Also noch mal mit mehr Info´s !
Basisdaten sind:
Ausgehende Regel
xxx: komplette Nummer ausgehend (ohne Vorwahl)
YYY: Nummer ausgehend letzte Ziffer fehlt (ohne Vorwahl)
asterisk -rvvvvvvvvvvvvvvvv | grep 163YYY
root@pascom:/etc/admin# asterisk -rvvvvvvvvvvvvvvvv | grep 163YYY
– Executing [0163xxx@mdc_location-94:1] Verbose("SIP/d042wsNVm2SRvfD-00028dfb", "1,TEST Fax") in new stack
– Executing [0163xxx@mdc_location-94:2] Set("SIP/d042wsNVm2SRvfD-00028dfb", "__MDC_CALLER_LOCATION_ID=94") in new stack
– Executing [0163xxx@mdc_location-94:3] Set("SIP/d042wsNVm2SRvfD-00028dfb", "__MDC_CALLER_LOCATION_NAME=TEST Fax") in new stack
– Executing [0163xxx@mdc_location-94:4] Gosub("SIP/d042wsNVm2SRvfD-00028dfb", "sub_location,s,1(94,0163xxx)") in new stack
– Executing [s@sub_location:1] Verbose("SIP/d042wsNVm2SRvfD-00028dfb", "1,used location id: 94 - dialed extension: 0163xxx") in new stack
– Executing [s@sub_location:2] Set("SIP/d042wsNVm2SRvfD-00028dfb", "MDC_CALLEE_NUM=0163xxx") in new stack
– Executing [0163xxx@mdc_location-94:5] Gosub("SIP/d042wsNVm2SRvfD-00028dfb", "sub_split-location,s,1(94)") in new stack
– Executing [0163xxx@mdc_location-94:6] GotoIf("SIP/d042wsNVm2SRvfD-00028dfb", "0?mdc_user-93,163YYY,1") in new stack
– Executing [0163xxx@mdc_location-94:7] Goto("SIP/d042wsNVm2SRvfD-00028dfb", "mdc_user-93,0163xxx,1") in new stack
– Goto (mdc_user-93,0163xxx,1)
– Executing [0163xxx@mdc_user-93:1] Verbose("SIP/d042wsNVm2SRvfD-00028dfb", "1,testfax") in new stack
– Executing [0163xxx@mdc_user-93:2] Gosub("SIP/d042wsNVm2SRvfD-00028dfb", "sub_user,s,1(caller,93,498,testfax,TEST Fax,498,498,0VorwahlAnschluß498,de)") in new stack
– Executing [0163xxx@mdc_user-93:3] Gosub("SIP/d042wsNVm2SRvfD-00028dfb", "sub_emergency-check,s,1(0163xxx)") in new stack
– Executing [s@sub_emergency-check:1] Verbose("SIP/d042wsNVm2SRvfD-00028dfb", "1,sub_emergency-check:: exten: 0163xxx - descent: ") in new stack
– Executing [s@sub_emergency-check:2] GotoIf("SIP/d042wsNVm2SRvfD-00028dfb", "1?0163xxx,1") in new stack
– Goto (sub_emergency-check,0163xxx,1)
– Channel ‘SIP/d042wsNVm2SRvfD-00028dfb’ sent to invalid extension: context,exten,priority=sub_emergency-check,0163xxx,1
– Executing [0163xxx@mdc_user-93:4] GotoIf("SIP/d042wsNVm2SRvfD-00028dfb", "0?mdc_emergency,dial,1") in new stack
– Executing [0163xxx@mdc_user-93:5] GotoIf("SIP/d042wsNVm2SRvfD-00028dfb", "0?mdc_extphonecall-,0163xxx,dial") in new stack
– Executing [0163xxx@mdc_user-93:6] Goto("SIP/d042wsNVm2SRvfD-00028dfb", "internal,0163xxx,1") in new stack
– Goto (internal,0163xxx,1)
– Executing [0163xxx@internal:1] SIPAddHeader("SIP/d042wsNVm2SRvfD-00028dfb", ""Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"") in new stack
– Executing [0163xxx@internal:2] GosubIf("SIP/d042wsNVm2SRvfD-00028dfb", "1?sub_initcall,s,1(int,0163xxx)") in new stack
– Executing [s@sub_initcall:1] Verbose("SIP/d042wsNVm2SRvfD-00028dfb", "1,sub_initcall descent: int exten: 0163xxx") in new stack
– Executing [int@sub_initcall:2] Set("SIP/d042wsNVm2SRvfD-00028dfb", "__MDC_DIALCALLEENUMINIT=0163xxx") in new stack
– Executing [int@sub_initcall:3] Set("SIP/d042wsNVm2SRvfD-00028dfb", "__MDC_DIALCALLEENUMMAP=0163xxx") in new stack
– Executing [0163xxx@internal:3] Goto("SIP/d042wsNVm2SRvfD-00028dfb", "main,0163xxx,1") in new stack
– Goto (main,0163xxx,1)
– Executing [0163xxx@main:1] ExecIf("SIP/d042wsNVm2SRvfD-00028dfb", "0?Set(MDC_MAIN_HOP=0)") in new stack
– Executing [0163xxx@main:2] Set("SIP/d042wsNVm2SRvfD-00028dfb", "MDC_MAIN_HOP=1") in new stack
– Executing [0163xxx@main:3] GotoIf("SIP/d042wsNVm2SRvfD-00028dfb", "0?mdc_loop,s,1") in new stack
– Executing [0163xxx@main:4] Gosub("SIP/d042wsNVm2SRvfD-00028dfb", "sub_defcall,s,1(0163xxx)") in new stack
– Executing [s@sub_defcall:2] Set("SIP/d042wsNVm2SRvfD-00028dfb", "__MDC_DIALCALLEENUM=0163xxx") in new stack
– Executing [0163xxx@main:5] Gosub("SIP/d042wsNVm2SRvfD-00028dfb", "sub_homer,s,1") in new stack
– Executing [0163xxx@main:6] Goto("SIP/d042wsNVm2SRvfD-00028dfb", "mdc_distribute,0163xxx,1") in new stack
– Goto (mdc_distribute,0163xxx,1)
– Executing [0163xxx@mdc_distribute:1] Set("SIP/d042wsNVm2SRvfD-00028dfb", "MDC_INPREFIX_TRUNK=0") in new stack
– Executing [0163xxx@mdc_distribute:2] Verbose("SIP/d042wsNVm2SRvfD-00028dfb", "1,remove inprefix: 0") in new stack
– Executing [0163xxx@mdc_distribute:3] Goto("SIP/d042wsNVm2SRvfD-00028dfb", "mdc_outgoing-2,163xxx,1") in new stack
– Goto (mdc_outgoing-2,163xxx,1)
– Executing [163xxx@mdc_outgoing-2:1] Gosub("SIP/d042wsNVm2SRvfD-00028dfb", "sub_trunk-outgoing-2,163xxx,1") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:1] Set("SIP/d042wsNVm2SRvfD-00028dfb", "MDC_CALLEE_NUM_INTERNAT=163xxx") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:2] Set("SIP/d042wsNVm2SRvfD-00028dfb", "MDC_CALLEE_NUM_NAT=163xxx") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:3] Set("SIP/d042wsNVm2SRvfD-00028dfb", "CALLERID(name)=VorwahlOhneNullAnschlußohneDurchwahlVorwahlAnschluß 498") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:4] Set("SIP/d042wsNVm2SRvfD-00028dfb", "CALLERID(num)= VorwahlOhneNullAnschlußohneDurchwahl 0VorwahlAnschluß498") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:5] GotoIf("SIP/d042wsNVm2SRvfD-00028dfb", "0?searchdone") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:6] UserEvent("SIP/d042wsNVm2SRvfD-00028dfb", "ResolveCallerName,Strategy: system,Outbound: 1,Channel: SIP/d042wsNVm2SRvfD-00028dfb") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:7] Wait("SIP/d042wsNVm2SRvfD-00028dfb", "0.25") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:8] Verbose("SIP/d042wsNVm2SRvfD-00028dfb", "1,MDC_RESOLVENAME_HITS = 1") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:9] Verbose("SIP/d042wsNVm2SRvfD-00028dfb", "1,MDC_DIALCALLEENAME = Nachname Marcus") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:10] Verbose("SIP/d042wsNVm2SRvfD-00028dfb", "1,end call deflection") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:11] Verbose("SIP/d042wsNVm2SRvfD-00028dfb", "1,beronet - Standard") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:12] Set("SIP/d042wsNVm2SRvfD-00028dfb", "__SPYGROUP=163xxx:498") in new stack
– Executing [163xxx@sub_trunk-outgoing-2:13] Dial("SIP/d042wsNVm2SRvfD-00028dfb", "SIP/d8df0d001f50/1#163xxx,t") in new stack
– Called SIP/d8df0d001f50/1#163xxx
== Spawn extension (sub_trunk-outgoing-2, 163xxx, 13) exited non-zero on ‘SIP/d042wsNVm2SRvfD-00028dfb’
kein Anschluß unter dieser Nummer
Den IN-Prefix wird weggenommen, ist ja auch richtig, aber ich sehe keine Auswirkung vom Out-Prefix (oder erkenn ihn nicht) . Laut Doku Out-Prefix Dieser Prefix kann einer angerufenen Nummer beim Anruf vorangestellt werden.
Hier wurde auch einmal die letzte Ziffer abgeschnitten:
- Executing [0163xxx@mdc_location-94:6] GotoIf("SIP/d042wsNVm2SRvfD-00028dfb", "0?mdc_user-93,163YYY,1") in new stack
Theoretisch sollte es doch gehen, oder sehe ich das Falsch?!?!?
Grüße, Marcus
