mobydick 7.13 Release – mobydick Cloud Telephony, more interop & much more!
mobydick 7.13 sees the release of our Cloud Telephony solution. Meaning our customers are now able to benefit from accessing all their mobydick phone system features as well as having the freedom to choose providers, endpoints etc whilst simultaneously enjoying the extra flexibility that a cloud telephony solution offers.
As an existing mobydick on-premise customer we have also put together a special introductory offer for you should you wish to switch to the cloud solution. Simply contact our sales team for further information.
Endpoint Management has Never Been Simpler
mobydick 7.13 also delivers not only more interoperability thanks to the addition of Unify’s (formerly Siemens, Enterprise Communications, SEN) OpenStage/Optipoint devices to our range of supported endpoints, but also vastly enhanced endpoint management thanks to an editable base configuration templates.
The new templates mean it is now possible to simply copy and modify the default base configurations for Snom, Yealink, Mitel and Auerswald Telephones to match your needs. This in turn greatly speeds up and facilitates device deployment, provisioning and ongoing fleet management.
Further mobydick 7.13 Modifications
md-cmd 7.13.00
- The directoy /var/log/jobs will now regularly be cleaned up
- Yealink Telephones will now be controlled remotely using SIP messaging as opposed to HTTP Requests - this is designed to improve the compatibility of HomeOffice / VPN scenarios
- The login window language will now be set according the browser language.
md-client 3.08.00
- The integrated Softphone now controls SRTP and SIP via TLS
For the full release notes and further information to the mobydick 7.13, our cloud telephony solution and the newly supported endpoints, please refer to our: Release Notes
