vermutlich seit dem Update auf 7.0.6 wird auf unserem MD das Macro pre-main nicht mehr ausgeführt.
Ich habe die Einstellungen noch einmal mit der Anleitung unter http://wiki.pascom.net/confluence/display/MD76DE/Anrufablauf+per+Skript+manipulieren verglichen, aber keinen Fehler gefunden.
Im Dialplan wird mir das Macro korrekt angezeigt:
Context ‘macro-pre-main’ created by ‘pbx_config’ ]
‘s’ => 1. SYSTEM(/bin/echo -e ‘CallerID: ${CALLERID(all)},Zeitpunkt: ${STRFTIME(${EPOCH},%H:%M:%S %d.%m.%Y)}’ >> /tmp/nvtel.log) [pbx_config]
Hier die Ausgabe aus dem CLI:
== Using SIP RTP CoS mark 5
– Executing [3#68032889@mdc_berofix-d8df0d00146a:1] Goto(“SIP/d8df0d00146a-00000132”, “mdc_incoming-gw8,68032xxx,1”) in new stack
– Goto (mdc_incoming-gw8,68032xxx,1)
– Executing [68032xxx@mdc_incoming-gw8:1] Set(“SIP/d8df0d00146a-00000132”, “MDC_CALLER_NUM_TRUNK=anonymous”) in new stack
– Executing [68032xxx@mdc_incoming-gw8:2] Set(“SIP/d8df0d00146a-00000132”, “MDC_CALLEE_NUM_TRUNK=68032xxx”) in new stack
– Executing [68032xxx@mdc_incoming-gw8:3] Goto(“SIP/d8df0d00146a-00000132”, “mdc_trunk-8,s,1”) in new stack
– Goto (mdc_trunk-8,s,1)
– Executing [s@mdc_trunk-8:1] Verbose(“SIP/d8df0d00146a-00000132”, “1,callee number: 68032xxx caller number: anonymous”) in new stack
– Executing [s@mdc_trunk-8:2] GosubIf(“SIP/d8df0d00146a-00000132”, “0?sub_internat,s,1(CALLERID(num),anonymous,00)”) in new stack
– Executing [s@mdc_trunk-8:3] Gosub(“SIP/d8df0d00146a-00000132”, “sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,anonymous,00,49,0,721)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“SIP/d8df0d00146a-00000132”, “1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - CALLERID(num): anonymous - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 721”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“SIP/d8df0d00146a-00000132”, “1?s-int,1”) in new stack
– Goto (sub_nat2int,s-int,1)
– Executing [s-int@sub_nat2int:1] Verbose(“SIP/d8df0d00146a-00000132”, “1,international”) in new stack
international
– Executing [s-int@sub_nat2int:2] Set(“SIP/d8df0d00146a-00000132”, “MDC_CALLER_NUM_INTERNAT=anonymous”) in new stack
– Executing [s-int@sub_nat2int:3] Return(“SIP/d8df0d00146a-00000132”, “”) in new stack
– Executing [s@mdc_trunk-8:4] Set(“SIP/d8df0d00146a-00000132”, “CALLERID(num)=anonymous”) in new stack
– Executing [s@mdc_trunk-8:5] Gosub(“SIP/d8df0d00146a-00000132”, “sub_int2nat,s,1(MDC_CALLER_NUM_NAT,anonymous,00,49,0,721)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“SIP/d8df0d00146a-00000132”, “1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: anonymous - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 721”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“SIP/d8df0d00146a-00000132”, “1?nat”) in new stack
– Goto (sub_int2nat,s,4)
– Executing [s@sub_int2nat:4] Set(“SIP/d8df0d00146a-00000132”, “MDC_CALLER_NUM_NAT=anonymous”) in new stack
– Executing [s@sub_int2nat:5] Return(“SIP/d8df0d00146a-00000132”, “”) in new stack
– Executing [s@mdc_trunk-8:6] Set(“SIP/d8df0d00146a-00000132”, “CALLERID(num)=anonymous”) in new stack
– Executing [s@mdc_trunk-8:7] UserEvent(“SIP/d8df0d00146a-00000132”, “ResolveCallerName,Strategy: default,Outbound: 0,Channel: SIP/d8df0d00146a-00000132”) in new stack
– Executing [s@mdc_trunk-8:8] Wait(“SIP/d8df0d00146a-00000132”, “0.25”) in new stack
– Executing [s@mdc_trunk-8:9] Verbose(“SIP/d8df0d00146a-00000132”, “1,MDC_RESOLVENAME_HITS = 1”) in new stack
– Executing [s@mdc_trunk-8:10] Verbose(“SIP/d8df0d00146a-00000132”, “1,CALLERID(name) = Anonymous”) in new stack
– Executing [s@mdc_trunk-8:11] Set(“SIP/d8df0d00146a-00000132”, “MDC_NUMPREFIX_TRUNK=”) in new stack
– Executing [s@mdc_trunk-8:12] Goto(“SIP/d8df0d00146a-00000132”, “mdc_mapping-8,68032xxx,1”) in new stack
– Goto (mdc_mapping-8,68032xxx,1)
– Executing [68032xxx@mdc_mapping-8:1] Set(“SIP/d8df0d00146a-00000132”, “CHANNEL(language)=de”) in new stack
– Executing [68032xxx@mdc_mapping-8:2] Verbose(“SIP/d8df0d00146a-00000132”, “1,mapping from 68032xxx to 99”) in new stack
– Executing [68032xxx@mdc_mapping-8:3] Goto(“SIP/d8df0d00146a-00000132”, “mdc_external,99,1”) in new stack
– Goto (mdc_external,99,1)
– Executing [99@mdc_external:1] SIPAddHeader(“SIP/d8df0d00146a-00000132”, "“Alert-Info:<http://www.notused.de>;info=alert-external;x-line-id=0"”) in new stack
– Executing [99@mdc_external:2] GosubIf(“SIP/d8df0d00146a-00000132”, “1?sub_initcall,s,1(ext,99)”) in new stack
– Executing [s@sub_initcall:1] Verbose(“SIP/d8df0d00146a-00000132”, “1,sub_initcall descent: ext exten: 99”) in new stack
– Executing [s@sub_initcall:2] GosubIf(“SIP/d8df0d00146a-00000132”, “1?sub_initloop,s,1”) in new stack
– Executing [s@sub_initloop:1] Verbose(“SIP/d8df0d00146a-00000132”, “1,initial loop”) in new stack
initial loop
– Executing [s@sub_initloop:2] Set(“SIP/d8df0d00146a-00000132”, “MDC_ALIAS_HOP=0”) in new stack
– Executing [s@sub_initloop:3] Return(“SIP/d8df0d00146a-00000132”, “”) in new stack
– Executing [s@sub_initcall:3] Set(“SIP/d8df0d00146a-00000132”, “__MDC_DIALDESCENT=ext”) in new stack
– Executing [s@sub_initcall:4] Goto(“SIP/d8df0d00146a-00000132”, “ext,1”) in new stack
– Goto (sub_initcall,ext,1)
– Executing [ext@sub_initcall:1] Set(“SIP/d8df0d00146a-00000132”, “__MDC_DIALCALLERNUMINIT=anonymous”) in new stack
– Executing [ext@sub_initcall:2] Set(“SIP/d8df0d00146a-00000132”, “__MDC_DIALCALLEENUMINIT=68032xxx”) in new stack
– Executing [ext@sub_initcall:3] Return(“SIP/d8df0d00146a-00000132”, “”) in new stack
– Executing [99@mdc_external:3] Goto(“SIP/d8df0d00146a-00000132”, “main,99,1”) in new stack
– Goto (main,99,1)
– Executing [99@main:1] Gosub(“SIP/d8df0d00146a-00000132”, “sub_defcall,s,1(99)”) in new stack
– Executing [s@sub_defcall:1] Set(“SIP/d8df0d00146a-00000132”, “__MDC_ALIAS_HOP=1”) in new stack
– Executing [s@sub_defcall:2] Set(“SIP/d8df0d00146a-00000132”, “__MDC_DIALCALLEENUM=99”) in new stack
– Executing [s@sub_defcall:3] Set(“SIP/d8df0d00146a-00000132”, “__MDC_DIALCALLERNUM=anonymous”) in new stack
– Executing [s@sub_defcall:4] Set(“SIP/d8df0d00146a-00000132”, “__MDC_DIALCHANNELNAME=d8df0d00146a”) in new stack
– Executing [s@sub_defcall:5] GotoIf(“SIP/d8df0d00146a-00000132”, “1?nozap”) in new stack
– Goto (sub_defcall,s,8)
– Executing [s@sub_defcall:8] Set(“SIP/d8df0d00146a-00000132”, “__MDC_DIALCALLERNAME=Anonymous”) in new stack
– Executing [s@sub_defcall:9] Return(“SIP/d8df0d00146a-00000132”, “”) in new stack
– Executing [99@main:2] Goto(“SIP/d8df0d00146a-00000132”, “mdc_distribute,99,1”) in new stack
– Goto (mdc_distribute,99,1)
– Executing [99@mdc_distribute:1] Gosub(“SIP/d8df0d00146a-00000132”, “sub_user,s,1(callee,14,mitarbeiter,Mitarbeiter,99,99)”) in new stack
– Executing [s@sub_user:1] Verbose(“SIP/d8df0d00146a-00000132”, “1,sub_user mode callee”) in new stack
– Executing [s@sub_user:2] Goto(“SIP/d8df0d00146a-00000132”, “s-callee,1”) in new stack
– Goto (sub_user,s-callee,1)
– Executing [s-callee@sub_user:1] Verbose(“SIP/d8df0d00146a-00000132”, “1,sub_user user id: 14 - user: mitarbeiter - realname: Mitarbeiter - own mailbox: 99 - watched mailbox: 99”) in new stack
– Executing [s-callee@sub_user:2] Set(“SIP/d8df0d00146a-00000132”, “_MDC_CALLEE_USER_ID=14”) in new stack
– Executing [s-callee@sub_user:3] Set(“SIP/d8df0d00146a-00000132”, “_MDC_CALLEE_ACC_NAME=mitarbeiter”) in new stack
– Executing [s-callee@sub_user:4] Set(“SIP/d8df0d00146a-00000132”, “_MDC_CALLEE_ACC_REALNAME=Mitarbeiter”) in new stack
– Executing [s-callee@sub_user:5] Set(“SIP/d8df0d00146a-00000132”, “_MDC_CALLEE_VM_OWN=99”) in new stack
– Executing [s-callee@sub_user:6] Set(“SIP/d8df0d00146a-00000132”, “_MDC_CALLEE_VM_WATCHED=99”) in new stack
– Executing [s-callee@sub_user:7] Return(“SIP/d8df0d00146a-00000132”, “”) in new stack
– Executing [99@mdc_distribute:2] Goto(“SIP/d8df0d00146a-00000132”, “mdc_ident-14,99,1”) in new stack
– Goto (mdc_ident-14,99,1)
– Executing [99@mdc_ident-14:1] NoOp(“SIP/d8df0d00146a-00000132”, “alias-check:: call forwarding from 99 - 0”) in new stack
– Executing [99@mdc_ident-14:2] GotoIf(“SIP/d8df0d00146a-00000132”, “0?99-uml,1:99-dial,1”) in new stack
– Goto (mdc_ident-14,99-dial,1)
– Executing [99-dial@mdc_ident-14:1] Set(“SIP/d8df0d00146a-00000132”, “__MDC_EXTEN=99”) in new stack
– Executing [99-dial@mdc_ident-14:2] Gosub(“SIP/d8df0d00146a-00000132”, “sub_prefix-99,ext,1”) in new stack
– Executing [ext@sub_prefix-99:1] Verbose(“SIP/d8df0d00146a-00000132”, “1,no action”) in new stack
no action
– Executing [ext@sub_prefix-99:2] Return(“SIP/d8df0d00146a-00000132”, “”) in new stack
– Executing [99-dial@mdc_ident-14:3] GotoIf(“SIP/d8df0d00146a-00000132”, “0?99-unavail,1”) in new stack
– Executing [99-dial@mdc_ident-14:4] GotoIf(“SIP/d8df0d00146a-00000132”, “0?99-busy,1”) in new stack
– Executing [99-dial@mdc_ident-14:5] Gosub(“SIP/d8df0d00146a-00000132”, “sub_main-99,ext,1”) in new stack
– Executing [ext@sub_main-99:1] Set(“SIP/d8df0d00146a-00000132”, “__PICKUPMARK=99”) in new stack
– Executing [ext@sub_main-99:2] Set(“SIP/d8df0d00146a-00000132”, “__SPYGROUP=99”) in new stack
– Executing [ext@sub_main-99:3] Dial(“SIP/d8df0d00146a-00000132”, “Local/99@mdc_diallocation”) in new stack
– Called Local/99@mdc_diallocation
– Executing [99@mdc_diallocation:1] Verbose(“Local/99@mdc_diallocation-000002c9;2”, “1,dial to 99 for user 14”) in new stack
– Executing [99@mdc_diallocation:2] Set(“Local/99@mdc_diallocation-000002c9;2”, “MDC_EXTEN=99”) in new stack
– Executing [99@mdc_diallocation:3] Gosub(“Local/99@mdc_diallocation-000002c9;2”, “sub_split-user,s,1(14)”) in new stack
– Executing [s@sub_split-user:1] Verbose(“Local/99@mdc_diallocation-000002c9;2”, “1,get locations for for: 14”) in new stack
– Executing [s@sub_split-user:2] GotoIf(“Local/99@mdc_diallocation-000002c9;2”, “0?s-zero,1”) in new stack
– Executing [s@sub_split-user:3] Set(“Local/99@mdc_diallocation-000002c9;2”, “TMP_LOCATIONS=12;0”) in new stack
– Executing [s@sub_split-user:4] Set(“Local/99@mdc_diallocation-000002c9;2”, “TMP_STATIC_ID=12”) in new stack
– Executing [s@sub_split-user:5] Verbose(“Local/99@mdc_diallocation-000002c9;2”, “1,static id: 12”) in new stack
static id: 12
– Executing [s@sub_split-user:6] Set(“Local/99@mdc_diallocation-000002c9;2”, “TMP_DYN_ID=0”) in new stack
– Executing [s@sub_split-user:7] Verbose(“Local/99@mdc_diallocation-000002c9;2”, “1,dynamic id: 0”) in new stack
dynamic id: 0
– Executing [s@sub_split-user:8] Return(“Local/99@mdc_diallocation-000002c9;2”, “”) in new stack
– Executing [99@mdc_diallocation:4] GotoIf(“Local/99@mdc_diallocation-000002c9;2”, “0?invalid,1”) in new stack
– Executing [99@mdc_diallocation:5] GotoIf(“Local/99@mdc_diallocation-000002c9;2”, “0?dynamic,1”) in new stack
– Executing [99@mdc_diallocation:6] GotoIf(“Local/99@mdc_diallocation-000002c9;2”, “1?static,1”) in new stack
– Goto (mdc_diallocation,static,1)
– Executing [static@mdc_diallocation:1] Dial(“Local/99@mdc_diallocation-000002c9;2”, “Local/ext@mdc_locallocation-12”) in new stack
– Called Local/ext@mdc_locallocation-12
– Executing [ext@mdc_locallocation-12:1] Dial(“Local/ext@mdc_locallocation-12-000002ca;2”, “Local/ext-37@mdc_localdevice-12”) in new stack
– Called Local/ext-37@mdc_localdevice-12
– Executing [ext-37@mdc_localdevice-12:1] Verbose(“Local/ext-37@mdc_localdevice-12-000002cb;2”, “1,Dialing with delay of 0 seconds for 20 seconds”) in new stack
– Executing [ext-37@mdc_localdevice-12:2] Dial(“Local/ext-37@mdc_localdevice-12-000002cb;2”, “SIP/8otRayTuY2e870a,20”) in new stack
– Called SIP/8otRayTuY2e870a
– SIP/8otRayTuY2e870a-00000133 is ringing
