So hier der Output del CLI
Connected to Asterisk 1.2.40-BRIstuffed-0.3.0-PRE-1z-c currently running on AFI-SRV-VoIP01 (pid = 4400)
No entry for terminal type “xterm-256color”;
using dumb terminal settings.
Verbosity is at least 3
– Remote UNIX connection
-- Executing Set("SIP/msachs-083b9078", "MDC_CHANNEL_PROTOCOL=SIP") in new stack
-- Executing Set("SIP/msachs-083b9078", "MDC_CHANNEL_ID=msachs-083b9078") in new stack
-- Executing Set("SIP/msachs-083b9078", "MDC_CHANNEL_TMP=msachs-083b9078") in new stack
-- Executing Set("SIP/msachs-083b9078", "MDC_CHANNEL_NAME=msachs") in new stack
-- Executing GosubIf("SIP/msachs-083b9078", "1?mdc_initcall-int|10|1") in new stack
-- Executing NoOp("SIP/msachs-083b9078", "initial call") in new stack
-- Executing Set("SIP/msachs-083b9078", "__MDC_DIALDESCENT=int") in new stack
-- Executing Set("SIP/msachs-083b9078", "__MDC_DIALCALLEENUM=10") in new stack
-- Executing Set("SIP/msachs-083b9078", "__MDC_DIALCALLERNUM=310") in new stack
-- Executing GotoIf("SIP/msachs-083b9078", "1?nozap") in new stack
-- Goto (mdc_initcall-int,10,8)
-- Executing Set("SIP/msachs-083b9078", "__MDC_DIALCALLERNAME=Markus Sachs") in new stack
-- Executing Return("SIP/msachs-083b9078", "") in new stack
-- Executing Gosub("SIP/msachs-083b9078", "mdc_defcall|10|1") in new stack
-- Goto (mdc_defcall,10,4)
-- Executing Set("SIP/msachs-083b9078", "__MDC_DIALCHANNELNAME=msachs") in new stack
-- Executing SIPAddHeader("SIP/msachs-083b9078", ""Alert-Info:<http://www.notused.de>;info=alert-internal;x-line-id=0"") in new stack
-- Executing Macro("SIP/msachs-083b9078", "pre-main") in new stack
Dec 15 09:05:02 WARNING[5424]: app_macro.c:208 macro_exec: No such context ‘macro-pre-main’ for macro ‘pre-main’
– Executing GosubIf(“SIP/msachs-083b9078”, “1?mdc_initloop|s|1”) in new stack
– Executing NoOp(“SIP/msachs-083b9078”, “initial loop”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “MDC_ALIAS_HOP=0”) in new stack
– Executing Return(“SIP/msachs-083b9078”, “”) in new stack
– Executing Gosub(“SIP/msachs-083b9078”, “mdc_cdr-int|10|1”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “CDR(mdcdst)=10”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “CDR(mdcinitdst)=10”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “CDR(mdcname)=msachs”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “CDR(mdcsrc)=310”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “CDR(mdcinitsrc)=310”) in new stack
– Executing GotoIf(“SIP/msachs-083b9078”, “0?prefix”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “CDR(mdcprefix)=”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “TMP_NAME=”) in new stack
– Executing GotoIf(“SIP/msachs-083b9078”, “0?dstname”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “TMP_NAME=10”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “CDR(mdcdstname)=10”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “CDR(mdcdescent)=int”) in new stack
– Executing Set(“SIP/msachs-083b9078”, “CDR(mdcsrcname)=Markus Sachs”) in new stack
– Executing AGI(“SIP/msachs-083b9078”, “script/mdc_billing-pricing.php|0”) in new stack
– Launched AGI Script /var/lib/asterisk/agi-bin/script/mdc_billing-pricing.php
-- AGI Script script/mdc_billing-pricing.php completed, returning 0
-- Executing Set("SIP/msachs-083b9078", "CDR(tarifid)=1") in new stack
-- Executing Goto("SIP/msachs-083b9078", "main|10|1") in new stack
-- Goto (main,10,1)
-- Executing Set("SIP/msachs-083b9078", "TMP_INPREFIX=") in new stack
-- Executing Goto("SIP/msachs-083b9078", "mdc_outgoing-trunk-7|10|1") in new stack
-- Goto (mdc_outgoing-trunk-7,10,1)
-- Executing Set("SIP/msachs-083b9078", "CDR(mdcinprefix)=") in new stack
-- Executing Macro("SIP/msachs-083b9078", "int2nat|10|00|49|0|7581") in new stack
-- Executing NoOp("SIP/msachs-083b9078", "macro-int2nat:: EXTEN: 10 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7581") in new stack
-- Executing GotoIf("SIP/msachs-083b9078", "0?s-ano|1") in new stack
-- Executing GotoIf("SIP/msachs-083b9078", "0?s-internat|1:s-nat|1") in new stack
-- Goto (macro-int2nat,s-nat,1)
-- Executing Set("SIP/msachs-083b9078", "MDC_EXTEN=10") in new stack
-- Executing Macro("SIP/msachs-083b9078", "nat2int|10|00|49|0|7581") in new stack
-- Executing NoOp("SIP/msachs-083b9078", "macro-nat2int:: CALLERID(num): 10 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7581") in new stack
-- Executing GotoIf("SIP/msachs-083b9078", "0?s-int|1") in new stack
-- Executing GotoIf("SIP/msachs-083b9078", "0?s-intshort|1") in new stack
-- Executing GotoIf("SIP/msachs-083b9078", "0?s-natshort|1") in new stack
-- Executing GotoIf("SIP/msachs-083b9078", "0?s-nat|1") in new stack
-- Executing Goto("SIP/msachs-083b9078", "s-local|1") in new stack
-- Goto (macro-nat2int,s-local,1)
-- Executing NoOp("SIP/msachs-083b9078", "local") in new stack
-- Executing Set("SIP/msachs-083b9078", "MDC_LONGEXTEN=0049758110") in new stack
-- Executing Macro("SIP/msachs-083b9078", "ldap|0|CDR(mdcdstname)|10|0049758110|10|+49758110") in new stack
-- Executing NoOp("SIP/msachs-083b9078", "macro-ldap:: Ldappraefix: 0 Variable: CDR(mdcdstname) MDC_DIALCALLERNUM: 10 MDC_LONGEXTEN: 0049758110 MDC_EXTEN: 10 +MDC_LONGEXTEN: +49758110") in new stack
-- Executing Set("SIP/msachs-083b9078", "TMP_NAME=") in new stack
-- Executing Macro("SIP/msachs-083b9078", "ldapsearch|10|TMP_NAME") in new stack
-- Executing NoOp("SIP/msachs-083b9078", "macro-ldapsearch:: number: 10 Variable: TMP_NAME") in new stack
-- Executing LDAPget("SIP/msachs-083b9078", "TMP_NAME=cidname/10|10|10") in new stack
-- LDAPget: varname=TMP_NAME, config-section=cidname, keys=10|10|10
== Parsing ‘/etc/asterisk/ldap.conf’: Found
– LDAPget: ldap://localhost/dc=mobydick?cn?sub?(&(objectClass=person)(|(telephoneNumber=10)(mobile=10)(homephone=10)))
– LDAPget: bind to localhost as cn=admin,dc=telefonbuch,dc=mobydick
-- LDAPget: Value not found in directory.
-- Executing GotoIf("SIP/msachs-083b9078", "0?hit") in new stack
-- Executing Macro("SIP/msachs-083b9078", "ldapsearch|0049758110|TMP_NAME") in new stack
-- Executing NoOp("SIP/msachs-083b9078", "macro-ldapsearch:: number: 0049758110 Variable: TMP_NAME") in new stack
-- Executing LDAPget("SIP/msachs-083b9078", "TMP_NAME=cidname/0049758110|0049758110|0049758110") in new stack
-- LDAPget: varname=TMP_NAME, config-section=cidname, keys=0049758110|0049758110|0049758110
– LDAPget: ldap://localhost/dc=mobydick?cn?sub?(&(objectClass=person)(|(telephoneNumber=0049758110)(mobile=0049758110)(homephone=0049758110)))
-- Executing Macro("SIP/msachs-083b9078", "ldapsearch|+49758110|TMP_NAME") in new stack
-- Executing NoOp("SIP/msachs-083b9078", "macro-ldapsearch:: number: +49758110 Variable: TMP_NAME") in new stack
-- Executing LDAPget("SIP/msachs-083b9078", "TMP_NAME=cidname/+49758110|+49758110|+49758110") in new stack
-- LDAPget: varname=TMP_NAME, config-section=cidname, keys=+49758110|+49758110|+49758110
– LDAPget: ldap://localhost/dc=mobydick?cn?sub?(&(objectClass=person)(|(telephoneNumber=+49758110)(mobile=+49758110)(homephone=+49758110)))
-- Executing GotoIf("SIP/msachs-083b9078", "0?fallback") in new stack
-- Executing Macro("SIP/msachs-083b9078", "ldapsearch|010|TMP_NAME") in new stack
-- Executing NoOp("SIP/msachs-083b9078", "macro-ldapsearch:: number: 010 Variable: TMP_NAME") in new stack
-- Executing LDAPget("SIP/msachs-083b9078", "TMP_NAME=cidname/010|010|010") in new stack
-- LDAPget: varname=TMP_NAME, config-section=cidname, keys=010|010|010
– LDAPget: ldap://localhost/dc=mobydick?cn?sub?(&(objectClass=person)(|(telephoneNumber=010)(mobile=010)(homephone=010)))
-- Executing Macro("SIP/msachs-083b9078", "ldapsearch|00049758110|TMP_NAME") in new stack
-- Executing NoOp("SIP/msachs-083b9078", "macro-ldapsearch:: number: 00049758110 Variable: TMP_NAME") in new stack
-- Executing LDAPget("SIP/msachs-083b9078", "TMP_NAME=cidname/00049758110|00049758110|00049758110") in new stack
-- LDAPget: varname=TMP_NAME, config-section=cidname, keys=00049758110|00049758110|00049758110
– LDAPget: ldap://localhost/dc=mobydick?cn?sub?(&(objectClass=person)(|(telephoneNumber=00049758110)(mobile=00049758110)(homephone=00049758110)))
-- Executing GotoIf("SIP/msachs-083b9078", "1?int") in new stack
-- Goto (macro-ldap,s,21)
-- Executing Set("SIP/msachs-083b9078", "CDR(mdcdstname)=10") in new stack
-- Executing Goto("SIP/msachs-083b9078", "back") in new stack
-- Goto (macro-ldap,s,25)
-- Executing NoOp("SIP/msachs-083b9078", "macro-ldap:: finished") in new stack
-- Executing Set("SIP/msachs-083b9078", "CDR(mdcdst)=0049758110") in new stack
-- Executing Set("SIP/msachs-083b9078", "CDR(mdctrubez)=Amt:98") in new stack
-- Executing Set("SIP/msachs-083b9078", "CDR(mdcprefix)=0") in new stack
-- Executing Set("SIP/msachs-083b9078", "CALLERID(num)=310") in new stack
-- Executing AGI("SIP/msachs-083b9078", "script/mdc_billing-pricing.php|8") in new stack
-- Launched AGI Script /var/lib/asterisk/agi-bin/script/mdc_billing-pricing.php
-- Executing Dial("SIP/msachs-083b9078", "SIP/98/**10||t") in new stack
-- Called 98/**10
-- SIP/98-083ee3d8 is circuit-busy
== Everyone is busy/congested at this time (1:0/1/0)
– Executing Hangup(“SIP/msachs-083b9078”, “1”) in new stack
== Spawn extension (mdc_outgoing-trunk-7, 10, 12) exited non-zero on ‘SIP/msachs-083b9078’
– Executing Macro(“SIP/msachs-083b9078”, “hangup|10|CONGESTION|”) in new stack
– Executing NoOp(“SIP/msachs-083b9078”, ">>>macro-hangup:: EXTEN: 10 DIALSTATUS: CONGESTION QUEUESTATUS: ") in new stack
