Hallo Mathias,
habe nichts dergleichen entdecken können.
PP_addr at 360[a]: 0xffff
eth1: incorrect signature at 360[c]: 0xffff!=0x630E
PP_addr at 200[a]: 0xffff
eth1: incorrect signature at 200[c]: 0xffff!=0x630E
PP_addr at 220[a]: 0xffff
eth1: incorrect signature at 220[c]: 0xffff!=0x630E
PP_addr at 240[a]: 0xffff
eth1: incorrect signature at 240[c]: 0xffff!=0x630E
PP_addr at 260[a]: 0xffff
eth1: incorrect signature at 260[c]: 0xffff!=0x630E
PP_addr at 280[a]: 0xffff
eth1: incorrect signature at 280[c]: 0xffff!=0x630E
PP_addr at 2a0[a]: 0xffff
eth1: incorrect signature at 2a0[c]: 0xffff!=0x630E
PP_addr at 2c0[a]: 0xffff
eth1: incorrect signature at 2c0[c]: 0xffff!=0x630E
PP_addr at 2e0[a]: 0xffff
eth1: incorrect signature at 2e0[c]: 0xffff!=0x630E
cs89x0: no cs8900 or cs8920 detected. Be sure to disable PnP with SETUP
Trying to free nonexistent resource <0000000000000000-0000000000000010>
forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.56.
8139too Fast Ethernet driver 0.9.27
ACPI: PCI Interrupt 0000:00:0b.0[A] -> GSI 19 (level, low) -> IRQ 177
eth1: RealTek RTL8139 at 0xf000, 00:30:18:ae:0d:c8, IRQ 177
eth1: Identified 8139 chip type ‘RTL-8100B/8139D’
depca: probe of depca.0 failed with error -16
eth%d: i82596 initialization timed out
tun: Universal TUN/TAP device driver, 1.6
tun: © 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
dmfe: Davicom DM9xxx net driver, version 1.36.4 (2002-01-17)
winbond-840.c:v1.01-d (2.4 port) Nov-17-2001 Donald Becker <becker@scyld.com>
http://www.scyld.com/network/drivers.html
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:0f.1
ACPI: PCI Interrupt Link [ALKA] enabled at IRQ 20
ACPI: PCI Interrupt 0000:00:0f.1[A] -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 185
PCI: VIA IRQ fixup for 0000:00:0f.1, from 255 to 9
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
ide0: BM-DMA at 0xf800-0xf807, BIOS settings: hda:pio, hdb:pio
ide1: BM-DMA at 0xf808-0xf80f, BIOS settings: hdc:pio, hdd:pio
Probing IDE interface ide0…
Probing IDE interface ide1…
Loading Adaptec I2O RAID: Version 2.4 Build 5go
Detecting Adaptec I2O RAID controllers…
Adaptec aacraid driver (1.1-5[2409]-mh2)
megasas: 00.00.03.01 Sun May 14 22:49:52 PDT 2006
3ware Storage Controller device driver for Linux v1.26.02.001.
3ware 9000 Storage Controller device driver for Linux v2.26.06.003-2.6.18.
ipr: IBM Power RAID SCSI Device Driver version: 2.1.3 (March 29, 2006)
libata version 2.00 loaded.
sata_via 0000:00:0f.0: version 2.0
ACPI: PCI Interrupt 0000:00:0f.0** -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 185
sata_via 0000:00:0f.0: routed to hard irq line 11
ata1: SATA max UDMA/133 cmd 0xFD00 ctl 0xFC02 bmdma 0xF900 irq 185
ata2: SATA max UDMA/133 cmd 0xFB00 ctl 0xFA02 bmdma 0xF908 irq 185
scsi2 : sata_via
ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata1.00: ATA-7, max UDMA/133, 156301488 sectors: LBA48 NCQ (depth 0/32)
ata1.00: ata1: dev 0 multi count 16
ata1.00: configured for UDMA/133
scsi3 : sata_via
ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xFB07
Vendor: ATA Model: ST980811AS Rev: 3.AL
Type: Direct-Access ANSI SCSI revision: 05
SCSI device sda: 156301488 512-byte hdwr sectors (80026 MB)
sda: Write Protect is off
sda: Mode Sense: 00 3a 00 00
SCSI device sda: drive cache: write back
sda: sda1 sda2 sda3
sd 2:0:0:0: Attached scsi disk sda
sd 2:0:0:0: Attached scsi generic sg0 type 0
Fusion MPT base driver 3.04.01
Copyright © 1999-2005 LSI Logic Corporation
Fusion MPT SPI Host driver 3.04.01
Fusion MPT FC Host driver 3.04.01
Fusion MPT SAS Host driver 3.04.01
ACPI: PCI Interrupt Link [ALKB] enabled at IRQ 21
ACPI: PCI Interrupt 0000:00:10.4[C] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 193
PCI: VIA IRQ fixup for 0000:00:10.4, from 11 to 1
ehci_hcd 0000:00:10.4: EHCI Host Controller
ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:10.4: irq 193, io mem 0xfdffc000
ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 8 ports detected
ohci_hcd: 2005 April 22 USB 1.1 ‘Open’ Host Controller (OHCI) Driver (PCI)
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:10.0[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 193
PCI: VIA IRQ fixup for 0000:00:10.0, from 10 to 1
uhci_hcd 0000:00:10.0: UHCI Host Controller
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:10.0: irq 193, io base 0x0000f700
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.1[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 193
PCI: VIA IRQ fixup for 0000:00:10.1, from 10 to 1
uhci_hcd 0000:00:10.1: UHCI Host Controller
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:10.1: irq 193, io base 0x0000f600
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.2** -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 193
PCI: VIA IRQ fixup for 0000:00:10.2, from 11 to 1
uhci_hcd 0000:00:10.2: UHCI Host Controller
uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:10.2: irq 193, io base 0x0000f500
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
usb 1-2: new high speed USB device using ehci_hcd and address 2
ACPI: PCI Interrupt 0000:00:10.3** -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 193
PCI: VIA IRQ fixup for 0000:00:10.3, from 11 to 1
uhci_hcd 0000:00:10.3: UHCI Host Controller
uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 5
uhci_hcd 0000:00:10.3: irq 193, io base 0x0000f400
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 2 ports detected
usb 1-2: configuration #1 chosen from 1 choice
Initializing USB Mass Storage driver…
scsi4 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
EISA: Probing bus 0 at eisa.0
EISA: Detected 0 cards.
TCP bic registered
NET: Registered protocol family 1
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI Shortcut mode
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Time: tsc clocksource has been installed.
Freeing unused kernel memory: 368k freed
input: AT Translated Set 2 keyboard as /class/input/input0
kjournald starting. Commit interval 5 seconds
EXT3 FS on sda2, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
EXT3 FS on sda3, internal journal
cloop: Initializing cloop v2.06
cloop: loaded (max 8 devices)
cloop: /SYSTEM/mobydick.gz: 4213 blocks, 131072 bytes/block, largest block is 131118 bytes.
aufs 20090126
ISO 9660 Extensions: RRIP_1991A
Vendor: Generic Model: STORAGE DEVICE Rev: 9228
Type: Direct-Access ANSI SCSI revision: 00
sd 4:0:0:0: Attached scsi removable disk sdb
sd 4:0:0:0: Attached scsi generic sg1 type 0
usb-storage: device scan complete
agpgart: Detected VIA P4M800CE chipset
agpgart: AGP aperture is 128M @ 0xe8000000
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
input: PC Speaker as /class/input/input1
input: ImPS/2 Logitech Wheel Mouse as /class/input/input2
ts: Compaq touchscreen protocol output
mice: PS/2 mouse device common for all mice
eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
eth1: link up, 100Mbps, full-duplex, lpa 0xC1E1
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Capability LSM initialized
eth1: no IPv6 routers present
eth0: no IPv6 routers present
Zapata Telephony Interface Registered on major 196
Zaptel Version: 1.2.27
Zaptel Echo Canceller: MG2
qozap: no version for “zt_receive” found: kernel tainted.
ACPI: PCI Interrupt 0000:00:08.0[A] -> GSI 17 (level, low) -> IRQ 201
qozap: Starting hardware watchdog.
qozap: Junghanns.NET quadBRI (Version 2.0) card configured at io port 0xff00 IRQ 201 HZ 1000 CardID 0
qozap: S/T ports: 4 TE NT NT NT ]
qozap: 1 multiBRI card(s) in this box, 4 BRI ports total, bloop 0, pcmslave 0, dacs 1.
Registered tone zone 29 (Germany)
zaptel Disabled echo canceller because of tone (rx) on channel 2
eth1: link down
eth1: link down
eth1: link down
eth1: link down
eth1: link down
eth1: link down
eth1: link down
eth1: link down
Hast du dazu noch eine Idee?
Andi******
