ich hoffe Ihr könnt mir weiterhelfen.
Da leider die Vorlage zu toplink Xpress in der 18 und 19 nicht verwendbar ist,
habe ich das generische SIP-Amt ausprobiert.
Hierbei wurde es zwar möglich eingehende Anrufe entgegennehmen zunehmen, aber beim Versuch Anrufe durchzuführen wird in der CLi ein 500’ter Fehler zurückgegeben.
– Executing [00049151********@mdc_distribute:3] Goto(“SIP/Os1FTjArlWDC4Zt-0000002c”, “mdc_outgoing-15,0049151********,1”) in new stack
– Goto (mdc_outgoing-15,0049151********,1)
– Executing [0049151********@mdc_outgoing-15:1] Gosub(“SIP/Os1FTjArlWDC4Zt-0000002c”, “sub_trunk-outgoing-15,0049151********,1”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:1] Gosub(“SIP/Os1FTjArlWDC4Zt-0000002c”, “sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,0049151********,00,49,0,2835,0)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“SIP/Os1FTjArlWDC4Zt-0000002c”, “1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - number: 0049151******** - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 2835 - incoming: 0”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“SIP/Os1FTjArlWDC4Zt-0000002c”, “0?s-emergency,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“SIP/Os1FTjArlWDC4Zt-0000002c”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“SIP/Os1FTjArlWDC4Zt-0000002c”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“SIP/Os1FTjArlWDC4Zt-0000002c”, “0?s-convert,1”) in new stack
– Executing [s@sub_nat2int:6] GotoIf(“SIP/Os1FTjArlWDC4Zt-0000002c”, “1?s-int,1”) in new stack
– Goto (sub_nat2int,s-int,1)
– Executing [s-int@sub_nat2int:1] Verbose(“SIP/Os1FTjArlWDC4Zt-0000002c”, “1,international”) in new stack
international
– Executing [s-int@sub_nat2int:2] Set(“SIP/Os1FTjArlWDC4Zt-0000002c”, “MDC_CALLEE_NUM_INTERNAT=0049151********”) in new stack
– Executing [s-int@sub_nat2int:3] Return(“SIP/Os1FTjArlWDC4Zt-0000002c”, “”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:2] Gosub(“SIP/Os1FTjArlWDC4Zt-0000002c”, “sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,0049151********,00,49,0,2835,0)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“SIP/Os1FTjArlWDC4Zt-0000002c”, “1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 0049151******** - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 2835 - incoming: 0”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“SIP/Os1FTjArlWDC4Zt-0000002c”, “0?s-emergency,1”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“SIP/Os1FTjArlWDC4Zt-0000002c”, “0?nat”) in new stack
– Executing [s@sub_int2nat:4] GotoIf(“SIP/Os1FTjArlWDC4Zt-0000002c”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“SIP/Os1FTjArlWDC4Zt-0000002c”, “MDC_CALLEE_NUM_NAT=0151********”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“SIP/Os1FTjArlWDC4Zt-0000002c”, “”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:3] SIPAddHeader(“SIP/Os1FTjArlWDC4Zt-0000002c”, “P-Preferred-Identity: sip:02835*******@sip.toplink-xpress.de”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:4] SIPAddHeader(“SIP/Os1FTjArlWDC4Zt-0000002c”, “P-Asserted-Identity: sip:02835*******@sip.toplink-xpress.de”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:5] Set(“SIP/Os1FTjArlWDC4Zt-0000002c”, “CALLERID(num)=02835*******”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:6] GotoIf(“SIP/Os1FTjArlWDC4Zt-0000002c”, “0?searchdone”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:7] UserEvent(“SIP/Os1FTjArlWDC4Zt-0000002c”, “ResolveCallerName,Strategy: system,Outbound: 1”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:8] Wait(“SIP/Os1FTjArlWDC4Zt-0000002c”, “0.25”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:9] Verbose(“SIP/Os1FTjArlWDC4Zt-0000002c”, “1,MDC_RESOLVENAME_HITS = 0”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:10] Verbose(“SIP/Os1FTjArlWDC4Zt-0000002c”, "1,MDC_DIALCALLEENAME = ") in new stack
– Executing [0049151********@sub_trunk-outgoing-15:11] Verbose(“SIP/Os1FTjArlWDC4Zt-0000002c”, “1,end call deflection”) in new stack
end call deflection
– Executing [0049151********@sub_trunk-outgoing-15:12] Verbose(“SIP/Os1FTjArlWDC4Zt-0000002c”, “1,Top Link SIP - Standardtelefonie”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:13] Set(“SIP/Os1FTjArlWDC4Zt-0000002c”, “__SPYGROUP=0151********:102”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:14] ExecIf(“SIP/Os1FTjArlWDC4Zt-0000002c”, “0?Set(CHANNEL(hangup_handler_push)=hdlr-hint,s,1())”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:15] ExecIf(“SIP/Os1FTjArlWDC4Zt-0000002c”, “0?Set(DEVICE_STATE(Custom:)=INUSE)”) in new stack
– Executing [0049151********@sub_trunk-outgoing-15:16] Dial(“SIP/Os1FTjArlWDC4Zt-0000002c”, “SIP/mdc_trunk_conf-14/0151********,t”) in new stack
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
– Called SIP/mdc_trunk_conf-14/0151********
– Got SIP response 500 “Server Internal Error” back from 213.218.12.195:5060
– SIP/mdc_trunk_conf-14-0000002d is circuit-busy
== Everyone is busy/congested at this time (1:0/1/0)
– Executing [0049151********@sub_trunk-outgoing-15:17] Return(“SIP/Os1FTjArlWDC4Zt-0000002c”, “”) in new stack
– Executing [0049151********@mdc_outgoing-15:2] Hangup(“SIP/Os1FTjArlWDC4Zt-0000002c”, “38”) in new stack
== Spawn extension (mdc_outgoing-15, 0049151********, 2) exited non-zero on ‘SIP/Os1FTjArlWDC4Zt-0000002c’
– Executing [h@mdc_outgoing-15:1] Gosub(“SIP/Os1FTjArlWDC4Zt-0000002c”, “def_hangup,s,1(,CONGESTION,CALL)”) in new stack
– Executing [s@def_hangup:1] NoOp(“SIP/Os1FTjArlWDC4Zt-0000002c”, “>>>def_hangup:: EXTEN: DIALSTATUS: CONGESTION QUEUESTATUS: REASON: CALL”) in new stack
Neben den hier von toplink Xpress vorgegeben Einstellungen ist bei der ausgehenden Regel die CIDNumer mit der zu übermittelnden Nummer versehen worden.
