aktuell gibt die CLI folgendes aus, wenn ich eine Nummer anrufe…
mobydick*CLI>
Disconnected from Asterisk server
Asterisk cleanly ending (0).
Executing last minute cleanups
root@mobydick:~# asterisk -r
Asterisk 11.6-cert5, Copyright © 1999 - 2013 Digium, Inc. and others.
Created by Mark Spencer <markster@digium.com>
Asterisk comes with ABSOLUTELY NO WARRANTY; type ‘core show warranty’ for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type ‘core show license’ for details.
Connected to Asterisk 11.6-cert5 currently running on mobydick (pid = 23580)
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
– Executing [623@mdc_incoming-2:1] Set(“SIP/mdc_trunk_conf-2-00000000”, “MDC_CALLER_NUM_TRUNK=015115600”) in new stack
– Executing [623@mdc_incoming-2:2] Set(“SIP/mdc_trunk_conf-2-00000000”, “MDC_CALLEE_NUM_TRUNK=623”) in new stack
– Executing [623@mdc_incoming-2:3] Goto(“SIP/mdc_trunk_conf-2-00000000”, “mdc_trunk-2,s,1”) in new stack
– Goto (mdc_trunk-2,s,1)
– Executing [s@mdc_trunk-2:1] Verbose(“SIP/mdc_trunk_conf-2-00000000”, “1,callee number: 623 caller number: 015115600”) in new stack
– Executing [s@mdc_trunk-2:2] Gosub(“SIP/mdc_trunk_conf-2-00000000”, “sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,015115600,00,49,0,6132)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“SIP/mdc_trunk_conf-2-00000000”, “1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - number: 015115600 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 6132”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “0?s-emergency,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, " 0?s-convert,1") in new stack
– Executing [s@sub_nat2int:6] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:7] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:8] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:9] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “1?s-nat,1”) in new stack
– Goto (sub_nat2int,s-nat,1)
– Executing [s-nat@sub_nat2int:1] Verbose(“SIP/mdc_trunk_conf-2-00000000”, “1,national”) in new stack
national
– Executing [s-nat@sub_nat2int:2] Set(“SIP/mdc_trunk_conf-2-00000000”, “MDC_CALLER_NUM_INTERNAT=004915115600246”) in new stack
– Executing [s-nat@sub_nat2int:3] Return(“SIP/mdc_trunk_conf-2-00000000”, “”) in new stack
– Executing [s@mdc_trunk-2:3] Set(“SIP/mdc_trunk_conf-2-00000000”, “CALLERID(num)=004915115600246”) in new stack
– Executing [s@mdc_trunk-2:4] Gosub(“SIP/mdc_trunk_conf-2-00000000”, “sub_int2nat,s,1(MDC_CALLER_NUM_NAT,004915115600246,00,49,0,6132)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“SIP/mdc_trunk_conf-2-00000000”, “1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 004915115600246 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 6132”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “0?s-emergency,1”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “0?nat”) in new stack
– Executing [s@sub_int2nat:4] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“SIP/mdc_trunk_conf-2-00000000”, “MDC_CALLER_NUM_NAT=015115600”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“SIP/mdc_trunk_conf-2-00000000”, “”) in new stack
– Executing [s@mdc_trunk-2:5] Set(“SIP/mdc_trunk_conf-2-00000000”, “CALLERID(num)=015115600”) in new stack
– Executing [s@mdc_trunk-2:6] UserEvent(“SIP/mdc_trunk_conf-2-00000000”, “ResolveCallerName,Strategy: default,Outbound: 0,Channel: SIP/mdc_trunk_conf-2-00000000”) in new stack
– Executing [s@mdc_trunk-2:7] Wait(“SIP/mdc_trunk_conf-2-00000000”, “0.25”) in new stack
– Executing [s@mdc_trunk-2:8] Verbose(“SIP/mdc_trunk_conf-2-00000000”, “1,MDC_RESOLVENAME_HITS = 0”) in new stack
– Executing [s@mdc_trunk-2:9] Verbose(“SIP/mdc_trunk_conf-2-00000000”, “1,CALLERID(name) = Tino”) in new stack
– Executing [s@mdc_trunk-2:10] Set(“SIP/mdc_trunk_conf-2-00000000”, “MDC_NUMPREFIX_TRUNK=0”) in new stack
– Executing [s@mdc_trunk-2:11] ExecIf(“SIP/mdc_trunk_conf-2-00000000”, “1?Set(CALLERID(num)=0015115600246)”) in new stack
– Executing [s@mdc_trunk-2:12] Goto(“SIP/mdc_trunk_conf-2-00000000”, “mdc_mapping-2,623,1”) in new stack
– Goto (mdc_mapping-2,623,1)
– Executing [623@mdc_mapping-2:1] Set(“SIP/mdc_trunk_conf-2-00000000”, “CHANNEL(language)=de”) in new stack
– Executing [623@mdc_mapping-2:2] Verbose(“SIP/mdc_trunk_conf-2-00000000”, “1,mapping from 623 to *60”) in new stack
– Executing [623@mdc_mapping-2:3] Goto(“SIP/mdc_trunk_conf-2-00000000”, “mdc_external,*60,1”) in new stack
– Goto (mdc_external,*60,1)
– Executing *60@mdc_external:1] SIPAddHeader(“SIP/mdc_trunk_conf-2-00000000”, "“Alert-Info:<http://www.notused.de>;info=alert-external;x-line-id=0"”) in new stack
– Executing *60@mdc_external:2] GosubIf(“SIP/mdc_trunk_conf-2-00000000”, “1?sub_initcall,s,1(ext,*60)”) in new stack
– Executing [s@sub_initcall:1] Verbose(“SIP/mdc_trunk_conf-2-00000000”, “1,sub_initcall descent: ext exten: *60”) in new stack
– Executing [s@sub_initcall:2] GosubIf(“SIP/mdc_trunk_conf-2-00000000”, “1?sub_initloop,s,1”) in new stack
– Executing [s@sub_initloop:1] Verbose(“SIP/mdc_trunk_conf-2-00000000”, “1,initial loop”) in new stack
initial loop
– Executing [s@sub_initloop:2] Set(“SIP/mdc_trunk_conf-2-00000000”, “MDC_ALIAS_HOP=0”) in new stack
– Executing [s@sub_initloop:3] Return(“SIP/mdc_trunk_conf-2-00000000”, “”) in new stack
– Executing [s@sub_initcall:3] Set(“SIP/mdc_trunk_conf-2-00000000”, “__MDC_TRANSFERBACK_HOP=0”) in new stack
– Executing [s@sub_initcall:4] Set(“SIP/mdc_trunk_conf-2-00000000”, “__MDC_DIALDESCENT=ext”) in new stack
– Executing [s@sub_initcall:5] Goto(“SIP/mdc_trunk_conf-2-00000000”, “ext,1”) in new stack
– Goto (sub_initcall,ext,1)
– Executing [ext@sub_initcall:1] Set(“SIP/mdc_trunk_conf-2-00000000”, “__MDC_DIALCALLERNUMINIT=015115600”) in new stack
– Executing [ext@sub_initcall:2] Set(“SIP/mdc_trunk_conf-2-00000000”, “__MDC_DIALCALLEENUMINIT=623”) in new stack
– Executing [ext@sub_initcall:3] Set(“SIP/mdc_trunk_conf-2-00000000”, “__MDC_DIALCALLEENUMMAP=*60”) in new stack
– Executing [ext@sub_initcall:4] Return(“SIP/mdc_trunk_conf-2-00000000”, “”) in new stack
– Executing *60@mdc_external:3] Goto(“SIP/mdc_trunk_conf-2-00000000”, “main,*60,1”) in new stack
– Goto (main,*60,1)
– Executing *60@main:1] Gosub(“SIP/mdc_trunk_conf-2-00000000”, “sub_defcall,s,1(*60)”) in new stack
– Executing [s@sub_defcall:1] Set(“SIP/mdc_trunk_conf-2-00000000”, “__MDC_ALIAS_HOP=1”) in new stack
– Executing [s@sub_defcall:2] Set(“SIP/mdc_trunk_conf-2-00000000”, “__MDC_DIALCALLEENUM=*60”) in new stack
– Executing [s@sub_defcall:3] Set(“SIP/mdc_trunk_conf-2-00000000”, “__MDC_DIALCALLERNUM=0015115600246”) in new stack
– Executing [s@sub_defcall:4] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “1?nozap”) in new stack
– Goto (sub_defcall,s,8)
– Executing [s@sub_defcall:8] Set(“SIP/mdc_trunk_conf-2-00000000”, “__MDC_DIALCALLERNAME=Tino”) in new stack
– Executing [s@sub_defcall:9] Set(“SIP/mdc_trunk_conf-2-00000000”, “__MDC_DIALCHANNELNAME=mdc_trunk_conf-2”) in new stack
– Executing [s@sub_defcall:10] Return(“SIP/mdc_trunk_conf-2-00000000”, “”) in new stack
– Executing *60@main:2] Goto(“SIP/mdc_trunk_conf-2-00000000”, “mdc_distribute,*60,1”) in new stack
– Goto (mdc_distribute,*60,1)
– Executing 60@mdc_distribute:1] Gosub(“SIP/mdc_trunk_conf-2-00000000”, “sub_mobility,s,1(015115600)”) in new stack
– Executing [s@sub_mobility:1] Verbose(“SIP/mdc_trunk_conf-2-00000000”, “1,sub_mobility:: callerid(num): 015115600”) in new stack
– Executing [s@sub_mobility:2] Set(“SIP/mdc_trunk_conf-2-00000000”, “__MDC_MOBILITY_INCOMING=1”) in new stack
– Executing [s@sub_mobility:3] GotoIf(“SIP/mdc_trunk_conf-2-00000000”, “0?failed,1”) in new stack
– Executing [s@sub_mobility:4] Goto(“SIP/mdc_trunk_conf-2-00000000”, “015115600,1”) in new stack
– Goto (sub_mobility,015115600,1)
– Executing [015115600@sub_mobility:1] Set(“SIP/mdc_trunk_conf-2-00000000”, “MDC_EXTEN=015115600”) in new stack
– Executing [015115600@sub_mobility:2] Goto(“SIP/mdc_trunk_conf-2-00000000”, “failed,1”) in new stack
– Goto (sub_mobility,failed,1)
– Executing [failed@sub_mobility:1] Answer(“SIP/mdc_trunk_conf-2-00000000”, “”) in new stack
– Executing [failed@sub_mobility:2] Playback(“SIP/mdc_trunk_conf-2-00000000”, “invalid”) in new stack
– <SIP/mdc_trunk_conf-2-00000000> Playing ‘invalid.alaw’ (language ‘de’)
== Spawn extension (sub_mobility, failed, 2) exited non-zero on ‘SIP/mdc_trunk_conf-2-00000000’
– Executing [h@sub_mobility:1] Gosub(“SIP/mdc_trunk_conf-2-00000000”, “def_hangup,s,1(015115600,CALL)”) in new stack
– Executing [s@def_hangup:1] NoOp(“SIP/mdc_trunk_conf-2-00000000”, “>>>def_hangup:: EXTEN: 015115600 DIALSTATUS: QUEUESTATUS: REASON: CALL”) in new stack
mobydickCLI>
Gruß Tino
Edit: Nun habe ich es hinbekommen! Aber keine Ahnung, wieso es nun geht…
