Ich habe mir nun von extern versucht ein Fax zu schicken. Ging leider nicht also finge ich an zu suchen. Dabei fiel mir das folgende auf:
Service: asterisk SIP
Host: mobydick
Address: 127.0.0.1
Hier sollte doch eigentlich die ethernet IP stehen oder?
Das passiert während des Faxeingangs (der ja nicht klappt) auf dem Asterisk
-- Executing [4935017929702@mdc_incoming-2:1] Set("SIP/mdc_trunk_conf-2-0000001e", "MDC_CALLER_NUM_TRUNK=+4935014405017") in new stack
-- Executing [4935017929702@mdc_incoming-2:2] Set("SIP/mdc_trunk_conf-2-0000001e", "MDC_CALLEE_NUM_TRUNK=4935017929702") in new stack
-- Executing [4935017929702@mdc_incoming-2:3] Goto("SIP/mdc_trunk_conf-2-0000001e", "mdc_trunk-1,s,1") in new stack
-- Goto (mdc_trunk-1,s,1)
-- Executing [s@mdc_trunk-1:1] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,callee number: 4935017929702 caller number: +4935014405017") in new stack
-- Executing [s@mdc_trunk-1:2] Gosub("SIP/mdc_trunk_conf-2-0000001e", "sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,+4935014405017,00,49,0,3501,1)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - number: +4935014405017 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 3501 - incoming: 1") in new stack
-- Executing [s@sub_nat2int:2] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "0?s-emergency,1") in new stack
-- Executing [s@sub_nat2int:3] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:4] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "1?s-convert,1") in new stack
-- Goto (sub_nat2int,s-convert,1)
-- Executing [s-convert@sub_nat2int:1] Set("SIP/mdc_trunk_conf-2-0000001e", "ARG2=004935014405017") in new stack
-- Executing [s-convert@sub_nat2int:2] Goto("SIP/mdc_trunk_conf-2-0000001e", "s,check") in new stack
-- Goto (sub_nat2int,s,6)
-- Executing [s@sub_nat2int:6] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "1?s-int,1") in new stack
-- Goto (sub_nat2int,s-int,1)
-- Executing [s-int@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,international") in new stack
international
-- Executing [s-int@sub_nat2int:2] Set("SIP/mdc_trunk_conf-2-0000001e", "MDC_CALLER_NUM_INTERNAT=004935014405017") in new stack
-- Executing [s-int@sub_nat2int:3] Return("SIP/mdc_trunk_conf-2-0000001e", "") in new stack
-- Executing [s@mdc_trunk-1:3] Set("SIP/mdc_trunk_conf-2-0000001e", "CALLERID(num)=004935014405017") in new stack
-- Executing [s@mdc_trunk-1:4] Gosub("SIP/mdc_trunk_conf-2-0000001e", "sub_int2nat,s,1(MDC_CALLER_NUM_NAT,004935014405017,00,49,0,3501,1)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 004935014405017 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 3501 - incoming: 1") in new stack
-- Executing [s@sub_int2nat:2] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "0?s-emergency,1") in new stack
-- Executing [s@sub_int2nat:3] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "0?nat") in new stack
-- Executing [s@sub_int2nat:4] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "1?s-internat,1") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("SIP/mdc_trunk_conf-2-0000001e", "MDC_CALLER_NUM_NAT=035014405017") in new stack
-- Executing [s-internat@sub_int2nat:2] Return("SIP/mdc_trunk_conf-2-0000001e", "") in new stack
-- Executing [s@mdc_trunk-1:5] Set("SIP/mdc_trunk_conf-2-0000001e", "CALLERID(num)=035014405017") in new stack
-- Executing [s@mdc_trunk-1:6] UserEvent("SIP/mdc_trunk_conf-2-0000001e", "ResolveCallerName,Strategy: default,Outbound: 0,Channel: SIP/mdc_trunk_conf-2-0000001e") in new stack
-- Executing [s@mdc_trunk-1:7] Wait("SIP/mdc_trunk_conf-2-0000001e", "0.25") in new stack
-- Executing [s@mdc_trunk-1:8] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,MDC_RESOLVENAME_HITS = 0") in new stack
-- Executing [s@mdc_trunk-1:9] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,CALLERID(name) = ") in new stack
CALLERID(name) =
-- Executing [s@mdc_trunk-1:10] Set("SIP/mdc_trunk_conf-2-0000001e", "MDC_NUMPREFIX_TRUNK=") in new stack
-- Executing [s@mdc_trunk-1:11] Goto("SIP/mdc_trunk_conf-2-0000001e", "mdc_mapping-1,4935017929702,1") in new stack
-- Goto (mdc_mapping-1,4935017929702,1)
-- Executing [4935017929702@mdc_mapping-1:1] Set("SIP/mdc_trunk_conf-2-0000001e", "CHANNEL(language)=de") in new stack
-- Executing [4935017929702@mdc_mapping-1:2] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,mapping from 4935017929702 to 111") in new stack
-- Executing [4935017929702@mdc_mapping-1:3] Goto("SIP/mdc_trunk_conf-2-0000001e", "mdc_external,111,1") in new stack
-- Goto (mdc_external,111,1)
-- Executing [111@mdc_external:1] SIPAddHeader("SIP/mdc_trunk_conf-2-0000001e", ""Alert-Info:<http://www.notused.de>;info=alert-external;x-line-id=0"") in new stack
-- Executing [111@mdc_external:2] GosubIf("SIP/mdc_trunk_conf-2-0000001e", "1?sub_initcall,s,1(ext,111)") in new stack
-- Executing [s@sub_initcall:1] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,sub_initcall descent: ext exten: 111") in new stack
-- Executing [s@sub_initcall:2] GosubIf("SIP/mdc_trunk_conf-2-0000001e", "1?sub_initloop,s,1") in new stack
-- Executing [s@sub_initloop:1] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,initial loop") in new stack
initial loop
-- Executing [s@sub_initloop:2] Set("SIP/mdc_trunk_conf-2-0000001e", "MDC_ALIAS_HOP=0") in new stack
-- Executing [s@sub_initloop:3] Return("SIP/mdc_trunk_conf-2-0000001e", "") in new stack
-- Executing [s@sub_initcall:3] Set("SIP/mdc_trunk_conf-2-0000001e", "__MDC_TRANSFERBACK_HOP=0") in new stack
-- Executing [s@sub_initcall:4] Set("SIP/mdc_trunk_conf-2-0000001e", "__MDC_DIALDESCENT=ext") in new stack
-- Executing [s@sub_initcall:5] Goto("SIP/mdc_trunk_conf-2-0000001e", "ext,1") in new stack
-- Goto (sub_initcall,ext,1)
-- Executing [ext@sub_initcall:1] Set("SIP/mdc_trunk_conf-2-0000001e", "__MDC_DIALCALLERNUMINIT=+4935014405017") in new stack
-- Executing [ext@sub_initcall:2] Set("SIP/mdc_trunk_conf-2-0000001e", "__MDC_DIALCALLEENUMINIT=4935017929702") in new stack
-- Executing [ext@sub_initcall:3] Set("SIP/mdc_trunk_conf-2-0000001e", "__MDC_DIALCALLEENUMMAP=111") in new stack
-- Executing [ext@sub_initcall:4] Return("SIP/mdc_trunk_conf-2-0000001e", "") in new stack
-- Executing [111@mdc_external:3] Goto("SIP/mdc_trunk_conf-2-0000001e", "main,111,1") in new stack
-- Goto (main,111,1)
-- Executing [111@main:1] Gosub("SIP/mdc_trunk_conf-2-0000001e", "sub_defcall,s,1(111)") in new stack
-- Executing [s@sub_defcall:1] Set("SIP/mdc_trunk_conf-2-0000001e", "__MDC_ALIAS_HOP=1") in new stack
-- Executing [s@sub_defcall:2] Set("SIP/mdc_trunk_conf-2-0000001e", "__MDC_DIALCALLEENUM=111") in new stack
-- Executing [s@sub_defcall:3] Set("SIP/mdc_trunk_conf-2-0000001e", "__MDC_DIALCALLERNUM=035014405017") in new stack
-- Executing [s@sub_defcall:4] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "1?nozap") in new stack
-- Goto (sub_defcall,s,8)
-- Executing [s@sub_defcall:8] Set("SIP/mdc_trunk_conf-2-0000001e", "__MDC_DIALCALLERNAME=") in new stack
-- Executing [s@sub_defcall:9] Set("SIP/mdc_trunk_conf-2-0000001e", "__MDC_DIALCHANNELNAME=mdc_trunk_conf-2") in new stack
-- Executing [s@sub_defcall:10] Return("SIP/mdc_trunk_conf-2-0000001e", "") in new stack
-- Executing [111@main:2] Goto("SIP/mdc_trunk_conf-2-0000001e", "mdc_distribute,111,1") in new stack
-- Goto (mdc_distribute,111,1)
-- Executing [111@mdc_distribute:1] Set("SIP/mdc_trunk_conf-2-0000001e", "MDC_INPREFIX_TRUNK=") in new stack
-- Executing [111@mdc_distribute:2] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,remove inprefix: ") in new stack
remove inprefix:
-- Executing [111@mdc_distribute:3] Goto("SIP/mdc_trunk_conf-2-0000001e", "mdc_outgoing-3,111,1") in new stack
-- Goto (mdc_outgoing-3,111,1)
-- Executing [111@mdc_outgoing-3:1] Gosub("SIP/mdc_trunk_conf-2-0000001e", "sub_trunk-outgoing-3,111,1") in new stack
-- Executing [111@sub_trunk-outgoing-3:1] Gosub("SIP/mdc_trunk_conf-2-0000001e", "sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,111,00,49,0,3501,0)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - number: 111 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 3501 - incoming: 0") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "0?s-convert,1") in new stack
-- Executing [s@sub_nat2int:6] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:7] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "0?s-intshort,1") in new stack
-- Executing [s@sub_nat2int:8] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "0?s-natshort,1") in new stack
-- Executing [s@sub_nat2int:9] GotoIf("SIP/mdc_trunk_conf-2-0000001e", "0?s-nat,1") in new stack
-- Executing [s@sub_nat2int:10] Goto("SIP/mdc_trunk_conf-2-0000001e", "s-local,1") in new stack
-- Goto (sub_nat2int,s-local,1)
-- Executing [s-local@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,local") in new stack
local
-- Executing [s-local@sub_nat2int:2] Set("SIP/mdc_trunk_conf-2-0000001e", "MDC_CALLEE_NUM_INTERNAT=00493501111") in new stack
-- Executing [s-local@sub_nat2int:3] Return("SIP/mdc_trunk_conf-2-0000001e", "") in new stack
-- Executing [111@sub_trunk-outgoing-3:2] Gosub("SIP/mdc_trunk_conf-2-0000001e", "sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,00493501111,00,49,0,3501,0)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 00493501111 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 3501 - incoming: 0") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("SIP/mdc_trunk_conf-2-0000001e", "MDC_CALLEE_NUM_NAT=03501111") in new stack
-- Executing [111@sub_trunk-outgoing-3:3] Set("SIP/mdc_trunk_conf-2-0000001e", "CALLERID(name)=004935017929700") in new stack
-- Executing [111@sub_trunk-outgoing-3:4] Set("SIP/mdc_trunk_conf-2-0000001e", "CALLERID(num)=004935017929700") in new stack
-- Executing [111@sub_trunk-outgoing-3:5] UserEvent("SIP/mdc_trunk_conf-2-0000001e", "ResolveCallerName,Strategy: default,Outbound: 1,Channel: SIP/mdc_trunk_conf-2-0000001e") in new stack
-- Executing [111@sub_trunk-outgoing-3:6] Wait("SIP/mdc_trunk_conf-2-0000001e", "0.25") in new stack
-- Executing [111@sub_trunk-outgoing-3:7] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,MDC_RESOLVENAME_HITS = 0") in new stack
-- Executing [111@sub_trunk-outgoing-3:8] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,MDC_DIALCALLEENAME = ") in new stack
-- Executing [111@sub_trunk-outgoing-3:9] Verbose("SIP/mdc_trunk_conf-2-0000001e", "1,T-Online - PDD") in new stack
T-Online - PDD
-- Executing [111@sub_trunk-outgoing-3:10] Set("SIP/mdc_trunk_conf-2-0000001e", "__SPYGROUP=03501111:") in new stack
-- Executing [111@sub_trunk-outgoing-3:11] Dial("SIP/mdc_trunk_conf-2-0000001e", "SIP/mdc_trunk_conf-1/03501111,,t") in new stack
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
-- Called SIP/mdc_trunk_conf-1/03501111
-- SIP/mdc_trunk_conf-1-0000001f is making progress passing it to SIP/mdc_trunk_conf-2-0000001e
-- Executing [111@sub_trunk-outgoing-3:12] Return("SIP/mdc_trunk_conf-2-0000001e", "") in new stack
-- Executing [111@mdc_outgoing-3:2] Hangup("SIP/mdc_trunk_conf-2-0000001e", "1") in new stack
== Spawn extension (mdc_outgoing-3, 111, 2) exited non-zero on 'SIP/mdc_trunk_conf-2-0000001e'
-- Executing [h@mdc_outgoing-3:1] Gosub("SIP/mdc_trunk_conf-2-0000001e", "def_hangup,s,1(,CHANUNAVAIL,,CALL)") in new stack
-- Executing [s@def_hangup:1] NoOp("SIP/mdc_trunk_conf-2-0000001e", ">>>def_hangup:: EXTEN: DIALSTATUS: CHANUNAVAIL QUEUESTATUS: REASON: CALL") in new stack
Fax gerät is kein Persönliches angelegt sondern nur das unter Basisdaten, nach Vorgaben im Wiki. Faxkonfig wurde auch angewendet.
