Ich kann seit 1-2 Wochen den Linux Pascom Client nicht mehr starten. Hier mal direkt der Auszug, wenn ich es per Kommando starte:
andrin@westerOS ~/pascom_Client $ ./AppRun
QApplication: invalid style override passed, ignoring it.
Available styles: Windows, Fusion
Userdir is “/home/andrin/.local/share/AppRun”
[2019-11-01 11:02:22.691] [Debug] [ui.NotificationController] unknown:0 - Primary screen changed. Rows 4 / Cols: 4
[2019-11-01 11:02:22.711] [Debug] [service.IpcService] unknown:0 - Initialized shared memory IPC
[2019-11-01 11:02:22.714] [Info] [MdApplication] unknown:0 - installationid: “{9c9432e1-c0bc-48da-8cce-0538e5b0a757}”
[2019-11-01 11:02:22.777] [Info] [service.UILoader] unknown:0 - Loading component “view/MainForm.qml”
[2019-11-01 11:02:22.891] [Warning] [default] :-1 - : QML QQuickLayoutAttached: Binding loop detected for property “preferredWidth”
[2019-11-01 11:02:22.906] [Warning] [default] :-1 - : QML QQuickLayoutAttached: Binding loop detected for property “preferredWidth”
[2019-11-01 11:02:22.919] [Info] [MdApplication] unknown:0 - “Version: 56.R659_2299eab\r\nBuild Timestamp: 20191029113657\r\nMemory: 77.8Mb used, 15.4Gb available\r\nOS: Linux Mint 18.3\r\nHostname: westerOS\r\nType: linuxmint 18.3 x86_64\r\nKernel: linux 4.15.0-66-generic\r\nInstallationId: {9c9432e1-c0bc-48da-8cce-0538e5b0a757}\r\n”
Failed to open curl lib from binary, use libcurl.so instead
{“response”:“ok”,“_rxid”:“a9000000-85e9-6f03-0000-000000000000”}
Segmentation fault (core dumped)
andrin@westerOS ~/pascom_Client $ rm /home/andrin/.local/share/AppRun/ -rfandrin@westerOS ~/pascom_Client $ ./pascom_Client
Userdir is “/home/andrin/.local/share/pascom_Client”
[2019-11-01 11:03:03.556] [Debug] [ui.NotificationController] unknown:0 - Primary screen changed. Rows 4 / Cols: 4
[2019-11-01 11:03:03.557] [Debug] [service.IpcService] unknown:0 - Initialized shared memory IPC
[2019-11-01 11:03:03.565] [Info] [MdApplication] unknown:0 - installationid: “{a1feb006-0ddd-4f54-9598-ed9338d582bb}”
[2019-11-01 11:03:03.602] [Info] [service.UILoader] unknown:0 - Loading component “view/MainForm.qml”
[2019-11-01 11:03:03.691] [Warning] [default] :-1 - : QML QQuickLayoutAttached: Binding loop detected for property “preferredWidth”
[2019-11-01 11:03:03.692] [Warning] [default] :-1 - : QML QQuickLayoutAttached: Binding loop detected for property “preferredWidth”
[2019-11-01 11:03:03.708] [Warning] [default] :-1 - : QML QQuickLayoutAttached: Binding loop detected for property “preferredWidth”
[2019-11-01 11:03:03.721] [Info] [MdApplication] unknown:0 - “Version: 56.R659_2299eab\r\nBuild Timestamp: 20191029113657\r\nMemory: 78.3Mb used, 15.4Gb available\r\nOS: Linux Mint 18.3\r\nHostname: westerOS\r\nType: linuxmint 18.3 x86_64\r\nKernel: linux 4.15.0-66-generic\r\nInstallationId: {a1feb006-0ddd-4f54-9598-ed9338d582bb}\r\n”
{“response”:“ok”,“_rxid”:“aa000000-85e9-6f03-0000-000000000000”}
Ich habe es mit verschiedenen Versionen des Client versucht (auch Beta). Es resultiert immer in dem gleichen Error.
Als root User lässt es sich problemlos ausführen. Berechtigungen stimmen aber (Owner ist der User).
Ist das ein bekannter Fehler?
Beste Grüsse
