Hallo Mathias,
== Using SIP RTP CoS mark 5
-- Executing [4958264021XXX@mdc_incoming-40:1] Set("SIP/mdc_trunk_conf-40-00000025", "MDC_CALLER_NUM_TRUNK=+49580245XX") in new stack
-- Executing [4958264021XXX@mdc_incoming-40:2] Set("SIP/mdc_trunk_conf-40-00000025", "MDC_CALLEE_NUM_TRUNK=4958264021XXX") in new stack
-- Executing [4958264021XXX@mdc_incoming-40:3] Goto("SIP/mdc_trunk_conf-40-00000025", "mdc_trunk-2,s,1") in new stack
-- Goto (mdc_trunk-2,s,1)
-- Executing [s@mdc_trunk-2:1] Verbose("SIP/mdc_trunk_conf-40-00000025", "1,callee number: 4958264021XXX caller number: +49580245XX") in new stack
-- Executing [s@mdc_trunk-2:2] Gosub("SIP/mdc_trunk_conf-40-00000025", "sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,+49580245XX,00,49,0,5826,1)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-40-00000025", "1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - number: +49580245XX - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 5826 - incoming: 1") in new stack
-- Executing [s@sub_nat2int:2] GotoIf("SIP/mdc_trunk_conf-40-00000025", "0?s-emergency,1") in new stack
-- Executing [s@sub_nat2int:3] GotoIf("SIP/mdc_trunk_conf-40-00000025", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:4] GotoIf("SIP/mdc_trunk_conf-40-00000025", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("SIP/mdc_trunk_conf-40-00000025", "1?s-convert,1") in new stack
-- Goto (sub_nat2int,s-convert,1)
-- Executing [s-convert@sub_nat2int:1] Set("SIP/mdc_trunk_conf-40-00000025", "ARG2=0049580245XX") in new stack
-- Executing [s-convert@sub_nat2int:2] Goto("SIP/mdc_trunk_conf-40-00000025", "s,check") in new stack
-- Goto (sub_nat2int,s,6)
-- Executing [s@sub_nat2int:6] GotoIf("SIP/mdc_trunk_conf-40-00000025", "1?s-int,1") in new stack
-- Goto (sub_nat2int,s-int,1)
-- Executing [s-int@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-40-00000025", "1,international") in new stack
international
-- Executing [s-int@sub_nat2int:2] Set("SIP/mdc_trunk_conf-40-00000025", "MDC_CALLER_NUM_INTERNAT=0049580245XX") in new stack
-- Executing [s-int@sub_nat2int:3] Return("SIP/mdc_trunk_conf-40-00000025", "") in new stack
-- Executing [s@mdc_trunk-2:3] Set("SIP/mdc_trunk_conf-40-00000025", "CALLERID(num)=0049580245XX") in new stack
-- Executing [s@mdc_trunk-2:4] Gosub("SIP/mdc_trunk_conf-40-00000025", "sub_int2nat,s,1(MDC_CALLER_NUM_NAT,0049580245XX,00,49,0,5826,1)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("SIP/mdc_trunk_conf-40-00000025", "1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 0049580245XX - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 5826 - incoming: 1") in new stack
-- Executing [s@sub_int2nat:2] GotoIf("SIP/mdc_trunk_conf-40-00000025", "0?s-emergency,1") in new stack
-- Executing [s@sub_int2nat:3] GotoIf("SIP/mdc_trunk_conf-40-00000025", "0?nat") in new stack
-- Executing [s@sub_int2nat:4] GotoIf("SIP/mdc_trunk_conf-40-00000025", "1?s-internat,1") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("SIP/mdc_trunk_conf-40-00000025", "MDC_CALLER_NUM_NAT=058024538") in new stack
-- Executing [s-internat@sub_int2nat:2] Return("SIP/mdc_trunk_conf-40-00000025", "") in new stack
-- Executing [s@mdc_trunk-2:5] Set("SIP/mdc_trunk_conf-40-00000025", "CALLERID(num)=058024538") in new stack
-- Executing [s@mdc_trunk-2:6] UserEvent("SIP/mdc_trunk_conf-40-00000025", "ResolveCallerName,Strategy: system,Outbound: 0,Channel: SIP/mdc_trunk_conf-40-00000025") in new stack
-- Executing [s@mdc_trunk-2:7] Wait("SIP/mdc_trunk_conf-40-00000025", "0.25") in new stack
-- Executing [s@mdc_trunk-2:8] Verbose("SIP/mdc_trunk_conf-40-00000025", "1,MDC_RESOLVENAME_HITS = 0") in new stack
-- Executing [s@mdc_trunk-2:9] Verbose("SIP/mdc_trunk_conf-40-00000025", "1,CALLERID(name) = ") in new stack
CALLERID(name) =
-- Executing [s@mdc_trunk-2:10] Set("SIP/mdc_trunk_conf-40-00000025", "MDC_NUMPREFIX_TRUNK=0") in new stack
-- Executing [s@mdc_trunk-2:11] ExecIf("SIP/mdc_trunk_conf-40-00000025", "1?Set(CALLERID(num)=0058024538)") in new stack
-- Executing [s@mdc_trunk-2:12] Goto("SIP/mdc_trunk_conf-40-00000025", "mdc_mapping-2,4958264021XXX,1") in new stack
-- Goto (mdc_mapping-2,4958264021XXX,1)
-- Executing [4958264021XXX@mdc_mapping-2:1] Set("SIP/mdc_trunk_conf-40-00000025", "CHANNEL(language)=de") in new stack
-- Executing [4958264021XXX@mdc_mapping-2:2] Verbose("SIP/mdc_trunk_conf-40-00000025", "1,mapping from _[+*%#a-zA-Z0-9]. to 301") in new stack
-- Executing [4958264021XXX@mdc_mapping-2:3] Goto("SIP/mdc_trunk_conf-40-00000025", "mdc_external,301,1") in new stack
-- Goto (mdc_external,301,1)
-- Executing [301@mdc_external:1] SIPAddHeader("SIP/mdc_trunk_conf-40-00000025", ""Alert-Info:<http://www.notused.de>;info=alert-external;x-line-id=0"") in new stack
-- Executing [301@mdc_external:2] GosubIf("SIP/mdc_trunk_conf-40-00000025", "1?sub_initcall,s,1(ext,301)") in new stack
-- Executing [s@sub_initcall:1] Verbose("SIP/mdc_trunk_conf-40-00000025", "1,sub_initcall descent: ext exten: 301") in new stack
-- Executing [s@sub_initcall:2] GosubIf("SIP/mdc_trunk_conf-40-00000025", "1?sub_initloop,s,1") in new stack
-- Executing [s@sub_initloop:1] Verbose("SIP/mdc_trunk_conf-40-00000025", "1,initial loop") in new stack
initial loop
-- Executing [s@sub_initloop:2] Set("SIP/mdc_trunk_conf-40-00000025", "MDC_ALIAS_HOP=0") in new stack
-- Executing [s@sub_initloop:3] Set("SIP/mdc_trunk_conf-40-00000025", "MDC_MAIN_HOP=0") in new stack
-- Executing [s@sub_initloop:4] Return("SIP/mdc_trunk_conf-40-00000025", "") in new stack
-- Executing [s@sub_initcall:3] Set("SIP/mdc_trunk_conf-40-00000025", "__MDC_TRANSFERBACK_HOP=0") in new stack
-- Executing [s@sub_initcall:4] Set("SIP/mdc_trunk_conf-40-00000025", "__MDC_DIALDESCENT=ext") in new stack
-- Executing [s@sub_initcall:5] Goto("SIP/mdc_trunk_conf-40-00000025", "ext,1") in new stack
-- Goto (sub_initcall,ext,1)
-- Executing [ext@sub_initcall:1] Set("SIP/mdc_trunk_conf-40-00000025", "__MDC_DIALCALLERNUMINIT=+49580245XX") in new stack
-- Executing [ext@sub_initcall:2] Set("SIP/mdc_trunk_conf-40-00000025", "__MDC_DIALCALLEENUMINIT=4958264021XXX") in new stack
-- Executing [ext@sub_initcall:3] Set("SIP/mdc_trunk_conf-40-00000025", "__MDC_DIALCALLEENUMMAP=301") in new stack
-- Executing [ext@sub_initcall:4] Return("SIP/mdc_trunk_conf-40-00000025", "") in new stack
-- Executing [301@mdc_external:3] Goto("SIP/mdc_trunk_conf-40-00000025", "main,301,1") in new stack
-- Goto (main,301,1)
-- Executing [301@main:1] ExecIf("SIP/mdc_trunk_conf-40-00000025", "0?Set(MDC_MAIN_HOP=0)") in new stack
-- Executing [301@main:2] Set("SIP/mdc_trunk_conf-40-00000025", "MDC_MAIN_HOP=1") in new stack
-- Executing [301@main:3] GotoIf("SIP/mdc_trunk_conf-40-00000025", "0?mdc_loop,s,1") in new stack
-- Executing [301@main:4] Gosub("SIP/mdc_trunk_conf-40-00000025", "sub_defcall,s,1(301)") in new stack
-- Executing [s@sub_defcall:1] Set("SIP/mdc_trunk_conf-40-00000025", "__MDC_ALIAS_HOP=1") in new stack
-- Executing [s@sub_defcall:2] Set("SIP/mdc_trunk_conf-40-00000025", "__MDC_DIALCALLEENUM=301") in new stack
-- Executing [s@sub_defcall:3] Set("SIP/mdc_trunk_conf-40-00000025", "__MDC_DIALCALLERNUM=0058024538") in new stack
-- Executing [s@sub_defcall:4] Set("SIP/mdc_trunk_conf-40-00000025", "__MDC_DIALCALLERLANGUAGE=de") in new stack
-- Executing [s@sub_defcall:5] Set("SIP/mdc_trunk_conf-40-00000025", "__MDC_DIALCALLERNAME=") in new stack
-- Executing [s@sub_defcall:6] Set("SIP/mdc_trunk_conf-40-00000025", "__MDC_DIALCHANNELNAME=mdc_trunk_conf-40") in new stack
-- Executing [s@sub_defcall:7] Return("SIP/mdc_trunk_conf-40-00000025", "") in new stack
-- Executing [301@main:5] Gosub("SIP/mdc_trunk_conf-40-00000025", "sub_homer,s,1") in new stack
-- Executing [s@sub_homer:1] SIPRemoveHeader("SIP/mdc_trunk_conf-40-00000025", "P-cs-cid:") in new stack
-- Executing [s@sub_homer:2] ExecIf("SIP/mdc_trunk_conf-40-00000025", "1?SipAddHeader(P-cs-cid: 1915e0000af5-59f755da-7e28f169-359ad6e0-1c006d6@127.0.0.1)") in new stack
-- Executing [s@sub_homer:3] Return("SIP/mdc_trunk_conf-40-00000025", "") in new stack
-- Executing [301@main:6] Goto("SIP/mdc_trunk_conf-40-00000025", "mdc_distribute,301,1") in new stack
-- Goto (mdc_distribute,301,1)
-- Executing [301@mdc_distribute:1] Goto("SIP/mdc_trunk_conf-40-00000025", "mdc_faxdevice-15,301,1") in new stack
-- Goto (mdc_faxdevice-15,301,1)
-- Executing [301@mdc_faxdevice-15:1] Answer("SIP/mdc_trunk_conf-40-00000025", "") in new stack
-- Executing [301@mdc_faxdevice-15:2] Ringing("SIP/mdc_trunk_conf-40-00000025", "") in new stack
-- Executing [301@mdc_faxdevice-15:3] Wait("SIP/mdc_trunk_conf-40-00000025", "1") in new stack
-- Executing [301@mdc_faxdevice-15:4] Dial("SIP/mdc_trunk_conf-40-00000025", "IAX2/iaxmodem0/301") in new stack
-- Called IAX2/iaxmodem0/301
-- Call accepted by 127.0.0.1 (format alaw)
-- Format for call is (alaw)
-- IAX2/iaxmodem0-937 is ringing
-- IAX2/iaxmodem0-937 answered SIP/mdc_trunk_conf-40-00000025
-- Executing [h@mdc_faxdevice-15:1] Gosub("SIP/mdc_trunk_conf-40-00000025", "def_hangup,s,1(,ANSWER,,CALL)") in new stack
-- Executing [s@def_hangup:1] NoOp("SIP/mdc_trunk_conf-40-00000025", ">>>def_hangup:: EXTEN: DIALSTATUS: ANSWER QUEUESTATUS: REASON: CALL") in new stack
-- Hungup 'IAX2/iaxmodem0-937'
== Spawn extension (mdc_faxdevice-15, 301, 4) exited non-zero on 'SIP/mdc_trunk_conf-40-00000025'
Ich erkenne leider noch nicht so viel. Aber ich vermute du schon?!
Irritierend ist nun das da ein Fax ran geht, das habe ich gar nicht eingestellt.
Viele Grüße,
Philip
