- macOS/Windows: Support for Yealink Headsets
- Windows: Datev integration sometimes transmitted an invalid callid
- Various smaller bugfixes
How to participate in the beta?
Tickets
- [CL-3173] Implement Yealink Headset integration
- [CL-3193] Datev newJournal is invoked with a 0 callid
- [CL-3421] Remove email notification field from client fax form
- [CL-3515] Fetch contact infos if a Roster Item has no name / avatar after adding
- [CL-3545] pascom Client sometimes needs a very long time to reconnect and login after wakeup
- [CL-3549] Avatar selection does not handle exif rotation tags
- [CL-3564] Android Navigation Bar appears when we click anywhere on screen
- [CL-3573] Update to bowser client version doesn’t work
- [CL-3575] Click on phonebook cell button broken
- [CL-3600] Client plays no ringtone, if default tone is set to silent but “use different ringtones” is enabled
