Die Telefonbuchsuche war grundsätzlich aktiviert… aber auch ein ausschalten hat mich nicht weiter gebracht.  Kurioserweise wird im MD Client ein/ausgehend korrekt angezeigt.
-- Executing [102@mdc_location-3:1] Verbose("SIP/Si9TqiSsL8483b2-00000102", "1,Uwe Steuer") in new stack
Uwe Steuer
– Executing [102@mdc_location-3:2] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_CALLER_LOCATION_ID=3”) in new stack
– Executing [102@mdc_location-3:3] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_CALLER_LOCATION_NAME=Uwe Steuer”) in new stack
– Executing [102@mdc_location-3:4] Gosub(“SIP/Si9TqiSsL8483b2-00000102”, “sub_location,s,1(3,102)”) in new stack
– Executing [s@sub_location:1] Verbose(“SIP/Si9TqiSsL8483b2-00000102”, “1,used location id: 3 - dialed extension: 102”) in new stack
– Executing [s@sub_location:2] Set(“SIP/Si9TqiSsL8483b2-00000102”, “MDC_CALLEE_NUM=102”) in new stack
– Executing [s@sub_location:3] Return(“SIP/Si9TqiSsL8483b2-00000102”, “”) in new stack
– Executing [102@mdc_location-3:5] Gosub(“SIP/Si9TqiSsL8483b2-00000102”, “sub_split-location,s,1(3)”) in new stack
– Executing [s@sub_split-location:1] Verbose(“SIP/Si9TqiSsL8483b2-00000102”, “1,get user for location: 3”) in new stack
– Executing [s@sub_split-location:2] GotoIf(“SIP/Si9TqiSsL8483b2-00000102”, “0?s-zero,1”) in new stack
– Executing [s@sub_split-location:3] Set(“SIP/Si9TqiSsL8483b2-00000102”, “TMP_USER_ID=4”) in new stack
– Executing [s@sub_split-location:4] Verbose(“SIP/Si9TqiSsL8483b2-00000102”, “1,user id: 4”) in new stack
user id: 4
– Executing [s@sub_split-location:5] Return(“SIP/Si9TqiSsL8483b2-00000102”, “”) in new stack
– Executing [102@mdc_location-3:6] Goto(“SIP/Si9TqiSsL8483b2-00000102”, “mdc_user-4,102,1”) in new stack
– Goto (mdc_user-4,102,1)
– Executing [102@mdc_user-4:1] Verbose(“SIP/Si9TqiSsL8483b2-00000102”, “1,uwe.steuer”) in new stack
uwe.steuer
– Executing [102@mdc_user-4:2] Gosub(“SIP/Si9TqiSsL8483b2-00000102”, “sub_user,s,1(caller,4,101,uwe.steuer,Uwe Steuer,101,101,4922384794972)”) in new stack
– Executing [s@sub_user:1] Verbose(“SIP/Si9TqiSsL8483b2-00000102”, “1,sub_user mode caller”) in new stack
– Executing [s@sub_user:2] Goto(“SIP/Si9TqiSsL8483b2-00000102”, “s-caller,1”) in new stack
– Goto (sub_user,s-caller,1)
– Executing [s-caller@sub_user:1] Verbose(“SIP/Si9TqiSsL8483b2-00000102”, “1,sub_user user id: 4 - user exten: 101 - user: uwe.steuer - realname: Uwe Steuer - own mailbox: 101 - watched mailbox: 101 - callerid(num): 4922384794972”) in new stack
– Executing [s-caller@sub_user:2] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_CALLER_USER_ID=4”) in new stack
– Executing [s-caller@sub_user:3] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_CALLER_NUM=101”) in new stack
– Executing [s-caller@sub_user:4] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_CALLER_ACC_NAME=uwe.steuer”) in new stack
– Executing [s-caller@sub_user:5] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_CALLER_ACC_REALNAME=Uwe Steuer”) in new stack
– Executing [s-caller@sub_user:6] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_CALLER_VM_OWN=101”) in new stack
– Executing [s-caller@sub_user:7] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_CALLER_VM_WATCHED=101”) in new stack
– Executing [s-caller@sub_user:8] Set(“SIP/Si9TqiSsL8483b2-00000102”, “CALLERID(name)=Uwe Steuer”) in new stack
– Executing [s-caller@sub_user:9] Set(“SIP/Si9TqiSsL8483b2-00000102”, “CALLERID(num)=4922384794972”) in new stack
– Executing [s-caller@sub_user:10] Return(“SIP/Si9TqiSsL8483b2-00000102”, “”) in new stack
– Executing [102@mdc_user-4:3] Goto(“SIP/Si9TqiSsL8483b2-00000102”, “internal,102,1”) in new stack
– Goto (internal,102,1)
– Executing [102@internal:1] SIPAddHeader(“SIP/Si9TqiSsL8483b2-00000102”, "“Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"”) in new stack
– Executing [102@internal:2] GosubIf(“SIP/Si9TqiSsL8483b2-00000102”, “1?sub_initcall,s,1(int,102)”) in new stack
– Executing [s@sub_initcall:1] Verbose(“SIP/Si9TqiSsL8483b2-00000102”, “1,sub_initcall descent: int exten: 102”) in new stack
– Executing [s@sub_initcall:2] GosubIf(“SIP/Si9TqiSsL8483b2-00000102”, “1?sub_initloop,s,1”) in new stack
– Executing [s@sub_initloop:1] Verbose(“SIP/Si9TqiSsL8483b2-00000102”, “1,initial loop”) in new stack
initial loop
– Executing [s@sub_initloop:2] Set(“SIP/Si9TqiSsL8483b2-00000102”, “MDC_ALIAS_HOP=0”) in new stack
– Executing [s@sub_initloop:3] Return(“SIP/Si9TqiSsL8483b2-00000102”, “”) in new stack
– Executing [s@sub_initcall:3] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_TRANSFERBACK_HOP=0”) in new stack
– Executing [s@sub_initcall:4] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_DIALDESCENT=int”) in new stack
– Executing [s@sub_initcall:5] Goto(“SIP/Si9TqiSsL8483b2-00000102”, “int,1”) in new stack
– Goto (sub_initcall,int,1)
– Executing [int@sub_initcall:1] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_DIALCALLERNUMINIT=101”) in new stack
– Executing [int@sub_initcall:2] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_DIALCALLEENUMINIT=102”) in new stack
– Executing [int@sub_initcall:3] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_DIALCALLEENUMMAP=102”) in new stack
– Executing [int@sub_initcall:4] Return(“SIP/Si9TqiSsL8483b2-00000102”, “”) in new stack
– Executing [102@internal:3] Goto(“SIP/Si9TqiSsL8483b2-00000102”, “main,102,1”) in new stack
– Goto (main,102,1)
– Executing [102@main:1] Gosub(“SIP/Si9TqiSsL8483b2-00000102”, “sub_defcall,s,1(102)”) in new stack
– Executing [s@sub_defcall:1] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_ALIAS_HOP=1”) in new stack
– Executing [s@sub_defcall:2] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_DIALCALLEENUM=102”) in new stack
– Executing [s@sub_defcall:3] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_DIALCALLERNUM=4922384794972”) in new stack
– Executing [s@sub_defcall:4] GotoIf(“SIP/Si9TqiSsL8483b2-00000102”, “1?nozap”) in new stack
– Goto (sub_defcall,s,8)
– Executing [s@sub_defcall:8] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_DIALCALLERNAME=Uwe Steuer”) in new stack
– Executing [s@sub_defcall:9] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_DIALCHANNELNAME=Si9TqiSsL8483b2”) in new stack
– Executing [s@sub_defcall:10] Return(“SIP/Si9TqiSsL8483b2-00000102”, “”) in new stack
– Executing [102@main:2] Goto(“SIP/Si9TqiSsL8483b2-00000102”, “mdc_distribute,102,1”) in new stack
– Goto (mdc_distribute,102,1)
– Executing [102@mdc_distribute:1] Gosub(“SIP/Si9TqiSsL8483b2-00000102”, “sub_user,s,1(callee,5,jens.kirschneit,Jens Kirschneit,102,102)”) in new stack
– Executing [s@sub_user:1] Verbose(“SIP/Si9TqiSsL8483b2-00000102”, “1,sub_user mode callee”) in new stack
– Executing [s@sub_user:2] Goto(“SIP/Si9TqiSsL8483b2-00000102”, “s-callee,1”) in new stack
– Goto (sub_user,s-callee,1)
– Executing [s-callee@sub_user:1] Verbose(“SIP/Si9TqiSsL8483b2-00000102”, “1,sub_user user id: 5 - user: jens.kirschneit - realname: Jens Kirschneit - own mailbox: 102 - watched mailbox: 102”) in new stack
– Executing [s-callee@sub_user:2] Set(“SIP/Si9TqiSsL8483b2-00000102”, “_MDC_CALLEE_USER_ID=5”) in new stack
– Executing [s-callee@sub_user:3] Set(“SIP/Si9TqiSsL8483b2-00000102”, “_MDC_CALLEE_ACC_NAME=jens.kirschneit”) in new stack
– Executing [s-callee@sub_user:4] Set(“SIP/Si9TqiSsL8483b2-00000102”, “_MDC_CALLEE_ACC_REALNAME=Jens Kirschneit”) in new stack
– Executing [s-callee@sub_user:5] Set(“SIP/Si9TqiSsL8483b2-00000102”, “_MDC_CALLEE_VM_OWN=102”) in new stack
– Executing [s-callee@sub_user:6] Set(“SIP/Si9TqiSsL8483b2-00000102”, “_MDC_CALLEE_VM_WATCHED=102”) in new stack
– Executing [s-callee@sub_user:7] Return(“SIP/Si9TqiSsL8483b2-00000102”, “”) in new stack
– Executing [102@mdc_distribute:2] Goto(“SIP/Si9TqiSsL8483b2-00000102”, “mdc_ident-5,102,1”) in new stack
– Goto (mdc_ident-5,102,1)
– Executing [102@mdc_ident-5:1] NoOp(“SIP/Si9TqiSsL8483b2-00000102”, “alias-check:: call forwarding from 102 - 0”) in new stack
– Executing [102@mdc_ident-5:2] GotoIf(“SIP/Si9TqiSsL8483b2-00000102”, “0?102-uml,1:102-dial,1”) in new stack
– Goto (mdc_ident-5,102-dial,1)
– Executing [102-dial@mdc_ident-5:1] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__MDC_EXTEN=102”) in new stack
– Executing [102-dial@mdc_ident-5:2] Gosub(“SIP/Si9TqiSsL8483b2-00000102”, “sub_prefix-102,int,1”) in new stack
– Executing [int@sub_prefix-102:1] Verbose(“SIP/Si9TqiSsL8483b2-00000102”, “1,no action”) in new stack
no action
– Executing [int@sub_prefix-102:2] Return(“SIP/Si9TqiSsL8483b2-00000102”, “”) in new stack
– Executing [102-dial@mdc_ident-5:3] GotoIf(“SIP/Si9TqiSsL8483b2-00000102”, “0?102-unavail,1”) in new stack
– Executing [102-dial@mdc_ident-5:4] GotoIf(“SIP/Si9TqiSsL8483b2-00000102”, “0?102-busy,1”) in new stack
– Executing [102-dial@mdc_ident-5:5] Gosub(“SIP/Si9TqiSsL8483b2-00000102”, “sub_main-102,int,1”) in new stack
– Executing [int@sub_main-102:1] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__PICKUPMARK=102”) in new stack
– Executing [int@sub_main-102:2] Set(“SIP/Si9TqiSsL8483b2-00000102”, “__SPYGROUP=102”) in new stack
– Executing [int@sub_main-102:3] Dial(“SIP/Si9TqiSsL8483b2-00000102”, “Local/102@mdc_diallocation”) in new stack
– Called Local/102@mdc_diallocation
– Executing [102@mdc_diallocation:1] Verbose(“Local/102@mdc_diallocation-00000122;2”, “1,dial to 102 for user 5”) in new stack
– Executing [102@mdc_diallocation:2] Set(“Local/102@mdc_diallocation-00000122;2”, “__MDC_DIALLOCATION_CHANNEL=Local/102@mdc_diallocation-00000122;2”) in new stack
– Executing [102@mdc_diallocation:3] Set(“Local/102@mdc_diallocation-00000122;2”, “SHARED(MDC_CALLEE_PEERS)=”) in new stack
– Executing [102@mdc_diallocation:4] Set(“Local/102@mdc_diallocation-00000122;2”, “MDC_EXTEN=102”) in new stack
– Executing [102@mdc_diallocation:5] ExecIf(“Local/102@mdc_diallocation-00000122;2”, “0?Set(TMP_TARGET=team):Set(TMP_TARGET=int)”) in new stack
– Executing [102@mdc_diallocation:6] Gosub(“Local/102@mdc_diallocation-00000122;2”, “sub_split-user,s,1(5)”) in new stack
– Executing [s@sub_split-user:1] Verbose(“Local/102@mdc_diallocation-00000122;2”, “1,get locations for for: 5”) in new stack
– Executing [s@sub_split-user:2] GotoIf(“Local/102@mdc_diallocation-00000122;2”, “0?s-zero,1”) in new stack
– Executing [s@sub_split-user:3] Set(“Local/102@mdc_diallocation-00000122;2”, “TMP_LOCATIONS=4;0”) in new stack
– Executing [s@sub_split-user:4] Set(“Local/102@mdc_diallocation-00000122;2”, “TMP_STATIC_ID=4”) in new stack
– Executing [s@sub_split-user:5] Verbose(“Local/102@mdc_diallocation-00000122;2”, “1,static id: 4”) in new stack
static id: 4
– Executing [s@sub_split-user:6] Set(“Local/102@mdc_diallocation-00000122;2”, “TMP_DYN_ID=0”) in new stack
– Executing [s@sub_split-user:7] Verbose(“Local/102@mdc_diallocation-00000122;2”, “1,dynamic id: 0”) in new stack
dynamic id: 0
– Executing [s@sub_split-user:8] Return(“Local/102@mdc_diallocation-00000122;2”, “”) in new stack
– Executing [102@mdc_diallocation:7] GotoIf(“Local/102@mdc_diallocation-00000122;2”, “0?invalid,1”) in new stack
– Executing [102@mdc_diallocation:8] GotoIf(“Local/102@mdc_diallocation-00000122;2”, “0?dynamic,1”) in new stack
– Executing [102@mdc_diallocation:9] GotoIf(“Local/102@mdc_diallocation-00000122;2”, “1?static,1”) in new stack
– Goto (mdc_diallocation,static,1)
– Executing [static@mdc_diallocation:1] Dial(“Local/102@mdc_diallocation-00000122;2”, “Local/int@mdc_locallocation-4”) in new stack
– Called Local/int@mdc_locallocation-4
– Executing [int@mdc_locallocation-4:1] Set(“Local/int@mdc_locallocation-4-00000123;2”, “PUSH(SHARED(MDC_CALLEE_PEERS,Local/102@mdc_diallocation-00000122;2))=Local/int-3@mdc_localdevice-4”) in new stack
– Executing [int@mdc_locallocation-4:2] Set(“Local/int@mdc_locallocation-4-00000123;2”, “PUSH(SHARED(MDC_CALLEE_PEERS,Local/102@mdc_diallocation-00000122;2))=Local/int-5@mdc_localdevice-4”) in new stack
– Executing [int@mdc_locallocation-4:3] Dial(“Local/int@mdc_locallocation-4-00000123;2”, “Local/int-3@mdc_localdevice-4&Local/int-5@mdc_localdevice-4”) in new stack
– Called Local/int-3@mdc_localdevice-4
– Executing [int-3@mdc_localdevice-4:1] Verbose(“Local/int-3@mdc_localdevice-4-00000124;2”, “1,Dialing with delay of 0 seconds for 999 seconds”) in new stack
– Executing [int-3@mdc_localdevice-4:2] Dial(“Local/int-3@mdc_localdevice-4-00000124;2”, “SIP/ac8n9BFAuboRMg3,999”) in new stack
– Called Local/int-5@mdc_localdevice-4
– Executing [int-5@mdc_localdevice-4:1] Verbose(“Local/int-5@mdc_localdevice-4-00000125;2”, “1,Dialing with delay of 0 seconds for 999 seconds”) in new stack
– Executing [int-5@mdc_localdevice-4:2] Dial(“Local/int-5@mdc_localdevice-4-00000125;2”, “SIP/briFpkLqV71d4fa,999”) in new stack
[Feb 18 10:22:04] WARNING[4861][C-000000a1]: app_dial.c:2437 dial_exec_full: Unable to create channel of type ‘SIP’ (cause 20 - Subscriber absent)
– Executing [int-3@mdc_localdevice-4:3] Verbose(“Local/int-3@mdc_localdevice-4-00000124;2”, “1,mdc_localdevice-Dialstatus: CHANUNAVAIL - cause: 20”) in new stack
– Executing [int-3@mdc_localdevice-4:4] Gosub(“Local/int-3@mdc_localdevice-4-00000124;2”, “sub_hangup,s,1(CHANUNAVAIL)”) in new stack
– Executing [s@sub_hangup:1] Verbose(“Local/int-3@mdc_localdevice-4-00000124;2”, “1,sub_hangup dialstatus: CHANUNAVAIL”) in new stack
– Executing [s@sub_hangup:2] GotoIf(“Local/int-3@mdc_localdevice-4-00000124;2”, “0?noanswer,1”) in new stack
– Executing [s@sub_hangup:3] GotoIf(“Local/int-3@mdc_localdevice-4-00000124;2”, “0?busy,1”) in new stack
– Executing [s@sub_hangup:4] GotoIf(“Local/int-3@mdc_localdevice-4-00000124;2”, “0?busy,1”) in new stack
– Executing [s@sub_hangup:5] Goto(“Local/int-3@mdc_localdevice-4-00000124;2”, “unavailable,1”) in new stack
– Goto (sub_hangup,unavailable,1)
– Executing [unavailable@sub_hangup:1] Hangup(“Local/int-3@mdc_localdevice-4-00000124;2”, “20”) in new stack
== Spawn extension (sub_hangup, unavailable, 1) exited non-zero on ‘Local/int-3@mdc_localdevice-4-00000124;2’
== Using SIP VIDEO CoS mark 6
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
– Called SIP/briFpkLqV71d4fa
== Extension Changed 102[mdc_hint-ident] new state Ringing for Notify User Si9TqiSsL8483b2
== Extension Changed 102[mdc_hint-ident] new state Ringing for Notify User briFpkLqV71d4fa
– SIP/briFpkLqV71d4fa-00000103 is ringing
– Local/int-5@mdc_localdevice-4-00000125;1 is ringing
– Local/int@mdc_locallocation-4-00000123;1 is ringing
– Local/102@mdc_diallocation-00000122;1 is ringing
== Spawn extension (sub_main-102, int, 3) exited non-zero on ‘SIP/Si9TqiSsL8483b2-00000102’
– Executing [h@sub_main-102:1] Gosub(“SIP/Si9TqiSsL8483b2-00000102”, “def_hangup,s,1(102,CANCEL,CALL)”) in new stack
– Executing [s@def_hangup:1] NoOp(“SIP/Si9TqiSsL8483b2-00000102”, “>>>def_hangup:: EXTEN: 102 DIALSTATUS: CANCEL QUEUESTATUS:  REASON: CALL”) in new stack
== Spawn extension (mdc_diallocation, static, 1) exited non-zero on ‘Local/102@mdc_diallocation-00000122;2’
== Spawn extension (mdc_locallocation-4, int, 3) exited non-zero on ‘Local/int@mdc_locallocation-4-00000123;2’
== Spawn extension (mdc_localdevice-4, int-5, 2) exited non-zero on ‘Local/int-5@mdc_localdevice-4-00000125;2’
== Extension Changed 102[mdc_hint-ident] new state Idle for Notify User Si9TqiSsL8483b2
== Extension Changed 102[mdc_hint-ident] new state Idle for Notify User briFpkLqV71d4fa
