How to make a call by using mobydick?
hi, i would like to ask how to use the mobydick to make a call? issit require any configuration by using the mobydick web interface?
thx in advance :slight_smile:
Hello xiaomax,
yes, you need to do some steps of configuration before you can make your first phonecall, e. g. specify some extensions for your users, which phones you want to use and so on.
We have a detailed step-by-step instruction (by using an example setup) over here: https://www.pascom.net/doc/en/quick-start/
Please feel free to ask in our community or contact our support (NOT free of charge) if you need further assistance.
Greetings,
hi, thx for the reply
and i would like to ask about the DHCP configuration…where do i find the server manager in the windows? thx in advance :slight_smile:
Hello xiaomax,
that depends on the windows version you are using. Please refer to the MSDN Documentation for more information on that subject.
Greetings,
