ich habe auf einer MD 7.11.03 seit dem Update das Problem, dass der Icinga Critical für den Faxserver wirft.
Auch nach mehrmaligen Neustart von hylafax oder “Faxserver Konfigurieren” bekomme ich Ihn nicht mehr Grün.
“CRITICAL: iaxmodem procs PROCS OK: 6 processes with command name ‘iaxmodem’”
Korrekt scheint der Faxserver eingerichtet zu sein, mit aktuell 5 Leitungen
Mar 23 12:36:38 localhost FaxGetty[29095]: CAUGHT SIGNAL 15
Mar 23 12:36:38 localhost FaxGetty[29095]: CLOSE /dev/ttyIAX0
Mar 23 12:36:38 localhost FaxGetty[29099]: CAUGHT SIGNAL 15
Mar 23 12:36:38 localhost FaxGetty[29099]: CLOSE /dev/ttyIAX2
Mar 23 12:36:38 localhost FaxGetty[29102]: CAUGHT SIGNAL 15
Mar 23 12:36:38 localhost FaxGetty[29102]: CLOSE /dev/ttyIAX3
Mar 23 12:36:38 localhost FaxGetty[29103]: CAUGHT SIGNAL 15
Mar 23 12:36:38 localhost FaxGetty[29103]: CLOSE /dev/ttyIAX1
Mar 23 12:36:38 localhost FaxGetty[29104]: CAUGHT SIGNAL 15
Mar 23 12:36:38 localhost FaxGetty[29104]: CLOSE /dev/ttyIAX4
Mar 23 12:36:41 localhost FaxQueuer[23533]: HylaFAX (tm) Version 6.0.5
Mar 23 12:36:41 localhost FaxQueuer[23533]: Copyright (c) 1990-1996 Sam Leffler
Mar 23 12:36:41 localhost FaxQueuer[23533]: Copyright (c) 1991-1996 Silicon Graphics, Inc.
Mar 23 12:36:41 localhost FaxQueuer[23533]: HylaClient::send: client/29221: Cannot open FIFO: No such device or address
Mar 23 12:36:41 localhost HylaFAX[23538]: Listening to 0.0.0.0:4559
Mar 23 12:36:41 localhost HylaFAX[23538]: HylaFAX INET Protocol Server: restarted.
Mar 23 12:36:41 localhost FaxGetty[23553]: Cannot open file "etc/dialrule.europe" for reading
Mar 23 12:36:41 localhost FaxGetty[23553]: Parse error in dial string rules "etc/dialrule.europe"
Mar 23 12:36:41 localhost FaxGetty[23560]: Cannot open file "etc/dialrule.europe" for reading
Mar 23 12:36:41 localhost FaxGetty[23560]: Parse error in dial string rules "etc/dialrule.europe"
Mar 23 12:36:41 localhost FaxGetty[23559]: Cannot open file "etc/dialrule.europe" for reading
Mar 23 12:36:41 localhost FaxGetty[23559]: Parse error in dial string rules "etc/dialrule.europe"
Mar 23 12:36:41 localhost FaxGetty[23570]: OPEN /dev/ttyIAX0 HylaFAX (tm) Version 6.0.5
Mar 23 12:36:41 localhost FaxGetty[23574]: OPEN /dev/ttyIAX3 HylaFAX (tm) Version 6.0.5
Mar 23 12:36:41 localhost FaxGetty[23573]: OPEN /dev/ttyIAX4 HylaFAX (tm) Version 6.0.5
Mar 23 12:36:41 localhost FaxGetty[23555]: Cannot open file "etc/dialrule.europe" for reading
Mar 23 12:36:41 localhost FaxGetty[23555]: Parse error in dial string rules "etc/dialrule.europe"
Mar 23 12:36:41 localhost FaxGetty[23581]: OPEN /dev/ttyIAX1 HylaFAX (tm) Version 6.0.5
Mar 23 12:36:41 localhost FaxGetty[23558]: Cannot open file "etc/dialrule.europe" for reading
Mar 23 12:36:41 localhost FaxGetty[23558]: Parse error in dial string rules "etc/dialrule.europe"
Mar 23 12:36:41 localhost FaxGetty[23582]: OPEN /dev/ttyIAX2 HylaFAX (tm) Version 6.0.5
Mar 23 12:36:50 localhost FaxGetty[23573]: MODEM WWW.SOFT-SWITCH.ORG spandsp/
Mar 23 12:36:50 localhost FaxGetty[23570]: MODEM WWW.SOFT-SWITCH.ORG spandsp/
Mar 23 12:36:50 localhost FaxGetty[23574]: MODEM WWW.SOFT-SWITCH.ORG spandsp/
Mar 23 12:36:50 localhost FaxGetty[23582]: MODEM WWW.SOFT-SWITCH.ORG spandsp/
Mar 23 12:36:50 localhost FaxGetty[23581]: MODEM WWW.SOFT-SWITCH.ORG spandsp/
Ein Re-check sieht so aus und keine Besserung
Mar 23 12:37:13 localhost HylaFAX[23603]: checkHostIdentity("srv2012-00.office.reinisch.de")
Mar 23 12:37:13 localhost HylaFAX[23603]: pam_authenticate failed in pamCheck with 0x7: Authentication failure
Mar 23 12:37:48 localhost icinga: EXTERNAL COMMAND: SCHEDULE_FORCED_SVC_CHECK;rei-voip;Faxserver;1458733068
Mar 23 12:37:49 localhost HylaFAX[23686]: checkHostIdentity("localhost.localdomain")
Mar 23 12:37:49 localhost HylaFAX[23686]: Parsing hostPort(): "PORT"
der Icinga meldet, dass 2x der hafxd Deamon läuft er aber wie es ausschaut nur einen haben will
Ich habe mal einen von beiden gekillt und schau mal was nun passiert
Jetzt ist icinga grün, aber nur kurzfristig. Zum test mal die Faxkonfiguration neu eingerichtet und siehe da, der Daemon ist wieder 2x da. Also nur eine kurzfristige Lösung.
der “hfaxd” sollte nur einmal laufen. Für bitte mal auf der Shell
/etc/inti.d/hylafax stop
und
/etc/init.d/iaxmodem stop
aus.
Falls dann noch Fax-Prozesse oder IAX Prozesse über sind, beende die bitte (kill).
Danach bitte wieder iaxmodem und hylafax starten
