wir sind gerade dabei die MobyDick Anlage zu testen, heute wollte ich den Faxserver ausprobieren.
Eingehende Faxe werden problemlos verarbeitet und per Mail weitergeleitet.
Allerdings konnte ich bisher den Faxversand nicht Laufen bringen:
Die Fehlermeldungen beim Versenden lauten entweder: “Busy signal detected” oder “No carrier detected”.
Asterisk-CLI Ausgabe:
Connected to Asterisk 11.6-cert10 currently running on mobydick (pid = 1939)
-- Accepting AUTHENTICATED call from 127.0.0.1:
-- > requested format = alaw,
-- > requested prefs = (),
-- > actual format = ulaw,
-- > host prefs = (),
-- > priority = mine
-- Executing [0321210XXXXX@internal:1] SIPAddHeader("IAX2/iaxmodem0-2196", ""Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"") in new stack
-- Executing [0321210XXXXX@internal:2] GosubIf("IAX2/iaxmodem0-2196", "1?sub_initcall,s,1(int,0321210XXXXX)") in new stack
-- Executing [s@sub_initcall:1] Verbose("IAX2/iaxmodem0-2196", "1,sub_initcall descent: int exten: 0321210XXXXX") in new stack
-- Executing [s@sub_initcall:2] GosubIf("IAX2/iaxmodem0-2196", "1?sub_initloop,s,1") in new stack
-- Executing [s@sub_initloop:1] Verbose("IAX2/iaxmodem0-2196", "1,initial loop") in new stack
initial loop
-- Executing [s@sub_initloop:2] Set("IAX2/iaxmodem0-2196", "MDC_ALIAS_HOP=0") in new stack
-- Executing [s@sub_initloop:3] Return("IAX2/iaxmodem0-2196", "") in new stack
-- Executing [s@sub_initcall:3] Set("IAX2/iaxmodem0-2196", "__MDC_TRANSFERBACK_HOP=0") in new stack
-- Executing [s@sub_initcall:4] Set("IAX2/iaxmodem0-2196", "__MDC_DIALDESCENT=int") in new stack
-- Executing [s@sub_initcall:5] Goto("IAX2/iaxmodem0-2196", "int,1") in new stack
-- Goto (sub_initcall,int,1)
-- Executing [int@sub_initcall:1] Set("IAX2/iaxmodem0-2196", "__MDC_DIALCALLERNUMINIT=") in new stack
-- Executing [int@sub_initcall:2] Set("IAX2/iaxmodem0-2196", "__MDC_DIALCALLEENUMINIT=") in new stack
-- Executing [int@sub_initcall:3] Set("IAX2/iaxmodem0-2196", "__MDC_DIALCALLEENUMMAP=0321210XXXXX") in new stack
-- Executing [int@sub_initcall:4] Return("IAX2/iaxmodem0-2196", "") in new stack
-- Executing [0321210XXXXX@internal:3] Goto("IAX2/iaxmodem0-2196", "main,0321210XXXXX,1") in new stack
-- Goto (main,0321210XXXXX,1)
-- Executing [0321210XXXXX@main:1] Gosub("IAX2/iaxmodem0-2196", "sub_defcall,s,1(0321210XXXXX)") in new stack
-- Executing [s@sub_defcall:1] Set("IAX2/iaxmodem0-2196", "__MDC_ALIAS_HOP=1") in new stack
-- Executing [s@sub_defcall:2] Set("IAX2/iaxmodem0-2196", "__MDC_DIALCALLEENUM=0321210XXXXX") in new stack
-- Executing [s@sub_defcall:3] Set("IAX2/iaxmodem0-2196", "__MDC_DIALCALLERNUM=21") in new stack
-- Executing [s@sub_defcall:4] GotoIf("IAX2/iaxmodem0-2196", "1?nozap") in new stack
-- Goto (sub_defcall,s,8)
-- Executing [s@sub_defcall:8] Set("IAX2/iaxmodem0-2196", "__MDC_DIALCALLERNAME=") in new stack
-- Executing [s@sub_defcall:9] Set("IAX2/iaxmodem0-2196", "__MDC_DIALCHANNELNAME=iaxmodem0") in new stack
-- Executing [s@sub_defcall:10] Return("IAX2/iaxmodem0-2196", "") in new stack
-- Executing [0321210XXXXX@main:2] Goto("IAX2/iaxmodem0-2196", "mdc_distribute,0321210XXXXX,1") in new stack
-- Goto (mdc_distribute,0321210XXXXX,1)
-- Executing [0321210XXXXX@mdc_distribute:1] Set("IAX2/iaxmodem0-2196", "MDC_INPREFIX_TRUNK=") in new stack
-- Executing [0321210XXXXX@mdc_distribute:2] Verbose("IAX2/iaxmodem0-2196", "1,remove inprefix: ") in new stack
remove inprefix:
-- Executing [0321210XXXXX@mdc_distribute:3] Goto("IAX2/iaxmodem0-2196", "mdc_outgoing-5,0321210XXXXX,1") in new stack
-- Goto (mdc_outgoing-5,0321210XXXXX,1)
-- Executing [0321210XXXXX@mdc_outgoing-5:1] Set("IAX2/iaxmodem0-2196", "CHANNEL(transfercapability)=VIDEO") in new stack
-- Executing [0321210XXXXX@mdc_outgoing-5:2] Gosub("IAX2/iaxmodem0-2196", "sub_trunk-outgoing-5,0321210XXXXX,1") in new stack
-- Executing [0321210XXXXX@sub_trunk-outgoing-5:1] Gosub("IAX2/iaxmodem0-2196", "sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,0321210XXXXX,00,49,0,7823,0)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("IAX2/iaxmodem0-2196", "1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - number: 0321210XXXXX - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7823 - incoming: 0") in new s tack
-- Executing [s@sub_nat2int:2] GotoIf("IAX2/iaxmodem0-2196", "0?s-emergency,1") in new stack
-- Executing [s@sub_nat2int:3] GotoIf("IAX2/iaxmodem0-2196", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:4] GotoIf("IAX2/iaxmodem0-2196", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("IAX2/iaxmodem0-2196", "0?s-convert,1") in new stack
-- Executing [s@sub_nat2int:6] GotoIf("IAX2/iaxmodem0-2196", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:7] GotoIf("IAX2/iaxmodem0-2196", "0?s-intshort,1") in new stack
-- Executing [s@sub_nat2int:8] GotoIf("IAX2/iaxmodem0-2196", "0?s-natshort,1") in new stack
-- Executing [s@sub_nat2int:9] GotoIf("IAX2/iaxmodem0-2196", "1?s-nat,1") in new stack
-- Goto (sub_nat2int,s-nat,1)
-- Executing [s-nat@sub_nat2int:1] Verbose("IAX2/iaxmodem0-2196", "1,national") in new stack
national
-- Executing [s-nat@sub_nat2int:2] Set("IAX2/iaxmodem0-2196", "MDC_CALLEE_NUM_INTERNAT=0049321210XXXXX") in new stack
-- Executing [s-nat@sub_nat2int:3] Return("IAX2/iaxmodem0-2196", "") in new stack
-- Executing [0321210XXXXX@sub_trunk-outgoing-5:2] Gosub("IAX2/iaxmodem0-2196", "sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,0049321210XXXXX,00,49,0,7823,0)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("IAX2/iaxmodem0-2196", "1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 0049321210XXXXX - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7823 - incoming: 0") in new stac k
-- Executing [s@sub_int2nat:2] GotoIf("IAX2/iaxmodem0-2196", "0?s-emergency,1") in new stack
-- Executing [s@sub_int2nat:3] GotoIf("IAX2/iaxmodem0-2196", "0?nat") in new stack
-- Executing [s@sub_int2nat:4] GotoIf("IAX2/iaxmodem0-2196", "1?s-internat,1") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("IAX2/iaxmodem0-2196", "MDC_CALLEE_NUM_NAT=0321210XXXXX") in new stack
-- Executing [s-internat@sub_int2nat:2] Return("IAX2/iaxmodem0-2196", "") in new stack
-- Executing [0321210XXXXX@sub_trunk-outgoing-5:3] Set("IAX2/iaxmodem0-2196", "CALLERID(name)=78239612321") in new stack
-- Executing [0321210XXXXX@sub_trunk-outgoing-5:4] Set("IAX2/iaxmodem0-2196", "CALLERID(num)=78239612321") in new stack
-- Executing [0321210XXXXX@sub_trunk-outgoing-5:5] UserEvent("IAX2/iaxmodem0-2196", "ResolveCallerName,Strategy: default,Outbound: 1,Channel: IAX2/iaxmodem0-2196") in new stack
-- Executing [0321210XXXXX@sub_trunk-outgoing-5:6] Wait("IAX2/iaxmodem0-2196", "0.25") in new stack
-- Executing [0321210XXXXX@sub_trunk-outgoing-5:7] Verbose("IAX2/iaxmodem0-2196", "1,MDC_RESOLVENAME_HITS = 0") in new stack
-- Executing [0321210XXXXX@sub_trunk-outgoing-5:8] Verbose("IAX2/iaxmodem0-2196", "1,MDC_DIALCALLEENAME = ") in new stack
-- Executing [0321210XXXXX@sub_trunk-outgoing-5:9] Verbose("IAX2/iaxmodem0-2196", "1,ISDN Anlagenanschluss - Fax") in new stack
-- Executing [0321210XXXXX@sub_trunk-outgoing-5:10] Dial("IAX2/iaxmodem0-2196", "SIP/d8df0d00222a/12#0321210XXXXX,,t") in new stack
== Using SIP VIDEO CoS mark 6
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
-- Called SIP/d8df0d00222a/12#0321210XXXXX
[May 8 19:48:29] WARNING[2260][C-00000021]: chan_sip.c:10047 process_sdp: Ignoring video stream offer because port number is zero
-- SIP/d8df0d00222a-00000022 is making progress passing it to IAX2/iaxmodem0-2196
-- SIP/d8df0d00222a-00000022 is ringing
-- SIP/d8df0d00222a-00000022 answered IAX2/iaxmodem0-2196
-- Executing [h@sub_trunk-outgoing-5:1] Gosub("IAX2/iaxmodem0-2196", "def_hangup,s,1(,ANSWER,,CALL)") in new stack
-- Executing [s@def_hangup:1] NoOp("IAX2/iaxmodem0-2196", ">>>def_hangup:: EXTEN: DIALSTATUS: ANSWER QUEUESTATUS: REASON: CALL") in new stack
== Spawn extension (sub_trunk-outgoing-5, 0321210XXXXX, 10) exited non-zero on 'IAX2/iaxmodem0-2196'
-- Hungup 'IAX2/iaxmodem0-2196'
Wir verwenden die Version 7.08.06 zusammen mit einem Berofix ISDN Gateway an einem Telekom-Anlagenanschluss.
Die Verbindung nach funktioniert grundsätzlich, Telefonie ist möglich. Wenn ich versuche ein Fax an das Handy zu senden, klingelt das Gerät, allerdings höre ich keine Faxmodem-Geräusche nach dem Abnehmen.
