Hi
I know it´s the first release, but I already have a few questions:
- How can I get into the host, to go to the asterisk -rvvv ?
- After installation the md-1 can´t reach internet, no ntp to 0.pool.ntp.org and the SIP Trunk is not connecting, is this known?
Or how can I check?
Rest looks fine so far!!!
BR
Linuxuser
Hi Linuxuser,
try sudo lcx-attach -n md-1 to get a console in container md-1.
Thy Markus,
with lxc-attach --name md-1 worked.
Internet is working, but no DNS is placed
root@cloudstack:~# cat /etc/resolv.conf
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.0.1
At installation i wasn´t asked to define.
yes, please add the dns server manually for now. We will change that in the final version for sure ;).
Regards,
