Wenn ich nun die anlagenbasierte Rufumleitung einschalte mit meiner Handynummer als Ziel, dann erhalte ich am Handy die Nummer +4994154321122 angezeigt
CLI dazu:
== Setting global variable ‘SIPDOMAIN’ to ‘100.96.221.151’
== Using SIP RTP Audio TOS bits 184
== Using SIP RTP Audio CoS mark 5
– Executing [4994112345666@mdc_incoming-1:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,Inbound call on trunk: easybell, getting number by: request-uri”) in new stack
– Executing [4994112345666@mdc_incoming-1:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_CALLER_NUM_TRUNK=094154321122”) in new stack
– Executing [4994112345666@mdc_incoming-1:3] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_CALLEE_NUM_TRUNK=4994112345666”) in new stack
– Executing [4994112345666@mdc_incoming-1:4] Goto(“PJSIP/mdc_trunk_conf-1-00000716”, “mdc_trunk-1,s,1”) in new stack
– Goto (mdc_trunk-1,s,1)
– Executing [s@mdc_trunk-1:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,callee number: 4994112345666 caller number: 094154321122”) in new stack
– Executing [s@mdc_trunk-1:2] ExecIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?Set(CALLERID(num)=anonymous)”) in new stack
– Executing [s@mdc_trunk-1:3] ExecIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?Set(CALLERID(num)=anonymous)”) in new stack
– Executing [s@mdc_trunk-1:4] ExecIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?Set(CALLERID(num)=anonymous)”) in new stack
– Executing [s@mdc_trunk-1:5] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “CHANNEL(language)=de”) in new stack
– Executing [s@mdc_trunk-1:6] Ringing(“PJSIP/mdc_trunk_conf-1-00000716”, “”) in new stack
– Executing [s@mdc_trunk-1:7] Progress(“PJSIP/mdc_trunk_conf-1-00000716”, “”) in new stack
– Executing [s@mdc_trunk-1:8] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_FALLBACK_TRUNK=488”) in new stack
– Executing [s@mdc_trunk-1:9] Gosub(“PJSIP/mdc_trunk_conf-1-00000716”, “sub_nat2int,s,1(MDC_CALLER_NUM_INTERNAT,094154321122,00,49,0,941,1)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,sub_nat2int:: variable: MDC_CALLER_NUM_INTERNAT - number: 094154321122 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 941 - incoming: 1”) in new stack
– Executing [s@sub_nat2int:2] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?s-emergency,1”) in new stack
– Executing [s@sub_nat2int:3] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:4] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:5] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?s-convert,1”) in new stack
– Executing [s@sub_nat2int:6] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?s-int,1”) in new stack
– Executing [s@sub_nat2int:7] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?s-intshort,1”) in new stack
– Executing [s@sub_nat2int:8] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?s-natshort,1”) in new stack
– Executing [s@sub_nat2int:9] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “1?s-nat,1”) in new stack
– Goto (sub_nat2int,s-nat,1)
– Executing [s-nat@sub_nat2int:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,national”) in new stack
national
– Executing [s-nat@sub_nat2int:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_CALLER_NUM_INTERNAT=004994154321122”) in new stack
– Executing [s-nat@sub_nat2int:3] Return(“PJSIP/mdc_trunk_conf-1-00000716”, “”) in new stack
– Executing [s@mdc_trunk-1:10] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “CALLERID(num)=004994154321122”) in new stack
– Executing [s@mdc_trunk-1:11] Gosub(“PJSIP/mdc_trunk_conf-1-00000716”, “sub_int2nat,s,1(MDC_CALLER_NUM_NAT,004994154321122,00,49,0,941,1)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,sub_int2nat:: variable: MDC_CALLER_NUM_NAT - exten: 004994154321122 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 941 - incoming: 1”) in new stack
– Executing [s@sub_int2nat:2] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?s-emergency,1”) in new stack
– Executing [s@sub_int2nat:3] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?nat”) in new stack
– Executing [s@sub_int2nat:4] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “1?s-internat,1”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_CALLER_NUM_NAT=094154321122”) in new stack
– Executing [s-internat@sub_int2nat:2] Return(“PJSIP/mdc_trunk_conf-1-00000716”, “”) in new stack
– Executing [s@mdc_trunk-1:12] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “CALLERID(num)=094154321122”) in new stack
– Executing [s@mdc_trunk-1:13] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_NUMPREFIX_TRUNK=0”) in new stack
– Executing [s@mdc_trunk-1:14] ExecIf(“PJSIP/mdc_trunk_conf-1-00000716”, “1?Set(CALLERID(all)=0094154321122)”) in new stack
– Executing [s@mdc_trunk-1:15] UserEvent(“PJSIP/mdc_trunk_conf-1-00000716”, “ResolveCallerName,Strategy: system,Outbound: 0”) in new stack
– Executing [s@mdc_trunk-1:16] Wait(“PJSIP/mdc_trunk_conf-1-00000716”, “0.25”) in new stack
– Executing [s@mdc_trunk-1:17] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,MDC_RESOLVENAME_HITS = 0”) in new stack
– Executing [s@mdc_trunk-1:18] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, "1,CALLERID(name) = ") in new stack
CALLERID(name) =
– Executing [s@mdc_trunk-1:19] Goto(“PJSIP/mdc_trunk_conf-1-00000716”, “mdc_mapping-1,4994112345666,1”) in new stack
– Goto (mdc_mapping-1,4994112345666,1)
– Executing [4994112345666@mdc_mapping-1:1] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “CHANNEL(language)=de”) in new stack
– Executing [4994112345666@mdc_mapping-1:2] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,mapping from _4994112345XXX to 666”) in new stack
– Executing [4994112345666@mdc_mapping-1:3] Goto(“PJSIP/mdc_trunk_conf-1-00000716”, “mdc_external,666,1”) in new stack
– Goto (mdc_external,666,1)
– Executing [666@mdc_external:1] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “HASH(__SIPHEADERS,Alert-info)=http://www.notused.de;info=alert-external;x-line-id=0”) in new stack
– Executing [666@mdc_external:2] GosubIf(“PJSIP/mdc_trunk_conf-1-00000716”, “1?sub_initcall,s,1(ext,666)”) in new stack
– Executing [s@sub_initcall:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,sub_initcall descent: ext exten: 666”) in new stack
– Executing [s@sub_initcall:2] GosubIf(“PJSIP/mdc_trunk_conf-1-00000716”, “1?sub_initloop,s,1”) in new stack
– Executing [s@sub_initloop:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,initial loop”) in new stack
initial loop
– Executing [s@sub_initloop:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_ALIAS_HOP=0”) in new stack
– Executing [s@sub_initloop:3] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_MAIN_HOP=0”) in new stack
– Executing [s@sub_initloop:4] Return(“PJSIP/mdc_trunk_conf-1-00000716”, “”) in new stack
– Executing [s@sub_initcall:3] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_TRANSFERBACK_HOP=0”) in new stack
– Executing [s@sub_initcall:4] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_DIALDESCENT=ext”) in new stack
– Executing [s@sub_initcall:5] Goto(“PJSIP/mdc_trunk_conf-1-00000716”, “ext,1”) in new stack
– Goto (sub_initcall,ext,1)
– Executing [ext@sub_initcall:1] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_DIALCALLERNUMINIT=094154321122”) in new stack
– Executing [ext@sub_initcall:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_DIALCALLEENUMINIT=4994112345666”) in new stack
– Executing [ext@sub_initcall:3] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_DIALCALLEENUMMAP=666”) in new stack
– Executing [ext@sub_initcall:4] Return(“PJSIP/mdc_trunk_conf-1-00000716”, “”) in new stack
– Executing [666@mdc_external:3] Goto(“PJSIP/mdc_trunk_conf-1-00000716”, “main,666,1”) in new stack
– Goto (main,666,1)
– Executing [666@main:1] ExecIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?Set(MDC_MAIN_HOP=0)”) in new stack
– Executing [666@main:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_MAIN_HOP=1”) in new stack
– Executing [666@main:3] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?mdc_loop,s,1”) in new stack
– Executing [666@main:4] Gosub(“PJSIP/mdc_trunk_conf-1-00000716”, “sub_defcall,s,1(666)”) in new stack
– Executing [s@sub_defcall:1] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_ALIAS_HOP=1”) in new stack
– Executing [s@sub_defcall:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_DIALCALLEENUM=666”) in new stack
– Executing [s@sub_defcall:3] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_DIALCALLERNUM=0094154321122”) in new stack
– Executing [s@sub_defcall:4] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_DIALCALLERLANGUAGE=de”) in new stack
– Executing [s@sub_defcall:5] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_DIALCALLERNAME=”) in new stack
– Executing [s@sub_defcall:6] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_DIALCHANNELNAME=mdc_trunk_conf-1”) in new stack
– Executing [s@sub_defcall:7] Return(“PJSIP/mdc_trunk_conf-1-00000716”, “”) in new stack
– Executing [666@main:5] GosubIf(“PJSIP/mdc_trunk_conf-1-00000716”, “1?sub_homer,s,1”) in new stack
– Executing [s@sub_homer:1] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “PJSIP_HEADER(remove,P-cs-cid)=”) in new stack
– Executing [s@sub_homer:2] ExecIf(“PJSIP/mdc_trunk_conf-1-00000716”, “1?Set(PJSIP_HEADER(add,P-cs-cid)=SBCbf15e00009f5-5ec51356-600f656d-359dd480-9a0a123-01_b2b-1)”) in new stack
– Executing [s@sub_homer:3] Return(“PJSIP/mdc_trunk_conf-1-00000716”, “”) in new stack
– Executing [666@main:6] Goto(“PJSIP/mdc_trunk_conf-1-00000716”, “mdc_distribute,666,1”) in new stack
– Goto (mdc_distribute,666,1)
– Executing [666@mdc_distribute:1] Gosub(“PJSIP/mdc_trunk_conf-1-00000716”, “sub_user,s,1(callee,5,b.muster,Bjoern muster 666,666,666)”) in new stack
– Executing [s@sub_user:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,sub_user mode callee”) in new stack
– Executing [s@sub_user:2] Goto(“PJSIP/mdc_trunk_conf-1-00000716”, “s-callee,1”) in new stack
– Goto (sub_user,s-callee,1)
– Executing [s-callee@sub_user:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,sub_user user id: 5 - user: b.muster - realname: Bjoern muster 666 - own mailbox: 666 - watched mailbox: 666”) in new stack
– Executing [s-callee@sub_user:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “_MDC_CALLEE_USER_ID=5”) in new stack
– Executing [s-callee@sub_user:3] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “_MDC_CALLEE_ACC_NAME=b.muster”) in new stack
– Executing [s-callee@sub_user:4] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “_MDC_CALLEE_ACC_REALNAME=Bjoern muster 666”) in new stack
– Executing [s-callee@sub_user:5] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “_MDC_CALLEE_VM_OWN=666”) in new stack
– Executing [s-callee@sub_user:6] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “_MDC_CALLEE_VM_WATCHED=666”) in new stack
– Executing [s-callee@sub_user:7] Return(“PJSIP/mdc_trunk_conf-1-00000716”, “”) in new stack
– Executing [666@mdc_distribute:2] Goto(“PJSIP/mdc_trunk_conf-1-00000716”, “mdc_ident-5,666,1”) in new stack
– Goto (mdc_ident-5,666,1)
– Executing [666@mdc_ident-5:1] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?mdc_loop,s,1”) in new stack
– Executing [666@mdc_ident-5:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_MAIN_HOP=2”) in new stack
– Executing [666@mdc_ident-5:3] NoOp(“PJSIP/mdc_trunk_conf-1-00000716”, “alias-check:: call forwarding from 666 - 1”) in new stack
– Executing [666@mdc_ident-5:4] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “1?666-uml,1:666-dial,1”) in new stack
– Goto (mdc_ident-5,666-uml,1)
– Executing [666-uml@mdc_ident-5:1] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?mdc_alias-loop,s,1”) in new stack
– Executing [666-uml@mdc_ident-5:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_ALIAS_HOP=2”) in new stack
– Executing [666-uml@mdc_ident-5:3] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_DIALCHANNELNAME=b.muster”) in new stack
– Executing [666-uml@mdc_ident-5:4] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?666-dial,1”) in new stack
– Executing [666-uml@mdc_ident-5:5] AGI(“PJSIP/mdc_trunk_conf-1-00000716”, “agi_roletype.php,redirect.choice,0094154321122,666”) in new stack
– Launched AGI Script /etc/asterisk/agi/agi_roletype.php
– <PJSIP/mdc_trunk_conf-1-00000716>AGI Script agi_roletype.php completed, returning 0
– Executing [666-uml@mdc_ident-5:6] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?666-dial,1”) in new stack
– Executing [666-uml@mdc_ident-5:7] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?666-dial,1”) in new stack
– Executing [666-uml@mdc_ident-5:8] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “CALLERID(name)=”) in new stack
– Executing [666-uml@mdc_ident-5:9] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “REDIRECTING(to-num,i)=0015199999922”) in new stack
– Executing [666-uml@mdc_ident-5:10] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “REDIRECTING(to-num-pres,i)=allowed”) in new stack
– Executing [666-uml@mdc_ident-5:11] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “REDIRECTING(from-num,i)=666”) in new stack
– Executing [666-uml@mdc_ident-5:12] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “REDIRECTING(from-num-pres,i)=allowed”) in new stack
– Executing [666-uml@mdc_ident-5:13] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “REDIRECTING(from-name,i)=Bjoern muster 666”) in new stack
– Executing [666-uml@mdc_ident-5:14] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “REDIRECTING(from-name-pres,i)=allowed”) in new stack
– Executing [666-uml@mdc_ident-5:15] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “REDIRECTING(count,i)=2”) in new stack
– Executing [666-uml@mdc_ident-5:16] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “REDIRECTING(reason)=cfu”) in new stack
– Executing [666-uml@mdc_ident-5:17] UserEvent(“PJSIP/mdc_trunk_conf-1-00000716”, “Transition,Type: mdredirect,Arg1: 0015199999922”) in new stack
– Executing [666-uml@mdc_ident-5:18] Goto(“PJSIP/mdc_trunk_conf-1-00000716”, “main,0015199999922,1”) in new stack
– Goto (main,0015199999922,1)
– Executing [0015199999922@main:1] ExecIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?Set(MDC_MAIN_HOP=0)”) in new stack
– Executing [0015199999922@main:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_MAIN_HOP=3”) in new stack
– Executing [0015199999922@main:3] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?mdc_loop,s,1”) in new stack
– Executing [0015199999922@main:4] Gosub(“PJSIP/mdc_trunk_conf-1-00000716”, “sub_defcall,s,1(0015199999922)”) in new stack
– Executing [s@sub_defcall:1] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_ALIAS_HOP=3”) in new stack
– Executing [s@sub_defcall:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_DIALCALLEENUM=0015199999922”) in new stack
– Executing [0015199999922@main:5] GosubIf(“PJSIP/mdc_trunk_conf-1-00000716”, “1?sub_homer,s,1”) in new stack
– Executing [0015199999922@main:6] Goto(“PJSIP/mdc_trunk_conf-1-00000716”, “mdc_distribute,0015199999922,1”) in new stack
– Goto (mdc_distribute,0015199999922,1)
– Executing [0015199999922@mdc_distribute:1] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_INPREFIX_TRUNK=0”) in new stack
– Executing [0015199999922@mdc_distribute:2] ClearHash(“PJSIP/mdc_trunk_conf-1-00000716”, “SIPHEADERS”) in new stack
– Executing [0015199999922@mdc_distribute:3] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,remove inprefix: 0”) in new stack
remove inprefix: 0
– Executing [0015199999922@mdc_distribute:4] Goto(“PJSIP/mdc_trunk_conf-1-00000716”, “mdc_outgoing-22,015199999922,1”) in new stack
– Goto (mdc_outgoing-22,015199999922,1)
– Executing [015199999922@mdc_outgoing-22:1] Gosub(“PJSIP/mdc_trunk_conf-1-00000716”, “sub_trunk-outgoing-22,015199999922,1”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:1] Gosub(“PJSIP/mdc_trunk_conf-1-00000716”, “sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,015199999922,00,49,0,941,0)”) in new stack
– Executing [s@sub_nat2int:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - number: 015199999922 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 941 - incoming: 0”) in new stack
national
– Executing [s-nat@sub_nat2int:2] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_CALLEE_NUM_INTERNAT=004915199999922”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:2] Gosub(“PJSIP/mdc_trunk_conf-1-00000716”, “sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,004915199999922,00,49,0,941,0)”) in new stack
– Executing [s@sub_int2nat:1] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 004915199999922 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 941 - incoming: 0”) in new stack
– Executing [s-internat@sub_int2nat:1] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “MDC_CALLEE_NUM_NAT=015199999922”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:3] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “__MDC_OUTBOUND_CIDNUM=094112345094154321122”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:4] Set(“PJSIP/mdc_trunk_conf-1-00000716”, “CALLERID(num)=094112345094154321122”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:5] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?searchdone”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:6] UserEvent(“PJSIP/mdc_trunk_conf-1-00000716”, “ResolveCallerName,Strategy: system,Outbound: 1”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:7] Wait(“PJSIP/mdc_trunk_conf-1-00000716”, “0.25”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:8] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,MDC_RESOLVENAME_HITS = 0”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:9] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, "1,MDC_DIALCALLEENAME = ") in new stack
– Executing [015199999922@sub_trunk-outgoing-22:10] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?enddeflection”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:11] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?rtp”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:12] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?rtp”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:13] Verbose(“PJSIP/mdc_trunk_conf-1-00000716”, “1,Response 302”) in new stack
Response 302
– Executing [015199999922@sub_trunk-outgoing-22:14] Wait(“PJSIP/mdc_trunk_conf-1-00000716”, “1”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:15] Transfer(“PJSIP/mdc_trunk_conf-1-00000716”, “PJSIP/sip:015199999922@sip.easybell.de”) in new stack
– Executing [015199999922@sub_trunk-outgoing-22:16] GotoIf(“PJSIP/mdc_trunk_conf-1-00000716”, “0?rtp”) in new stack
– Executing [h@sub_trunk-outgoing-22:1] Gosub(“PJSIP/mdc_trunk_conf-1-00000716”, “def_hangup,s,1(,CALL)”) in new stack
– Executing [s@def_hangup:1] NoOp(“PJSIP/mdc_trunk_conf-1-00000716”, “>>>def_hangup:: EXTEN:  DIALSTATUS:  QUEUESTATUS:  REASON: CALL”) in new stack
