Guten Tag,
bei einem Kunden ist der Zugriff auf das LDAP-Telefonbuch der pascom vom M65 aus nicht mehr möglich.
Bei einem eingehenden Anruf erscheint im Syslofg der M700:
loc7 .Info 2017-08-28T13:08:57Z 173- Call Incoming user M65_07]
loc3 .Info 2017-08-28T13:08:57Z 173- LDAP: TCP not ready 1]
loc3 .Info 2017-08-28T13:08:57Z 173- LDAP: LDAP_BIND_CFM fails. 49]
loc7 .Info 2017-08-28T13:09:02Z 173- Call Release user M65_07]
Das LDAP-Log zu diesem Zeitpunkt:
Aug 28 13:08:59 localhost slapd[4684]: conn=1003 fd=12 ACCEPT from IP=127.0.0.1:33926 (IP=0.0.0.0:389)
Aug 28 13:08:59 localhost slapd[4684]: conn=1003 op=0 SRCH base="" scope=2 deref=3 filter="(|(telephoneNumber=*035141887711)(mobile=*035141887711)(homePhone=*035141887711)(facsimileTelephoneNumber=*035141887711)(telephoneNumber=*035141887711)(mobile=*035141887711)(homePhone=*035141887711)(facsimileTelephoneNumber=*035141887711)(telephoneNumber=*035141887711)(mobile=*035141887711)(homePhone=*035141887711)(facsimileTelephoneNumber=*035141887711))"
Aug 28 13:08:59 localhost slapd[4684]: conn=1003 op=0 SEARCH RESULT tag=101 err=0 nentries=2 text=
Aug 28 13:08:59 localhost slapd[4684]: conn=1003 fd=12 closed (connection lost)
Aug 28 13:09:00 localhost slapd[4684]: conn=1004 fd=12 ACCEPT from IP=192.168.0.110:46430 (IP=0.0.0.0:389)
Aug 28 13:09:00 localhost slapd[4684]: conn=1004 op=0 BIND dn="" method=128
Aug 28 13:09:00 localhost slapd[4684]: conn=1004 op=0 RESULT tag=97 err=0 text=
Aug 28 13:09:00 localhost slapd[4684]: conn=1004 op=1 SRCH base="dc=phonebook,dc=mobydick" scope=2 deref=0 filter="(|(&(telephoneNumber=004935141887711)(cn=*))(&(telephoneNumber=035141887711)(cn=*)))"
Aug 28 13:09:00 localhost slapd[4684]: conn=1004 op=1 SRCH attr=cn sn displayName telephoneNumber jpegPhoto
Aug 28 13:09:00 localhost slapd[4684]: conn=1004 op=1 SEARCH RESULT tag=101 err=0 nentries=1 text=
Aug 28 13:09:01 localhost /USR/SBIN/CRON[4881]: (root) CMD ( -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean)
Aug 28 13:09:06 localhost slapd[4684]: conn=1004 op=2 UNBIND
Aug 28 13:09:06 localhost slapd[4684]: conn=1004 fd=12 closed
Die Einstellung am M700:
Firmware der M700/M65: 3.55
Version der pascom: 7.12.06
Vielen Dank schon einmal
