Hallo zusammen
Ich habe beim testen herausgefunden, dass exteren Servicenummern nicht gewählt werden können. Gewählt wird ins Festnetz via ISDN.
Ein kleines Beispiel:
0 161 --> ist die sprechene Uhr (CH)
Die Anlage antwortet mit einem Besetztzeichen und im Display steht Adress incomplett. Die ISDN Apparate reagieren gleich.
Der Trace sagt folgendes:
– Starting simple switch on ‘Zap/5-1’
– Executing Set(“Zap/5-1”, “MDC_CHANNEL_PROTOCOL=Zap”) in new stack
– Executing Set(“Zap/5-1”, “MDC_CHANNEL_ID=5-1”) in new stack
– Executing Set(“Zap/5-1”, “MDC_CHANNEL_TMP=5-1”) in new stack
– Executing Set(“Zap/5-1”, “MDC_CHANNEL_NAME=5”) in new stack
– Executing GosubIf(“Zap/5-1”, “1?mdc_initcall-int|0161|1”) in new stack
– Executing NoOp(“Zap/5-1”, “initial call”) in new stack
– Executing Set(“Zap/5-1”, “__MDC_DIALDESCENT=int”) in new stack
– Executing Set(“Zap/5-1”, “__MDC_DIALCALLEENUM=0161”) in new stack
– Executing Set(“Zap/5-1”, “__MDC_DIALCALLERNUM=14”) in new stack
– Executing GotoIf(“Zap/5-1”, “0?nozap”) in new stack
– Executing Set(“Zap/5-1”, “__MDC_DIALCALLERNAME=CID withheld”) in new stack
– Executing Return(“Zap/5-1”, “”) in new stack
– Executing Gosub(“Zap/5-1”, “mdc_defcall|0161|1”) in new stack
– Executing Set(“Zap/5-1”, “__MDC_DIALCHANNELNAME=14”) in new stack
– Executing SIPAddHeader(“Zap/5-1”, "“Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"”) in new stack
– Executing Macro(“Zap/5-1”, “pre-main”) in new stack
Sep 16 11:14:56 WARNING[30317]: app_macro.c:208 macro_exec: No such context ‘macro-pre-main’ for macro ‘pre-main’
– Executing GosubIf(“Zap/5-1”, “1?mdc_initloop|s|1”) in new stack
– Executing NoOp(“Zap/5-1”, “initial loop”) in new stack
– Executing Set(“Zap/5-1”, “MDC_ALIAS_HOP=0”) in new stack
– Executing Goto(“Zap/5-1”, “main|0161|1”) in new stack
– Goto (main,0161,1)
– Executing Set(“Zap/5-1”, “TMP_INPREFIX=0”) in new stack
– Executing Goto(“Zap/5-1”, “mdc_outgoing-trunk-1|161|1”) in new stack
– Goto (mdc_outgoing-trunk-1,161,1)
– Executing Set(“Zap/5-1”, “TMP_USERFIELD=”) in new stack
– Executing Set(“Zap/5-1”, “CDR(userfield)=<dst>161</dst><name>14</name><inprefix>0</inprefix>”) in new stack
– Executing Set(“Zap/5-1”, “MDC_EXTEN=161”) in new stack
– Executing Set(“Zap/5-1”, “CALLERID(num)=004141XXXXXXXX”) in new stack
– Executing Dial(“Zap/5-1”, “ZAP/r1/161”) in new stack
– Requested transfer capability: 0x00 - SPEECH
– Called r1/161
– Zap/1-1 is proceeding passing it to Zap/5-1
– Channel 0/1, span 1 got hangup request, cause 28
– Channel 0/1, span 1 received AOC-E charging 0 units
Sep 16 11:14:56 WARNING[30317]: app_dial.c:741 wait_for_answer: Unable to forward voice
– Hungup ‘Zap/1-1’
– Executing Hangup(“Zap/5-1”, “28”) in new stack
== Spawn extension (mdc_outgoing-trunk-1, 161, 6) exited non-zero on ‘Zap/5-1’
– Hungup ‘Zap/5-1’
Bin ich etwa der einzige der diese Nummer wählt? Den Notruf habe ich bis jetzt noch nicht getestet :eek: …
Gruss
René
