Hello,
My hard drive is full. Can you tell me how can I clean it.
Hello,
first of all (if the appliance is still accessable) you have to figure out what consumes all the diskspace. To get this information you have to log on to the mobydick via ssh (@ windows with putty(.org) for example) as admin user.
After this please follow this steps:
switch to root user with “sudo su”
switch to /var directory (in most cases there are the disk consuming files) with “cd /var”
gather information which folders consume most diskspace with “df -h --max-depth=1”
go down the sub-directorys with “cd ./subfoldername”
when you have found the issue, make shure it is not needed bevor you delete it:
.log files can be deleted, but just the not currently used ones (will have .log.1 or .log.2.gz and so on)
the currently used logfiles can be cleared with “echo ‘’ > filename” (content is empty afterwards)
for all other files post them here pls if you are not sure if they can be deleted withoud bad impact
possible common scenarios are monitor/voicemail/fax/mail files in /var/spool/
if some databasefiles grow to much it could be possible that you are under attack (wan accessable open sip port) or some other problem accurs, that should be investigated by our support team
If you wanna extend the disk space (for a virtual maschine for example) you have to gather space in the backup partition at least and create a fullbackup. afterwards increase the virtual disk and install the appliance new with the created appliance.iso (you will have to download it first to mount it). If you do so, please make sure the fullbackup finished without errors.
Best Regards,
Hello Steve,
Thank you for your help.
Here are the files, could you take a look please.
total 73090
drwxr-xr-x 35 root root 4096 Jun 15 06:25 .
drwxr-xr-x 31 root root 4096 Dec 7 2015 …
-rw-r–r-- 1 root root 0 Dec 31 23:25 alternatives.log
-rw-r–r-- 1 root root 19478 Nov 16 2015 alternatives.log.1
drwxr-x— 2 root adm 4096 Jun 12 06:25 apache2
drwxr-xr-x 2 root root 4096 May 1 06:25 apt
drwxr-xr-x 5 asterisk asterisk 4096 Mar 30 04:38 asterisk
drwxr-xr-x 2 root root 3 Aug 3 2011 atop
-rw-r–r-- 1 root root 181560 Jun 15 09:35 atop.log
-rw-r–r-- 1 root root 1162207 Jun 15 06:15 atop.log.1
-rw-r–r-- 1 root root 2918498 Jun 6 06:15 atop.log.10
-rw-r–r-- 1 root root 1227925 Jun 5 06:25 atop.log.11
-rw-r–r-- 1 root root 2847433 Jun 4 06:15 atop.log.12
-rw-r–r-- 1 root root 3439067 Jun 3 06:25 atop.log.13
-rw-r–r-- 1 root root 2999316 Jun 2 06:15 atop.log.14
-rw-r–r-- 1 root root 1161527 Jun 14 06:15 atop.log.2
-rw-r–r-- 1 root root 961579 Jun 13 06:15 atop.log.3
-rw-r–r-- 1 root root 1220922 Jun 12 06:25 atop.log.4
-rw-r–r-- 1 root root 1503615 Jun 11 06:15 atop.log.5
-rw-r–r-- 1 root root 1194501 Jun 10 06:15 atop.log.6
-rw-r–r-- 1 root root 1261850 Jun 9 06:15 atop.log.7
-rw-r–r-- 1 root root 1372711 Jun 8 06:25 atop.log.8
-rw-r–r-- 1 root root 2036401 Jun 7 06:25 atop.log.9
-rw-r----- 1 root adm 8574784 Jun 15 09:44 auth.log
-rw-r----- 1 root adm 23419526 Jun 12 06:25 auth.log.1
-rw-r----- 1 root adm 595136 Jun 5 06:25 auth.log.2.gz
-rw-r----- 1 root adm 960355 May 29 06:25 auth.log.3.gz
-rw-r----- 1 root adm 1520563 May 22 06:25 auth.log.4.gz
-rw-r–r-- 1 root root 63253 Jan 21 11:16 backup.log
-rw-r----- 1 root adm 31 Nov 16 2015 boot
-rw-r–r-- 1 root root 40553 Nov 16 2015 bootstrap.log
-rw-rw---- 1 root utmp 0 Jun 1 06:25 btmp
-rw-rw---- 1 root utmp 0 May 1 06:25 btmp.1
drwxr-xr-x 2 root root 29 Nov 16 2015 corosync
drwxr-xr-x 2 root root 4096 Dec 8 2015 cups
-rw-r----- 1 root adm 74652 Jun 15 09:18 daemon.log
-rw-r----- 1 root adm 175631 Jun 12 06:13 daemon.log.1
-rw-r----- 1 root adm 8488 Jun 5 05:58 daemon.log.2.gz
-rw-r----- 1 root adm 7560 May 29 06:23 daemon.log.3.gz
-rw-r----- 1 root adm 8897 May 22 06:11 daemon.log.4.gz
-rw-r----- 1 root adm 0 May 8 06:25 debug
-rw-r----- 1 root adm 60513 May 2 06:51 debug.1
-rw-r----- 1 root adm 7457 Apr 30 07:54 debug.2.gz
-rw-r----- 1 root adm 14900 Apr 18 11:21 debug.3.gz
-rw-r----- 1 root adm 7456 Apr 15 12:54 debug.4.gz
-rw-r----- 1 root adm 95466 May 2 06:51 dmesg
-rw-r----- 1 root adm 95341 Apr 30 07:54 dmesg.0
-rw-r----- 1 root adm 17839 Apr 18 11:21 dmesg.1.gz
-rw-r----- 1 root adm 17884 Apr 18 11:03 dmesg.2.gz
-rw-r----- 1 root adm 17878 Apr 15 12:54 dmesg.3.gz
-rw-r----- 1 root adm 17948 Mar 27 03:40 dmesg.4.gz
-rw-r–r-- 1 root root 0 May 1 06:25 dpkg.log
-rw-r–r-- 1 root root 1312 Apr 4 10:03 dpkg.log.1
-rw-r–r-- 1 root root 213 Mar 9 01:20 dpkg.log.2.gz
-rw-r–r-- 1 root root 178 Mar 8 05:43 dpkg.log.3.gz
-rw-r–r-- 1 root root 400 Jan 18 09:16 dpkg.log.4.gz
-rw-r–r-- 1 root root 31895 Dec 7 2015 dpkg.log.5.gz
-rw-r–r-- 1 root root 946 Jun 14 23:47 exd.log
-rw-r–r-- 1 root root 2975 Jun 12 06:25 exd.log.1
-rw-r–r-- 1 root root 2476 Jun 5 06:25 exd.log.2
-rw-r–r-- 1 root root 2476 May 29 06:25 exd.log.3
-rw-r–r-- 1 root root 2476 May 22 06:25 exd.log.4
-rw-r–r-- 1 root root 2476 May 15 06:25 exd.log.5
drwxr-s— 2 Debian-exim adm 4096 Jun 15 06:25 exim4
-rw-r–r-- 1 root root 32032 Mar 8 05:43 faillog
-rw-r–r-- 1 root root 638 Nov 16 2015 fontconfig.log
drwxr-xr-x 2 root root 4096 Nov 16 2015 fsck
drwxr-xr-x 2 root root 3 Dec 12 2010 hylafax
drwxr-xr-x 3 root root 54 Nov 16 2015 iaxmodem
drwxr-s–x 4 nagios adm 4096 Jun 15 00:00 icinga
drwx------ 2 root root 3 Sep 13 2009 iptraf
drwxr-xr-x 2 root root 61440 Jun 14 23:47 jobs
-rw-r----- 1 root adm 13198 Jun 15 09:42 kern.log
-rw-r----- 1 root adm 2025 Jun 12 01:50 kern.log.1
-rw-r----- 1 root adm 96 Jun 4 06:25 kern.log.2.gz
-rw-r----- 1 root adm 97 Jun 3 14:56 kern.log.3.gz
-rw-r----- 1 root adm 3739 May 16 23:53 kern.log.4.gz
-rw-rw-r-- 1 root utmp 292292 Jun 15 08:55 lastlog
-rw-r----- 1 root adm 0 Nov 16 2015 lpr.log
-rw-r----- 1 root adm 2142 Jun 15 01:12 mail.err
-rw-r----- 1 root adm 528 Jun 11 21:24 mail.err.1
-rw-r----- 1 root adm 272 Jun 10 23:54 mail.err.2.gz
-rw-r----- 1 root adm 284582 Feb 10 19:56 mail.err.3.gz
-rw-r----- 1 root adm 42352 Feb 9 05:55 mail.err.4.gz
-rw-r----- 1 root adm 2142 Jun 15 01:12 mail.info
-rw-r----- 1 root adm 528 Jun 11 21:24 mail.info.1
-rw-r----- 1 root adm 272 Jun 10 23:54 mail.info.2.gz
-rw-r----- 1 root adm 284582 Feb 10 19:56 mail.info.3.gz
-rw-r----- 1 root adm 42352 Feb 9 05:55 mail.info.4.gz
-rw-r----- 1 root adm 2142 Jun 15 01:12 mail.log
-rw-r----- 1 root adm 528 Jun 11 21:24 mail.log.1
-rw-r----- 1 root adm 272 Jun 10 23:54 mail.log.2.gz
-rw-r----- 1 root adm 284582 Feb 10 19:56 mail.log.3.gz
-rw-r----- 1 root adm 42352 Feb 9 05:55 mail.log.4.gz
-rw-r----- 1 root adm 2142 Jun 15 01:12 mail.warn
-rw-r----- 1 root adm 528 Jun 11 21:24 mail.warn.1
-rw-r----- 1 root adm 272 Jun 10 23:54 mail.warn.2.gz
-rw-r----- 1 root adm 284582 Feb 10 19:56 mail.warn.3.gz
-rw-r----- 1 root adm 42352 Feb 9 05:55 mail.warn.4.gz
-rw-r–r-- 1 root root 0 Nov 16 2015 memcached.log
-rw-r----- 1 root adm 2933868 Jun 15 09:42 messages
-rw-r----- 1 root adm 1933904 Jun 12 06:25 messages.1
-rw-r----- 1 root adm 2998 Jun 5 06:25 messages.2.gz
-rw-r----- 1 root adm 2665 May 29 06:25 messages.3.gz
-rw-r----- 1 root adm 7012 May 22 06:25 messages.4.gz
drwxrwx— 4 www-data nogroup 4096 Dec 17 18:22 mobydick
drwxr-xr-x 2 root root 4096 Apr 16 06:25 newrelic
drwxr-xr-x 2 root root 67 Nov 16 2015 news
drwxr-xr-x 2 ntp ntp 4096 Jun 15 06:25 ntpstats
drwxrwxr-t 2 root postgres 4096 Jun 12 06:25 postgresql
drwxr-x— 2 privoxy adm 4096 Jun 12 06:25 privoxy
drwxr-xr-x 2 root root 3 Feb 22 2015 samba
-rw-r–r-- 1 root root 20967 May 2 06:51 setup.log
drwxr-xr-x 2 stunnel4 stunnel4 34 Nov 16 2015 stunnel4
-rw-r----- 1 root adm 158963 Jun 15 09:42 syslog
-rw-r----- 1 root adm 1158935 Jun 15 06:25 syslog.1
-rw-r----- 1 root adm 77765 Jun 14 06:25 syslog.2.gz
-rw-r----- 1 root adm 44881 Jun 13 06:25 syslog.3.gz
-rw-r----- 1 root adm 53513 Jun 12 06:25 syslog.4.gz
-rw-r----- 1 root adm 78821 Jun 11 06:25 syslog.5.gz
-rw-r----- 1 root adm 17459 Jun 10 06:25 syslog.6.gz
-rw-r----- 1 root adm 6159 Jun 9 06:25 syslog.7.gz
drwxr-xr-x 2 root root 3 Jun 29 2015 unattended-upgrades
-rw-r----- 1 root adm 2919998 Jun 15 09:38 user.log
-rw-r----- 1 root adm 1930484 Jun 12 06:24 user.log.1
-rw-r----- 1 root adm 2767 Jun 5 05:51 user.log.2.gz
-rw-r----- 1 root adm 2512 May 29 05:51 user.log.3.gz
-rw-r----- 1 root adm 2715 May 22 05:51 user.log.4.gz
-rw-rw-r-- 1 root utmp 1152 Jun 15 08:55 wtmp
-rw-rw-r-- 1 root utmp 9984 May 2 06:51 wtmp.1
lrwxrwxrwx 1 root root 15 Jan 12 09:24 xmppd -> /var/xmppd/logs
lrwxrwxrwx 1 root root 23 Nov 16 2015 zend -> /usr/local/zend/var/log
Hello,
please always use the -h parameter additionally, for easier reading of the file sizes.
If you don’t need past logs you can run “rm /var/log/.1" and "rm /var/log/.gz”.
