-- Executing Set("SIP/3135-b6932e68", "MDC_CHANNEL_PROTOCOL=SIP") in new sta ck
-- Executing Set("SIP/3135-b6932e68", "MDC_CHANNEL_ID=3135-b6932e68") in new stack
-- Executing Set("SIP/3135-b6932e68", "MDC_CHANNEL_TMP=3135-b6932e68") in ne w stack
-- Executing Set("SIP/3135-b6932e68", "MDC_CHANNEL_NAME=3135") in new stack
-- Executing GosubIf("SIP/3135-b6932e68", "1?mdc_initcall-int|3199|1") in ne w stack
-- Executing NoOp("SIP/3135-b6932e68", "initial call") in new stack
-- Executing Set("SIP/3135-b6932e68", "__MDC_DIALDESCENT=int") in new stack
-- Executing Set("SIP/3135-b6932e68", "__MDC_DIALCALLEENUM=3199") in new sta ck
-- Executing Set("SIP/3135-b6932e68", "__MDC_DIALCALLERNUM=3135") in new sta ck
-- Executing GotoIf("SIP/3135-b6932e68", "1?nozap") in new stack
-- Goto (mdc_initcall-int,3199,8)
-- Executing Set("SIP/3135-b6932e68", "__MDC_DIALCALLERNAME=3135 Heinz Mustermann") in new stack
-- Executing Return("SIP/3135-b6932e68", "") in new stack
-- Executing Gosub("SIP/3135-b6932e68", "mdc_defcall|3199|1") in new stack
-- Goto (mdc_defcall,3199,4)
-- Executing Set("SIP/3135-b6932e68", "__MDC_DIALCHANNELNAME=3135") in new s tack
-- Executing SIPAddHeader("SIP/3135-b6932e68", ""Alert-Info:<http://www.notu sed.de>;info=alert-internal;x-line-id=0"") in new stack
-- Executing Macro("SIP/3135-b6932e68", "pre-main") in new stack
-- Executing NoOp("SIP/3135-b6932e68", "macro-pre-main") in new stack
-- Executing NoOp("SIP/3135-b6932e68", "CALLEENUM == 3199 ") in new stack
-- Executing GotoIf("SIP/3135-b6932e68", "0?s-intern|1") in new stack
-- Executing GotoIf("SIP/3135-b6932e68", "0?s-anonymous|1 ") in new stack
-- Executing NoOp("SIP/3135-b6932e68", "nichts") in new stack
-- Executing GosubIf("SIP/3135-b6932e68", "1?mdc_initloop|s|1") in new stack
-- Executing NoOp("SIP/3135-b6932e68", "initial loop") in new stack
-- Executing Set("SIP/3135-b6932e68", "MDC_ALIAS_HOP=0") in new stack
-- Executing Gosub("SIP/3135-b6932e68", "mdc_cdr-int|3199|1") in new stack
-- Executing Set("SIP/3135-b6932e68", "CDR(mdcdst)=3199") in new stack
-- Executing Set("SIP/3135-b6932e68", "CDR(mdcinitdst)=3199") in new stack
-- Executing Set("SIP/3135-b6932e68", "CDR(mdcname)=3135") in new stack
-- Executing Set("SIP/3135-b6932e68", "CDR(mdcsrc)=3135") in new stack
-- Executing Set("SIP/3135-b6932e68", "CDR(mdcinitsrc)=3135") in new stack
-- Executing GotoIf("SIP/3135-b6932e68", "0?prefix") in new stack
-- Executing Set("SIP/3135-b6932e68", "CDR(mdcprefix)=") in new stack
-- Executing Set("SIP/3135-b6932e68", "TMP_NAME=:testtest") in new stack
-- Executing Set("SIP/3135-b6932e68", "TMP_NAME=testtest") in new stack
-- Executing GotoIf("SIP/3135-b6932e68", "1?dstname") in new stack
-- Goto (mdc_cdr-int,3199,13)
-- Executing Set("SIP/3135-b6932e68", "CDR(mdcdstname)=testtest") in new sta ck
-- Executing Set("SIP/3135-b6932e68", "CDR(mdcdescent)=int") in new stack
-- Executing Set("SIP/3135-b6932e68", "CDR(mdcsrcname)=3135 Heinz Mustermann") in new stack
-- Executing AGI("SIP/3135-b6932e68", "script/mdc_billing-pricing.php|0") in new stack
-- Launched AGI Script /var/lib/asterisk/agi-bin/script/mdc_billing-pricing. php
-- AGI Script script/mdc_billing-pricing.php completed, returning 0
-- Executing Set("SIP/3135-b6932e68", "CDR(tarifid)=") in new stack
-- Executing Goto("SIP/3135-b6932e68", "main|3199|1") in new stack
-- Goto (main,3199,1)
-- Executing Goto("SIP/3135-b6932e68", "mdc_callgroup-95|3199|1") in new sta ck
-- Goto (mdc_callgroup-95,3199,1)
-- Executing NoOp("SIP/3135-b6932e68", "alias-check:: call forwarding from 3 199 - 0") in new stack
-- Executing GotoIf("SIP/3135-b6932e68", "0?3199-umleitung|1:3199-dial|1") i n new stack
-- Goto (mdc_callgroup-95,3199-dial,1)
-- Executing Gosub("SIP/3135-b6932e68", "mdc_prefix-3199-int|3199|1") in new stack
-- Executing Gosub("SIP/3135-b6932e68", "mdc_main-3199-int|3199|1") in new s tack
-- Executing Set("SIP/3135-b6932e68", "TOUCH_MONITOR=3135-3199-20150702-1514 13-int") in new stack
-- Executing Set("SIP/3135-b6932e68", "CALLERID(name)=testtest") in new stac k
-- Executing Dial("SIP/3135-b6932e68", "SIP/e1gate/XXXXXXXXXXXX&SIP/83124|10 |owW") in new stack
-- Called e1gate/ XXXXXXXXXXXX
-- Called 83124
-- SIP/83124-08cc10e8 is ringing
-- SIP/e1gate-08dd1a18 is making progress passing it to SIP/3135-b6932e68
-- SIP/e1gate-08dd1a18 is ringing
Jul 2 15:14:21 NOTICE[13652]: chan_sip.c:11787 handle_request_subscribe: Got SU BSCRIBE for extension 0016093972236@internal from 172.23.232.98, but there is no hint for that extension
-- Nobody picked up in 10000 ms
-- Executing Gosub("SIP/3135-b6932e68", "mdc_suffix-3199-int|3199|1") in new stack
-- Executing Hangup("SIP/3135-b6932e68", "0") in new stack
== Spawn extension (mdc_callgroup-95, 3199-dial, 4) exited non-zero on 'SIP/31 35-b6932e68'
Jul 2 15:14:23 NOTICE[13652]: chan_sip.c:11787 handle_request_subscribe: Got SU BSCRIBE for extension 001626260761@internal from 172.23.231.76, but there is no hint for that extension
Jul 2 15:14:26 NOTICE[13652]: chan_sip.c:10511 handle_response_peerpoke: Peer ' 3988' is now REACHABLE! (7ms / 2000ms)
EDIT: Log von der Mobydick
