Ich habe den CLI bei einem Faxversuch laufen lassen:
Connected to Asterisk 11.6-cert11 currently running on Albxxxx (pid = 1755)
-- Accepting AUTHENTICATED call from 127.0.0.1:
-- > requested format = alaw,
-- > requested prefs = (),
-- > actual format = ulaw,
-- > host prefs = (),
-- > priority = mine
-- Executing [0089451XXXXXX@internal:1] SIPAddHeader("IAX2/iaxmodem1-14483",""Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"") in new stack
-- Executing [0089451XXXXXX@internal:2] GosubIf("IAX2/iaxmodem1-14483", "1?sub_initcall,s,1(int,0089451XXXXXX)") in new stack
-- Executing [s@sub_initcall:1] Verbose("IAX2/iaxmodem1-14483", "1,sub_initcall descent: int exten: 0089451XXXXXX") in new stack
-- Executing [s@sub_initcall:2] GosubIf("IAX2/iaxmodem1-14483", "1?sub_initloop,s,1") in new stack
-- Executing [s@sub_initloop:1] Verbose("IAX2/iaxmodem1-14483", "1,initial loop") in new stack
initial loop
-- Executing [s@sub_initloop:2] Set("IAX2/iaxmodem1-14483", "MDC_ALIAS_HOP=0") in new stack
-- Executing [s@sub_initloop:3] Return("IAX2/iaxmodem1-14483", "") in new stack
-- Executing [s@sub_initcall:3] Set("IAX2/iaxmodem1-14483", "__MDC_TRANSFERBACK_HOP=0") in new stack
-- Executing [s@sub_initcall:4] Set("IAX2/iaxmodem1-14483", "__MDC_DIALDESCENT=int") in new stack
-- Executing [s@sub_initcall:5] Goto("IAX2/iaxmodem1-14483", "int,1") in newstack
-- Goto (sub_initcall,int,1)
-- Executing [int@sub_initcall:1] Set("IAX2/iaxmodem1-14483", "__MDC_DIALCALLERNUMINIT=") in new stack
-- Executing [int@sub_initcall:2] Set("IAX2/iaxmodem1-14483", "__MDC_DIALCALLEENUMINIT=") in new stack
-- Executing [int@sub_initcall:3] Set("IAX2/iaxmodem1-14483", "__MDC_DIALCALLEENUMMAP=0089451XXXXXX") in new stack
-- Executing [int@sub_initcall:4] Return("IAX2/iaxmodem1-14483", "") in new stack
-- Executing [0089451XXXXXX@internal:3] Goto("IAX2/iaxmodem1-14483", "main,0089451XXXXXX,1") in new stack
-- Goto (main,0089451XXXXXX,1)
-- Executing [0089451XXXXXX@main:1] Gosub("IAX2/iaxmodem1-14483", "sub_defcall,s,1(0089451XXXXXX)") in new stack
-- Executing [s@sub_defcall:1] Set("IAX2/iaxmodem1-14483", "__MDC_ALIAS_HOP=1") in new stack
-- Executing [s@sub_defcall:2] Set("IAX2/iaxmodem1-14483", "__MDC_DIALCALLEENUM=0089451XXXXXX") in new stack
-- Executing [s@sub_defcall:3] Set("IAX2/iaxmodem1-14483", "__MDC_DIALCALLERNUM=415") in new stack
-- Executing [s@sub_defcall:4] GotoIf("IAX2/iaxmodem1-14483", "1?nozap") in new stack
-- Goto (sub_defcall,s,8)
-- Executing [s@sub_defcall:8] Set("IAX2/iaxmodem1-14483", "__MDC_DIALCALLERNAME=") in new stack
-- Executing [s@sub_defcall:9] Set("IAX2/iaxmodem1-14483", "__MDC_DIALCHANNELNAME=iaxmodem1") in new stack
-- Executing [s@sub_defcall:10] Return("IAX2/iaxmodem1-14483", "") in new stack
-- Executing [0089451XXXXXX@main:2] Goto("IAX2/iaxmodem1-14483", "mdc_distribute,0089451XXXXXX,1") in new stack
-- Goto (mdc_distribute,0089451XXXXXX,1)
-- Executing [0089451503800@mdc_distribute:1] Set("IAX2/iaxmodem1-14483", "MDC_INPREFIX_TRUNK=0") in new stack
-- Executing [0089451XXXXXX@mdc_distribute:2] Verbose("IAX2/iaxmodem1-14483", "1,remove inprefix: 0") in new stack
remove inprefix: 0
-- Executing [0089451XXXXXX@mdc_distribute:3] Goto("IAX2/iaxmodem1-14483", "mdc_outgoing-1,089451XXXXXX,1") in new stack
-- Goto (mdc_outgoing-1,089451XXXXXX,1)
-- Executing [089451503800@mdc_outgoing-1:1] Gosub("IAX2/iaxmodem1-14483", "sub_trunk-outgoing-1,089451503800,1") in new stack
-- Executing [089451XXXXXX@sub_trunk-outgoing-1:1] Gosub("IAX2/iaxmodem1-14483", "sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,089451XXXXXX,00,49,0,89,0)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("IAX2/iaxmodem1-14483", "1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - number: 089451XXXXXX - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 89 - incoming: 0") in new stack
-- Executing [s@sub_nat2int:2] GotoIf("IAX2/iaxmodem1-14483", "0?s-emergency,1") in new stack
-- Executing [s@sub_nat2int:3] GotoIf("IAX2/iaxmodem1-14483", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:4] GotoIf("IAX2/iaxmodem1-14483", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("IAX2/iaxmodem1-14483", "0?s-convert,1") in new stack
-- Executing [s@sub_nat2int:6] GotoIf("IAX2/iaxmodem1-14483", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:7] GotoIf("IAX2/iaxmodem1-14483", "0?s-intshort,1") in new stack
-- Executing [s@sub_nat2int:8] GotoIf("IAX2/iaxmodem1-14483", "0?s-natshort,1") in new stack
-- Executing [s@sub_nat2int:9] GotoIf("IAX2/iaxmodem1-14483", "1?s-nat,1") in new stack
-- Goto (sub_nat2int,s-nat,1)
-- Executing [s-nat@sub_nat2int:1] Verbose("IAX2/iaxmodem1-14483", "1,national") in new stack
national
-- Executing [s-nat@sub_nat2int:2] Set("IAX2/iaxmodem1-14483", "MDC_CALLEE_NUM_INTERNAT=004989451XXXXXX") in new stack
-- Executing [s-nat@sub_nat2int:3] Return("IAX2/iaxmodem1-14483", "") in new stack
-- Executing [089451XXXXXX@sub_trunk-outgoing-1:2] Gosub("IAX2/iaxmodem1-14483", "sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,004989451XXXXXX,00,49,0,89,0)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("IAX2/iaxmodem1-14483", "1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 004989451XXXXXX - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 89 - incoming: 0") in new stack
-- Executing [s@sub_int2nat:2] GotoIf("IAX2/iaxmodem1-14483", "0?s-emergency,1") in new stack
-- Executing [s@sub_int2nat:3] GotoIf("IAX2/iaxmodem1-14483", "0?nat") in new stack
-- Executing [s@sub_int2nat:4] GotoIf("IAX2/iaxmodem1-14483", "1?s-internat,1") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("IAX2/iaxmodem1-14483", "MDC_CALLEE_NUM_NAT=089451503800") in new stack
-- Executing [s-internat@sub_int2nat:2] Return("IAX2/iaxmodem1-14483", "") in new stack
-- Executing [089451XXXXXX@sub_trunk-outgoing-1:3] Set("IAX2/iaxmodem1-14483", "CALLERID(name)=8985XXXX") in new stack
-- Executing [089451XXXXXX@sub_trunk-outgoing-1:4] Set("IAX2/iaxmodem1-14483", "CALLERID(num)=8985XXXX") in new stack
-- Executing [089451XXXXXX@sub_trunk-outgoing-1:5] UserEvent("IAX2/iaxmodem1-14483", "ResolveCallerName,Strategy: system,Outbound: 1,Channel: IAX2/iaxmodem1-14483") in new stack
-- Executing [089451XXXXXX@sub_trunk-outgoing-1:6] Wait("IAX2/iaxmodem1-14483", "0.25") in new stack
-- Executing [089451XXXXXX@sub_trunk-outgoing-1:7] Verbose("IAX2/iaxmodem1-14483", "1,MDC_RESOLVENAME_HITS = 0") in new stack
-- Executing [089451XXXXXX@sub_trunk-outgoing-1:8] Verbose("IAX2/iaxmodem1-14483", "1,MDC_DIALCALLEENAME = ") in new stack
-- Executing [089451XXXXXX@sub_trunk-outgoing-1:9] Verbose("IAX2/iaxmodem1-14483", "1,beronet - Standard") in new stack
beronet - Standard
-- Executing [089451XXXXXX@sub_trunk-outgoing-1:10] Set("IAX2/iaxmodem1-14483", "__SPYGROUP=089451XXXXXX:") in new stack
-- Executing [089451XXXXXX@sub_trunk-outgoing-1:11] Dial("IAX2/iaxmodem1-14483", "SIP/d8df0d001ff7/12#089451XXXXXX,,t") in new stack
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
-- Called SIP/d8df0d001ff7/12#089451XXXXXX
-- SIP/d8df0d001ff7-00000e8c is making progress passing it to IAX2/iaxmodem1-14483
-- SIP/d8df0d001ff7-00000e8c is ringing
-- SIP/d8df0d001ff7-00000e8c answered IAX2/iaxmodem1-14483
[Jul 20 22:19:02] WARNING[1939][C-000005c3]: chan_sip.c:10193 process_sdp: Failed to initialize UDPTL, declining image stream
[Jul 20 22:19:02] WARNING[1939][C-000005c3]: chan_sip.c:10354 process_sdp: Failing due to no acceptable offer found
-- Executing [h@sub_trunk-outgoing-1:1] Gosub("IAX2/iaxmodem1-14483", "def_hangup,s,1(,ANSWER,,CALL)") in new stack
-- Executing [s@def_hangup:1] NoOp("IAX2/iaxmodem1-14483", ">>>def_hangup:: EXTEN: DIALSTATUS: ANSWER QUEUESTATUS: REASON: CALL") in new stack
== Spawn extension (sub_trunk-outgoing-1, 089451XXXXXX, 11) exited non-zero on 'IAX2/iaxmodem1-14483'
-- Hungup 'IAX2/iaxmodem1-14483'
Außerdem ist mir aufgefallen, dass wenn ich auf ein analoges Telefon anrufe (ein Fax dort hinschicke), dann habe ich sehr wohl das bekannte Fax"piepen" in der Leitung.
Achja und ausgehende Rufregel steht auf FAX und funktioniert auch, da ich die entsprechende CID auf dem Telefon sehe.
Ich steh auf dem Schlauch…
VG
