Hello Steve,
thanks for the reply,
in this case I do not even get the chance to press a dtmf key, but if i call the IVR directly I can press a digit and the selected action works.
when I wait for the upstream prompt to end, the keypad on the softphone changes back to the ‘normal’ dailer interface (with the green call button)
Connected to Asterisk 18.12.1 currently running on curaict-580fba56-da01-4e93-6665-772b7bc67451 (pid = 571)
== Using SIP RTP Audio TOS bits 184
== Using SIP RTP Audio CoS mark 5
-- Executing [9001@mdc_location:1] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "SIPCALLID=39794a1667d6419ab4981be7e43476ba") in new stack
-- Executing [9001@mdc_location:2] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_CALLER_LOCATION_ID=2") in new stack
-- Executing [9001@mdc_location:3] Gosub("PJSIP/cQnCujlemdD3uLw-0000002d", "sub_location,s,1(2,9001)") in new stack
-- Executing [s@sub_location:1] Verbose("PJSIP/cQnCujlemdD3uLw-0000002d", "1,used location id: 2 - dialed extension: 9001") in new stack
-- Executing [s@sub_location:2] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "MDC_CALLEE_NUM=9001") in new stack
-- Executing [s@sub_location:3] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [9001@mdc_location:4] Gosub("PJSIP/cQnCujlemdD3uLw-0000002d", "sub_split-location,s,1(2)") in new stack
-- Executing [s@sub_split-location:1] Verbose("PJSIP/cQnCujlemdD3uLw-0000002d", "1,get user for location: 2") in new stack
-- Executing [s@sub_split-location:2] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "0?s-zero,1") in new stack
-- Executing [s@sub_split-location:3] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "TMP_USER_ID=3") in new stack
-- Executing [s@sub_split-location:4] Verbose("PJSIP/cQnCujlemdD3uLw-0000002d", "1,user id: 3") in new stack
user id: 3
-- Executing [s@sub_split-location:5] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [9001@mdc_location:5] Gosub("PJSIP/cQnCujlemdD3uLw-0000002d", "mdc_user-3,9001,1()") in new stack
-- Executing [9001@mdc_user-3:1] Gosub("PJSIP/cQnCujlemdD3uLw-0000002d", "sub_user,s,1(caller,3,101,info,Cura ICT,101,101,101,en)") in new stack
-- Executing [s@sub_user:1] Verbose("PJSIP/cQnCujlemdD3uLw-0000002d", "1,sub_user mode caller") in new stack
-- Executing [s@sub_user:2] Goto("PJSIP/cQnCujlemdD3uLw-0000002d", "s-caller,1") in new stack
-- Goto (sub_user,s-caller,1)
-- Executing [s-caller@sub_user:1] Verbose("PJSIP/cQnCujlemdD3uLw-0000002d", "1,sub_user user id: 3 - user exten: 101 - user: info - realname: Cura ICT - own mailbox: 101 - watched mailbox: 101 - callerid(num): 101 - language: en") in new stack
-- Executing [s-caller@sub_user:2] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_CALLER_USER_ID=3") in new stack
-- Executing [s-caller@sub_user:3] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_CALLER_NUM=101") in new stack
-- Executing [s-caller@sub_user:4] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_CALLER_ACC_NAME=info") in new stack
-- Executing [s-caller@sub_user:5] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_CALLER_ACC_REALNAME=Cura ICT") in new stack
-- Executing [s-caller@sub_user:6] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_CALLER_VM_OWN=101") in new stack
-- Executing [s-caller@sub_user:7] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_CALLER_VM_WATCHED=101") in new stack
-- Executing [s-caller@sub_user:8] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "CALLERID(name)=Cura ICT") in new stack
-- Executing [s-caller@sub_user:9] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "CALLERID(num)=101") in new stack
-- Executing [s-caller@sub_user:10] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "CHANNEL(language)=en") in new stack
-- Executing [s-caller@sub_user:11] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [9001@mdc_user-3:2] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [9001@mdc_location:6] Gosub("PJSIP/cQnCujlemdD3uLw-0000002d", "sub_emergency-check,s,1(9001)") in new stack
-- Executing [s@sub_emergency-check:1] Verbose("PJSIP/cQnCujlemdD3uLw-0000002d", "1,sub_emergency-check:: exten: 9001 - descent: ") in new stack
-- Executing [s@sub_emergency-check:2] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "1?9001,1") in new stack
-- Goto (sub_emergency-check,9001,1)
-- Channel 'PJSIP/cQnCujlemdD3uLw-0000002d' sent to invalid extension: context,exten,priority=sub_emergency-check,9001,1
-- Executing [i@sub_emergency-check:1] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [9001@mdc_location:7] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "0?mdc_emergency,dial,1") in new stack
-- Executing [9001@mdc_location:8] GosubIf("PJSIP/cQnCujlemdD3uLw-0000002d", "1?sub_license_check,s,1(3)") in new stack
-- Executing [s@sub_license_check:1] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "0?skip") in new stack
-- Executing [s@sub_license_check:2] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "1?skip") in new stack
-- Goto (sub_license_check,s,7)
-- Executing [s@sub_license_check:7] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [9001@mdc_location:9] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "0?mdc_extphonecall-,9001,dial") in new stack
-- Executing [9001@mdc_location:10] Goto("PJSIP/cQnCujlemdD3uLw-0000002d", "internal,9001,1") in new stack
-- Goto (internal,9001,1)
-- Executing [9001@internal:1] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "HASH(__SIPHEADERS,Alert-info)=<http://www.notused.de>;info=alert-internal;x-line-id=0") in new stack
-- Executing [9001@internal:2] GosubIf("PJSIP/cQnCujlemdD3uLw-0000002d", "1?sub_initcall,s,1(int,9001)") in new stack
-- Executing [s@sub_initcall:1] Verbose("PJSIP/cQnCujlemdD3uLw-0000002d", "1,sub_initcall descent: int exten: 9001") in new stack
-- Executing [s@sub_initcall:2] GosubIf("PJSIP/cQnCujlemdD3uLw-0000002d", "1?sub_initloop,s,1") in new stack
-- Executing [s@sub_initloop:1] Verbose("PJSIP/cQnCujlemdD3uLw-0000002d", "1,initial loop") in new stack
initial loop
-- Executing [s@sub_initloop:2] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "MDC_ALIAS_HOP=0") in new stack
-- Executing [s@sub_initloop:3] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "MDC_MAIN_HOP=0") in new stack
-- Executing [s@sub_initloop:4] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [s@sub_initcall:3] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_TRANSFERBACK_HOP=0") in new stack
-- Executing [s@sub_initcall:4] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_DIALDESCENT=int") in new stack
-- Executing [s@sub_initcall:5] Goto("PJSIP/cQnCujlemdD3uLw-0000002d", "int,1") in new stack
-- Goto (sub_initcall,int,1)
-- Executing [int@sub_initcall:1] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_DIALCALLERNUMINIT=101") in new stack
-- Executing [int@sub_initcall:2] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_DIALCALLEENUMINIT=9001") in new stack
-- Executing [int@sub_initcall:3] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_DIALCALLEENUMMAP=9001") in new stack
-- Executing [int@sub_initcall:4] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [9001@internal:3] Goto("PJSIP/cQnCujlemdD3uLw-0000002d", "main,9001,1") in new stack
-- Goto (main,9001,1)
-- Executing [9001@main:1] ExecIf("PJSIP/cQnCujlemdD3uLw-0000002d", "0?Set(MDC_MAIN_HOP=0)") in new stack
-- Executing [9001@main:2] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "MDC_MAIN_HOP=1") in new stack
-- Executing [9001@main:3] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "0?mdc_loop,s,1") in new stack
-- Executing [9001@main:4] Gosub("PJSIP/cQnCujlemdD3uLw-0000002d", "sub_defcall,s,1(9001)") in new stack
-- Executing [s@sub_defcall:1] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_ALIAS_HOP=1") in new stack
-- Executing [s@sub_defcall:2] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_DIALCALLEENUM=9001") in new stack
-- Executing [s@sub_defcall:3] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_DIALCALLERNUM=101") in new stack
-- Executing [s@sub_defcall:4] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_DIALCALLERLANGUAGE=en") in new stack
-- Executing [s@sub_defcall:5] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_DIALCALLERNAME=Cura ICT") in new stack
-- Executing [s@sub_defcall:6] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_DIALCHANNELNAME=cQnCujlemdD3uLw") in new stack
-- Executing [s@sub_defcall:7] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [9001@main:5] GosubIf("PJSIP/cQnCujlemdD3uLw-0000002d", "1?sub_homer,s,1") in new stack
-- Executing [s@sub_homer:1] ExecIf("PJSIP/cQnCujlemdD3uLw-0000002d", "1?Set(HASH(__SIPHEADERS,P-cs-cid)=39794a1667d6419ab4981be7e43476ba)") in new stack
-- Executing [s@sub_homer:2] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [9001@main:6] Goto("PJSIP/cQnCujlemdD3uLw-0000002d", "mdc_distribute,9001,1") in new stack
-- Goto (mdc_distribute,9001,1)
-- Executing [9001@mdc_distribute:1] Goto("PJSIP/cQnCujlemdD3uLw-0000002d", "mdc_router-5,9001,1") in new stack
-- Goto (mdc_router-5,9001,1)
-- Executing [9001@mdc_router-5:1] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_DIALCHANNELNAME=9001") in new stack
-- Executing [9001@mdc_router-5:2] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_EXTEN=9001") in new stack
-- Executing [9001@mdc_router-5:3] Gosub("PJSIP/cQnCujlemdD3uLw-0000002d", "sub_main-9001,9001,1") in new stack
-- Executing [9001@sub_main-9001:1] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "CHANNEL(language)=NL") in new stack
-- Executing [9001@sub_main-9001:2] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "1?next_27") in new stack
-- Goto (sub_main-9001,9001,5)
-- Executing [9001@sub_main-9001:5] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "1?next_26") in new stack
-- Goto (sub_main-9001,9001,8)
-- Executing [9001@sub_main-9001:8] Playback("PJSIP/cQnCujlemdD3uLw-0000002d", "_welkom") in new stack
-- <PJSIP/cQnCujlemdD3uLw-0000002d> Playing '_welkom.slin' (language 'NL')
-- Executing [9001@sub_main-9001:9] Playback("PJSIP/cQnCujlemdD3uLw-0000002d", "_keuze_aankondiging") in new stack
-- <PJSIP/cQnCujlemdD3uLw-0000002d> Playing '_keuze_aankondiging.slin' (language 'NL')
-- Executing [9001@sub_main-9001:10] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "tmp_action_target=mdc_ivr-1,501,1") in new stack
-- Executing [9001@sub_main-9001:11] Goto("PJSIP/cQnCujlemdD3uLw-0000002d", "mdc_forward_action,s,1") in new stack
-- Goto (mdc_forward_action,s,1)
-- Executing [s@mdc_forward_action:1] Wait("PJSIP/cQnCujlemdD3uLw-0000002d", "0.3") in new stack
-- Executing [s@mdc_forward_action:2] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "MDC_MAIN_HOP=2") in new stack
-- Executing [s@mdc_forward_action:3] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "0?mdc_loop,s,1") in new stack
-- Executing [s@mdc_forward_action:4] Gosub("PJSIP/cQnCujlemdD3uLw-0000002d", "sub_user,s,1(callee,,,,,,)") in new stack
-- Executing [s@sub_user:1] Verbose("PJSIP/cQnCujlemdD3uLw-0000002d", "1,sub_user mode callee") in new stack
-- Executing [s@sub_user:2] Goto("PJSIP/cQnCujlemdD3uLw-0000002d", "s-callee,1") in new stack
-- Goto (sub_user,s-callee,1)
-- Executing [s-callee@sub_user:1] Verbose("PJSIP/cQnCujlemdD3uLw-0000002d", "1,sub_user user id: - user number: - user: - realname: - own mailbox: - watched mailbox: ") in new stack
-- Executing [s-callee@sub_user:2] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "_MDC_CALLEE_USER_ID=") in new stack
-- Executing [s-callee@sub_user:3] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "_MDC_CALLEE_ACC_NAME=") in new stack
-- Executing [s-callee@sub_user:4] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "_MDC_CALLEE_ACC_REALNAME=") in new stack
-- Executing [s-callee@sub_user:5] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "_MDC_DIALCALLEENAME=") in new stack
-- Executing [s-callee@sub_user:6] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "_MDC_CALLEE_VM_OWN=") in new stack
-- Executing [s-callee@sub_user:7] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "_MDC_CALLEE_VM_WATCHED=") in new stack
-- Executing [s-callee@sub_user:8] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "_MDC_DIALCALLEENUM=") in new stack
-- Executing [s-callee@sub_user:9] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [s@mdc_forward_action:5] UserEvent("PJSIP/cQnCujlemdD3uLw-0000002d", "ForwardAction,target:"mdc_ivr-1,501,1"") in new stack
-- Executing [s@mdc_forward_action:6] Goto("PJSIP/cQnCujlemdD3uLw-0000002d", "mdc_ivr-1,501,1") in new stack
-- Goto (mdc_ivr-1,501,1)
-- Executing [501@mdc_ivr-1:1] Gosub("PJSIP/cQnCujlemdD3uLw-0000002d", "sub_alias,s,1(501)") in new stack
-- Executing [s@sub_alias:1] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "tmpexten=501") in new stack
-- Executing [s@sub_alias:2] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "0?loop") in new stack
-- Executing [s@sub_alias:3] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "MDC_MAIN_HOP=3") in new stack
-- Executing [s@sub_alias:4] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "target=") in new stack
-- Executing [s@sub_alias:5] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "0?uml,1:nouml,1") in new stack
-- Goto (sub_alias,nouml,1)
-- Executing [nouml@sub_alias:1] Return("PJSIP/cQnCujlemdD3uLw-0000002d", "") in new stack
-- Executing [501@mdc_ivr-1:2] GotoIf("PJSIP/cQnCujlemdD3uLw-0000002d", "1?501-dial,1:") in new stack
-- Goto (mdc_ivr-1,501-dial,1)
-- Executing [501-dial@mdc_ivr-1:1] Set("PJSIP/cQnCujlemdD3uLw-0000002d", "__MDC_EXTEN=501") in new stack
-- Executing [501-dial@mdc_ivr-1:2] Answer("PJSIP/cQnCujlemdD3uLw-0000002d", "5") in new stack
-- Executing [501-dial@mdc_ivr-1:3] Gosub("PJSIP/cQnCujlemdD3uLw-0000002d", "sub_main-501,501,1") in new stack
-- Executing [501@sub_main-501:1] BackGround("PJSIP/cQnCujlemdD3uLw-0000002d", "_Keuzemenu") in new stack
-- <PJSIP/cQnCujlemdD3uLw-0000002d> Playing '_Keuzemenu.slin' (language 'NL')
-- Executing [501@sub_main-501:2] WaitExten("PJSIP/cQnCujlemdD3uLw-0000002d", "10") in new stack
== Spawn extension (sub_main-501, 501, 2) exited non-zero on 'PJSIP/cQnCujlemdD3uLw-0000002d'
-- Executing [h@sub_main-501:1] Gosub("PJSIP/cQnCujlemdD3uLw-0000002d", "def_hangup,s,1(501,,,CALL)") in new stack
-- Executing [s@def_hangup:1] NoOp("PJSIP/cQnCujlemdD3uLw-0000002d", ">>>def_hangup:: EXTEN: 501 DIALSTATUS: QUEUESTATUS: REASON: CALL") in new stack
