beim Update ist folgender Fehler aufgetreten.
Reading package lists...
Building dependency tree...
The following packages will be upgraded:
md-branding-community
1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 0B/43.3kB of archives.
After unpacking 0B of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ...
dpkg: serious warning: files list file for package `fw-blocker' missing, assuming package has no files currently installed.
36932 files and directories currently installed.)
Preparing to replace md-branding-community 1.01.01.R (using .../md-branding-community_1.02.00.R_all.deb) ...
Unpacking replacement md-branding-community ...
dpkg: error processing /var/cache/apt/archives/md-branding-community_1.02.00.R_all.deb (--unpack):
trying to overwrite `/var/www/mobydickcmd/nbproject/project.xml', which is also in package md-webservice
Postinst von /var/lib/dpkg/info/md-branding-community.postinst Modus abort-upgrade Revision 1.01.01.R
Preparing apache2 restart
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Gruss
Flo
