hier noch einmal:
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
-- Executing [072239914102@mdc_incoming-7:1] Set("SIP/mdc_trunk_conf-7-00000044", "MDC_CALLER_NUM_TRUNK=+491712345678") in new stack
-- Executing [072239914102@mdc_incoming-7:2] Set("SIP/mdc_trunk_conf-7-00000044", "MDC_CALLEE_NUM_TRUNK=072239914102") in new stack
-- Executing [072239914102@mdc_incoming-7:3] Goto("SIP/mdc_trunk_conf-7-00000044", "mdc_trunk-1,s,1") in new stack
-- Goto (mdc_trunk-1,s,1)
-- Executing [s@mdc_trunk-1:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,callee number: 072239914102 caller number: +491712345678") in new stack
-- Executing [s@mdc_trunk-1:2] Gosub("SIP/mdc_trunk_conf-7-00000044", "sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,+491712345678,00,49,0,7223,1)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - number: +491712345678 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7223 - incoming: 1") in new stack
-- Executing [s@sub_nat2int:2] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?s-emergency,1") in new stack
-- Executing [s@sub_nat2int:3] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:4] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("SIP/mdc_trunk_conf-7-00000044", "1?s-convert,1") in new stack
-- Goto (sub_nat2int,s-convert,1)
-- Executing [s-convert@sub_nat2int:1] Set("SIP/mdc_trunk_conf-7-00000044", "ARG2=00491712345678") in new stack
-- Executing [s-convert@sub_nat2int:2] Goto("SIP/mdc_trunk_conf-7-00000044", "s,check") in new stack
-- Goto (sub_nat2int,s,6)
-- Executing [s@sub_nat2int:6] GotoIf("SIP/mdc_trunk_conf-7-00000044", "1?s-int,1") in new stack
-- Goto (sub_nat2int,s-int,1)
-- Executing [s-int@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,international") in new stack
international
-- Executing [s-int@sub_nat2int:2] Set("SIP/mdc_trunk_conf-7-00000044", "MDC_CALLER_NUM_INTERNAT=00491712345678") in new stack
-- Executing [s-int@sub_nat2int:3] Return("SIP/mdc_trunk_conf-7-00000044", "") in new stack
-- Executing [s@mdc_trunk-1:3] Set("SIP/mdc_trunk_conf-7-00000044", "CALLERID(num)=00491712345678") in new stack
-- Executing [s@mdc_trunk-1:4] Gosub("SIP/mdc_trunk_conf-7-00000044", "sub_int2nat,s,1(MDC_CALLER_NUM_NAT,00491712345678,00,49,0,7223,1)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 00491712345678 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7223 - incoming: 1") in new stack
-- Executing [s@sub_int2nat:2] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?s-emergency,1") in new stack
-- Executing [s@sub_int2nat:3] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?nat") in new stack
-- Executing [s@sub_int2nat:4] GotoIf("SIP/mdc_trunk_conf-7-00000044", "1?s-internat,1") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("SIP/mdc_trunk_conf-7-00000044", "MDC_CALLER_NUM_NAT=01712345678") in new stack
-- Executing [s-internat@sub_int2nat:2] Return("SIP/mdc_trunk_conf-7-00000044", "") in new stack
-- Executing [s@mdc_trunk-1:5] Set("SIP/mdc_trunk_conf-7-00000044", "CALLERID(num)=01712345678") in new stack
-- Executing [s@mdc_trunk-1:6] UserEvent("SIP/mdc_trunk_conf-7-00000044", "ResolveCallerName,Strategy: system,Outbound: 0,Channel: SIP/mdc_trunk_conf-7-00000044") in new stack
-- Executing [s@mdc_trunk-1:7] Wait("SIP/mdc_trunk_conf-7-00000044", "0.25") in new stack
-- Executing [s@mdc_trunk-1:8] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,MDC_RESOLVENAME_HITS = 0") in new stack
-- Executing [s@mdc_trunk-1:9] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,CALLERID(name) = ") in new stack
CALLERID(name) =
-- Executing [s@mdc_trunk-1:10] Set("SIP/mdc_trunk_conf-7-00000044", "MDC_NUMPREFIX_TRUNK=") in new stack
-- Executing [s@mdc_trunk-1:11] Goto("SIP/mdc_trunk_conf-7-00000044", "mdc_mapping-1,072239914102,1") in new stack
-- Goto (mdc_mapping-1,072239914102,1)
-- Executing [072239914102@mdc_mapping-1:1] Set("SIP/mdc_trunk_conf-7-00000044", "CHANNEL(language)=de") in new stack
-- Executing [072239914102@mdc_mapping-1:2] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,mapping from 072239914102 to *60") in new stack
-- Executing [072239914102@mdc_mapping-1:3] Goto("SIP/mdc_trunk_conf-7-00000044", "mdc_external,*60,1") in new stack
-- Goto (mdc_external,*60,1)
-- Executing *60@mdc_external:1] SIPAddHeader("SIP/mdc_trunk_conf-7-00000044", ""Alert-Info:<http://www.notused.de>;info=alert-external;x-line-id=0"") in new stack
-- Executing *60@mdc_external:2] GosubIf("SIP/mdc_trunk_conf-7-00000044", "1?sub_initcall,s,1(ext,*60)") in new stack
-- Executing [s@sub_initcall:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,sub_initcall descent: ext exten: *60") in new stack
-- Executing [s@sub_initcall:2] GosubIf("SIP/mdc_trunk_conf-7-00000044", "1?sub_initloop,s,1") in new stack
-- Executing [s@sub_initloop:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,initial loop") in new stack
initial loop
-- Executing [s@sub_initloop:2] Set("SIP/mdc_trunk_conf-7-00000044", "MDC_ALIAS_HOP=0") in new stack
-- Executing [s@sub_initloop:3] Return("SIP/mdc_trunk_conf-7-00000044", "") in new stack
-- Executing [s@sub_initcall:3] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_TRANSFERBACK_HOP=0") in new stack
-- Executing [s@sub_initcall:4] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_DIALDESCENT=ext") in new stack
-- Executing [s@sub_initcall:5] Goto("SIP/mdc_trunk_conf-7-00000044", "ext,1") in new stack
-- Goto (sub_initcall,ext,1)
-- Executing [ext@sub_initcall:1] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_DIALCALLERNUMINIT=+491712345678") in new stack
-- Executing [ext@sub_initcall:2] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_DIALCALLEENUMINIT=072239914102") in new stack
-- Executing [ext@sub_initcall:3] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_DIALCALLEENUMMAP=*60") in new stack
-- Executing [ext@sub_initcall:4] Return("SIP/mdc_trunk_conf-7-00000044", "") in new stack
-- Executing *60@mdc_external:3] Goto("SIP/mdc_trunk_conf-7-00000044", "main,*60,1") in new stack
-- Goto (main,*60,1)
-- Executing *60@main:1] Gosub("SIP/mdc_trunk_conf-7-00000044", "sub_defcall,s,1(*60)") in new stack
-- Executing [s@sub_defcall:1] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_ALIAS_HOP=1") in new stack
-- Executing [s@sub_defcall:2] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_DIALCALLEENUM=*60") in new stack
-- Executing [s@sub_defcall:3] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_DIALCALLERNUM=01712345678") in new stack
-- Executing [s@sub_defcall:4] GotoIf("SIP/mdc_trunk_conf-7-00000044", "1?nozap") in new stack
-- Goto (sub_defcall,s,8)
-- Executing [s@sub_defcall:8] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_DIALCALLERNAME=") in new stack
-- Executing [s@sub_defcall:9] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_DIALCHANNELNAME=mdc_trunk_conf-7") in new stack
-- Executing [s@sub_defcall:10] Return("SIP/mdc_trunk_conf-7-00000044", "") in new stack
-- Executing *60@main:2] Goto("SIP/mdc_trunk_conf-7-00000044", "mdc_distribute,*60,1") in new stack
-- Goto (mdc_distribute,*60,1)
-- Executing *60@mdc_distribute:1] Gosub("SIP/mdc_trunk_conf-7-00000044", "sub_mobility,s,1(00491712345678)") in new stack
-- Executing [s@sub_mobility:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,sub_mobility:: callerid(num): 00491712345678") in new stack
-- Executing [s@sub_mobility:2] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_MOBILITY_INCOMING=1") in new stack
-- Executing [s@sub_mobility:3] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?failed,1") in new stack
-- Executing [s@sub_mobility:4] Goto("SIP/mdc_trunk_conf-7-00000044", "00491712345678,1") in new stack
-- Goto (sub_mobility,00491712345678,1)
-- Executing [00491712345678@sub_mobility:1] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?failed,1") in new stack
-- Executing [00491712345678@sub_mobility:2] Set("SIP/mdc_trunk_conf-7-00000044", "MDC_CALLEE_NUM=01738765432") in new stack
-- Executing [00491712345678@sub_mobility:3] Gosub("SIP/mdc_trunk_conf-7-00000044", "sub_user,s,1(caller,8,100,s.gehr,Sven Gehr,100,100,100,de)") in new stack
-- Executing [s@sub_user:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,sub_user mode caller") in new stack
-- Executing [s@sub_user:2] Goto("SIP/mdc_trunk_conf-7-00000044", "s-caller,1") in new stack
-- Goto (sub_user,s-caller,1)
-- Executing [s-caller@sub_user:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,sub_user user id: 8 - user exten: 100 - user: s.gehr - realname: Sven Gehr - own mailbox: 100 - watched mailbox: 100 - callerid(num): 100 - language: de") in new stack
-- Executing [s-caller@sub_user:2] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_CALLER_USER_ID=8") in new stack
-- Executing [s-caller@sub_user:3] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_CALLER_NUM=100") in new stack
-- Executing [s-caller@sub_user:4] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_CALLER_ACC_NAME=s.gehr") in new stack
-- Executing [s-caller@sub_user:5] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_CALLER_ACC_REALNAME=Sven Gehr") in new stack
-- Executing [s-caller@sub_user:6] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_CALLER_VM_OWN=100") in new stack
-- Executing [s-caller@sub_user:7] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_CALLER_VM_WATCHED=100") in new stack
-- Executing [s-caller@sub_user:8] Set("SIP/mdc_trunk_conf-7-00000044", "CALLERID(name)=Sven Gehr") in new stack
-- Executing [s-caller@sub_user:9] Set("SIP/mdc_trunk_conf-7-00000044", "CALLERID(num)=100") in new stack
-- Executing [s-caller@sub_user:10] Set("SIP/mdc_trunk_conf-7-00000044", "CHANNEL(language)=de") in new stack
-- Executing [s-caller@sub_user:11] Return("SIP/mdc_trunk_conf-7-00000044", "") in new stack
-- Executing [00491712345678@sub_mobility:4] Goto("SIP/mdc_trunk_conf-7-00000044", "main,01738765432,1") in new stack
-- Goto (main,01738765432,1)
-- Executing [01738765432@main:1] Gosub("SIP/mdc_trunk_conf-7-00000044", "sub_defcall,s,1(01738765432)") in new stack
-- Executing [s@sub_defcall:1] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_ALIAS_HOP=2") in new stack
-- Executing [s@sub_defcall:2] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_DIALCALLEENUM=01738765432") in new stack
-- Executing [s@sub_defcall:3] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_DIALCALLERNUM=100") in new stack
-- Executing [s@sub_defcall:8] Set("SIP/mdc_trunk_conf-7-00000044", "__MDC_DIALCALLERNAME=Sven Gehr") in new stack
-- Executing [01738765432@main:2] Goto("SIP/mdc_trunk_conf-7-00000044", "mdc_distribute,01738765432,1") in new stack
-- Goto (mdc_distribute,01738765432,1)
-- Executing [01738765432@mdc_distribute:1] Set("SIP/mdc_trunk_conf-7-00000044", "MDC_INPREFIX_TRUNK=") in new stack
-- Executing [01738765432@mdc_distribute:2] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,remove inprefix: ") in new stack
remove inprefix:
-- Executing [01738765432@mdc_distribute:3] Goto("SIP/mdc_trunk_conf-7-00000044", "mdc_outgoing-2,01738765432,1") in new stack
-- Goto (mdc_outgoing-2,01738765432,1)
-- Executing [01738765432@mdc_outgoing-2:1] Gosub("SIP/mdc_trunk_conf-7-00000044", "sub_trunk-outgoing-2,01738765432,1") in new stack
-- Executing [01738765432@sub_trunk-outgoing-2:1] Gosub("SIP/mdc_trunk_conf-7-00000044", "sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,01738765432,00,49,0,7223,0)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - number: 01738765432 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7223 - incoming: 0") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?s-convert,1") in new stack
-- Executing [s@sub_nat2int:6] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:7] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?s-intshort,1") in new stack
-- Executing [s@sub_nat2int:8] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?s-natshort,1") in new stack
-- Executing [s@sub_nat2int:9] GotoIf("SIP/mdc_trunk_conf-7-00000044", "1?s-nat,1") in new stack
-- Goto (sub_nat2int,s-nat,1)
-- Executing [s-nat@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,national") in new stack
national
-- Executing [s-nat@sub_nat2int:2] Set("SIP/mdc_trunk_conf-7-00000044", "MDC_CALLEE_NUM_INTERNAT=00491738765432") in new stack
-- Executing [s-nat@sub_nat2int:3] Return("SIP/mdc_trunk_conf-7-00000044", "") in new stack
-- Executing [01738765432@sub_trunk-outgoing-2:2] Gosub("SIP/mdc_trunk_conf-7-00000044", "sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,00491738765432,00,49,0,7223,0)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 00491738765432 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7223 - incoming: 0") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("SIP/mdc_trunk_conf-7-00000044", "MDC_CALLEE_NUM_NAT=01738765432") in new stack
-- Executing [01738765432@sub_trunk-outgoing-2:3] Set("SIP/mdc_trunk_conf-7-00000044", "CALLERID(name)=072239914101") in new stack
-- Executing [01738765432@sub_trunk-outgoing-2:4] Set("SIP/mdc_trunk_conf-7-00000044", "CALLERID(num)=072239914101") in new stack
-- Executing [01738765432@sub_trunk-outgoing-2:5] GotoIf("SIP/mdc_trunk_conf-7-00000044", "0?searchdone") in new stack
-- Executing [01738765432@sub_trunk-outgoing-2:6] UserEvent("SIP/mdc_trunk_conf-7-00000044", "ResolveCallerName,Strategy: system,Outbound: 1,Channel: SIP/mdc_trunk_conf-7-00000044") in new stack
-- Executing [01738765432@sub_trunk-outgoing-2:7] Wait("SIP/mdc_trunk_conf-7-00000044", "0.25") in new stack
-- Executing [01738765432@sub_trunk-outgoing-2:8] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,MDC_RESOLVENAME_HITS = 0") in new stack
-- Executing [01738765432@sub_trunk-outgoing-2:9] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,MDC_DIALCALLEENAME = ") in new stack
-- Executing [01738765432@sub_trunk-outgoing-2:10] Verbose("SIP/mdc_trunk_conf-7-00000044", "1,Telekom - 9914101") in new stack
Telekom - 9914101
-- Executing [01738765432@sub_trunk-outgoing-2:11] Set("SIP/mdc_trunk_conf-7-00000044", "__SPYGROUP=01738765432:100") in new stack
-- Executing [01738765432@sub_trunk-outgoing-2:12] Dial("SIP/mdc_trunk_conf-7-00000044", "SIP/mdc_trunk_conf-4/01738765432,,t") in new stack
-- Called SIP/mdc_trunk_conf-4/01738765432
-- SIP/mdc_trunk_conf-4-00000045 is making progress passing it to SIP/mdc_trunk_conf-7-00000044
-- SIP/mdc_trunk_conf-4-00000045 is ringing
-- SIP/mdc_trunk_conf-4-00000045 answered SIP/mdc_trunk_conf-7-00000044
-- Executing [h@sub_trunk-outgoing-2:1] Gosub("SIP/mdc_trunk_conf-7-00000044", "def_hangup,s,1(,ANSWER,,CALL)") in new stack
-- Executing [s@def_hangup:1] NoOp("SIP/mdc_trunk_conf-7-00000044", ">>>def_hangup:: EXTEN: DIALSTATUS: ANSWER QUEUESTATUS: REASON: CALL") in new stack
== Spawn extension (sub_trunk-outgoing-2, 01738765432, 12) exited non-zero on 'SIP/mdc_trunk_conf-7-00000044'
