Ganz frische Installation 19.04
… und die Telefonanlage startet nicht - Internet ist da, sowohl traceroute auf google als auch curl -i gibt entsprechende Infos - falls was mit der Lizenz nicht passt.
Nachfolgend die Fehlermeldungen aus dem Log vom dem Tele-Container:
tail -f /var/log/syslog
Feb 25 18:30:32 ullmer asterisk[1708]: #033[1;30m #033[0mAsterisk Dynamic Loader Starting:
Feb 25 18:30:32 ullmer asterisk[1708]: [Feb 25 18:30:32] #033[1;31mWARNING#033[0m[1708]: #033[1;37mloader.c#033[0m:#033[1;37m2222#033[0m #033[1;37mloader_config_init#033[0m: ‘modules.conf’ invalid or missing.
Feb 25 18:30:32 ullmer asterisk[1708]: [Feb 25 18:30:32] #033[1;31mERROR#033[0m[1708]: #033[1;37masterisk.c#033[0m:#033[1;37m3927#033[0m #033[1;37mcheck_init#033[0m: Module initialization failed. ASTERISK EXITING!
Feb 25 18:30:32 ullmer asterisk[1708]: #033[0m#033[1;30m == #033[0mManager unregistered action DBGet
Feb 25 18:30:32 ullmer asterisk[1708]: #033[1;30m == #033[0mManager unregistered action DBPut
Feb 25 18:30:32 ullmer asterisk[1708]: #033[1;30m == #033[0mManager unregistered action DBDel
Feb 25 18:30:32 ullmer asterisk[1708]: #033[1;30m == #033[0mManager unregistered action DBDelTree
Feb 25 18:30:33 ullmer systemd[1]: asterisk.service: Main process exited, code=exited, status=1/FAILURE
Feb 25 18:30:33 ullmer systemd[1]: asterisk.service: Unit entered failed state.
Feb 25 18:30:33 ullmer systemd[1]: asterisk.service: Failed with result ‘exit-code’.
Feb 25 18:30:37 ullmer systemd[1]: asterisk.service: Service hold-off time over, scheduling restart.
Feb 25 18:30:37 ullmer systemd[1]: Stopped Asterisk PBX and telephony daemon…
Feb 25 18:30:37 ullmer systemd[1]: Failed to reset devices.list on /system.slice/asterisk.service: Operation not permitted
Feb 25 18:30:37 ullmer systemd[1]: Started Asterisk PBX and telephony daemon…
Feb 25 18:30:37 ullmer asterisk[1728]: Unable to open specified master config file ‘/etc/asterisk/asterisk.conf’, using built-in defaults
Feb 25 18:30:37 ullmer asterisk[1728]: #033[0mAsterisk 16.6.1, Copyright © 1999 - 2018, Digium, Inc. and others.
Feb 25 18:30:37 ullmer asterisk[1728]: Created by Mark Spencer markster@digium.com
Feb 25 18:30:37 ullmer asterisk[1728]: Asterisk comes with ABSOLUTELY NO WARRANTY; type ‘core show warranty’ for details.
Feb 25 18:30:37 ullmer asterisk[1728]: This is free software, with components licensed under the GNU General Public
Feb 25 18:30:37 ullmer asterisk[1728]: License version 2 and other licenses; you are welcome to redistribute it under
Feb 25 18:30:37 ullmer asterisk[1728]: certain conditions. Type ‘core show license’ for details.
Feb 25 18:30:37 ullmer asterisk[1728]: =========================================================================
Feb 25 18:30:37 ullmer asterisk[1728]: XSLT support not found. XML documentation may be incomplete.
Feb 25 18:30:37 ullmer asterisk[1728]: Manager registered action DBGet
Feb 25 18:30:37 ullmer asterisk[1728]: Manager registered action DBPut
Feb 25 18:30:37 ullmer asterisk[1728]: Manager registered action DBDel
Feb 25 18:30:37 ullmer asterisk[1728]: Manager registered action DBDelTree
Feb 25 18:30:37 ullmer asterisk[1728]: PBX UUID: d487ac65-4db2-48c7-bc52-201e8eb30e66
Feb 25 18:30:37 ullmer asterisk[1728]: Unable to load config file ‘stasis.conf’
Feb 25 18:30:37 ullmer asterisk[1728]: Could not load Stasis configuration; using defaults
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘codec2’ at sample rate ‘8000’ with id ‘1’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘codec2’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘g723’ at sample rate ‘8000’ with id ‘2’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘g723’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘ulaw’ at sample rate ‘8000’ with id ‘3’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘ulaw’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘alaw’ at sample rate ‘8000’ with id ‘4’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘alaw’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘gsm’ at sample rate ‘8000’ with id ‘5’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘gsm’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘g726’ at sample rate ‘8000’ with id ‘6’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘g726’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘g726aal2’ at sample rate ‘8000’ with id ‘7’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘g726aal2’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘adpcm’ at sample rate ‘8000’ with id ‘8’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘adpcm’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘slin’ at sample rate ‘8000’ with id ‘9’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘slin’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘slin’ at sample rate ‘12000’ with id ‘10’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘slin12’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘slin’ at sample rate ‘16000’ with id ‘11’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘slin16’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘slin’ at sample rate ‘24000’ with id ‘12’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘slin24’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘slin’ at sample rate ‘32000’ with id ‘13’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘slin32’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘slin’ at sample rate ‘44100’ with id ‘14’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘slin44’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘slin’ at sample rate ‘48000’ with id ‘15’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘slin48’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘slin’ at sample rate ‘96000’ with id ‘16’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘slin96’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘slin’ at sample rate ‘192000’ with id ‘17’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘slin192’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘lpc10’ at sample rate ‘8000’ with id ‘18’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘lpc10’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘g729’ at sample rate ‘8000’ with id ‘19’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘g729’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘speex’ at sample rate ‘8000’ with id ‘20’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘speex’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘speex’ at sample rate ‘16000’ with id ‘21’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘speex16’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘speex’ at sample rate ‘32000’ with id ‘22’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘speex32’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘ilbc’ at sample rate ‘8000’ with id ‘23’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘ilbc’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘g722’ at sample rate ‘16000’ with id ‘24’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘g722’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘siren7’ at sample rate ‘16000’ with id ‘25’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘siren7’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘siren14’ at sample rate ‘32000’ with id ‘26’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘siren14’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘testlaw’ at sample rate ‘8000’ with id ‘27’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘testlaw’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘g719’ at sample rate ‘48000’ with id ‘28’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘g719’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘opus’ at sample rate ‘48000’ with id ‘29’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘opus’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘image’ codec ‘jpeg’ at sample rate ‘0’ with id ‘30’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘jpeg’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘image’ codec ‘png’ at sample rate ‘0’ with id ‘31’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘png’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘video’ codec ‘h261’ at sample rate ‘1000’ with id ‘32’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘h261’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘video’ codec ‘h263’ at sample rate ‘1000’ with id ‘33’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘h263’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘video’ codec ‘h263p’ at sample rate ‘1000’ with id ‘34’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘h263p’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘video’ codec ‘h264’ at sample rate ‘1000’ with id ‘35’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘h264’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘video’ codec ‘mpeg4’ at sample rate ‘1000’ with id ‘36’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘mpeg4’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘video’ codec ‘vp8’ at sample rate ‘1000’ with id ‘37’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘vp8’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘video’ codec ‘vp9’ at sample rate ‘1000’ with id ‘38’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘vp9’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘text’ codec ‘red’ at sample rate ‘0’ with id ‘39’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘red’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘text’ codec ‘t140’ at sample rate ‘0’ with id ‘40’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘t140’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘image’ codec ‘t38’ at sample rate ‘0’ with id ‘41’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘t38’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘none’ at sample rate ‘8000’ with id ‘42’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘none’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘silk’ at sample rate ‘8000’ with id ‘43’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘silk8’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘silk’ at sample rate ‘12000’ with id ‘44’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘silk12’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘silk’ at sample rate ‘16000’ with id ‘45’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘silk16’
Feb 25 18:30:37 ullmer asterisk[1728]: Registered ‘audio’ codec ‘silk’ at sample rate ‘24000’ with id ‘46’
Feb 25 18:30:37 ullmer asterisk[1728]: Created cached format with name ‘silk24’
Feb 25 18:30:37 ullmer asterisk[1728]: Sorcery registered wizard ‘bucket’
Feb 25 18:30:37 ullmer asterisk[1728]: Sorcery registered wizard ‘bucket_file’
Feb 25 18:30:37 ullmer asterisk[1728]: [Feb 25 18:30:37] #033[1;31mERROR#033[0m[1728]: #033[1;37mlogger.c#033[0m:#033[1;37m1816#033[0m #033[1;37minit_logger#033[0m: Errors detected in logger.conf. Default console logging is being used.
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mMessage handler ‘dialplan’ registered.
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered custom function ‘#033[1;36mMESSAGE#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered custom function ‘#033[1;36mMESSAGE_DATA#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mMessageSend#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mManager registered action MessageSend
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered channel type ‘Surrogate’ (Surrogate channel used to pull channel from an application)
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mManager registered action BridgeTechnologyList
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mManager registered action BridgeTechnologySuspend
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mManager registered action BridgeTechnologyUnsuspend
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered DNS resolver ‘system’ with priority ‘2147483647’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m #033[0mAsterisk PBX Core Initializing
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistering builtin functions:
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered custom function ‘#033[1;36mEXCEPTION#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered custom function ‘#033[1;36mTESTTIME#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mManager registered action ShowDialPlan
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mManager registered action ExtensionStateList
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mAnswer#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mBackGround#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mBusy#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mCongestion#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mExecIfTime#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mGoto#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mGotoIf#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mGotoIfTime#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mImportVar#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mHangup#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mIncomplete#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mNoOp#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mProceeding#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mProgress#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mRaiseException#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mRinging#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mSayAlpha#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mSayAlphaCase#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mSayDigits#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mSayNumber#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mSayPhonetic#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mSetAMAFlags#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mWait#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mWaitDigit#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mWaitExten#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mSet#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered application ‘#033[1;36mMSet#033[0m’
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mRegistered channel type ‘Local’ (Local Proxy Channel Driver)
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mManager registered action LocalOptimizeAway
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m #033[0mAsterisk Dynamic Loader Starting:
Feb 25 18:30:37 ullmer asterisk[1728]: [Feb 25 18:30:37] #033[1;31mWARNING#033[0m[1728]: #033[1;37mloader.c#033[0m:#033[1;37m2222#033[0m #033[1;37mloader_config_init#033[0m: ‘modules.conf’ invalid or missing.
Feb 25 18:30:37 ullmer asterisk[1728]: [Feb 25 18:30:37] #033[1;31mERROR#033[0m[1728]: #033[1;37masterisk.c#033[0m:#033[1;37m3927#033[0m #033[1;37mcheck_init#033[0m: Module initialization failed. ASTERISK EXITING!
Feb 25 18:30:37 ullmer asterisk[1728]: #033[0m#033[1;30m == #033[0mManager unregistered action DBGet
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mManager unregistered action DBPut
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mManager unregistered action DBDel
Feb 25 18:30:37 ullmer asterisk[1728]: #033[1;30m == #033[0mManager unregistered action DBDelTree
Feb 25 18:30:38 ullmer systemd[1]: asterisk.service: Main process exited, code=exited, status=1/FAILURE
Feb 25 18:30:38 ullmer systemd[1]: asterisk.service: Unit entered failed state.
Feb 25 18:30:38 ullmer systemd[1]: asterisk.service: Failed with result ‘exit-code’.
Irgendwelche Hinweise?
Gruß Michael
