LDAP Anzeige an Snom an Sammerruf
Ich habe das entsprechenden Amt unter “Wahl” konfiguriert sowie dem Telefon den Nummernanzeigestil im “Nummer+Name” gesetzt.
Die Nummer wird im LDAP gefunden doch sichtbar wird der Name nicht wenn der Anruf auf einen Sammelruf geht!?
– Starting simple switch on ‘Zap/1-1’
– Executing Goto(“Zap/1-1”, “mdc_trunk-1|342XXXX|1”) in new stack
– Goto (mdc_trunk-1,342XXXX,1)
– Executing Set(“Zap/1-1”, “__MDC_DIALCALLERNUM=079433XXXX”) in new stack
– Executing Set(“Zap/1-1”, “LANGUAGE()=de”) in new stack
– Executing GotoIf(“Zap/1-1”, “0?forward”) in new stack
– Executing LDAPget(“Zap/1-1”, “CALLERID(name)=cidname/079433XXXX|079433XXXX|079433XXXX”) in new stack
– LDAPget: varname=CALLERID(name), config-section=cidname, keys=079433XXXX|079433XXXX|079433XXXX
== Parsing ‘/etc/asterisk/ldap.conf’: Found
– LDAPget: ldap://localhost/dc=mobydick?cn?sub?(&(objectClass=person)(|(telephoneNumber=079433XXXX)(mobile=079433XXXX)(homephone=079433XXXX)))
– LDAPget: bind to localhost as cn=admin,dc=telefonbuch,dc=mobydick
– LDAPget: cn=Rene Natel
– LDAPget: set CALLERID(name)=‘Rene Natel’
– Executing Set(“Zap/1-1”, “CALLERID(num)=0079433XXXX”) in new stack
– Executing Goto(“Zap/1-1”, “mdc_external-1|342XXXX|1”) in new stack
– Goto (mdc_external-1,342XXXX,1)
– Executing Goto(“Zap/1-1”, “mdc_external|222|1”) in new stack
– Goto (mdc_external,222,1)
– Executing Set(“Zap/1-1”, “MDC_CHANNEL_PROTOCOL=Zap”) in new stack
– Executing Set(“Zap/1-1”, “MDC_CHANNEL_ID=1-1”) in new stack
– Executing Set(“Zap/1-1”, “MDC_CHANNEL_TMP=1-1”) in new stack
– Executing Set(“Zap/1-1”, “MDC_CHANNEL_NAME=1”) in new stack
– Executing GosubIf(“Zap/1-1”, “1?mdc_initcall-ext|222|1”) in new stack
– Executing NoOp(“Zap/1-1”, “initial call”) in new stack
– Executing Set(“Zap/1-1”, “__MDC_DIALDESCENT=ext”) in new stack
– Executing Set(“Zap/1-1”, “__MDC_DIALCALLEENUM=222”) in new stack
– Executing GotoIf(“Zap/1-1”, “0?nozap”) in new stack
– Executing Set(“Zap/1-1”, “__MDC_DIALCALLERNAME=Rene Natel”) in new stack
– Executing Return(“Zap/1-1”, “”) in new stack
– Executing Gosub(“Zap/1-1”, “mdc_defcall|222|1”) in new stack
– Executing Set(“Zap/1-1”, “__MDC_DIALCHANNELNAME=0079433XXXX”) in new stack
– Executing SIPAddHeader(“Zap/1-1”, "“Alert-Info:<http://www.notused.de>;info=alert-external;x-line-id=0"”) in new stack
– Executing Macro(“Zap/1-1”, “pre-main”) in new stack
Sep 10 14:54:00 WARNING[22268]: app_macro.c:208 macro_exec: No such context ‘macro-pre-main’ for macro ‘pre-main’
– Executing GosubIf(“Zap/1-1”, “1?mdc_initloop|s|1”) in new stack
– Executing NoOp(“Zap/1-1”, “initial loop”) in new stack
– Executing Set(“Zap/1-1”, “MDC_ALIAS_HOP=0”) in new stack
– Executing Goto(“Zap/1-1”, “main|222|1”) in new stack
– Goto (main,222,1)
– Executing Goto(“Zap/1-1”, “mdc_callgroup-1|222|1”) in new stack
– Goto (mdc_callgroup-1,222,1)
– Executing NoOp(“Zap/1-1”, “alias-check:: Rufumleitung von 222 - 0”) in new stack
– Executing GotoIf(“Zap/1-1”, “0?222-umleitung|1:222-dial|1”) in new stack
– Goto (mdc_callgroup-1,222-dial,1)
– Executing Gosub(“Zap/1-1”, “mdc_prefix-222-ext|222|1”) in new stack
– Executing Gosub(“Zap/1-1”, “mdc_main-222-ext|222|1”) in new stack
– Executing Set(“Zap/1-1”, “TOUCH_MONITOR=0079433XXXX-222-20100910-145400-ext”) in new stack
– Executing Set(“Zap/1-1”, “CALLERID(name)=Extern”) in new stack
– Executing Dial(“Zap/1-1”, “SIP/reke&SIP/rimi|60|owW”) in new stack
– Called reke
– Called rimi
– SIP/rimi-081fbcf0 is ringing
Extension Changed 12 new state Ringing for Notify User reke
– SIP/reke-081f6500 is ringing
Extension Changed 11 new state Ringing for Notify User reke
– Channel 0/1, span 1 got hangup, cause 16
== Spawn extension (mdc_main-222-ext, 222, 3) exited non-zero on ‘Zap/1-1’
– Executing Macro(“Zap/1-1”, “hangup||CANCEL|”) in new stack
Gruss
René
