ich habe mal ne Frage zum Mobile Hub.
Irgendwie klappt das bei mir nicht wirklich richtig.
Ich habe denke ich alles nach Anleitung konfiguriert, aber ich bekomme immer “Leider haben Sie haben die falsche Nummer gewählt”
Hier mal Screenshots wie ich das konfiguriert habe.
== Using SIP RTP CoS mark 5
-- Executing [12#488807500@mdc_berofix-d8df0d000d10:1] Goto("SIP/d8df0d000d10-00000002", "mdc_incoming-3,488807500,1") in new stack
-- Goto (mdc_incoming-3,488807500,1)
-- Executing [488807500@mdc_incoming-3:1] Set("SIP/d8df0d000d10-00000002", "MDC_CALLER_NUM_TRUNK=01799424574") in new stack
-- Executing [488807500@mdc_incoming-3:2] Set("SIP/d8df0d000d10-00000002", "MDC_CALLEE_NUM_TRUNK=488807500") in new stack
-- Executing [488807500@mdc_incoming-3:3] Goto("SIP/d8df0d000d10-00000002", "mdc_trunk-3,s,1") in new stack
-- Goto (mdc_trunk-3,s,1)
-- Executing [s@mdc_trunk-3:1] Verbose("SIP/d8df0d000d10-00000002", "1,callee number: 488807500 caller number: 01799424574") in new stack
-- Executing [s@mdc_trunk-3:2] GosubIf("SIP/d8df0d000d10-00000002", "0?sub_internat,s,1(CALLERID(num),01799424574,00)") in new stack
-- Executing [s@mdc_trunk-3:3] Gosub("SIP/d8df0d000d10-00000002", "sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,01799424574,00,49,0,7581)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("SIP/d8df0d000d10-00000002", "1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - CALLERID(num): 01799424574 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7581") in new stack
-- Executing [s@sub_nat2int:2] GotoIf("SIP/d8df0d000d10-00000002", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:3] GotoIf("SIP/d8df0d000d10-00000002", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:4] GotoIf("SIP/d8df0d000d10-00000002", "0?s-intshort,1") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("SIP/d8df0d000d10-00000002", "0?s-natshort,1") in new stack
-- Executing [s@sub_nat2int:6] GotoIf("SIP/d8df0d000d10-00000002", "1?s-nat,1") in new stack
-- Goto (sub_nat2int,s-nat,1)
-- Executing [s-nat@sub_nat2int:1] Verbose("SIP/d8df0d000d10-00000002", "1,national") in new stack
national
-- Executing [s-nat@sub_nat2int:2] Set("SIP/d8df0d000d10-00000002", "MDC_CALLER_NUM_INTERNAT=00491799424574") in new stack
-- Executing [s-nat@sub_nat2int:3] Return("SIP/d8df0d000d10-00000002", "") in new stack
-- Executing [s@mdc_trunk-3:4] Set("SIP/d8df0d000d10-00000002", "CALLERID(num)=00491799424574") in new stack
-- Executing [s@mdc_trunk-3:5] Gosub("SIP/d8df0d000d10-00000002", "sub_int2nat,s,1(MDC_CALLER_NUM_NAT,00491799424574,00,49,0,7581)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("SIP/d8df0d000d10-00000002", "1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 00491799424574 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7581") in new stack
-- Executing [s@sub_int2nat:2] GotoIf("SIP/d8df0d000d10-00000002", "0?nat") in new stack
-- Executing [s@sub_int2nat:3] GotoIf("SIP/d8df0d000d10-00000002", "1?s-internat,1") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("SIP/d8df0d000d10-00000002", "MDC_CALLER_NUM_NAT=01799424574") in new stack
-- Executing [s-internat@sub_int2nat:2] Return("SIP/d8df0d000d10-00000002", "") in new stack
-- Executing [s@mdc_trunk-3:6] Set("SIP/d8df0d000d10-00000002", "CALLERID(num)=01799424574") in new stack
-- Executing [s@mdc_trunk-3:7] Gosub("SIP/d8df0d000d10-00000002", "sub_pb-search,s,1(CALLERID(name),01799424574,01799424574,00491799424574,+491799424574)") in new stack
-- Executing [s@sub_pb-search:1] Verbose("SIP/d8df0d000d10-00000002", "1,sub_pb-search variable: CALLERID(name) calleridnum: 01799424574 national: 01799424574 international: 00491799424574 +internat: +491799424574") in new stack
-- Executing [s@sub_pb-search:2] Set("SIP/d8df0d000d10-00000002", "HASH(PB_ENTRY)=Markus Sachs,Markus,Sachs,all for IT Systemhaus GmbH") in new stack
-- Executing [s@sub_pb-search:3] Verbose("SIP/d8df0d000d10-00000002", "1,Markus Sachs") in new stack
Markus Sachs
-- Executing [s@sub_pb-search:4] Verbose("SIP/d8df0d000d10-00000002", "1,Markus") in new stack
-- Executing [s@sub_pb-search:5] Verbose("SIP/d8df0d000d10-00000002", "1,Sachs") in new stack
Sachs
-- Executing [s@sub_pb-search:6] Verbose("SIP/d8df0d000d10-00000002", "1,all for IT Systemhaus GmbH") in new stack
-- Executing [s@sub_pb-search:7] Set("SIP/d8df0d000d10-00000002", "CALLERID(name)=Markus Sachs") in new stack
-- Executing [s@sub_pb-search:8] Return("SIP/d8df0d000d10-00000002", "") in new stack
-- Executing [s@mdc_trunk-3:8] Set("SIP/d8df0d000d10-00000002", "MDC_NUMPREFIX_TRUNK=0") in new stack
-- Executing [s@mdc_trunk-3:9] Set("SIP/d8df0d000d10-00000002", "CALLERID(num)=001799424574") in new stack
-- Executing [s@mdc_trunk-3:10] Goto("SIP/d8df0d000d10-00000002", "mdc_mapping-3,488807500,1") in new stack
-- Goto (mdc_mapping-3,488807500,1)
-- Executing [488807500@mdc_mapping-3:1] Set("SIP/d8df0d000d10-00000002", "CHANNEL(language)=de") in new stack
-- Executing [488807500@mdc_mapping-3:2] Verbose("SIP/d8df0d000d10-00000002", "1,mapping from 488807500 to *60") in new stack
-- Executing [488807500@mdc_mapping-3:3] Goto("SIP/d8df0d000d10-00000002", "mdc_external,*60,1") in new stack
-- Goto (mdc_external,*60,1)
-- Executing *60@mdc_external:1] SIPAddHeader("SIP/d8df0d00
-- Executing *60@mdc_external:2] GosubIf("SIP/d8df0d000d10-00000002", "1?sub_initcall,s,1(ext,*60)") in new stack
-- Executing [s@sub_initcall:1] Verbose("SIP/d8df0d000d10-00000002", "1,sub_initcall descent: ext exten: *60") in new stack
-- Executing [s@sub_initcall:2] GosubIf("SIP/d8df0d000d10-00000002", "1?sub_initloop,s,1") in new stack
-- Executing [s@sub_initloop:1] Verbose("SIP/d8df0d000d10-00000002", "1,initial loop") in new stack
initial loop
-- Executing [s@sub_initloop:2] Set("SIP/d8df0d000d10-00000002", "MDC_ALIAS_HOP=0") in new stack
-- Executing [s@sub_initloop:3] Return("SIP/d8df0d000d10-00000002", "") in new stack
-- Executing [s@sub_initcall:3] Set("SIP/d8df0d000d10-00000002", "__MDC_DIALDESCENT=ext") in new stack
-- Executing [s@sub_initcall:4] Goto("SIP/d8df0d000d10-00000002", "ext,1") in new stack
-- Goto (sub_initcall,ext,1)
-- Executing [ext@sub_initcall:1] Set("SIP/d8df0d000d10-00000002", "__MDC_DIALCALLERNUMINIT=01799424574") in new stack
-- Executing [ext@sub_initcall:2] Set("SIP/d8df0d000d10-00000002", "__MDC_DIALCALLEENUMINIT=488807500") in new stack
-- Executing [ext@sub_initcall:3] Return("SIP/d8df0d000d10-00000002", "") in new stack
-- Executing *60@mdc_external:3] Goto("SIP/d8df0d000d10-00000002", "main,*60,1") in new stack
-- Goto (main,*60,1)
-- Executing *60@main:1] Gosub("SIP/d8df0d000d10-00000002", "sub_defcall,s,1(*60)") in new stack
[Mar 17 16:27:00] NOTICE[22525]: func_math.c:424 crement_function_read: The value is now: 1
-- Executing [s@sub_defcall:1] Set("SIP/d8df0d000d10-00000002", "MDC_ALIAS_HOP=1") in new stack
-- Executing [s@sub_defcall:2] Set("SIP/d8df0d000d10-00000002", "__MDC_DIALCALLEENUM=*60") in new stack
-- Executing [s@sub_defcall:3] Set("SIP/d8df0d000d10-00000002", "__MDC_DIALCALLERNUM=001799424574") in new stack
-- Executing [s@sub_defcall:4] Set("SIP/d8df0d000d10-00000002", "__MDC_DIALCHANNELNAME=d8df0d000d10") in new stack
-- Executing [s@sub_defcall:5] GotoIf("SIP/d8df0d000d10-00000002", "1?nozap") in new stack
-- Goto (sub_defcall,s,8)
-- Executing [s@sub_defcall:8] Set("SIP/d8df0d000d10-00000002", "__MDC_DIALCALLERNAME=Markus Sachs") in new stack
-- Executing [s@sub_defcall:9] Return("SIP/d8df0d000d10-00000002", "") in new stack
-- Executing *60@main:2] Goto("SIP/d8df0d000d10-00000002", "mdc_distribute,*60,1") in new stack
-- Goto (mdc_distribute,*60,1)
-- Executing *60@mdc_distribute:1] Gosub("SIP/d8df0d000d10-00000002", "sub_mobility,s,1(01799424574)") in new stack
-- Executing [s@sub_mobility:1] Verbose("SIP/d8df0d000d10-00000002", "1,sub_mobility:: callerid(num): 01799424574") in new stack
-- Executing [s@sub_mobility:2] Set("SIP/d8df0d000d10-00000002", "__MDC_MOBILITY_INCOMING=1") in new stack
-- Executing [s@sub_mobility:3] GotoIf("SIP/d8df0d000d10-00000002", "0?failed,1") in new stack
-- Executing [s@sub_mobility:4] Goto("SIP/d8df0d000d10-00000002", "01799424574,1") in new stack
-- Goto (sub_mobility,01799424574,1)
-- Executing [01799424574@sub_mobility:1] Goto("SIP/d8df0d000d10-00000002", "failed,1") in new stack
-- Goto (sub_mobility,failed,1)
-- Executing [failed@sub_mobility:1] Answer("SIP/d8df0d000d10-00000002", "") in new stack
-- Executing [failed@sub_mobility:2] Playback("SIP/d8df0d000d10-00000002", "invalid") in new stack
-- <SIP/d8df0d000d10-00000002> Playing 'invalid.alaw' (language 'de')
-- Registered IAX2 'iaxmodem0' (AUTHENTICATED) at 127.0.0.1:35462
-- Registered IAX2 'iaxmodem3' (AUTHENTICATED) at 127.0.0.1:59813
-- Registered IAX2 'iaxmodem2' (AUTHENTICATED) at 127.0.0.1:49304
-- Registered IAX2 'iaxmodem1' (AUTHENTICATED) at 127.0.0.1:53235
-- Executing [failed@sub_mobility:3] Hangup("SIP/d8df0d000d10-00000002", "0") in new stack
== Spawn extension (sub_mobility, failed, 3) exited non-zero on 'SIP/d8df0d000d10-00000002'
afi-srv-voip01*CLI>
Was habe ich falsch gemacht?
Danke.
