Hi
i baught mobydick appliance. i can access it through web (http://192.168.100.1), but default username and password (admin / mobydick) doesn’t work!!
is there a way to reset password?
regards,
Hi
regards,
so, it is not mobydick, it is mobzdick.
i’m in
Hi Emina,
glad that you figured it out. Sometimes we have a keyboard setup mismatch between setup-ui and console-ui.
Just for the record: do you run your system in vmware? The vmware console keyboard emulation is a little bit tricky…
Regards,
