wir mussten auf einer unserer Anlagen ein Backup aufspielen. Da diese dadurch auf die alte Firmware zurückgesetzt wurde, wollten wir ein Update von der 7.08.05 auf die 7.11.02 machen. Es erscheinen beim Update folgende Fehlermeldungen:
Cleaning apt cache...
Installing package md-lic ...
2016/03/08 22:20:07 [main] [INFO]: Updater Command: install
2016/03/08 22:20:07 [main] [INFO]: Executing: /usr/bin/perl /usr/lib/exdjob/pl700010.pl 62
2016/03/08 22:20:07 [main] [INFO]: Command: install
2016/03/08 22:20:07 [main] [INFO]: Download and install package
2016/03/08 22:20:07 [main] [INFO]: Executing: apt-get -y --force-yes install 'md-lic'
2016/03/08 22:20:07 [main] [INFO]: Reading package lists...
2016/03/08 22:20:07 [main] [INFO]: Building dependency tree...
2016/03/08 22:20:07 [main] [INFO]: Reading state information...
2016/03/08 22:20:07 [main] [INFO]: You might want to run 'apt-get -f install' to correct these:
2016/03/08 22:20:07 [main] [INFO]: The following packages have unmet dependencies:
2016/03/08 22:20:07 [main] [INFO]: tzdata-java : Depends: tzdata (= 2014h-0squeeze1) but 2015d-0+deb6u1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
2016/03/08 22:20:07 [main] [ERROR]: command failed
State: 4 = Error
Installation of md-lic failed (err:1)
Installing package md-cmd ...
2016/03/08 22:20:12 [main] [INFO]: Updater Command: install
2016/03/08 22:20:12 [main] [INFO]: Executing: /usr/bin/perl /usr/lib/exdjob/pl700010.pl 63
2016/03/08 22:20:12 [main] [INFO]: Command: install
2016/03/08 22:20:12 [main] [INFO]: Download and install package
2016/03/08 22:20:12 [main] [INFO]: Executing: apt-get -y --force-yes install 'md-cmd'
2016/03/08 22:20:12 [main] [INFO]: Reading package lists...
2016/03/08 22:20:12 [main] [INFO]: Building dependency tree...
2016/03/08 22:20:12 [main] [INFO]: Reading state information...
2016/03/08 22:20:12 [main] [INFO]: You might want to run 'apt-get -f install' to correct these:
2016/03/08 22:20:12 [main] [INFO]: The following packages have unmet dependencies:
2016/03/08 22:20:12 [main] [INFO]: tzdata-java : Depends: tzdata (= 2014h-0squeeze1) but 2015d-0+deb6u1 is to be installed
2016/03/08 22:20:12 [main] [ERROR]: command failed
State: 4 = Error
Installation of md-cmd failed (err:1)
Installing package md-jasperreports ...
2016/03/08 22:20:16 [main] [INFO]: Updater Command: install
2016/03/08 22:20:16 [main] [INFO]: Executing: /usr/bin/perl /usr/lib/exdjob/pl700010.pl 64
2016/03/08 22:20:17 [main] [INFO]: Command: install
2016/03/08 22:20:17 [main] [INFO]: Download and install package
2016/03/08 22:20:17 [main] [INFO]: Executing: apt-get -y --force-yes install 'md-jasperreports'
2016/03/08 22:20:17 [main] [INFO]: Reading package lists...
2016/03/08 22:20:17 [main] [INFO]: Building dependency tree...
2016/03/08 22:20:17 [main] [INFO]: Reading state information...
2016/03/08 22:20:17 [main] [INFO]: You might want to run 'apt-get -f install' to correct these:
2016/03/08 22:20:17 [main] [INFO]: The following packages have unmet dependencies:
2016/03/08 22:20:17 [main] [INFO]: md-jasperreports : PreDepends: md-cmd (>= 7.09.00) but 7.08.05.R is to be installed
2016/03/08 22:20:17 [main] [INFO]: tzdata-java : Depends: tzdata (= 2014h-0squeeze1) but 2015d-0+deb6u1 is to be installed
2016/03/08 22:20:17 [main] [ERROR]: command failed
State: 4 = Error
Installation of md-jasperreports failed (err:1)
Installing package md-aastra-data ...
2016/03/08 22:20:21 [main] [INFO]: Updater Command: install
2016/03/08 22:20:21 [main] [INFO]: Executing: /usr/bin/perl /usr/lib/exdjob/pl700010.pl 65
2016/03/08 22:20:21 [main] [INFO]: Command: install
2016/03/08 22:20:21 [main] [INFO]: Download and install package
2016/03/08 22:20:21 [main] [INFO]: Executing: apt-get -y --force-yes install 'md-aastra-data'
2016/03/08 22:20:21 [main] [INFO]: Reading package lists...
2016/03/08 22:20:21 [main] [INFO]: Building dependency tree...
2016/03/08 22:20:21 [main] [INFO]: Reading state information...
2016/03/08 22:20:21 [main] [INFO]: You might want to run 'apt-get -f install' to correct these:
2016/03/08 22:20:21 [main] [INFO]: The following packages have unmet dependencies:
2016/03/08 22:20:21 [main] [INFO]: md-aastra-data : PreDepends: md-cmd (>= 7.09.00) but 7.08.05.R is to be installed
2016/03/08 22:20:21 [main] [INFO]: tzdata-java : Depends: tzdata (= 2014h-0squeeze1) but 2015d-0+deb6u1 is to be installed
2016/03/08 22:20:21 [main] [ERROR]: command failed
State: 4 = Error
Installation of md-aastra-data failed (err:1)
Installing package md-xmppd ...
2016/03/08 22:20:26 [main] [INFO]: Updater Command: install
2016/03/08 22:20:26 [main] [INFO]: Executing: /usr/bin/perl /usr/lib/exdjob/pl700010.pl 66
2016/03/08 22:20:26 [main] [INFO]: Command: install
2016/03/08 22:20:26 [main] [INFO]: Download and install package
2016/03/08 22:20:26 [main] [INFO]: Executing: apt-get -y --force-yes install 'md-xmppd'
2016/03/08 22:20:26 [main] [INFO]: Reading package lists...
2016/03/08 22:20:26 [main] [INFO]: Building dependency tree...
2016/03/08 22:20:26 [main] [INFO]: Reading state information...
2016/03/08 22:20:26 [main] [INFO]: You might want to run 'apt-get -f install' to correct these:
2016/03/08 22:20:26 [main] [INFO]: The following packages have unmet dependencies:
2016/03/08 22:20:26 [main] [INFO]: tzdata-java : Depends: tzdata (= 2014h-0squeeze1) but 2015d-0+deb6u1 is to be installed
2016/03/08 22:20:26 [main] [ERROR]: command failed
State: 4 = Error
Installation of md-xmppd failed (err:1)
Installing package md-xmppserver ...
2016/03/08 22:20:30 [main] [INFO]: Updater Command: install
2016/03/08 22:20:30 [main] [INFO]: Executing: /usr/bin/perl /usr/lib/exdjob/pl700010.pl 67
2016/03/08 22:20:30 [main] [INFO]: Command: install
2016/03/08 22:20:30 [main] [INFO]: Download and install package
2016/03/08 22:20:30 [main] [INFO]: Executing: apt-get -y --force-yes install 'md-xmppserver'
2016/03/08 22:20:31 [main] [INFO]: Reading package lists...
2016/03/08 22:20:31 [main] [INFO]: Building dependency tree...
2016/03/08 22:20:31 [main] [INFO]: Reading state information...
2016/03/08 22:20:31 [main] [INFO]: You might want to run 'apt-get -f install' to correct these:
2016/03/08 22:20:31 [main] [INFO]: The following packages have unmet dependencies:
2016/03/08 22:20:31 [main] [INFO]: tzdata-java : Depends: tzdata (= 2014h-0squeeze1) but 2015d-0+deb6u1 is to be installed
2016/03/08 22:20:31 [main] [ERROR]: command failed
State: 4 = Error
Installation of md-xmppserver failed (err:1)
Installing package md-client ...
2016/03/08 22:20:35 [main] [INFO]: Updater Command: install
2016/03/08 22:20:35 [main] [INFO]: Executing: /usr/bin/perl /usr/lib/exdjob/pl700010.pl 68
2016/03/08 22:20:35 [main] [INFO]: Command: install
2016/03/08 22:20:35 [main] [INFO]: Download and install package
2016/03/08 22:20:35 [main] [INFO]: Executing: apt-get -y --force-yes install 'md-client'
2016/03/08 22:20:35 [main] [INFO]: Reading package lists...
2016/03/08 22:20:35 [main] [INFO]: Building dependency tree...
2016/03/08 22:20:35 [main] [INFO]: Reading state information...
2016/03/08 22:20:35 [main] [INFO]: You might want to run 'apt-get -f install' to correct these:
2016/03/08 22:20:35 [main] [INFO]: The following packages have unmet dependencies:
2016/03/08 22:20:35 [main] [INFO]: tzdata-java : Depends: tzdata (= 2014h-0squeeze1) but 2015d-0+deb6u1 is to be installed
2016/03/08 22:20:35 [main] [ERROR]: command failed
State: 4 = Error
Installation of md-client failed (err:1)
Installing package md-snom-data ...
2016/03/08 22:20:39 [main] [INFO]: Updater Command: install
2016/03/08 22:20:39 [main] [INFO]: Executing: /usr/bin/perl /usr/lib/exdjob/pl700010.pl 69
2016/03/08 22:20:40 [main] [INFO]: Command: install
2016/03/08 22:20:40 [main] [INFO]: Download and install package
2016/03/08 22:20:40 [main] [INFO]: Executing: apt-get -y --force-yes install 'md-snom-data'
2016/03/08 22:20:40 [main] [INFO]: Reading package lists...
2016/03/08 22:20:40 [main] [INFO]: Building dependency tree...
2016/03/08 22:20:40 [main] [INFO]: Reading state information...
2016/03/08 22:20:40 [main] [INFO]: You might want to run 'apt-get -f install' to correct these:
2016/03/08 22:20:40 [main] [INFO]: The following packages have unmet dependencies:
2016/03/08 22:20:40 [main] [INFO]: md-snom-data : PreDepends: md-cmd (>= 7.09.00) but 7.08.05.R is to be installed
2016/03/08 22:20:40 [main] [INFO]: tzdata-java : Depends: tzdata (= 2014h-0squeeze1) but 2015d-0+deb6u1 is to be installed
2016/03/08 22:20:40 [main] [ERROR]: command failed
State: 4 = Error
Installation of md-snom-data failed (err:1)
Installing package md-sound ...
2016/03/08 22:20:44 [main] [INFO]: Updater Command: install
2016/03/08 22:20:44 [main] [INFO]: Executing: /usr/bin/perl /usr/lib/exdjob/pl700010.pl 70
2016/03/08 22:20:44 [main] [INFO]: Command: install
2016/03/08 22:20:44 [main] [INFO]: Download and install package
2016/03/08 22:20:44 [main] [INFO]: Executing: apt-get -y --force-yes install 'md-sound'
2016/03/08 22:20:44 [main] [INFO]: Reading package lists...
2016/03/08 22:20:44 [main] [INFO]: Building dependency tree...
2016/03/08 22:20:44 [main] [INFO]: Reading state information...
2016/03/08 22:20:44 [main] [INFO]: You might want to run 'apt-get -f install' to correct these:
2016/03/08 22:20:44 [main] [INFO]: The following packages have unmet dependencies:
2016/03/08 22:20:44 [main] [INFO]: md-sound : Depends: md-cmd (>= 7.11.00) but 7.08.05.R is to be installed
2016/03/08 22:20:44 [main] [INFO]: Conflicts: md-prompt-en but 3.01.00.R is to be installed
2016/03/08 22:20:44 [main] [INFO]: Conflicts: md-prompt-de but 3.01.00.R is to be installed
2016/03/08 22:20:44 [main] [INFO]: tzdata-java : Depends: tzdata (= 2014h-0squeeze1) but 2015d-0+deb6u1 is to be installed
2016/03/08 22:20:44 [main] [ERROR]: command failed
State: 4 = Error
Installation of md-sound failed (err:1)
Installing package md-tapi ...
2016/03/08 22:20:49 [main] [INFO]: Updater Command: install
2016/03/08 22:20:49 [main] [INFO]: Executing: /usr/bin/perl /usr/lib/exdjob/pl700010.pl 71
2016/03/08 22:20:49 [main] [INFO]: Command: install
2016/03/08 22:20:49 [main] [INFO]: Download and install package
2016/03/08 22:20:49 [main] [INFO]: Executing: apt-get -y --force-yes install 'md-tapi'
2016/03/08 22:20:49 [main] [INFO]: Reading package lists...
2016/03/08 22:20:49 [main] [INFO]: Building dependency tree...
2016/03/08 22:20:49 [main] [INFO]: Reading state information...
2016/03/08 22:20:49 [main] [INFO]: You might want to run 'apt-get -f install' to correct these:
2016/03/08 22:20:49 [main] [INFO]: The following packages have unmet dependencies:
2016/03/08 22:20:49 [main] [INFO]: tzdata-java : Depends: tzdata (= 2014h-0squeeze1) but 2015d-0+deb6u1 is to be installed
2016/03/08 22:20:49 [main] [ERROR]: command failed
State: 4 = Error
Installation of md-tapi failed (err:1)
Installing package md-yealink-data ...
2016/03/08 22:20:53 [main] [INFO]: Updater Command: install
2016/03/08 22:20:53 [main] [INFO]: Executing: /usr/bin/perl /usr/lib/exdjob/pl700010.pl 72
2016/03/08 22:20:54 [main] [INFO]: Command: install
2016/03/08 22:20:54 [main] [INFO]: Download and install package
2016/03/08 22:20:54 [main] [INFO]: Executing: apt-get -y --force-yes install 'md-yealink-data'
2016/03/08 22:20:54 [main] [INFO]: Reading package lists...
2016/03/08 22:20:54 [main] [INFO]: Building dependency tree...
2016/03/08 22:20:54 [main] [INFO]: Reading state information...
2016/03/08 22:20:54 [main] [INFO]: You might want to run 'apt-get -f install' to correct these:
2016/03/08 22:20:54 [main] [INFO]: The following packages have unmet dependencies:
2016/03/08 22:20:54 [main] [INFO]: md-yealink-data : PreDepends: md-cmd (>= 7.09.00) but 7.08.05.R is to be installed
2016/03/08 22:20:54 [main] [INFO]: tzdata-java : Depends: tzdata (= 2014h-0squeeze1) but 2015d-0+deb6u1 is to be installed
2016/03/08 22:20:54 [main] [ERROR]: command failed
State: 4 = Error
Installation of md-yealink-data failed (err:1)
Installation could not be completed.
Please try installing again or contact support: Back
Anscheinend hat er ein Problem mit den vorhandenen Paketversionen und den, die er aufspielen soll.
Wie kann ich hierbei am saubersten verfahren?
Danke im Voraus und viele Grüße
André
