hier mal ein Debug-Auszug aus der CLI. (Hier nur das Debugging nach dem Rufaufbau)
Haben zum Test bei einer Dame eines großen Flughafenbetreibers in unserer Region angerufen.
admin@telefon:/var/log/asterisk$ sudo asterisk -vvvvvvvvvr
Asterisk 11.6-cert5, Copyright (C) 1999 - 2013 Digium, Inc. and others.
Created by Mark Spencer <markster@digium.com>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
Connected to Asterisk 11.6-cert5 currently running on telefon (pid = 4605)
-- Started music on hold, class 'default', on SIP/M27IgtYq238XXXX-00000076
-- Stopped music on hold on SIP/M27IgtYq238XXXX-00000076
telefon*CLI>
Ich glaube nicht, dass das wirklich viel weiter hilft.
Irgendwelche Optionen die man im CLI noch wählen sollte?
Stefan
Hier noch der Auszug aus der CLI zum Rufaufbau:
admin@telefon:/var/log/asterisk$ sudo asterisk -vr
== Using SIP VIDEO CoS mark 6
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
-- Executing [0069XXXXXXXX@mdc_location-8:1] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,Stefan G.") in new stack
Stefan G.
-- Executing [0069XXXXXXXX@mdc_location-8:2] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_CALLER_LOCATION_ID=8") in new stack
-- Executing [0069XXXXXXXX@mdc_location-8:3] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_CALLER_LOCATION_NAME=Stefan G.") in new stack
== Extension Changed 09[mdc_hint-ident] new state InUse for Notify User XXX
-- Executing [0069XXXXXXXX@mdc_location-8:4] Gosub("SIP/M27IgtYq238XXXX-00000076", "sub_location,s,1(8,0069XXXXXXXX)") in new stack
-- Executing [s@sub_location:1] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,used location id: 8 - dialed extension: 0069XXXXXXXX") in new stack
-- Executing [s@sub_location:2] Set("SIP/M27IgtYq238XXXX-00000076", "MDC_CALLEE_NUM=0069XXXXXXXX") in new stack
-- Executing [s@sub_location:3] Return("SIP/M27IgtYq238XXXX-00000076", "") in new stack
-- Executing [0069XXXXXXXX@mdc_location-8:5] Gosub("SIP/M27IgtYq238XXXX-00000076", "sub_split-location,s,1(8)") in new stack
-- Executing [s@sub_split-location:1] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,get user for location: 8") in new stack
-- Executing [s@sub_split-location:2] GotoIf("SIP/M27IgtYq238XXXX-00000076", "0?s-zero,1") in new stack
-- Executing [s@sub_split-location:3] Set("SIP/M27IgtYq238XXXX-00000076", "TMP_USER_ID=8") in new stack
-- Executing [s@sub_split-location:4] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,user id: 8") in new stack
user id: 8
-- Executing [s@sub_split-location:5] Return("SIP/M27IgtYq238XXXX-00000076", "") in new stack
-- Executing [0069XXXXXXXX@mdc_location-8:6] Goto("SIP/M27IgtYq238XXXX-00000076", "mdc_user-8,0069XXXXXXXX,1") in new stack
-- Goto (mdc_user-8,0069XXXXXXXX,1)
-- Executing [0069XXXXXXXX@mdc_user-8:1] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,sG.") in new stack
sG.
-- Executing [0069XXXXXXXX@mdc_user-8:2] Gosub("SIP/M27IgtYq238XXXX-00000076", "sub_user,s,1(caller,8,09,sG.,Stefan G.,09,09,09)") in new stack
-- Executing [s@sub_user:1] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,sub_user mode caller") in new stack
-- Executing [s@sub_user:2] Goto("SIP/M27IgtYq238XXXX-00000076", "s-caller,1") in new stack
-- Goto (sub_user,s-caller,1)
-- Executing [s-caller@sub_user:1] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,sub_user user id: 8 - user exten: 09 - user: sG. - realname: Stefan G. - own mailbox: 09 - watched mailbox: 09 - callerid(num): 09") in new stack
-- Executing [s-caller@sub_user:2] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_CALLER_USER_ID=8") in new stack
-- Executing [s-caller@sub_user:3] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_CALLER_NUM=09") in new stack
-- Executing [s-caller@sub_user:4] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_CALLER_ACC_NAME=sG.") in new stack
-- Executing [s-caller@sub_user:5] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_CALLER_ACC_REALNAME=Stefan G.") in new stack
-- Executing [s-caller@sub_user:6] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_CALLER_VM_OWN=09") in new stack
-- Executing [s-caller@sub_user:7] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_CALLER_VM_WATCHED=09") in new stack
-- Executing [s-caller@sub_user:8] Set("SIP/M27IgtYq238XXXX-00000076", "CALLERID(name)=Stefan G.") in new stack
-- Executing [s-caller@sub_user:9] Set("SIP/M27IgtYq238XXXX-00000076", "CALLERID(num)=09") in new stack
-- Executing [s-caller@sub_user:10] Return("SIP/M27IgtYq238XXXX-00000076", "") in new stack
-- Executing [0069XXXXXXXX@mdc_user-8:3] Goto("SIP/M27IgtYq238XXXX-00000076", "internal,0069XXXXXXXX,1") in new stack
-- Goto (internal,0069XXXXXXXX,1)
-- Executing [0069XXXXXXXX@internal:1] SIPAddHeader("SIP/M27IgtYq238XXXX-00000076", ""Alert-Info:<http://www.notused.de>\;info=alert-internal\;x-line-id=0"") in new stack
-- Executing [0069XXXXXXXX@internal:2] GosubIf("SIP/M27IgtYq238XXXX-00000076", "1?sub_initcall,s,1(int,0069XXXXXXXX)") in new stack
-- Executing [s@sub_initcall:1] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,sub_initcall descent: int exten: 0069XXXXXXXX") in new stack
-- Executing [s@sub_initcall:2] GosubIf("SIP/M27IgtYq238XXXX-00000076", "1?sub_initloop,s,1") in new stack
-- Executing [s@sub_initloop:1] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,initial loop") in new stack
initial loop
-- Executing [s@sub_initloop:2] Set("SIP/M27IgtYq238XXXX-00000076", "MDC_ALIAS_HOP=0") in new stack
-- Executing [s@sub_initloop:3] Return("SIP/M27IgtYq238XXXX-00000076", "") in new stack
-- Executing [s@sub_initcall:3] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_TRANSFERBACK_HOP=0") in new stack
-- Executing [s@sub_initcall:4] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_DIALDESCENT=int") in new stack
-- Executing [s@sub_initcall:5] Goto("SIP/M27IgtYq238XXXX-00000076", "int,1") in new stack
-- Goto (sub_initcall,int,1)
-- Executing [int@sub_initcall:1] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_DIALCALLERNUMINIT=09") in new stack
-- Executing [int@sub_initcall:2] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_DIALCALLEENUMINIT=0069XXXXXXXX") in new stack
-- Executing [int@sub_initcall:3] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_DIALCALLEENUMMAP=0069XXXXXXXX") in new stack
-- Executing [int@sub_initcall:4] Return("SIP/M27IgtYq238XXXX-00000076", "") in new stack
-- Executing [0069XXXXXXXX@internal:3] Goto("SIP/M27IgtYq238XXXX-00000076", "main,0069XXXXXXXX,1") in new stack
-- Goto (main,0069XXXXXXXX,1)
-- Executing [0069XXXXXXXX@main:1] Gosub("SIP/M27IgtYq238XXXX-00000076", "sub_defcall,s,1(0069XXXXXXXX)") in new stack
-- Executing [s@sub_defcall:1] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_ALIAS_HOP=1") in new stack
-- Executing [s@sub_defcall:2] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_DIALCALLEENUM=0069XXXXXXXX") in new stack
-- Executing [s@sub_defcall:3] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_DIALCALLERNUM=09") in new stack
-- Executing [s@sub_defcall:4] GotoIf("SIP/M27IgtYq238XXXX-00000076", "1?nozap") in new stack
-- Goto (sub_defcall,s,8)
-- Executing [s@sub_defcall:8] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_DIALCALLERNAME=Stefan G.") in new stack
-- Executing [s@sub_defcall:9] Set("SIP/M27IgtYq238XXXX-00000076", "__MDC_DIALCHANNELNAME=M27IgtYq238XXXX") in new stack
-- Executing [s@sub_defcall:10] Return("SIP/M27IgtYq238XXXX-00000076", "") in new stack
-- Executing [0069XXXXXXXX@main:2] Goto("SIP/M27IgtYq238XXXX-00000076", "mdc_distribute,0069XXXXXXXX,1") in new stack
-- Goto (mdc_distribute,0069XXXXXXXX,1)
-- Executing [0069XXXXXXXX@mdc_distribute:1] Set("SIP/M27IgtYq238XXXX-00000076", "MDC_INPREFIX_TRUNK=0") in new stack
-- Executing [0069XXXXXXXX@mdc_distribute:2] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,remove inprefix: 0") in new stack
remove inprefix: 0
-- Executing [0069XXXXXXXX@mdc_distribute:3] Goto("SIP/M27IgtYq238XXXX-00000076", "mdc_outgoing-1,069XXXXXXXX,1") in new stack
-- Goto (mdc_outgoing-1,069XXXXXXXX,1)
-- Executing [069XXXXXXXX@mdc_outgoing-1:1] Gosub("SIP/M27IgtYq238XXXX-00000076", "sub_trunk-outgoing-1,069XXXXXXXX,1") in new stack
-- Executing [069XXXXXXXX@sub_trunk-outgoing-1:1] Gosub("SIP/M27IgtYq238XXXX-00000076", "sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,069XXXXXXXX,00,49,0,6151)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - number: 069XXXXXXXX - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 6151") in new stack
-- Executing [s@sub_nat2int:2] GotoIf("SIP/M27IgtYq238XXXX-00000076", "0?s-emergency,1") in new stack
-- Executing [s@sub_nat2int:3] GotoIf("SIP/M27IgtYq238XXXX-00000076", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:4] GotoIf("SIP/M27IgtYq238XXXX-00000076", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("SIP/M27IgtYq238XXXX-00000076", " 0?s-convert,1") in new stack
-- Executing [s@sub_nat2int:6] GotoIf("SIP/M27IgtYq238XXXX-00000076", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:7] GotoIf("SIP/M27IgtYq238XXXX-00000076", "0?s-intshort,1") in new stack
-- Executing [s@sub_nat2int:8] GotoIf("SIP/M27IgtYq238XXXX-00000076", "0?s-natshort,1") in new stack
-- Executing [s@sub_nat2int:9] GotoIf("SIP/M27IgtYq238XXXX-00000076", "1?s-nat,1") in new stack
-- Goto (sub_nat2int,s-nat,1)
-- Executing [s-nat@sub_nat2int:1] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,national") in new stack
national
-- Executing [s-nat@sub_nat2int:2] Set("SIP/M27IgtYq238XXXX-00000076", "MDC_CALLEE_NUM_INTERNAT=004969XXXXXXXX") in new stack
-- Executing [s-nat@sub_nat2int:3] Return("SIP/M27IgtYq238XXXX-00000076", "") in new stack
-- Executing [069XXXXXXXX@sub_trunk-outgoing-1:2] Gosub("SIP/M27IgtYq238XXXX-00000076", "sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,004969XXXXXXXX,00,49,0,6151)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 004969XXXXXXXX - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 6151") in new stack
-- Executing [s@sub_int2nat:2] GotoIf("SIP/M27IgtYq238XXXX-00000076", "0?s-emergency,1") in new stack
-- Executing [s@sub_int2nat:3] GotoIf("SIP/M27IgtYq238XXXX-00000076", "0?nat") in new stack
-- Executing [s@sub_int2nat:4] GotoIf("SIP/M27IgtYq238XXXX-00000076", "1?s-internat,1") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("SIP/M27IgtYq238XXXX-00000076", "MDC_CALLEE_NUM_NAT=069XXXXXXXX") in new stack
-- Executing [s-internat@sub_int2nat:2] Return("SIP/M27IgtYq238XXXX-00000076", "") in new stack
-- Executing [069XXXXXXXX@sub_trunk-outgoing-1:3] Set("SIP/M27IgtYq238XXXX-00000076", "CALLERID(name)=06151XXXXXXX") in new stack
-- Executing [069XXXXXXXX@sub_trunk-outgoing-1:4] Set("SIP/M27IgtYq238XXXX-00000076", "CALLERID(num)=06151XXXXXXX") in new stack
-- Executing [069XXXXXXXX@sub_trunk-outgoing-1:5] UserEvent("SIP/M27IgtYq238XXXX-00000076", "ResolveCallerName,Strategy: default,Outbound: 1,Channel: SIP/M27IgtYq238XXXX-00000076") in new stack
-- Executing [069XXXXXXXX@sub_trunk-outgoing-1:6] Wait("SIP/M27IgtYq238XXXX-00000076", "0.25") in new stack
-- Executing [069XXXXXXXX@sub_trunk-outgoing-1:7] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,MDC_RESOLVENAME_HITS = 0") in new stack
-- Executing [069XXXXXXXX@sub_trunk-outgoing-1:8] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,MDC_DIALCALLEENAME = ") in new stack
-- Executing [069XXXXXXXX@sub_trunk-outgoing-1:9] Verbose("SIP/M27IgtYq238XXXX-00000076", "1,vodafone - standard") in new stack
vodafone - standard
-- Executing [069XXXXXXXX@sub_trunk-outgoing-1:10] Dial("SIP/M27IgtYq238XXXX-00000076", "DAHDI/g1/069XXXXXXXX") in new stack
-- Requested transfer capability: 0x00 - SPEECH
-- Called DAHDI/g1/069XXXXXXXX
-- DAHDI/i1/069XXXXXXXX-3c is making progress passing it to SIP/M27IgtYq238XXXX-00000076
-- DAHDI/i1/069XXXXXXXX-3c is proceeding passing it to SIP/M27IgtYq238XXXX-00000076
telefon*CLI>
